What is this technique called?
Looking at some photos of open baffle stuff and this one comes up... One calls it slot loaded, another calls it horn loaded.
Technically I suppose I'm curious of:
  • what the ring type relief is called?
  • does the phase plug simply avoid the flat slapback of leaving that central portion untreated?
  • is this slot or horn loading?
Maybe it's neither etc, I was just curious "what the folks at diyaudio called it" etc. Thanks
For Sale Babelfish XA252
-SOLD-
Built using full kit from ZenMod with Antek AN-10425 transformer, Randy’s W12 CRCRC PS board, DIYAudio Softstart, WBT binding posts and RCAs, KimberKable wire and custom 4U 500mm chassis with UMS hole pattern. Sounds fantastic. Only selling because I purchased a PassLabs Int-25.
Asking $1,000 with shipping within continental US included.
Highly confused about Texas Instrument TAS Class-D IC and LC output filter requirements for post-filter feedback
Hello everyone,
I put some effort into designing an output filter for a class-D IC. Here I am using Coil Craft's and Murata's SPICE models to calculate the filter with an 8 Ohm load.
Lines:
  • Red line is the capacitor impedance
  • Green line is the inductor impedance
  • Purple line is the filter response
Filter:
  • -3dB cutoff is around 25kHz, just outside the audio band
  • The filter works until about 10MHz where the parasitics of the components have a resonance.
  • Sure the values can be tweaked, but this is not a bad starting point for now.
Post filter feedback
The IC that I am using TAS2780 has a post filter feedback (PFFB) feature and I thought that would be good to use to keep the THD as low as possible. So I started reading about the PFFB requirements.
It seems crazy to me to specify the filter cut-off frequency to be greater than 10MHz when this device is switching is 380kHz.
What could they mean?
  1. The rise/fall time of 1/10MHz = 100ns. So maybe if the rise/fall time of the IC is around 10ns or less, the filter could filter that out?
  2. The cut-off frequency they mean where the parasitics break the filter? This is around 10MHz for the L and C parts I am using.
They have an application report SLOA260 that was not that helpful, if focuses on using ferrites.
Questions
  1. Can anyone experienced with Class-D and filter let me know if a -3dB cut-off just outside the audio band is sensible?
  2. Has anyone used TAS ICs from Texas Instruments before, or the TAS2780 specifically? Can you suggest a sensible filter with or without the PFFB feature.
  3. What the hell are they talking about in the data sheet and application report when they specify the cut-off must be greater than 10MHz?
Help for 2 way build with TAD2001 on top
Hi All,
I am going around in circles trying to decide how to proceed on my next build. I have a pair of lovely TAD2001s coupled to a beech plywood tractrix horn that I have made - very happy with the sound at home. Below it I am using a Supravox 285 in a ported enclosure as a 2 way monitor style. They seem to work very well together but the low end is limited in extension and the output of the woofer is slightly limited for high spl fun now and again albeit super detailed and fast in mid bass. The crossover is 2-way 2nd order at 800hz - that suits my horn fc and what TAD recommends. Using active crossover right now.
So I am now thinking how do I take this to the next level to accommodate more output without ruining quality but also being durable. I was considering either going for an alternative single 12” driver or building a new cabinet with MTM design using twin 12s per side OR going for a single 15” like the JBL 2226H. I did loads of Hornresp simulations of different drivers but can’t make up my mind. The 2226H in every sim I did didn’t really get adequately to 800hz. 700hz looked max but I realise many use it above that.
I do want to be able to play this system really loud on occasion so durability of woofers is also important. I am not too fussed about content well below 40Hz as I can augment with sub. Importantly I do want high efficiency.
Any advice much appreciated!
2SC3381 and 2SA1349 replacements
Hi y'all! New here but not entirely new to DIY audio projects.
My friends and I are looking for replacements for Toshiba 2SC3381 and 2SA1349 BJTs. There are forum posts with single package replacements over the years, but even those replacements are out of production. I'd like to avoid eBay or sketchy transistors if possible. If I'm not mistaken, the parameter we are having difficultly with is the DC current gain (hfe) classification we're looking for a minimum of 350.
Any help is appreciated, thank y'all!
Greetings from Italia
When I have reached retirement, I can finally dedicate myself to diy audio, which I have been doing for 50 years now, especially in speakers, both on magazine projects and designed by me, also thanks to the forums on the web.
To write in English I have to help myself with the automatic translation of the web, so sorry for mistakes.
I have also been passionate about environmental acoustics for many years, because of a friend acoustic engineer specializing in concert halls, acoustics in public places, companies etc.
I finally made a special listening room of 7x5x3 meters designed and evaluated by him with a final written report. This is because for years I have been convinced that 50% of the final quality depends on the environment, especially for the bass and high levels of listening that I like with the right music.
Again greetings to all.
Modify integrated amplifier as preamp
Hello,
Im new here, hope this is correct subforum. I plan to test my working integrated amplifier Marantz PM-750 DC, want to try their preamp.
I already research that its doable. I want to make sure, is this the correct signal path? Here is the zoomed schematic, and below is full schematic.
What i read is right before power amplifier board to make an output.
Red is right channel line
Orange is left channel line
Blue is where i plan to cut.
And second question, if i plan to test the amp, should i put E-CAP bipolar 10uF 25v in series each channel, just like what i see in my Marantz 1180 DC right after "MAIN IN"?
Thank you
DFPlayer output as Line-Out
I'm designing something in which audio plays a small but vital part. A DFPlayer module will be used to play a short audio file and the output will feed an external PA system. The easiest way to do this is to use one side of the BTL outputs as a Line-Out rather than create a balanced-to-unbalanced converter
With this arrangement, one output pin will be open and the other pin will face an unbalanced high impedance load to ground. Is there any possible issue with this arrangement, in terms of stability and distortion? None of the documentations I've seen about DFPlayer is very forthcoming with this kind of information.
Atention to Classe CDP.3 owners
As the DAC nearly newly released maybe somebody will have benefit for it. There was error during asembly and many (I checked photos in internet- same error) or probably all cdp.3 have wrong capacitor soldered in filter - 15nF instead 1.5nF. I accidely found after tried listen to it. high frequencies was rolled of quite badly at 10khz already -3db
once replaced sound become transparent and airy.
i have expierended same ~2011m on m2tech evo usb conveter were highs had -3db at 15khz and 1.5db at 8khz
hope this helps
Reactions: merlin el mago
Help with Sanwu PBTL
Ok as the title says I have the red Sanwu tda7498E version from Amazon. I soldered the 4 jumpers together on the bottom of the PCB and input a signal into the LEFT RCA only from my low pass filter preamp. I also put both dip switches that control gain to the max setting of 36db and the output level is approximately half of what I get in btl mode! I usually use this amp in btl with (2) 4-8ohm 2-way bookshelf speakers and it gets very loud. I measured 26vac average clean with my oscilloscope while using a 34v 10a PSU. While the amp is in PBTL I'm using a 4ohm GRS 8" high excursion sub from parts express. What's going on, am I doing something wrong?
Does anyone have experience with passive radiators and WINISD?
I am trying to mate some SB Acoustics drivers and passive radiators together. They are literally made for each other, however, when I enter it into WINISD it is simulating what I assume to be an improper frequency response. Part numbers below:
Driver:
5×8″ SB15SFCR39-4 / Paper
https://sbacoustics.com/product/5x8in-sb15sfcr39-4/
Radiator:
5×8″ SB15SFCR-00 / Paper
https://sbacoustics.com/product/5x8in-sb15sfcr-00/
These are small 5x8 drivers so I would think they wouldn't require a huge amount of space.
Can I get a sanity check? Yellow is the passive radiator. Blue is it vented. The vented looks great. I would think the passive radiator made for this driver would look similar.
The Martin Mars
The Hawaii, has left her home on Vancouver Island for the final time.
https://www.cbc.ca/news/canada/british-columbia/hawaii-martin-mars-last-flight-1.7291472
I had the pleasure of visiting the second to last unit, and parts of others, (the only flying one was anchored off shore), on a trip to Vancouver Island about a dozen years ago with then still somewhat spry Father. He left in 2015 but having him there, that day, that time, is something I am so glad we did. We had a couple of extra hours before the ferry took us back to the mainland, so what better way to spend time with your aging Dad, than doing things that had a big interest for him.
I did not want to be the 'Cat's in the Cradle' son.
Sorry for the picture quality. Maybe, it's just me, getting a little blurry eyed. 😉
She really was the queen of her skies.
One single driver with several frequency responses. What the heck?
I heard from a discussion about driver measurements. The topic was about generating xover filters, and about the best compromise measuring distance. I consider this an interesting playfield, and this motivated me to perform some simulations. It’s all about anechoic, direct sound and the influence of the measuring distance on the baffle diffraction step (BDS).
Assume a linear monopole point source on a circular baffle. When the pressure wave reaches the rim of a baffle, its’ room geometry changes from half-space to full-space. This is a change by a factor of 2.
In the time domain, this change theoretically will cause a negative impulse. As the room geometry changes by a factor of 2, the magnitude of this negative impulse might be half the amplitude of the initial positive impulse. In the frequency domain the response will show the well-known BDS and some comb filtering towards higher frequencies with a first minimum corresponding to the baffle width. This is widespread common knowledge.
Most models and graphs for the BDS assume an observation point in infinity. For the infinity case, in time domain the negative impulse occurs after the time needed for the soundwave to propagate from the centrepoint of the baffle to the periphery.
Instead, theoretically approaching the observation point to null distance from the baffle plane into it’s centre will double this time: The sound has to travel to the periphery first, and then return to the centre where it gets assessed. In time domain the negative impulse occurs delayed by a factor of 2 compared to the one assessed at Infinity. In frequency domain, this leads to a combined squeeze/shift of the typical frequency response along the frequency scale. The first minimum of the comb filtering pattern will occur one octave lower than in the infinite case.
In analogy to these both extreme cases, it becomes evident, that even without taking any room response (such as first reflections, echos and the like) into consideration, measuring at 1m and listening at 3m will not be the same in terms of frequency response. Therefore, relying to a measurement from 1m distance to optimize a set of xover-filters, and then later on listen to the result at 3m may lead to a mismatch between the filters and the actual frequency responses and thus to an awkward and unwanted experience.
Let’s do some simulations to explore this one. For the following graphs sampling rate was set to 192kHz. For the first three graphs the baffle diameter was assumed to be 34.3cm which corresponds to a wavelength corresponding to a frequency of 1kHz.
Curves show measurement distances of
green: 0, theoretical measure flush on the baffle's center, e.g. spot-on the point sound source
brown: 1 == 0.343 measuring distance (in baffle diameter length, 1 == 34.3cm)
blue: 2.9 == 1.0m measuring distance
grey: 8.7 == 3.0m measuring (=hearing) distance
black: Infinity theoretical measuring distance
Red individually shows the resulting magnitude difference between two test distances.
The time domain graph. The negative impulses of the baffle diffraction occur with different delays from the initial positive impulse:
Frequency domain: Red shows theoretical null distance vs. infinity BDS model distance
Frequency domain: Red shows the frequency response difference between 1m vs. 3m measuring distance:
Frequency domain: Difference 34.cm vs. 3m measuring distance … measuring very close is no good idea at all …
And now, what about a more narrow baffle at 17.15cm diameter, e.g. half the size of the former one?
Time domain for 1m vs. 3m measurement:
Same 17.15cm baffle, but in frequency range
Red 1m - 3m
Blue at 1m (5.8 times the baffle diameter)
Grey at 3m (17 times the baffle diameter )
Small baffles, as expected by geometry/trigonometry logic, show less severe shifts at the typical measuring/listening ranges of 1m/3m than large baffles. It’s evident, because relative to the smaller baffle width, the distance/bafflewidth quotient get bigger. By the way, this might be a contributing reason why baby baffles sound more pleasing at any listening distance than adult ones.
Caution: Take all these simulations all with a grain of salt. These graphs show a theoretical workout of the subject, highlighting a possible issue. In practice you will ideally not have to deal with central point sources on circular baffles. But the take-home message seems clear: Do not measure too close in a false idea to best possibly exclude room interferences. This will jam your measuring validity range. The closer you measure, the messier the result gets for more distant locations. Same goes not only for x-over filters, but also for whole speaker system measurements.
Guitar Pickup switching system (using microcontroller)
Dear forum,
It is not a new idea, but everywhere where I saw something like this in the internet, it was never accomplished and the thread just ended up with no conclusion.
I want to raise a topic of a Guitar pickup system, where it is possible to connect them in any possible way (parallel, series, out of phase) with the help of a microcontroller onboard. This was done ones commercially by a Music Man company in their Reflex Game Changer guitar. I was thinking on what it takes to re-make something similar.
QUESTIONS
  1. As the guitar pickup output has high impedance, and in general guitar output has a high impedance, when wired canonically of course, I am very concerned about preserving this high impedance (if it is at all possible). As I understood, the analog switch, even with the lowest on-resistance will affect the output of the pickup and lower the output impedance.
    Q1: is it indeed like that and it is not possible to carefully select such components, so the original impedance of the pickups is preserved?
    Therefore, I see recommendations to use a buffer, e.g. op-amp, between the pickup and the switch, so the sound characteristics are preserved, but the signal is then "transformed" into a low-impedance environment. As I understand, this is a compromise to use digitally controlled switches. Moreover, some people prefer the guitar to output a low-impedance signal, as it eliminates a lot of problems with long cables, nasty guitar pedals, etc. In other words, there's an opinion, that low impedance is not bad at all.
    Q2: if the buffer is needed, is it enough to put it after the pickup before the first switch for every pickup? Or does this chain needs more buffers?
  2. Buffer: I know there are a lot of buffer options with JFET and other transistors. I think the choice here is: as smaller as possible, as less components as possible, the best sound preservation. For me it looks like Op-Amp is the option to go, even if it can be costly.
    Q4: what do you think?
Hello from Cannon Rocks, South Africa
I've been lurking around for quite some time now, I guess introductions are in order. As the title says, I'm from sunny SA. Got my HiFi feet wet recently when I bought a secondhand pair of KEF Coda 7's. I'm powering them with a Aiyima A07. The plan is to upgrade all of that as time allows. I enjoy listening to blues and a bit of jazz but still have a lot to learn about music.
Using LM317/337 to power low current stages off of main +-40V supply
I picked up a nice looking old 70's Kenwood that was missing parts, so I retrofitted it with a new PS/amp/preamp and I'm trying to come up with the best way to power the legacy tuner/phono stages in the unit. I'm very tight on space so would prefer not to add another transformer.
3 voltages are needed, +28v, -19v, and 13.5v.
I was considering an lm317HV/lm337 connected to the main +-40V supply to derive the +28v & -19v.
For the lm337 I saw this thread which uses a zener across the input-output so you can use it with higher voltages.
For the +13.5v I was considering using the positive half of the preamp supply but wondering if pulling from half the supply is a bad idea.
I'd like to keep the legacy components functional, even though realistically they will probably rarely if ever be used.
usernames, passwords and scams
I got scammed a few weeks back on face book market place.
Recently I found my email address and password got hacked.
Stupidly I used same password for lots of different websites.
I managed to get in quick with ebay and changed my email address and password before any money was taken.
I got caught out on Ali Express as theye didnt ask for cvv number before making a payment.
I was down about £300 which HSBC are sorting out for me. Again got in quickly to block the card but still some damage done.
I guess the lesson is use different passwords for each website you buy from or use.
Shorted Harman Kardon main board (I think)
Hi everyone I'm triyng to repair an harman kardon ts2bq/ts11/I don't know how many name this subwoofer has...
The first problem was literally a hole big such a finger in the amplifer board with shorted mosfet and blowed up capacitors. After having fixed the amplifer board I've tied to turn it on, the results are two shorted mosfet and another problem.
After several tests with the tester I'm stuck, if I put the tips in the positive and negative of the diode bridge for a few seconds the tester tells me that there is a short circuit, after the value continues to rise up to 1560, after a few minutes it goes back to how it was before. I did these tests by removing the diode bridge (to check that it wasn't that) and removing both the amplifier board and the jack board.
What component can have this behavior? Could someone help me?
This is the datasheet
Martin Logan ESL upgrades
The cheapest Martin Logan ESL is a good value for the money. Can we make it a little better with a little effort? These are the things I successfully tried:
  1. Linear power supply. You don't even need to buy that fancy 'audio' power supplies. A normal, stabilised, linear (with a transformer) power supply also helps a lot. I tried something for $10, 15V, 1A, with a 5.5/2.1mm DC plug, plus in the middle.​
  2. Bass is probably the part where ML ESL is the weakest. We can at least try to mitigate some problems here. Adding a weight to the speakers could help. I had granite coasters laying around, that almost fitted perfectly. Also, it seems that the enclosure has some resonances, so I added self adhesive bitumen pads inside. That was very helpful for quality of the bass. When being at it, changed the filling to wool.​
  3. Unfortunately I couldn't place the speakers far enough from the wall. The back wave was messing the sound too much. Ideally it should be diffused behind the speakers somehow. Probably with some acoustic system on the wall. Anyway, I couldn't find anything aesthetically pleasing enough. I had to damp the back of the panel with an acoustic mat. It worked well for the purpose.​
  4. Next step was checking if bypassing the caps in the crossover can be beneficial. The result was also promising. Caps bypassed with 1% of the original values. It helps with resolution and smoothes the highs.​
Do you have any other modifications that can be easily tried?
For Sale Selling: Sony VFETs / SITs 2SJ28 and 2SK82 (fully tested with curve tracer and Vgs data)
Edit March 2024: You want parts? Read this post carefully. Do what it says, all of it. Otherwise your PM might not get an answer.
I have a bunch of Sony VFETs 2SJ28 and 2SK82 parts for sale. All parts were tested for gate-source voltage (Vgs) at ±1.6 A drain current (Id) and ±20.0 V drain-source volatge (Vds). There are full curve traces for all parts (Id vs. Vds at Vgs = 0, ±2, ... , ±16 V).
The parts were matched by "curve matching" as explained here.
If you are interested in getting some of these parts:
  • Take a look at the parts lists with parameters (Vgs, gm, μ), curve matching, and curve plots:
  • Select your parts:
    • I recommend to first look at the curve-matching list available at the links above. In short, a low delta-Vgs means a good overall match. Read this to learn how the curve matching works.
    • The parameters list may also be interesting.
    • This post may be useful to learn about parts matching based on their curves.
  • Send me a personal message (PM) here on diyAudio with your part numbers and complete contact details (see below) and I will reserve the parts for you
  • Payment: PayPal preferred
  • Once I receive payment, I will send the parts to you
Price per part is CHF 135.00 CHF 170.00
Shipping and handling is CHF 22.00
Contact details (I need all of this, and I may ignore reservations with incomplete information):
  • Shipping address (first and last name, street / building / number, town, ZIP, country)
  • Your telephone number (including country code)
  • Your email address
Adding a Headphone Amplifier Circuit to a DIY DAC
Hello, I recently made a PCM1794 DAC. The output of the I/V circuit was set to 2Vrms. I'd like to add a headphone output jack and a volume knob here. NE5532 based headphone amplifier Are there any problems driving low-impedance earphones or suitable headphones such as HD600?
Experimenting with this circuit in LTspice, I think the power is too large.
And why do you need a high-pass filter?
For Sale DCG3 + DCSTB fully built and working
Since I decided at the last stage for another preamplifier, I am forced to sell this one. It's definitely a great preamp but for capacity reasons I'm forced to sell it.
The preamplifier has a set bias voltage of 170mA, ideal for low-ohm headphone. All parts are genuine from @Tea-Bag
Sold only together DCG3+DCSTB. (Price is negotiable.)
Additional parts I can offer:
  • inteligent on/off module
  • Large heatsinks with pre-drilled holes.
  • 2 pcs toroidal transformers from (toroidy.pl), 50VA, 240V, 2x18V
  • Khozmo attenuator 25K
  • AC Power Entry Modules Shurter
I only send within the EU. (paypal, wire transfer)
I can give a discount when you buy all parts.
Reactions: passive420
So I was looking at Aliexpress for something else and I came across an IRS2092 implementation with balanced connection?
I had a look at the IRS12092 datasheet it seems to me there's only 1 input.
Also the amp seems to use 2 opamps to convert unbalanced to balanced (or maybe I misread the PCB labels and that it converts balanced to unbalanced). thoughts? Thank you.
https://www.aliexpress.com/i/32884021133.html
Speaker building parts/tools in carry on luggage
I’m visiting a friend and his boys…they are in the early stages of building a speaker…it’s their first one and they don’t have hardly any tools.
I have a twenty year carry on luggage only streak I don’t want to break and would like to bring the following with me….any problems?
Mylar dome tweeter
Speaker wire
Speaker terminals
Aux extension (3ft)
Aux to RCA
Wire stripper and crimper
Soldering iron and solder
The ones I’d think they might have issue with are the soldering iron and the wire stripper/crimper….but please inform me if there are others…or if you’d think no problem with any of the above.
Hello from Wichita, KS
Hey guys,
Long time lurker here. I play around mostly with Altec speaker stuff, but I do a reasonable amount of DIY audio things. I'm glad to be part of this community and the wealth of knowledge that is here. I'm a graphic designer by trade, so I worry more about the aesthetics then I probably should on my projects... but it comes with the job.
Thanks for having me.
- Woody
Citation II - 2023
Attached is my attempt at updating my Harmon Kardon Citation II amplifier to a PCB version.
It took me 7 versions,and a learning curve to understand the schematic & pcb software.
A friend of mine said that I should sell it as a kit, but I'm too old, 71 and I don't have all of the knowledge required to do so.
I do have a BOM built, and have determined that the cost to do this amp is about $650 for parts , minus tubes. KT88 cost about $400 for 4. The 12BY7A tubes price varies depending on where you buy them.
I'm curious if you or anybody else might be interested in my project.
If you are interested, please feel free to contact me.
Thank you for looking at my project.
Reactions: OtisCampbell
NAD D 3045 sonic blast, max db out
Today after 10 minutes of operation the NAD 3045 internal digital went amok resulting in a rapid rise to max volume. I rushed to turn it down and pull the AC cord which I will not connect again. In future, I will avoid integrated computerized amps because they have more failure modes with less reliability than classic amps or chip amps. I am upgrading an old (vintage?) NAD 320 to replace the 3045.
I dislike multi-turn volume controls because they compromise usability.
history: https://www.diyaudio.com/community/threads/nad-d-3045-overheating-allegedly.379438/
Weirdness with Benz Genz Shuttle 6.0
Help diagnosing Shuttle 6 Pre-Amp
Help Diagnosing Shuttle 6 Pre-Amp
I resoldered the major caps, all of the solder joints on the vacuum tube pcb, and the input and output ports. That doesn’t seem to have fixed the clipping, but the output did have a hole in the solder joint, which could be an issue, and I cleaned up some crappy solder joints on the vacuum tube pcb with holes too.
It could be an EQ thing where it’s just not going to sound right unless you play with a bass since it’s optimized for lower frequencies - that’s my main thesis as of right now. I do notice playing all higher notes on the bottom three strings the noise fades away really fast or clips, as does the same thing on the entire upper side of the fretboard so I think this one is likely.
If you keep the gain all the way up and volume low you can make playing with a guitar sound bearable, but it will clip on the highs and you will get that background distortion/rumble behind it no matter what, to varying degrees - mostly when hitting multiple strings and on long notes the sustain doesn’t seem right, but again, maybe EQ is to blame.
It’s also way too loud to be pleasant through the headphones unless you turn down the volume via the headphones themselves, I find that odd.
I do notice the input signal seems to be off, like I mentioned the his will cut off; the lows do too at at a lesser rate - but it will come in and out during long sustain notes, cutting off slightly early it seems. Not sure if it’s an EQ thing as mentioned.
I noticed some oddities with the input signal by listening and watching the light. The input light flickers as the sound cuts off - which could indicate a bad port input port, if, again, it’s not an EQ thing.
So perhaps it could be fixed with a new input port?
wparks from Lewiston Idaho Checking In
Howdy-
Apparently I'm not allowed to post anything until I introduce myself, so here goes.
I'm wparks from Lewiston, northern Idaho. Lewiston is a small town at the confluence of the Snake and Clearwater rivers, an actual ocean-going sea port way over here in the Idaho panhandle. We're at 700 feet elevation and deep down in a large valley so the weather is extremely mild. I'm a retired electrical engineer who specialized in microprocessor design and validation for HP and Intel until I burned out, sold everything, and ran to the off-grid lifestyle in the rural countryside. Best move =ever=.
Now that I know what I want to be when I grow up I'm moving into more discrete electronics. I cut my teeth on monochrome monitors before the internet was even a thing, so getting to learn about all of the newest technologies available now to the amateur hobbyist has been very empowering. I have a growing passion for high quality audio, and have begun learning, assembling and experimenting with my hi-fi gear. I am limiting myself to a low budget, building for myself as much as possible, and maximizing fun and experience rather than making some blind jump right at "end game" equipment- crawling before running and all that.
Music that is flowing in my veins: mainlining Portishead, freebasing Tool and more Tool, snorting Black Sabbath, smoking Pink Floyd, and popping Gorillaz
Some gear I own and am learning/having fun with:
Sony SSCS5 speakers - my favorite starter speakers and best sounding I have ever owned (so far . . .)
Philips SHP-9500 Headphones - Inherited from my father and discovered on my own just how sweet they are- Thanks Pop!
1961 Magnavox 9302 15Watt 6BQ5 tube amp - A $40 console pull I reworked into an audiophile contender with Dave Gillespie's mods from Audiokarma
1978 Magnavox R344 12W white trash transistor chassis from a $20 console I turned into a pretty stand-alone wooden cabinet integrated reciever
Denon DCD-1500ii CD player - my only piece of audiophile pedigree bought for $10 from an estate sale that just needed new tray belts (knowledge =IS= power)
Recent projects I have built or are building:
"Combat Audio" +/- 15V 1.5A regulated power supply in an army surplus ammo can for powering all of my diy audio gear
Phono Preamp based upon Rod Elliott's ESP project 06 Hi-Fi Phono Preamp that is the best sounding I have heard (comparing across 4 others)
Most excellent headphone amplifier based upon Rod Elliott's ESP Project 113 that drives my 32 Ohm cans to tantric ecstasy. Oh so good!
Modifying a several crappy Fisher "Studio Standard" 🤣 (B.P.C. era) amplifiers into something somewhat respectable
Repairing and cleaning junked stereos and boom-boxes for dontation to local charities
Crappy Acoustic Monitor PSM-1250 12" 3-way retro design tower speakers I am gutting and redesigning into something respectable.
I have learned an incredible amount about electronics design as supported by my education, and a lot about what makes good audio. I have a voratious appetite for new knowledge, and I love to teach what I have learned. I'm here to listen, learn, and teach when I can. Looks like a fun group.
-Warren
For Sale DALE Isolation Transformers & 19" ISOBAR Power Bar
have for sale:
2 (qty) DALE IT800 - Isolation Transformers (Medical Grade <100uA leakage)
Each unit contains an actual 900VA nominal rated Toroidal Transformer
Capacity - 6 Amps input
Capacity - 5.7 Amps Output
Hospital-Grade Power cord with 2 receptacles (Green Dot)
I used one for Analog sources and the other for digital sources to enable total isolation of digital " noise" getting into the analog system
$129.00 USD each with Free Shipping to US & Canada
Take BOTH for $199 USD with Free Shipping to US & Canada
ISOBAR 12 ULTRA 12-Outlet Power Bar - 19" Rack mountable,
15 ft. (4.57 m) Cord,
3840 Joules, Diagnostic LEDs,
1U Rackmount
NOTE: I used Stock pics for the ISOBAR
$99 USD with Free Shipping to US & Canada
  • 2512788-96e3f091-lot-of-partsmeasuring-toolscaps-amp-many-other-items-available.jpg
  • 2512789-3d0baa9b-lot-of-partsmeasuring-toolscaps-amp-many-other-items-available.jpg
Yet another crossfeed...
It all started when I decided, just to be a contrarian, to do a hardware simulation of a plugin, ha! I've used 112dB's Redline Monitor for mixing since it came out some fifteen years ago, and I'm sure there are better crossfeed solutions out there, both software and hardware, but it's what I like and am used to, so I thought, why not see if I can make an actual circuit that does the same thing.
Although I've never seen this topology and I arrived at it after lots of trial and error, I'd be surprised if it hasn't been done before, in fact I would assume that the plugin developers based their code on some existing circuit or other, which could be this one or something very similar... In any case, I was delighted that I could pretty much nail the plugin's response with such a simple circuit. So far I've only tested it using LTSpice's awesome WAV processing feature and, although it doesn't null perfectly with the plugin, it's more than close enough and I doubt I'd be able to tell them apart in a blind test.
The plugin has three parameters to adjust: a "center level", which adjusts the phantom center from 0 to -3 dB, a "soundstage", with selects the simulated angle between monitors from 30 to 90 degrees, and a self-explanatory "distance" from 0 to 2m. After some experimentation, I settled on, respectively, -1.5dB, 60 degrees and 0m (any other distance introduces FR ripples that I don't care for), so that's how I've always used it and what I've attempted to implement. In the first picture below you can see the left and right response when only the left channel is active, both as shown by Plugin Doctor and as simulated in LTSpice (I don't show the phase responses but they aso match). See also the schematic and two LTSpice circuits, the AC simulation and the WAV processing simulation.
I'll have more to say about component value selection, gain, opamp choice, etc. if there's interest, but in the meantime you can feed it your own WAV file and see how you like it, just change the file name in the voltage sources and place it in the same folder as the .asc file. Note that, as well as attenuating the output by the inverse of the gain, I knock off another 3dB to prevent clipping, which will happen if your WAV goes to full scale, so adjust accordingly when comparing the before and after. You can also adjust the duration in the .tran statement for the output file length (in seconds) you want. Anyway, have fun and let me know what you think!
Edit: typo in the schematic, it should say "move left to bypass"...
  • Cabi-XFeed.asc
    Cabi-XFeed.asc
  • Cabi-XFeed-wav.asc
    Cabi-XFeed-wav.asc
Reactions: jasonRF
Corner loading PA sub test and OMG
Guys,
Yesterday I DJied in a club
That I use to play sometimes
Humble old system below
2 Yorkies LS608's driven by a bridged XLS 2500 and a pair of yammies DSR12's
Although the Yorkies run out of gas before the yammies I balance the system so it sound even.
Anyway ...
I followed the place subs on center of the floor
Yeah normal sound
Coming from the system config.
So it occured to me recalling many reads that says if you face the subs to a corner it will "amplify" the sound ....
I just tested that that I have seen many years ... Never tried , I don't know , is just something that you think will not do much.
OMG!!
It sounded like 4 or even 8 ...cabs
(Never tested multiples next to each other)
So can't tell really but for sure sounded double or triple the volume.
Same cab count ..same single amp
The owner jAW dropped , he thought I bring more stuff and he can't locate the subs as they were not in the center !! Lol
I know that can't be done on some places
But if you can do it..DO it!!!
I will post some pics with some length measurements.
The ceiling is pretty high.
The bass covered the whole dance floor and even another section were another DJ was playing lol.
It was effin incredible....really
How it never occurred to me to actually do it
It was like ....nahh not noticeable or very little gains....nope...totally wrong
It was hugeeee.. improvement !!
And the clients were amazed
They told me ..wow new system sound incredible. Lol!!
Women never have nuff shuz...
Men never have nuff bazz!!
Balanced line amp - 1 noisy output
Hello,
I’ve build a clone Blowtorch line amp. See picture of build and circuit below.
As I’m busy with the actual assembly of the PCB’s on a bottom plate from the enclosure, I was testing with different wiring layouts and wires itself (twisted solid core and microphone coax).
During this testing I noticed that one of the 2 balanced line amps generates a Hiss / white noise on the ‘+Out = OUT_P’ output. Taking the signal from ‘-Out = OUT_M‘ gives no noise. Noise sounds like: Analoge ruis - Ambient Reel to Reel Bandrecorder Hiss & Hum - YouTube
I don’t have the knowledge to tell whether a Jfet or a mosfet can generate this as a failure mode due to a static decharge for example. And before I start to remove and change parts, I would like to ask here for experience.
Which part is highest change to resolve this noise issue?
Thanks in advance
Reactions: Mikerodrig27
Understanding the use of inductors in bandpass subwoofers
Understanding the use of inductors in bandpass subwoofers and impedance curves.
I've had two small bandpass subs (neither impressed me). One used a capacitor on the pass-through, a rudimentary high-pass filter to the main speakers. The other uses an inductor, a low-pass filter to the drivers.
I always believed bandpass subs didn't need filters, so I assume the inductor's purpose is related to impedance.
This brings me to the impedance curve of the setup. How many peaks would there be?
1 at the resonant frequency of sub driver.
1 at frequency sub's port.
1 at the resonant frequency of the satellite's woofer.
1 at the resonant frequency of the satellite's port.
Is that right?
For Sale Iso Tango FX 40-5
I need to sell 1 pair of Tango FX 40-5 audio output transformers, which I keep in storage unused.
perfect used condition.
desired price 420$
I live in Ho Chi Minh city
For Sale Allen-Bradley Type J Stereo Potentiometers, Alps Black Beauty, and other assorted goodies
Hi All
Item #1: SOLD
ALLEN-BRADLEY Type J dual potentiometer
, audio taper. These are original, all-sealed and pretty rare. 2Meg.
I have four pieces. One has some solder on the eyelets from some testing. You will see they all have nice long solid shafts. They don't make them like this anymore.
Price: CHF 20.- each OR the whole lot for CHF 60.- plus shipping.
Item #2: SOLD
ALPS BLACK BEAUTY stereo potentiometer
(stepped) from Japan up for grabs. This is the real deal- Vintage, straight out of the late 60's or 70's. It was used in Macintosh, Luxman and other great amplifiers of the day. 250k. This is not the cheaper small ALPS pots you find on ebay. Beautiful movement. Slightly soldered eyelets and back paper label a bit aged.
Price: CHF 80.- plus shipping.
Item #3: STILL AVAILABLE
SAMWHA RA-40
wire-wound 100 Ohm precision potentiometers. These are NOS and are superb quality. I used these many times for cathode bias duty. Sadly they are no longer available since some time.
Price: CHF 15.- each, plus shipping. All 4 pieces for CHF 50.-
Item #4: SOLD
TOKOS Cosmos RV24YG 20S 100k stereo potentiometers
. These are really decent quality stereo potentiometers - made in Japan. However, they have a very poor reputation for channel matching. It's like a lottery buying them. Some years ago I bought a BIG LOT of them and took the time to sort out the (very few) GOOD ones that happened to be decently matched. Often I would find only 1 or 2 our of every 10 pieces which matched decently enough.
IMG_0223.jpgIMG_0224.jpg * note some of these may have light solder on the contacts, only from testing.
I can sell a few of these in two varieties:
Select 2: Channel matching 2% or less. Price: CHF 25 each, plus shipping
Select 1: Channel matching 1% or less. Price: CHF 50 each, plus shipping
Free Stuff: ALL GONE NOW
If anyone wants some new, never used Tocos Cosmos RV24YG 20S 100k stereo potentiometers that don't match as well as the ones above, message me. You just pay for shipping. Update: 30 June 2023 - all gone now.
Also - I have two, 4 channel, 5 position USSR input selectors.
These have silver connectors. They are break-before-make and even come with a very nice vintage Bakelite knob. Never used. You just pay the shipping. Update 26 June 2023 - all gone now.
AND - If you want a nice decent Power Toggle switch with on/off label, message me. These ones I have from Toowei are from China and quite decent.
I have at least 5 of these that someone can have for free. You just pay the shipping. Update 30 June 2023 - all gone now.
Note: Buyers who might want the free stuff get first dibs.
Shipping is from Switzerland, and swiss post is not cheap... but it goes by weight, and I will only charge you what I pay.
Ian
Bedini amp repair advice
I'm hoping someone can point me in the right direction to repair my Bedini 100/100 amp. I build speakers. Amps are a mystery to me. I know I can't fix this myself unless it's a basic item. the amp has been in storage for years. It worked when it was put away. Now only the left channel works. This is a class A amp. The right channel doesn't even get warm like it should. I checked all the fuses. They all look and test fine. Is there anything else a novice can check to see why the right channel isn't powered up?
If not, is there anyone who works on these old amps? The Bedini brothers both have passed away. I'd like to get this amp back in service. I have a Bedini 25/25 DE that I'd like to use with the 100 to bi-amp. Any information is appreciated.
Hello from Slovenia
I'm reading this forum since years and posting a little but and now starting some repairs and i can see some real experts here 🙂
I'm Zoran from Slovenia, almost 50 years old and I'm repairing , building electronic in my free time since for ever i think ha ha.
Usuly some DAC or music servers , repairs of amps and Audio gear in general.
Hope i can find some ideas, tips and knowledge in next level of my journey 🙂
Greetings
Zoran
For Sale Thales Easy Tonearm
I purchased this Tonearm in April 2022, so it still has warranty to 04/23.
It was ~1 year in use. It just came back from the manufacturer where a check up was made.
Condition is absolutely as new. Comes with the complete & original accesories and boxing.
Shipping overseas is possible but checking customs conditions is up to the buyer.
Asking for 3500€ + shipping.
Thales Easy
Help, value of Lundahl SRxxx transformers
I have been cleaning a bit and found a box of old lundahl transformers. Are these still interesting and what is an appropriate value to sell these for?
8 pcs SR501
3 pcs SR502
17 pcs SR503
2 pcs SR504
Information from lundahl website:
https://www.lundahltransformers.com/faq/
  • SR501 is a high level 600 ohm : 600 ohm isolation transformer.
    • in+ 1
    • in- 5
    • out+ 7
    • out- 9
    • Faraday shields 6+10
  • SR502 is a high impedance bridging input transformer.
    • in+ 1
    • in- 5
    • in centertap 3
    • out+ 7
    • out- 9
  • SR503 is a line output transformer with turns ratio 1.4 : 1.
    • in+ 8
    • in- 6
    • out+ 10
    • out- 4
  • SR504A is a microphone transformer 200 ohm : 2k
    • 1 2 3 4
    • SR504
    • 5 6 7 8
    • SR504 /SR504A PCB Flying leads
    • in+ 2 red
    • in- 3 yellow
    • out+ 6 green
    • out- 7 grey
    • core 1
    • housing 4
    • Faraday shield 5+8 black
    • SR504a is similar to the more modern transformer LL1538
Failed CD laser repair - point me in the right direction?
I have an Audio Research CDT1 (https://www.arcdb.ws/model/CD1). It has occasional errors reading disks, and skips on disks that work fine in other players. I decided to replace the laser, and ordered one from Some Guy On eBay(TM). The replacement went smoothly enough, but on test the player always reports "no disk". The CD doesn't even spin up, the laser mechanism moves the head up and down a few times, then gives up.
I had this issue on a Rega CD player I replaced lasers on, but it was just that I hadn't cleared the ESD protection solder blob. I can't spot a similar blob on this unit.
I've emailed the seller to ask for advice. In the mean time, I wondered if you fine folks might have any suggestions I hadn't thought of. The spinner motor is not being sent power from the board, I checked with a meter, so it's not that the motor failed. I haven't tried reinstalling the old laser, because it's kind of a pain in the ***. I have contacted Audio Research about getting a proper laser, which they have, but apparently they are so behind on orders they can't take my money yet. So, that is on hold.
Capacitor voltage needs ?
I am new to valves, So obviously I do not understand them.
Having said that, I have been handed a preamp to 'update' (yes some of the parts really do need replacement due to eminent failure).
I believe it is capable of 12v output.
My questions are in regards to c2 3uf/200v film cap.
What voltage does it actually need to handle ?
How much frequency response change would it cause if it was changed to a 2.7uf or 3.3uf ?
Thanks 🙂
Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Following in the footsteps of the Aksa Lender preamp, Hugh and I have been working on a Class A power amp that uses the Aksa Lender front end. We wanted a SE Class A amp with more efficiency than a simple CCS so we decided to try using the very nice Pass Aleph (dynamic bias) CCS. Hugh is using a P-MOSFET as the lower output device, so this is sort of a hybrid, modified Aleph. It is a very simple 6 active amp with no fancy unobtanium JFETs, SITs, hockey pucks, power JFETs, fairy dust Sony FETs, or signal transformers. If you look at the prototype built on veroboard, you will see the usual low cost stuff. The fanciest part I have is a 10uF Silmic II input cap. The rest of the caps are budget Aliexpress. I like to proto with cheap parts, that way there is less pressure in case it flops 🙂 I am using genuine Vishay IRFP's from Mouser though.
Here is the basic circuit and predicted performance specs (it's good for about 20w with 24v rails):
659376d1517198709-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w-pchan-schematic-png
The circuit uses Hugh's Aksa Lender preamp front end with an Aleph CCS on the top, and a P-channel MOSFET on the bottom driven directly from the Aksa Lender LTP. No CCS on the LTP needed.
Hugh also worked on a monster version of this amp with +/-35v rails and 150w of dissipation per channel to make 53wrms into 8ohm before clipping. To get things rolling, I opted for the +/-24v rail version at a more modest bias of 1.2amps. Slowly work my way up in bias current and then maybe rail voltage (with bigger output devices).
So here is the prototype on a tiny 5cm x 7cm veroboard with two MOSFETs hanging off one end right next to each other. Why so close together? I wanted to use a computer CPU heatsink with heatpipes to cool them - in anticipation of 140w later on. This amp was particularly difficult for me to get running because I made so many wiring errors (a problem when you build it in the wee hours of the morning after a full day of work). Once I found all my errors, the amp fired up no problem. I matched the beta's of the input LTP KSA992's and got perfect 0mV DC offset with no trimpot. You will notice that the tiny (relatively speaking for a Class A) hetsink is fan cooled and has lots of heat pipes (which normally work flipped the other way unless they have capillary wicking inside). But I found them quite effective upside down even as temp was 31C with 55w dissipation. These are salvaged Dell heatsinks for workstation, about $12 to $15. For the record, I am using 1000uF 35v on C3, 22pF NP0 on C4 and C9, and 4x2.2nF (8.8nF) MKT film on C7, 0.47R on R17 and 0.15R on R18. I also have an input RFI filter consisting of 2k2 in series before C1 and a 220pF MKT cap to GND, and 100uF 63v on C2. On C5 and C6 I am using 220uF 100v caps. i had a nice 220uF Silmic II but it was too big to keep on the board and still let me see the resistors unerneath when I was debugging. Otherwise, parts are used as shown on schematic.
659377d1517198709-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-prototype-01-jpg
Closeup of the amp:
659378d1517198709-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-prototype-02-jpg
Without heatsinks (I eventually removed the Silmic II 220uF 50v Aleph feedback cap to make room for debugging):
659473d1517249318-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w-prototype-bare-jpg
Listened to it for a few tracks and must say, it sounds quite nice and engaging. I know the sound. Foot tapping good - typical Hugh Dean style amp. 😀
So here is the first measurement of this simple unassuming amp that takes the best of all worlds. 1kHz 2.83vrms into 8ohms and we get 0.027%THD but in typical Aksa style, mostly in second harmonic, and 10x less in third harmonic, and not much else. This is running well below the recommended 2.0amp bias. So I expect the THD to drop. But the noise floor looks great - actually very good for a linear PSU - perhaps the best I have I seen for one of my linear PSU amps. I am using a basic 100VA donut with 18VAC and a Project16/Prasi CRC PSU with 22mF caps all around and 0.235R on the CRC.
659379d1517198709-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-1-19amp-2-83vrms-8ohms-fft-jpg
I will try boosting the bias current next, and then maybe try to go for the monster 53wrms amp with 35v rails 🙂
Hope you enjoy it - and if enough interest, JPS64 can design a splendid PCB for us to use. Thanks to Hugh for another gem to the DIYA community. And thank you to Mr Pass for the wonderful Aleph CCS.
Here is the latest Schematic for the Big Boy 52W version - now at a little under 3amps bias and 90W dissipation per side, still need two CPU coolers per channel.
660208d1517584966-aksa-lender-mos-hybrid-aleph-alpha-amplifier-fciehdohbfnkegdm-png
Edit Feb 11, 2018: the Alpha 20 PCB is finally built and tested.
661735d1518324741-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha20-amp-build-02-left-jpg
It measures very well here with 1.31amps bias and produces 0.0069%THD for 2.86vrms into 8ohms:
661737d1518324741-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20-2-87vrms-8ohms-fft-png
ALPHA 20W schematics and stuffing guide for v4 (production boards) here:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier - Page 12 - diyAudio
660029d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_schematic-v4-png
660032d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_topview-png
660030d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_3d_render-png
Edit Feb 20, 2018:
BOM v1 for ALPHA 20W PCB layout v4 (above schematic) here:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier - Page 51 - diyAudio
Edit Mar 5, 2018: premium components build ALPHA20:
666395d1520249706-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-premium-build-02-jpg
It does indeed eek out a bit lower distortion with Vishay Dale resistors and all Wima and Silmic caps, now about under 0.006%THD for 2.75vrms into 8ohms:
666397d1520249706-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-ch2-fft-png
Edit March 25, 2018 - Alpha 20 for 4ohm loads version:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier - Page 124 - diyAudio
Ignore the triple outputs - purely used to simulate a single larger 500W capable IXYS MOSFET pair which will not need to be matched. Hugh does not recommend using triple output IRFP’s
669823d1521533665-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha4r-gif
Edit April 4, 2018: BigBoy is alive and singing! The Beta build went together almost perfectly. Only one minor circuit error on the grounding of the LTP smoothing cap (fixed with a jumper). Amp starts up uneventfully and without any adjustment to achieve 3.0amps bias current and 1mV DC offset.
672472d1522616478-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-test-mono-fast-closeup-jpg
Here is 34wrms into 8ohms from +/-27.6v rails:
672327d1522552973-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-sound-oscope-02-jpg
Here is FFT at 2.84vrms into 8ohms:
672545d1522650414-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-no1-2-95amp-2-84vrms-80hms-fft-jpg
Edit April 4, 2018 - here is the updated as-built schematic for Alpha 20 with 1.35amp bias and no turn-on thump feature. Note that if all pots are removed the amp is a simple adjustment-free Class A amp with DC coupled output that has DC offset within 10mV (typical) and self-tracking, bias current is auto-regulated and very stable:
673097d1522861468-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20-schematic-updates-1-35amps-built-png
Edit April 7, 2018: Alpha B.B. in stereo!
673651d1523088129-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-stereo-build-04-jpg
FFT of Alpha BB at 2.85vrms into 8ohms
673787d1523165499-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-2-854vrms-8ohms-fft-ch1-jpg
Edit April 10, 2018: Summary of various settings to change amplifier configuration bias setpoinysnand speaker impedance driving capabilities. Courtesy of Danny_66: Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier - Page 166 - diyAudio
Edit April 13, 2018: Simulation LTSpice files of Alpha 20 4R and 8R by Danny_66 here:
http://www.diyaudio.com/forums/soli...id-aleph-alpha-amplifier-172.html#post5404051
Edit April 19, 2018: 10kHz 17vpp square wave into 8ohms on Alpha BB:
675635d1523938773-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-5mhz-osc-study-10khz-square-wave-jpg
Edit Aug 23, 2018: several people have contacted me about ramping up for a new build. So here is a recap of suggested schematic for a 4ohm Alpha 20 (which probably puts out closer to 35w into 4ohms):
674314d1523391739-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20-schematic-updates-2-4amps-4r-png
Edit Sept 4, 2018: Tips for 4R capable circuit...
Edit June 11, 2019: revised table of source resistors for setting bias current in Alpha 20 for 8ohms and 4ohms by Danny66:
For Sale 4 Kubelic DACs including input boards $50 CAD
3 dac kits
3 spdif/coax input boards
1 usb input board
1 digital select switching board kit
1 complete and operational dac ready to use. I've ran this dac for a year or more off and on..
Dac Voltage is 20vdc
$50ca plus shipping for everything - canada and usa only
Hammond tube based organ - finding a short
I have a Hammond S-6 organ I picked up; with limited knowledge I am trying to trouble shoot it - using a light bulb limiter to power up.
Here's where I'm at with it now:
When I detach secondaries from p/s, I see correct voltages on p/s. (B+ 310v, 6.3v, 25v)
When I detach just the 6.3v, I am seeing almost right voltages - like 240v/5.5/22 and the light bulb limiter glows only faintly. So I think there is a problem in there. The 6.3v reads about 0.8ohms across it so the meter reads "short" between them, but I think that's normal (?)
With secondaries attached, I see 0 on B+, 1.2v, and 8v.
With secondaries attached (limiter glows bright), When I start pulling tubes (it has 2x 6v6, a couple 12ax7, three 12BH7, and lot of 12au7s) the bulb limiter gets dimmer and the voltages go up from that low starting point. As expected, the 12BH7s pull the most current and make the most difference. With just a few tubes in there I see a little bit of glow on some of the tubes with about 4.5v on that secondary.
I'm not sure this tells me anything about the tubes per se. No one or combination of them solves anything in terms of just getting good 6.3v voltage.
I replaced one filter cap, tested the other and it seems okay. Any ideas what kind of failure this might indicate? Although there is a lot to the circuit, nothing looks blown out or short. Any insights appreciated.
HammondChordOrganServiceManual-ModelsSS1S4.pdf - Adobe Acrobat Reader (64-bit) 8_18_2024 2_45_...png
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,538
Members
7,876,065
Messages
Filter
Forum Statistics
Threads
405,677
Messages
7,876,065
Members
507,538
Latest member
Rihab
