What speaker should I build next?
Hi All,
I have a small stereo system consisting of an F5 amp, a Korg Newtube preamp, an old Rotel RP1000, and Frugal horn speakers with Fostex 4" full range speakers. I love my home build stereo. It is best when played with records that are recorded the old way with a band around a mic. Miles Davis Kind of Blue is one that sounds best. Live recordings sound great. Anything that is well recorded sounds good. Bad recordings are really exposed. The system's weakness is on the low end. These speakers cannot reproduce full orchestra recordings very well. The problem is not what sound comes out of the speakers, it is what is missing on the low end.
So, what speakers would you recommend that I build next? I need speakers that will reproduce big complex recordings that include a lot of base. I do not think adding a sub will work well with my current speakers. I have the tools and capability to build fairly complex cabinets if necessary. I will not add store bought speakers to my home built stereo. I would get sent to hell for a sin of that magnitude.
I do not have a huge house or an unlimited budget. WAF score will be a factor, but she loves my stereo so far...
Ground loops, interconnects, safety grounds, etc.
In this video he demonstrates the potential that exists in every home between your neutral return and your homes safety ground. There can be several volts, and it can vary based on what is currently drawing power in your home, as well as differ at various locations in your home if you measured it at various outlets. Thought I'd post this as it shows the reason for ground loops, why people incorrectly try to circumvent problems by lifting safety grounds, and why we devise methods like the 10 ohm resistor with capacitor and
diodes that only engage if there is truly a safety fault (see the tubecad "house ground" circuit) to get a audio ground reference that is also safe. Nice short video, for a subject that mystifies.
Login to view embedded media
Come on Hyundai / Kia
I used to think they had a couple models that were tempting but the paint is peeling off now?
And that is on top of the lack of a simple transponder key leading to people's cars being stolen over and over. And don't even get me started on the 'fix' for the brake fluid leaking on a wiring harness being putting a lower rated fuse in so it will blow before the wiring harness catches fire. Shouldn't the leaking part be replaced?
  • Locked
To fuse or not to fuse?
Hi!
Have had a discussion about fuses in the preamp….
My thinking is:
The preamp fuse is dimensioned for the inrush current during start-up - thereby probably largely oversized for the preamp after the start-up period. So what is the purpose of the fuse?
For protection? But the house electrical network has fuses…. Isn’t that enough?
Can you please explain to me why is it necessary to have an preamp fuse? Is the fuse really nescesarry ?
/Anton
SPL Dips
Firstly apologies if this is posted in the wrong place. Please let me know if it needs to be moved.
I've just finished a new speaker build and I'm really happy with them. But in the interest of constantly improving I am using a measurement microphone for the first time with REW.
I've just taken a measurement and I see quite a significant dip between 200 and 1000hz. As I'm pretty new to this I am now unsure what to do next to go about getting these more balanced. I am using a JAB5 amp from sure that has a built in DAC so I assume I can make tweaks inside of sigmastudio. Or perhaps the issue is to do with standingwaves inside the enclosure and better padding would help? Any wisdom anyone can impart to get me looking in the right place would be greatly appreciated. Thanks
What resistor is this?
Hello everyone!
I've been trying to fix a FM receiver and I found this weird resistor. I've found it the receiver it's a blue box that says r22 so I would think it will be 22 ohm but it measures sort circuit. Is this some special kind of resistor or it is faulty and that's why it measures sort circuit? You can see it in the top right in the photo.
Bought belt idler roller kit for my deck, your opinion (pic attached)
So I have an old Nakamichi BX-125 which was in need for new set of fresh rubber and bought a generic replacement kit on ebay, the 2 belts and roller looked pretty nice visually, but the idler (see pic below) has a pretty poor surface finish full of larger holes, how much will this affect wow and flutter?
It's not a huge deal as it was pretty low cost anyway, but wondering should I give a positive, neutral or negative feedback on this, the seller didn't give any feedback yet which I consider another slight negative as I have already fulfilled my bit of the transaction and puts a pressure on the buyer to give a positive feedback in fear of receiving less than positive feedback in return, most sellers do give a feedback immediately after payment without awaiting the buyers feedback.
Nakamichi BX-125 replacement idler from ebay seller boonpc (happytapes3d).jpg
Red Rose Rossette 2 phono preamp
Hello friends.
Years ago I bought on Ebay, my Red Rose Music Rosette 2 phono preamp, which I use for MC cartridges, I have been very happy with it, but recently, when it has been running for about 15 minutes the right channel stops working.
If I turn it off, and leave it for 5 minutes, the channel starts working again.
I have opened it to see if it had any cold solder, and my surprise is that I have found it modified, it has changed the operational amplifiers and bridges on the PCB here and there.
I don't have the schematics of this preamplifier and I would like to leave it as it comes from the factory.
Does anyone have the service manual for this preamplifier, obviously I understand that there is a cost involved.
Drivers with Alu Oxidation
I have a pair of Celestion DL10 10" woofers.
They have white oxidation on the Alu driver baskets.
I've wiped away the powder but don't want to go to town on them as the oxidisation isn't affecting the sound of the cones/voice coil etc.
Would the oxidation affect the resale value?
I've decided to strip the speakers down and sell the components as I don't think the speakers as a whole are in demand.
Linn av 5140 tweeter repair
Hello
I need to replace the tweeter of my Linn AV5140 speakers. I have attached the pictures of tweeter. I don't know if it is soldered or not. I did some research and found someone already replaced. This is from him
" Finally got the job done with the help of my borther in law (recommend someone experienced in soldering and electrical repair!!) and confirmation on the "how to" from Linn. I will post to help someone else in my position. The AV5140 Linn Tweeter requires the speaker wire to be soldered into the back of the tweeter. Solder wire, then tease and remove strands of wire until it will fit snugly inside the terminals. Solder and seal with non conducting RTV or glue that can be removed if need be in the future"
I still don't understand where to desolder. Any help would be greatly appreciated.
Capacitors for testing crossover?
Probably a stupid question and I am not wanting to get into “what is the best capacitor” or “do capacitors sound dramatically different” but ……..
Just about to attempt my first passive crossover and do not have a stock of parts so will be buying everything from scratch so want to keep everything as cheap as possible so I can fine tune if necessary.
So I know it is OK to use Electrolytic Bipolar caps on the parallel part of the woofer low pass circuit, but what about using them everywhere else to test out the circuit. This is as opposed to using polypropylene.
My current parts list is -
82uf (woofer low pass) - Mundorf ECap / Jantzen eLeCap
then 27uf, 18uf, 15uf, 6.8uF, 3.3uf, 0.56uf caps which are a mix of Jantzen Cross Cap and Standard whichever was the cheapest, can I just use Electrolytic Bipolars for these as a starting point? This will save about £40 per speaker.
I guess if it all sounds good I can replace with polypropylene at a later stage.
low cost USBi programmer using cypress CY7C68013A board
I managed to use a low cost CY7C68013A as an usBi programmer for sigmastudio.
I had to change some of the stuff in the analog thread https://ez.analog.com/thread/11612?start=30&tstart=0
as the drivers did non install on win7 x64.
you need to create your own cable with 10 pin header and connect it to the board.
GND pin 10 on the ribbon
SDA pin3
SCL pin 1
RST pin 6, from PB0 via a 470 ohms resistor
as shown in the picture. (resistor is 1206 smd)
the download the CySuiteUSB_3_4_7_B204.exe and install.
for win7 and 8 also install the CY3684 DVK package.(cy3684setup.exe)
remove the jumper next to the eeprom and remove the programming cable from the audio DSP card. power up the cypress board. it may or may not find the driver. if not,in the win device manager point to location:
C:\Cypress\USB\CY3684_EZ-USB_FX2LP_DVK\1.1\Drivers and find the driver for your operating system as cyusb3.sys inselected folder.
then power up cypress/cypress suite USB 4.3.7/Cyconsole .
there is a little button showing a folder with doc thumbnail to load a script. find the script in the sigmastudio directory:
C:\Program Files\Analog Devices\SigmaStudio 3.11\USB drivers\x64\ADI_USBi.spt.
press play
then The board will re-enumerate on the USB bus as
Analog Device USBi (Programmed)
put the eeprom jumper back and power cycle the ezusb board. now connect the board to the audio card and check with sigma studio for proper operation.
I will put some hotglue on the wires to stabilize the solder joints...
New member looking for assistance with head amp for GAS Sleeping Beauty
Hello - New subscriber here. Just getting back into fiddling with my old esoteric stereo equipment. I have a couple of GAS Sleeping Beauty MC cartridges that I purchased eons ago at the GAS going out of business sale. Was wondering if anyone knows of a head amp commonly available today that would be compatible with these cartridges? Many thanks!
3-way side bipole speaker thoughts.
Hi folks,
I'm tempted of reading on bipole projects again, due to the reason one can neglect the baffle step compensation network, thus increase efficiency in the bass region.
I'm aware of the bipole dip of face-back bipoles and I'm wondering if two side midbass speakers would work.
However next come the following challenge - directivity limitation of side speakers. That limits the project to go above 2 way and puts it into 3-way, where a midrange is needed.
Another challenge would be the back location of the speakers, hence their acoustic centers located way back. How does one time align such projects?
What other challenges do you think the designer would have to face?
For Sale Eikona 2 (Pair) EJ Jordan -- Ship Worldwide
SOLD
For sale is a pair of EJ Jordan Eikona 2 loudspeakers in factory condition. They were mounted in a few test enclosures and measured, but that's about it. See the photos.
They are £600 new ($750 USD // €709 EUR)
My asking price is $450 plus shipping. I will ship anywhere in the world.
Please message me your location and postal code for a shipping quote. Thanks!
Custom cables and connectors
Apologies if this is posted in the wrong section. Please let me know and I’ll move.
I’ve build a couple of custom bookshelf speakers which sound really nice in my opinion.
One of the speakers has a 4x30 amplifier with dsp. There are two enclosures and each has a subwoofer and a full range drivers.
Where my design is really let down is with the speaker connectors, they feel cumbersome and clunky. I currently have 4 binding posts on the back of one enclosure which I used 4 cables with banana plugs to connect to the other enclosure.
Are there better connectors I could use? How about cables?
Some of my purchased speakers have custom cables and connectors so it’s just one cable with neat small form factor connectors. I think this would be way better but I’m not sure what to search for.
Thanks so much in advance and let me know if more info is required
For Sale F5Pi Voltage Gain Stage + M2 Output Stage (with matched transistors)
Hello All,
Unfortunately I have changed direction and will not be assembling this very nice amplifier. I'm offering everything as I purchased them from the 3 GB.
The F5Pi -- F5P Voltage Gain Stage + M2 Output Stage = Perfectly Integrated
https://www.diyaudio.com/community/...-m2-output-stage-perfectly-integrated.406024/
Group Buy for Toshiba Q-Set for the F5Pi
https://www.diyaudio.com/community/threads/group-buy-for-toshiba-q-set-for-the-f5pi.410439/
F5Pi - GB for US mosFETs, BoM etc
https://www.diyaudio.com/community/threads/f5pi-gb-for-us-mosfets-bom-etc.409406/
Potential GB for original PCB set for the F5Pi
https://www.diyaudio.com/community/threads/potential-gb-for-original-pcb-set-for-the-f5pi.410440/
I will only be shipping to Canada and USA for now and selling the whole lot for what I've paid but I'm including free shipping
Price is -SOLD- (shipping included) + 3% PayPal fees if goods and services is used.
Regards!
Do
Reactions: birdbox
3.5Way - XO design and measurements
Hi All!
I am building my first 3.5Way floorstanding speakers. I selected the drivers, designed the enclosure and built a test version, using scrap MDF that I had laying around my shop. The idea was to validate that it is a feasible project. Drivers are:
- Tweeter: Peerless XT25SC90-04
- Mid: HiVi Research DMB-A soft dome
- Mid Bass: Vifa P17WJ-00-08
- Woofers: Generic Aiyima chinese 8" woofers. I will be in the US by the end of the year and will get Dayton Audio DC200-8 8" Classic woofers. Box volume was already defined using Dayton's drivers.
The test box is built and I've just took a few measurements of each driver. I used REW in my macbook connected to a cheap car amplifier and a dayton audio umm-6 calibrated USB microphone, at 1m and aligned with the Mid dome (which is the height my ears will be when listening).
I also took measurements in my dedicated listening room, where I will put the speaker. In this case, the microphone was about 2,7 meters away and the speaker was toed out about 15 degrees.
Now comes the question. For each measurement, I generated a set of frd files, imported on VirtuixCad and designed a crossover. I expected the measurements to be different, but the differences that I found seem to be a little too much (do not mind the average SPL - i've used different volumes in each measurement).
This is the XO based (alpha draft version 😂) on the in-room measurement (do not mind the fact that it has only one woofer - I measured both woofers in parallel in a single sweep):
This is the XO (also alpha draft version 😂) based on the outdoor measurement:
I understand that reflections, room modes, etc would change the frequency response (that is noticeable specially below 200hz), but the huge phase difference that I am seeing - which is changing drastically crossover points and driver polarity - is bothering me a lot.
What could be causing this? Maybe the distance between the speaker and the microphone, which changes a lot the time arrival of each driver?
One last info: I am using in-room measurements because the speaker will be there for a long time. I will be using it in this room to listen to music only (for movies, the current setup that you see in the pictures will be used). So i am aiming for a passive XO that is tailor made for my room.
I would love to hear your insights.
Thanks!
  • Thank You
Reactions: GM
My first tuby
After lurking dozens of years here on diyaudio , I decided to build my own riaa tube preamps.
After retirement I recently picked up an old hobby, tubes and amps, combined with a renewed interest in playing vinyl , I acquired some pcb's on aliexpress. One board was based on the Mofi riaa mm/mc preamp, two dual opamps opa1652, two voltage regulators for symmetric psu ,+18V and -18V, and the split active low boost - passive high roll-off riaa network, ready in no time, and sounded quite nice, no hum, noise or other inconveniences, but not very satisfying to listen to.
After some reading on the internet, I got interested in some tube based riaa preamps, in particular the ear384 which seems a shunt feedback design, the Joe Tritschler split passive high - shunt fb active low boost design with unobtainable tubes , and the JL Hood , originally solid state but translated to tubes-mosfet hybrid by me, split series feedback low boost and shunt fb high roll-off design. To that end I acquired two pcb's from aliexpress, one designed for the ear384 design and one for the shure M65 preamp. I wasn't very impressed with the sound of the Mofi ear384, it seemed to have more than twice the voltage output at 20kHz than at 20Hz. Measured with an inverse riaa filter , modelled after the design on Rod Elliot's webpages, with the 1k gain setting resistor altered to 590R , much closer to the original 604R from this design, with all inverse riaa components selected to be within 0.1% of the target values, this fed by a GFG-8015 function generator. So I changed that to the tube-mosfet hybrid JL Hood design:
A few errors , the 43R from the shunt feedback network is connected after the 3.3uF capacitor and the 590R isn't there.
This was a lot better to my ears. Allso measurements with the inverse riaa filter seemed to indicate a much better riaa conformance , with deviations <0.2dB , and a slight roll of at 20kHz, depending on the actual value of the 81.5pF capacitor. The CCS loading the ecc83 is made out of a J112 jfet and a cpc3960 depletion mode mosfet with ca 1mA current. The active low boost riaa feedback network is targeted at around 4mA current. The capacitor parallel to the source resistor can be made into a rudimentary rumble filter. The 6J52P pentode can be anything , ef184 e280f e180f e186f e810f or 6j11p. This my not very tidy test model:
Two gas discharge tubes for ca. 289V stabilized HT and a LM317 for a stabilized 12.6V , the two 6J52P tubes here used run heaters in series, just like the single ecc83. Riaa componenets are selected to match between left and right channel. Because of the feedback design tube matching on gain is less relevant and left and rigt outputs match very nicely.
I allso read much regard for a completely passive design, so I used the shure M65 board to make a complete passive design:
Again a hybrid design , with a 2sk117 jfet cascading into a 6BK7A triode , here cascoding the jfet and the triode would give higher gain, but I wanted to have a line level output voltage. Output is buffered by the ccs loaded mosfet source follower, whereafter the passive riaa network, the values shown gave me the best riaa conformance, though official calculations give sligtly different values. The second triode is ccs loaded with the "mu?" output used as the output. The 825R for the cathode, unbypassed, is to limit output voltage , a LM385Z-adj. would yield more gain, but I wanted to keep the output at approx. line level. This amp allso sounded very nice , though somewhat softer in tone , but absolute no listening fatigue, so much so I have to reconsider playing records because the cost of good needles is pretty inflating my household budget. This is the modified shur M65 pcb:
I couldn't decide which was the better of the above two designs, or the solid state mofi design. I find the tube designs more interesting to listen to, I think mainly because of the looks, with solid state there ain't much to look at, and , despite what people might say, looks count for the listening experience.
To listen to the tube riaa preamps , I allso decided to build an integrated power tube amp, consisting of the standard PP power amp, a tube based tone control, and a builtin riaa preamp.
It's based om el86/6p43p tubes , with a 6BK7A based LTP phase splitter ,ccs in the tail to the -50V ,and a shared ecc83 input tube for L and R channels. The tone control is based on the ecc832 , the AU halve is used as the CF input with the AX halve serving as the actual tone control triode, baxandall type, so no gain in mid position. Both loaded with ccs's made of a J112 and a CPC3960, 4mA for the AU and 1.2mA for the AX , wherev the "mu" output is used for connecting to the power amp input. The riaa preamp is based on the Joe Tritschler passive -active shunt fb design, but with ecc83 tubes, a 2sk208 cascading into the the ecc83 as input, that is ccs loaded with 1.2mA , with the mu output loaded with the passive riaa high roll-of. It's cathode held at fixed voltage by two LM385Z-5 vref's that need only 10 micro A to work properly, and with 1Ohm dynamic resitance no capacitor for AC is needed. The second triode halve , allso ccs loaded with 1.2mA functions as the low boost shunt feedback amp and output to the volume pot. This riaa preamp allso sounds very good, albeit not as "clean" as the other two. The whole amp is fed by a smps , supposedly 300Watt, I got cheap from aliexpress. It's advertised to deliver 300V/600mA, 12.6V/?A , 6.3V/?A and -50V/100mA . Actual output voltages weren't that good. The 6.3V has it's own switcher to make the 6.3V from the 12.6V output. It gave under load only 5.9V and I had to change the feedback resistor value to the switcher to a slightly higher value, it's now 6.23V which seems close enough. The 12.6V was only 12.18V, after allso changing the feedback resitor to the calculated necessary value I got 12.54V , close enough, which allso brought the HT output from 278V to 283V, still quite some lower than the advertised 300V , but since I was using el86 tubes in standerd UL PP design, it was more than enough. Loaded with 5k OPT's , it delivers 18Watts per channel , constant tone test.
The amplifier has no appreciable hum or noise when line level inputs are selected and volume max with ear against speaker cone, but considerable hum when one of the riaa preamps is selected. The seperate riaa preamps have transformer psu's and sound more open than the built-in riaa preamp, but all have equal loud hum with volume at max. Might the smps be the reason for the less open sounding built-in riaa preamp ? I do see a lot of HF dirt on the several supply lines, in the 100kHz till 1MHz range. After changing the power supply input capacitor from the low quality 150uF 400V type to a brand quality 390uF 450V it was less, but still. From scope readings it seems to operate around the 115kHz region and is of the LLC resonant type. The output supply lines have no inductors , like you see in computer psu's. What would be usable types for this frequency and application? The tone control and power amp don't seem to suffer that much from the smps, but I have the idea the riaa preamp has. The tone control and riaa tubes are HT fed by a voltage regulator that brings down the 283V HT to 253V. I tried shielding the smps but that didn't had much effect. Allso, a signicant 50Hz ripple is present on the supply lines , as I understood from reading several papers, caused by the capacitor between the groundplanes of the power input and the supply output. Is there a preferred way of grounding this contraption. I now have a earthed power entry with HF filter to supress HF bleeding into the powerlines and at the supply side a bus ground connected to the power earth entry. Power ground is o.c. not connected. to any of earth or supply ground , except for the capacitor between the power ground and supply ground, which is there for safety reasons as I could make up of reading of the appropriate papers.
And the hum, how could I get most of the hum removed, when I connect the record player through the mofi solid state preamp, no hum at all, when I use one of the 3 tube riaa preamps lots of hum. I have to say that at the normal listening levels of the volume knob , there is no hum noticeable in listening position, only a bit with ear against speaker.
In the end I would say that all riaa preamps, when built to standards sound the same, with the fully active a bit more snappy and the fully passive a bit more airy , and the in-betweens , well , in between. The solid state preamp has no hum or noise issues whatsover, but is uninspiring and a bit flat sounding, probably mainly it doesn't look that good. The tube based riaa preamp are hummy at max volume, couldn't figure out where that comes from, grounding is exactly the same as with the solid state preamp. Noise is allso not a preblem for the tube preamps, though the smps fed riaa preamp seems to suffer a bit in cleanliness, hard to tell. I will at one point replace the smps with a transformer based psu, see how that goes. I am not sure if I hear that right, but smps seems to compress the audio a bit, but than again, might be completely subjective, knowing what you listen to might make you hear things that aren't there. Anyways, all the riaa preamps seem to perform quite well. The mofi ear384 and the shure M65 , the original designs for two of the pcb's I had bought sounded dreadful and very fatiguing, not recommended. I think I like the fully passive design best for acoustic/classical music and the JL Hood active series - active shunt design best for the electrified classic blues, blues-rock etc. music I like to listen to. Any comments on the designs would be appreciated. I am no electronics engineer so there might be a lot to comment on, all designs are cobbled together from bits and pieces I found lurking throught diyudio and the internet in general.
Thanks for reading this travel log into tubesland.
Systux
Life after Frugel-Horn Mk3
After completing and enjoying the Frugel Horn mk3 speakers I'm looking for a new project as my son has claimed them for his new apartment. I must thank everybody involved with design of this great floor standers. First listen was away from the rear wall and sounded far too sharp in the mid range but after some moving around wow, very nice. Bass very good but not over powering even close to wall, top end detailed but not sharp. My son felt the same and now they are gone 🙄.
Looking at the Frugel Horn XL as I believe these will have a smother and richer mid range but without bass overload hopefully. The Sibelis clone looks interesting but without driver cabinet match. Any recommendations on the next build and possible performance compared against the FH mk3.
Audio garage sale. Fane 15'' fullrange drivers in mint condition (FC152F01-TC)
Originally purchased an OEM pair of Fane FC1502F01 from Thomman music in Germany. Still ub original box and moved on with different DIY projects. The pair is in absolute mint condition!! So many projects. Too little time
Selling price is 50 USD + Shipping cost via Paypal to local 48 CONUS
Spec is here:
https://www.fane-international.com/downloads/Fane-FC152F01-DS280417.pdf
There's a whole thread from DIYaudio forum talking about this speaker build
https://www.diyaudio.com/forums/full-range/308652-15-range-fane.html
I live in San Diego, CA so local pick up is more than welcome to save shipping cost.
This sale is only for US local. No international shipping.
Thanks,
IMG_9765
IMG_9766
IMG_9769 (1)
IMG_9776
IMG_9859
IMG_9860
The ultimate OTL6080
Hi All,
I've been off for a while : no time, not much money to devote to... 🙁
My last Audio Hi-Fi build I posted was The ULTIMATE 300B :
In the same vein (same format, same chassis) I am building the prototype of what should be (one day) The ULTIMATE OTL6080 :
General layout of what should be a mono block :
Amp section prototype only, for tests and qualification purposes, same disposition as layout :
I have to build the PSU prototype now, in the days to come.
Wait and See ! 😉
A+!
Adding a remote control to the SPL Volume 2 preamp
Hello everybody!!
A SPL Volume 2 preamp is coming my way, and I'll be looking into adding remote controlled volume to it.
Looking around, there's this kind of motorized volume control kits: https://www.aliexpress.us/item/3256802832503035.html
They seem relatively straight-forward, but there's not much space inside the SPL preamp for adding the control kit to it:
At any rate, would you think this approach is feasible?
TIA!! 🙂
Peavey Bandit 112 Red Stripe issues
Hi guys.
I just got a Peavey Bandit Red Sripe (1995 or later) for repair. I received only the amp without speaker encosure.
Acording to the customer, it suddenly stopped working, only a very faint sound is comming out of the speaker.
I checked the power amp and it had an open diode (SZ-13886). I replaced it with a 1N4007 and the power amp works.
The preamp section only works after messing whith all controls and switches, and then wacking it a few times...
Once it starts working, it sounds just like expected.
It has the notorious "IC" brand e-caps in it. None of them looks bulged or otherwise suspicious, though.
I suspect a cold solder joint or in the worst case a broken trace. This preamp pcb has traces on both sides. But it also could be related to an electrolytic cap.
Any ideas what might be going on?
Class A SE amplifier
Here is my diy amp, front and inside 🙂
Just resently replaced bad mosfet, and installed copper heat spreader.
Now mosfet run about 70-80° celsius.
Maybe future i change thermal paste with thermal grizzly carbonaut pads.
Under the copper plate is 3* sot 247 ceramis insulators.
Copper plate is 30*70mm and 5mm, originally used power bar for transformer or something similar electric usage.
Classical point to point wiring and crimping vs soldering here and there.
Parts are someone else made, i only but them in practical use, but i think it always be like that, when you talk about diy setup more or less 😀
What do you think of the setup?
Reactions: cumbb
NE2H Neon indicator resistors
Hi all,
I hope this is the right forum.
I'm repairing our oven which has neon lamps for indicating oven on and thermostat on/off.
The power indicator which comes on with the oven popped (literally) so as I have new neons in my stuff I thought I'd just replace the broken one. However, when I pulled the lamp and extracted it from its housing, it had what appears to be a 1/8w resistor in parallel with the neon pigtails. There was no resistor in series UNLESS it completely vapourised (the unit is very blackened and this actually could have happened as it tripped the RCD).
The resistor measures 47-ish K but is pretty burned so may be out of spec.
Power for this lamp comes straight from an open mechanical switch for the oven so there is nothing hidden.
Can anyone shed light on why there's a resistor across the neon? I did search and could only find reference to this being a thing for inductive loads to stop the neon glowing when switched off.
What do you reckon?
Cheers
Stuey
(BTW the original part is very difficult to source, hence the DIY).
Low-Noise 5V-1A Wall Wart Recommendations?
My use case is a 3 meter looped lighting strip behind my audio rack, and a second use would be an HDMI audio converter. I have an analog setup on the rack and I’d like to avoid it picking up the switching frequency and sidebands.
I have been looking at the Motorola R410510, a rather bigger linear supply, but welcome other suggestions too. I’m uncertain how much noise those little iPhone USB/type C wall warts produce.
Wire and connectors embedded in resin - how to remove? Martin Logan Prodigy
One of the connectors that connect the panel to the electronics of my Martin Logan Prodigy has failed. This is a known issue at ML but they no longer have the connector available.
Does anyone have any ideas how I can remove that resin-like substance that the wires are embedded in? I would like to remove that to access the bare wires/connectors to fix the bad connection.
Or better yet, if anyone knows where I can get a new one that would be amazing. The connector is called Pulse-lok from Alden. Unfortunately ML says it is no longer available.
Amp volume issues
Greetings,
I have a weird one I wouldnt mind a few pointers on. This is a class D sub plate amp. It works, except the output volume is extremely, extremely low. This came out of a higher end deathtech tower speaker, no schematics or SM to be found anywhere.
The plate amp is split into 2 boards. One is the pre-amp (Filter, PWM generator), and the 2nd is the amp.
The fault occurs on high level speaker or LFE inputs. In order to get any volume, the pre-amp level has to be cranked to full. I definitely have an adequete source level going in and going higher makes no difference. The PWM signal leaving the pre amp looks nice at 38khz and there is clearly modulation ocurring.
Looking to rule out bad capacitors, I completely recapped both boards (and we definitely had some bad caps failing ESR tests). Unfortunately, no change in behavior. Maybe a bit more stable PWM signal out of the pre-amp.
Pre Amp: The voltages seem stable, but the OP amp + - rails aren't balanced; positive 13.4V and negative 15V or so. I checked around and the consensus seemed to be that having perfectly balanced rails isn't a huge deal. OK. Is that right?
Amp: I discovered a large patch of highly conductive circuit glue underneath the input connector. This encompassed several opto isolators and transistors. I carefully removed the glue and cleaned the board. No change. I'm considering the possibility of foobared optos, so will be changing those out in the coming days.
I'll see about posting the 38khz PWM signal for y'all to review.
In the mean time, what else could be going on here? Open to all ideas and suggestions. Thanks in advance!
Why OB driver decoupling?
I've seen a number of open baffle builds that hang drivers, or attach them to flexible mounts to decouple them from the vibrations of other drivers. The LX521 uses a stand to decouple the subwoofer frame from the rest.
I have not found any measurements to show how useful this is. Does anyone have some measurements to show the difference this decoupling creates?
Reactions: Juhazi
Mute Circuit Class 4 clone
I have a CT Sounds 2000.1 class 4 clone. I Need some help with the mute circuit. This one is staying high on Pin 3 of the driver board.
I have working driverboard I swapped in with the same results.
Driverboard has a njm4560, lm219, and mmhc74m which all have been replaced.
Inductor has been replaced. Original was cooked.
Power section and audio section had failed in this originally.
Drivers and mosfets replaced in both sections.
Optocouplers were replaced.
all 3 of the 5v regulators are within tolerance.
driving an 80hz square to the driveboard i can see on pin 1.
I was able to verify the drive in the output section before I put the rectifiers in.
Driverboard voltages:
1. -.848v
2. .07v
3. 10.22v
4. -11.40v
5. 11.40v
6. .154v
7. .154v
8. .06v
9. 5.04
10. .300v
11. .300v
TPA31xx custom design questions
Hello everyone,
This is my first audio project. Last few days I have been putting together a schematic as well as a BOM for a TPA3128D2 based class D amplifier. Most of the design is taken from the TPA3128D2 datasheet "Typical Application" at page 23 and TPA3116D2 EVM User's Guide (Rev. B) "TPS3116D2EVM Schematic" at page 5 as it is the same as TPA3128D2 Evaluation Module, but includes the schematic and the PCB layers are more readable. I have also included the anti-pop from 360customs and volume control that follows wiring shown in the attached image. The materials of different capacitors are determined by what I gathered from reading through different forum posts.
I am attaching my unfinished schematic. I have multiple questions regarding the design, but I am going to address them one by one in different posts in this thread. What I want to open this discussion with is whether the EMI C-RC snubber (see attached image) is necessary and what is the advantage of including one. Is the advantage audible?
To give you more insight the power supply used is 24V 6.5A, gain is set to 26dB and the speakers are a pair of older 35W 4ohm Pioneer S-P170's.
For the initial post this I believe should suffice, I would like to keep it concise so that it does not deter one from reading the post. Thank you to everyone for reading and responding.
  • tpa3128d2_class_D_unfinished.pdf
DIY spherical ESL
Moving this from the thread on DIY spherical speakers...
For those who haven't seen the previous posts, I am looking at using a 3D printer to produce a "spherical" ESL with 12 drivers about 200 mm in diameter each arranged on the surface of a truncated dodecahedron. The printed parts will serve as structural elements as well as the stator supports for wire screen stators unless I can find a cheap source of perforated sheet metal discs. Diaphragms will be 6 um polyester with Licron coating.
The diaphragm side of the printed parts will print on the printer's bed so they will be smooth and flat. My printer has a 300x300 mm cast aluminum tooling plate bed with a layer of PEI. I am planning to use ABS to print the actual speaker parts and will solvent weld them together using acetone. I have printed some 100 mm stator pieces and a gluing jig to test the accuracy of the printer.
Today I redesigned and printed the gluing jig for the smaller test build before I commit to the full size speaker build, and welded one hemisphere together. I used ethyl acetate (sold as MEK substitute) to solvent weld the 3D printed PETG parts together. As I was gluing it occurred to me that the jig may not be necessary- strategically placed binder clips might do the job just fine. It takes just a tiny drop of the solvent and the joint is secure in a less than a minute.
When I set the glued up assembly down on a flat table all the surfaces on the bottom of the assembly touch the table so I think the printer is producing the prints with accurate angles. The surfaces that are welded looked like they were parallel to each other. I will print the other 6 individual stator pieces and glue them together and see how the two assemblies line up. Then it will be on to more of the design work for the actual drivers.
Note- the print quality is less than ideal- I have a 1mm nozzle on the machine so retraction doesn't work worth a damn resulting in blobby defects. I'll probably switch to a smaller nozzle where I can use retraction effectively for the final prints.
This is a truncated dodecahedron:
Three of the outer stators pieces (red) in the gluing jig (blue). The orange piece is one of the inner stator pieces:
Here is a hemisphere made from the small, test-sized outer stator pieces:
It will be interesting to see if the diaphragm tension causes the stator pieces to flex out of shape. I'll probably add some supports for the wire screen to the inner and outer stator pieces, as well as some means to add dust covers to each driver using the same 6um film as the diaphragms. I still have to work out details of the electrical connections.
aleph 0 biasing
Hi Folks,
Got Aleph 0 from a friend to overlook. Figured out it needs dc re-adjusting and rebiasing. For DC offset it is quite clear, the right pot does the thing. But I am feeling a bit lost with biasing. I understand the left pot is setting the bias, but what is the best way to measure? Points and values, if you don't hesitate.
Thanks in advance.
NAD C 525BEE strange skipping...possibly solved
Hi!
Another NAD-issue here but hopefully solved by now. I guess skipping is more or less strange (and annoying) when it happens.
However, this one didn't make any sense due to the following:
- The C 525BEE quickly handled all my (troublesome) CD/CD-R/CD-RW's without any issues plus is remarkable resistent to movement during playback...not
at all like a player that struggles to read due to a weak laser...
And now the issue, many longer CD's (>=40min) started to skip towards the end.
Well, I opened the little bugger and while everything looked very nice:
However, after using it for a while I noticed the following little "collision" between the white flat ribbon and the black AC wires from the transformer. (Fixed in these photos).
The "collision" took place at the red markup below:
After moving the AC wires away they are never close to each other anymore and haven't heard a skip since then.
Could this really have been the root cause for the skipping - I hope so anyway and I'm a happy NAD CD listener now 🙂
/Per
Reactions: huggygood
Musical Fidelity F16 problem/Schematic
HI All
Little problem with a Musical Fidelity F16 power amp.Keeps coming through distorted on one side and occasionally completely cuts out.Takes a while to happen suggesting temp related but if you raise the input level it cures it possibly suggesting a dodgy capacitor somewhere.Have checked for dry joints.Also does anyone have a schematic for the above.Musical Fidelity will not sell me one.Thanks for any help.Smiffy
Low Budget 2 way speaker
Hi everyone, it's good to be here!
I'm planning to start my next speaker-building project. After building two pairs of full-range speakers (Dayton and Fostex), I would like to move on to a two-way bookshelf speaker.
I'm looking for recommendations on parts combinations for a two-way speaker with a budget of 650-800 euros for all parts (drivers and crossover).
It would be great if the recommendations are based on your experience and if you could suggest a ready-made or kit crossover.
I'll try to specify my requirements to help get accurate recommendations:
1. Room Size: I plan to build these speakers for a small room, around 25 m², so I guess they're near-field speakers.
2. Enclosure Size: I would like to limit the size of the speakers to 40x60 cm.
3. Materials: I think it will be easier with plywood, though I would like to try solid wood such as oak, ash, or walnut, and possibly 3D-printed parts if a horn or port is needed.
Thank you, and have a nice day!
Avi
  • Locked
Whammy Amp builder with quick question
Hi everyone,
I'm an absolute beginner that is nearly done my first build of any kind and I'm realizing that I'm missing a 2.2k resistor, no doubt I lost it myself. Can I replace it with any 2.2k resistor? Does it need to be 'audio grade', or also Dale to match all the others? If I can use a different brand, should I de-solder the one that's already in so that they match?
Thanks so much, this has been so much fun. I'm also very nervous(excited) to see the end result.
Appreciate getting a peek into your community and your expertise.
Project Ryu - DIY Field Coil Loudspeaker
Hello,
***First i want to say I'm not sure if i should post this under Fullrange or Multiway. Since at this point, there is a high posibility of the need for a supertweeter i chose Multiway forums. I won't mind tho if moderators think it's more suited for Fullrange forums.
About 6 months ago, i started thinking about a DIY fieldcoil speaker. I know opinions vary quite a lot on this matter and so i will do my best to offer as much data as possible for things to be judged objectively. Since that time I have been talking with some fellow countrymen and audio enthusiasts about this project and these conversations helped me in making some of the design decisions. The work is still in progress and i hope your opinions and comments can help tune it to higher performance.
To begin, here are the basic aspects about this project:
- field coil underhung motor structure
- 12" diameter
- Wide range (up to 10kHz), hopefully fullrange (up to 20kHz)
- high efficiency
- to be used in BLH
My personal taste in sound is that i like it when it comes out of large radiating surfaces. Large SD, large horn mouths etc. I think it's a necesity when one tries to reach real, live music levels and at the same time keep a good response to instruments' attack, sustain and decay. This is the reason i chose 12 inch diameter. I would've liked 15" better but it would've been too difficult to make it wide range. Perphaps a future project.
Field Coil Motor Structure:
I have spent a lot of time looking for other field coil projects, for any information on FC design or about available products and i have to say there isn't
much out there. From the pictures of opened FC units i could see a basic shape of the pole pieces. I have to say this is amongst the first design issues i encountered, there isn't much freedom to design these pole pieces, not like the case with permanent magnets anyway.
The next thing one can notice is that the new FCs are low impedance type and this is easily understandable. I have decided that my field coil will also work with 12-15V supply.
Underhung design means thick top plate. Of course this will cause a drop in flux density in the gap. The compromise here i found to be between flux density value and voice coil excursion. Since this speaker will mostly be used horn loaded i sacrificied Xmax to make a thinner top plate. I use standard 1010 steel with a maximum of 0.13% carbon, the best i could get my hands on.
I ran simmulations in FEMM for different values of top plate thickness, FC's number of turns, dimension, wire diameter etc. Here are the results i stopped at:
- magnetic gap height: 12mm
- magnetic gap width: 1-1.5mm
- 5.3 ohm FC 1400 turns of 1.25mm copper wire
Below you can find a rather crude sketch of motor structure:
Here are some results from FEMM analysis:
I ran simmulations with 1010 steel as well as 416 steel (has slightly more carbon typical 0.15%) to see the differences.
1010 Steel Curve over 20mm and 12mm:
416 Steel Curve over 20mm and 12mm: (actually the curves are smoother had to lower resolution a bit because of my computer)
Magnetic gap:
AS it is, at 2.2 Amps we have 25W for the FC. I don't expect to have too much trouble with heat at this power. Test will tell tho, depending on how well the metal does the job of sinking the heat. The value predicted by FEMM lies around 1.6 Tesla. In reality i believe this value will be smaller 1.4-1.5 T. In tests i will drive the FC with 3 amps and see how much it heats up.
In this design the gap width is 1.5mm. Somewhat large, I'm thinking to add a 0.5mm thick copper ring right in the gap (yellow part from picture below). Now
it's true i have never seen a picture with a FC unit having a faraday ring and I'm not sure if it's necesary. I guess the FC itself has a role in that too.
I'm also making a 1mm gap variant (without copper ring) in hopes to get more flux density. The FEMM simmulation shows:
Here are some parts of the magnetic structure after machining:
LM4766 vs LM3886 vs "textbook Class D"
after a long discussion and a few simulations i realised that going for an ic is the best idea in terms of cost and sound quality.
i realised that the lm4766 may not be that bad of an option considering its simmilar price to the 3886 and the fact that it haves two channels at good enough power out.
im geniuenly intrested in how it(lm4776) compares to class d amplifiers, discrete designs and the lm3886.
Electronics work bench tips and ideas
I finally decided to rent a work space, I have a really comfortable desk to software stuff sorted.
I want to buy a bench for electronics prototyping and figure out a good method for storing a few components. I need space of a scope, spectrum analyser, cables, hot air and solder station etc.
At the moment everything is stored in boxes, depending what I am doing, I take out what I need and put it away again.
I’d rather leave things out and have it looking neat.
Any advice welcomed!
Please post photos of your bench if it’s something I can buy. I’m UK based, so that might limit my options!
Tinkerer doing down the rabbit hole
I knew I should have avoided looking at DIYPerks - Building EXCEPTIONAL speakers using MODERN TECHNIQUES
but....
Here I am a week later, after spending most of my free time digging into the DIY Audio world.
I am located in Malaysia (but originally from Europe) since a few years now. I have always like DIY (Arduino, 3D printing, Raspberry, etc...) but I have never look into audio.
After getting a good deal for an OLED TV, I want now to match the audio to the picture quality (Current audio is a pair of Edifier 1280DB) !
I am particularly interested in a wireless home-theater system and I will post my findings so far in the dedicated section just after this post.
JBC CD-1BQF Soldering Station T245 Handle
Excellent condition JBC CD-1BQF Soldering station with T245 handle, no issues. Just upgrade to a multitool station so no longer needed. I will include a SMD hot air rework tool as well.
$300 USD
Weird wiring in Musical Fidelity phono preamp sections
does anyone know what the two wires in the Musical Fidelity A1, B200, and other amps from that perdiod are supposed to be for?
If I am not completely mistaken, the cut track is just reconnected with one of them, and the other wire is just in parallel to another (uncut) track.
This is the 2nd amp I see this "in person" on now and searching the net for pics of open A1s etc. shows this is "normal".
The tracks are both coming from the MM/MC switch.
Any reasonable explanation?
Thanks,
Mo
Help with ZK-TB21
Hi, i have a problem to disable this bluetooth thing... but i don't find any kind of solution for this...
I have try to disable the BT antenna and nothing happens.... this problem is sh**** because my neighbor is always connecting to it. And i can't hear anything from my PC (Connected via AUX)
Board is a ZK-TB21 (2.1 Channel Power Amp)
Chip is a JL AS208P08912-25A4
What are your ESL transformer requirements?
Hello everybody,
I am planning to make a wire stator full range ESL.
Planned width 198mm, height 1600mm, distance between stator and film 2mm.
I'm also thinking about segmentation using "esl_seg_ui".
I made a full-range ESL using Perforated metal in the past.
I used a 2x50VA 6V/230V power supply toroidal transformer and it didn't produce much bass.
I think the culprit is the step-up transformer.
What are the requirements for a transformer that can be used for a full range?
Required core cross-sectional area. What is the number of turns on the primary side? , what is the required turns ratio? , the gauge of the primary and secondary coils?
It was written in detail in the following URL, but there was something I didn't understand.
https://www.diyaudio.com/community/threads/diy-bass-transformer-for-esls.186011/
What value is "E" in the following formula?
Bmax = E x 10^8 / (4.44 x f x N x A)
Bmax = Peak AC flux density in core (Gauss)
f = frequency
N = number of primary turns
A = core area cm^2
The following transformer specifications seem to be suitable for full range.
The cross-sectional area of the core varies in size between inches and centimeters. Is it my reading problem?
which one is correct?
Soundlab A-1 bass transformer: step-up ratio(200:1)
EI transformer with core = 4.5 in^2 = 29 cm^2
Primary winding = 120 turns
Secondary winding = 24,000 turns
thank you.
(I am using Google Translate)
laboratory audio headphones
Hi everyone .
I would like to buy new headphones, or at a good price on the used market, it depends on the price.
the characteristics must be maximum transparency and no coloring, assuming it exists with these characteristics. practically a laboratory headset to be used to carry out experiments and modifications on the casings.
all this because I want to make an auditory comparison between a neutral sound transmitted by the headphones (which in my opinion are suitable for this purpose. Otherwise I wouldn't know what to use) and the one that comes out of the casing from the speaker (K12 prototype).
the aim is to understand what the defects of the K12 (cabinet) are in order to eliminate or limit them as much as possible to obtain maximum sound quality.
if the headphones also work as a soundproofer to protect my ears I get another important function, so I can use it when I sweep with REW.
I don't know if headphones with these characteristics can also be used to listen to music.
I use a laptop connected to the E-MU 0404 USB sound card.
The card has a headphone output, is it possible to use that directly?
the one below is a link inserted by me and is related to the same topic:
https://www.diyaudio.com/community/...strengths-and-weaknesses.412726/#post-7694471
I will also follow the other advice received but the first and simplest step is the headphones.
bye thank you .
  • Article Article
Reducing the noise out of my IEMs
I have an aged pair of IEMs from around 18 years ago - Shure e5s. I've barely used them as I found the coupling to my ears to be insanely sensitive to getting a tight seal - even a slight gap results in almost no bass response. They also have cables that wrap over the tops of the ears which make them more than averagely fiddly to fit. The rather unusual characteristic they have is that their sensitivity is extreme at 122dBSPL/mW - at their impedance of 110ohms this puts the 0dB point (threshold of hearing) at 0.26uV. From browsing Amir's reviews of headphone amps over on ASR I found precisely none to be low enough in noise so that its residual hiss is certain to be inaudible through the e5s. Which would mean a noise at output of below 260nV. The nearest seems to be the Topping A90 for which Amir records a 50mV referenced SNR of 93dB. Meaning its output noise is 1.1uV. That is at least 12dB too noisy.
Looking into more modern IEM designs I see the trend is towards lower impedances which make the HPs even more sensitive in voltage terms. I don't know if any reach over 130dB/V (the math gives me nearly 132dB for the e5s) but there are some mentioned here that go over 120dB/V so they too are too sensitive for the lowest noise recorded in ASR for a HP amp. What's a sensitive IEM user to do when no extant amps are going to deliver him/her a noise-free listening experience?
Clearly an output attenuator is called for, in order though to avoid adding more noise a resistive one would be less preferable than a transformer. With a big enough step-down ratio in hand I could drive the Shures directly from my Dark LED I/V, bypassing the need of an amp altogether. 10:1 step down would mean the output noise could be up to 2.6uV and as far as I recall, the Dark LED's output noise is lower than this when fed current from PCM58s. The PCM58 being about the lowest noise R2R DAC chip going. The Dark's maximum output level is 2VRMS which, through the trafo would send the e5s 200mV hence a peak SPL of 118dB. Should be sufficient.
Reactions: xpaladinx
Sony knobs
Hi guys So I gèet this sony str 7025 fixed it up to original glory
I took front off to clean display dial and knobs and switches
Any road put them knobs back on but there not as tight as before what do you good folk do don't wans be sprizing them 2 prongs apart don't wana snap um what's your thought on this problem yeh and I wana be able to take um off again at somepoint int future
Cheers
Mike
VSSA Lateral Mosfet Amplifier (lazycat) with EXICON
VSSA AMPLIFIER WITH EXICON LATERAL MOSFET
PCB is available
Safety Practices, General and Ultra-High Voltage
I want to live. :hbeat:
In the interest of safety, I would like to collect whatever safety tips and practices this forum kindly and experienced members will share, so that all may benefit. :grouphug:
First, some warnings and disclaimers:
  • Any voltage can be deadly. :hot: :RIP:
  • Amplifiers are dangerous--each person (me included) is responsible for deciding if they are willing to risk their life, and for ensuring that whatever information they receive is correct
  • This forum and its members accept no responsibility for any death, injury or property damage that result from any of these suggestions--your safety is your own responsibility.
And please note that I have *no* amplifier hardware on hand, and will not for a while. This is a discussion only, and I will only be talking about doing stupid things, not actually doing them.
Okay, with that out of the way, I would like any tube equipment electrical safety advice you care to share, both in general, and for what I will classify (for the purposes of this discussion) as UltraHighVoltage--1000V to 1500V.
I'll start with what I think I know, and you can add more or correct me if I am wrong.
I can think of two basic rules of thumb--
  • Make sure any charge-storing devices remain discharged while working on the equipment
  • Avoid creating a circuit which would pass current through the heart.
From those rules of thumb, I can think of these specific practices:
  1. Put a drain load across all significant charge-storage devices (e.g. B+), and leave them there for the duration of your work--some devices can redevelop voltage if left unloaded.
  2. Verify that all charge-storing devices are discharged before starting work.
  3. Always work with only one hand--keep the other hand in your pocket.
  4. Use hook probe for secure connections and to avoid shorts.
  5. Wear rubber gloves and rubber soled shoes--no bare feet or socks.
  6. Make sure your design has the chassis safety grounded--connected to the ground wire of the power plug.
    [/list=1]
    Okay, what do you think about these practices, and what can you add?
    One member spoke of a "bench isolating transformer". What is that, what does it do, and how is it installed/used?
    Also, what extra design and usage practices apply to UltraHighVoltage (1000V to 1500V) electronics? I'm thinking about things like component choices, test procedures (standard DMMs are only rated to 600V), design practices (danger of arcing), etc.
    Thanks for your attention and advice. Although I hope for courtesy, I'd rather be flamed figuratively than literally. :hot: 😉
    Best,
    George Ferguson
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,471
Members
7,921,122
Messages
Filter
Forum Statistics
Threads
407,840
Messages
7,921,122
Members
508,471
Latest member
Delrtm
