ali express super cheap amp - is it possible its 12wpc is 8ohms
-https://www.aliexpress.com/item/1005006746074265.html?spm=a2g0o.detail.pcDetailBottomMoreOtherSeller.94.2ee55DGe5DGeH7&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.40196.394786.0&scm_id=1007.40196.394786.0&scm-url=1007.40196.394786.0&pvid=70cac017-3398-42ef-b6a7-07ee3efdbcba&_t=gps-id😛cDetailBottomMoreOtherSeller,scm-url:1007.40196.394786.0,pvid:70cac017-3398-42ef-b6a7-07ee3efdbcba,tpp_buckets:668%232846%238111%231996&pdp_npi=4%40dis%21GBP%21196.38%2198.19%21%21%211795.06%21897.53%21%4021039c5917249515732538655e0268%2112000038168444962%21rec%21UK%21863394078%21ABX&utparam-url=scene%3ApcDetailBottomMoreOtherSeller%7Cquery_from%3A
Measuring Loop Gain on the Bench - Best Way?
I'm looking for the best, simple, way to do this on the bench without more than
a function generator (my HP goes to 11 MHz) and a scope. Our scope has a
readout of the signal amplitude and is 200 MHz. This amp is a prototype so soldering
minor changes is not a problem.
I used LTSpice to draw what I'm planning to do on the bench to measure the loop gain
of the original Universal Tiger (UT) amp. This is NOT the way to do it in simulation but
of course it will run. The best way in simulation is to use a Tian probe as explained in
these videos by one of our members:
https://www.diyaudio.com/community/...al-tiger-inconsistencies.365751/#post-7737499
Let me say that I understand that this method introduces errors but from what I
see/understand I don't think that they are significant and I welcome comments to
improve it or use another method.
The main feedback path is broken at the output and the SPICE ideal signal source drives
it. The obvious errors are that the loading on the output by the feedback network
is removed (more parts could be added to emulate it) but since the load is 4-8 ohms I
believe that the error is insignificant. The other error is that the source impedance of
the amp output is not accounted for. Now amps like this are (should be) high damping
factor and therefore the output impedance is low in the audio band. The zobel is in
parallel and should keep the impedance low at high frequencies. The circuit needs a
stable DC output and therefore a feedback network matching the pos input resistance
to ground is added with two resistors (R29, R28) and a large cap to ground to shunt
the signal. This introduces error below 1 KHz but that is not where the analysis takes
place. There was significant DC offset at the output, as is seen in real hardware, and
a very large resistor, R30, was added to trim the offset. This is not how to do it in real
hardware but with an ideal power supply in sim it works fine.
The output to measure is the point where the loop is broken with the OUT label, not
the SPK labeled net. Plotting frequency response in LTSpice is OUT/Vin from the source
which is what we want. Anyway, here's the diagram:
Ran it to see if the results are reasonable and what to expect on the bench:
It shows an unstable amp, but perhaps I'm missing something, we do know that these
amps certainly do oscillate in real hardware.
Odd that LTSpice does not make the two cursors different colors in the plot.
==== PHASE MARGIN
Cursor 1, furthest to the right, is at the 0dB gain point (the horizontal cursor is at 0dB)
where we should look for phase margin on the phase plot (the vertical cursor). Note
that we are driving the negative input and therefore, in the passband, we see -180 deg
as would be expected on the inverting input. The point where there is zero phase margin
is another -180 for a total of -360 bringing the signal back in phase to cause oscillation.
The amount less than -360 is the phase margin.
Note that for cursor 1 the phase is greater than -360 at about -390 and according to
this there is about -30 deg of phase margin - there is none. Keep in mind that this is
device and model dependent so real hardware could be better or worse.
Or is this not a valid method?
==== GAIN MARGIN
Cursor 2, on the left, is where the phase reaches -360 deg (vertical) and the gain
margin is how much less than 0dB the gain curve shows. The gain is actually greater
than 0dB and therefore there's negative gain margin with it showing 12.47 dB of gain
(horizontal) - it should be negative in order to have gain margin.
It should have been obvious that the stability of this amp is highly dependent on the
process variation of the semiconductors which is demonstrated by the fact that I have
one amp that readily oscillates and another of the same revision that does not.
Building a vintage speaker?
Lately I've been depressed (no, don't worry, this isn't a sob story) and I try to distract myself somehow. I also noticed there gathered lots of drivers and horns and damping material and other speaker stuff, a lot of chinese amp boards, PSs and I realized that's a lot more than I really need or I'll use for my 'serious' projects. A lot of cheap stuff but also good ones I've often got by bidding on eBay, thinking "eh, just enter the minimum bid, it will sell for much more anyway" without really planning to do something with it or getting it with a project in mind. But now I thought I should really get rid of something or actually do a project with it.
I don't want to do the 5738th 2-way with a 17cm/25mm, I find that rather boring. I like big speakers. I like vintage HiFi but not everything has to come from the 70s or 80s. So, my question is, would you invest time, wood etc to build a speaker that's a reminiscence to vintage speakers?But would it be a good idea to use the cheap-ish drivers and horns etc you know aren't optimal? Would you build (to name a few well known speakers) a Klipsch Cornwall clone, LaScala, Heresy or vintage JBL (etc) if it re-creates the look very close, even if i.e. the horns don't have a modern dispersion pattern? With 'original' front cloth? Without? Or would you use something less close to the classic speaker? Modern color/finish or vintage all the way? Would you like it to sound as neutral as possible or prefer the sound of the original? Modify the principle? Like a LaScala with BR for LF extension? What classic/vintage speaker do you think would be nice to build?
Just to show one example, here some pictures of the Klipsch Hersey but I'm not fixated on the Hersey or Klipsch in general.
Reactions: Upfront and AllenB
Best quality price AMT or ribbon Tweeters for 250/350 Euro each
After read many opinions about the quality of AMT and ribbon tweeter, I like to consider one of these instead of the domed ones
Many of there affirm that a good AMT and ribbon is generally better then a dome.
In fact, I have seen tweeters of this type in a very expensive speakers even over 10,000 Euro.
I would like to understand which are the most recommended ones within the 250/350 Euro range each.
My idea is use it in a 3 way speaker, with woofer Scan Speak 26W_8534G00 and midrange SB Acoustics Satori MW16TX-8.
About the various options available I would like to find something that has a relatively flat frequency response in the 3k-20Khz range.
Any personal experience would be welcome.
Thank you !!
Will this amp work with an external power bank?
hey.
i'm building a small portable speaker and thinking of using an external battery something like a power bank. is it posible? and if so will i be abel to get reasonable power from that setup?:
Up2Stream 2.1 Plate Amplifier​
Tang Band W3-1876S Subwoofer 4 ohms 15WRMS​
Dayton Audio HARB252-8 8 ohms 10WRMS X 2​
https://www.soundimports.eu/en/tang...zYxNS4xLjAuMTcyNDg3NzYxNS4wLjAuMTI3NjE0NzU3Mw..
https://www.soundimports.eu/en/dayt...zYxNS4xLjAuMTcyNDg3NzYxNS4wLjAuMTI3NjE0NzU3Mw..
https://www.soundimports.eu/en/aryl...zYxNS4xLjAuMTcyNDg3NzYxNS4wLjAuMTI3NjE0NzU3Mw..
DSP Active Crossover to Analog Active on a budget - Almost there, but need help with CD Horn Equalization - Altec 14s
Hi folks,
Background:
Have been working on a DIY project to replace the DSP functionality with analog, because I am OCD about SQ, and was able to hear immediately noticeable differences in Analog vs. Digital crossovers. Easily A/Bd at the same time as I was able to run the left channel through 1 crossover and right through another and easily level match using REW.
I've been using a Driverack PA2 with Altec Model 14s, but felt I could hear that was a definite difference in mid-bass texture/detail, soundstage and crispness of highs. Using the Driverack, I was able to follow the lead of the Audiophile Nirvana guys (https://www.audiophilenirvana.com/a...ws/altec-lansing-model-14-part-4-ultimate-14/) and get fantastic results.
2019 thread of that effort: https://audiokarma.org/forums/index...h-driverack-pa2-project-and-questions.870225/
With addtional tweaking I laned on LR 24 for the sub/mids and LR 18 for the mid/high, levels matched using the DSPs gain controls on the outputs and further EQ using the AutoEQ as a starting point. Was also able to perform time alignment.
I tried upgrading to a Venu360 and the new minidsp flex 8 (not balanced, unfortunately, but was still decently quiet), but that wasn't really much better. Digital signals are more noticeably impacted detail wise and analog signals seemed to lose some life. Tried a few pre-built pro analog crossovers and they were much better, but had a bit of noise and also I didn't like that the levels and in some cases crossover frequencies could easily be altered by an errant finger. The card versions are much better in this regard.
One thing's for sure... You can pretty much ignore the snr figures published by minidsp. Upon closer inspection they show the digital input to digital output and digital input to analog output figures, but never seem to put the analog in/analog out figures, lol. It was actually the worst of the bunch. Awesome for home theatre though, but the UI on the Harman dbx products is far superior and those include RTA and signal generators built in, so no having to setup and flipping back/forth to REW for anything except time alignment.
Results so far:
In the end, I settled on the Xkitz- 3-way FET opamp based balanced boards and linear ps, as seen here. Even with external EQ, quieter, more detailed, bigger soundstage, way better bass/mid-bass textures, clearer highs.
I used and old, broken SD dvd player as a donor for the power receptacle and case , with 3d printed front/back panels (still need to tweak the makeshift back) and just purchased a few standoffs to make this very budget friendly. This was a drastic improvement over the DSP xovers and quieter and more detailed than the pro analog crossovers. Completely silent, might be the slightest combo of buzz/hiss if it's very, very quiet and I wedge my head into the CD horn. Has never been this quiet. Balanced cables helped a lot here, but these xovers really cleaned it up.
So far I've been able to accomplish the following.
-crossover points
-levels
-eq (using a Kenwood GE-7030, absolutely fantastic!), with the exception of a dip at the mid/hi crossover
-phase adjustment to eradicate nulls and reduce dip at 1500hz xover point (changed wires at mid/tweeter as required using REW, sub has selectable phase 0, 90, 180, 270)
compromise...
-Only LR4 24db slopes available on the diy crossover.. I knew that and trying to be budget friendly and can't justify the Marchand crossover expense, particularly when this one gets me 90% there)
What remains is
1. CD equalization - the EQs 12db range handled the rest of the frequency response, but doesn't have enough differential to raise this dip enough.
2. Time alignment (not too worried about this as the mid/hi are under 2ms, and the sub is about 18ms, but moveable and a lot of is ringing from the 22' ceiling and gobs of windows)
So the questions:
I have a dip at the 1500 Hz region (and 10 to 20Hz needed to be lifted, the EQ took care of that) that I want to take care of.
1. Can I alter the circuit by inserting a capacitor to adjust for the CD horn, as is done in passive networks? (passive example here: https://techtalk.parts-express.com/forum/tech-talk-forum/1410233-cd-horn-passive-equalization)
2. Would it be better to add a circuit? (plenty of room in the case to add a circuit board... something like this? .... https://sound-au.com/project173.htm, but this seems to have minimal impact on the 1.5K region. Also wondering, that even so, might the overall flattening of the HF range help raise it enough for the external EQ to do the rest)
2. As a 3rd alternative, would I be able to easily alter the circuit to have perhaps an LR2 12db or LR3 18 slope for the tweeter low pass?
3. Should I forget about trying to make this work? I hate to do this as I'm almost there and like the price! Of course, if there's other similarly priced active crossover diy boards, I'm still in the 45 day trial period.
Trying to keep it budget friendly/diy friendly. Retired, so I have time.
Glad to post REW or Driverack analysis screenshots, if it helps.
Other info for context:
  • Asked maker of xkitz, if about this several days ago, and no response yet. Also asked about timing circuits and looking at Rod Elliots pages, but it's a bit above my mental pay grade.
  • Voltage readings of outputs at crossover in volts AC are.100 sub, .035 mid, .006 tweeter to get these leveled when fed sine waves for peak frequencies for each output (I believe it was 40hz, 800hz and ~4khz)
  • Crossed over at 80Hz for the mid-woofer/subwoofer (Mid: 200wpc rms amp with 150mV sensitivity, Sub: 1200wpc rms Velodyne, unknown input sensitivity, but leveling puts this about 3x the AC output voltage of the crossover LF outputs)
  • Crossed at 1500Hz for the midwoofer/horn (Horn: 70wpc rms, 150mV sensitivity)
  • Crossovers tried: digital- driverack PA2, Venu360 (locally available at guitar center!), MiniDSP flex 8 (unbalanced) Analog: BSS360, Rane AC23B, Ashly XR2001, xkitz - DIY
  • Subwoofer has it's own equalization and phase adjustments.
  • crossover circuit below:
Thank you for any and all advice, suggestions or comments!
passive radiator sim (hornresp)
rookie attempt atchecking this sectiion of HR out..... so far i have a strange looking overdamped super low tuned ....yuck. (I’m sure I’ve screwed up something (s))
it’s the 7” dayton epique driver and ‘one’ of the matching radiators at this point .
I need to add another. shoukd I add another Sd and Mmd in the PR section to perk up the low end extension section?
Greetings from Leamington Spa
Dear all,
I'm new to this forum but have been involved with audio since the late 1960s (putting together audio systems for the family members) as a hobbyist and then moved into telecoms professionally in the 70's through to present times. Most I had learned in those early days is now forgotten, but the problem is I think it can still be recovered when required!!
Alongside the professional career I also "hobbied" in theatre sound, recording (and studios), and stage pa, which involved making my own speakers, amps and mixers when professional products either didn't meet the precise requirements or were too expensive. In those days Wireless World, Practical Electronics and another electronics mag (not Elektor) were my go to places for designs and guidelines.
Recently, I've started to look again into those designs, although it's not so cost effective to build your own these days.
I hope to both contribute and seek advice while I visit here. Thanks for having me on-board.
G
Free classical CD collection
THESE ARE BACK UP AGAIN - not sure what happened, but the whole collection is still available.
A good collection of CD's I can't be bothered to list, they are all in excellent condition. Free to anyone just pay postage. (Alan Bennet tapes in pic, by accident)
6kg box - Call it £10 for delivery UK.
NAD C542 CD Player
I had purchased an NAD C542 cd player years back brand new. I've had an issue with it reading discs. So I figured that perhaps it was the optic/laser or something that was around that area. The section that contains the tray that accepts a cd to be placed in contains all of the gears/motors/laser optics/etc. So I found an optical/laser replacement online and purchased it. At first it would play the discs, but sometimes it would not even show that a disc was being read. Anyhow, now it looks like it tries to read a disc, but all I hear is a clicking noise that appears to be located on the main board near some fuses. I would like to fix it, but not exactly sure what's going on! Any help would be appreciated! Thanks!
Solving the ZIP-7 obstacle.
As I have amassed several thousands of these beauties, I also have to spec them. While a PEAK is perfectly acceptable it left me with a nagging feeling of dissatisfaction.
I came up with a solution and had my cabinet maker CNC a billet of aluminum. Fischer Electronic manufacture some really nice transistor sockets, but sadly no ZIP-7. I had a special one made and transferred pins into it.
A ZIF socket kind of fulfills all my TO-92 needs.
Two five pin Neutrik sockets communicate with a Keithley SMU for complete verification of specs needed.
Pretty nifty.
R
Reactions: Ine
Modification of Triode Dicks Topcap PP amplifier. "Mono Bills Topcap"
I'm putting this out there as my next project. During my covid layoff I built Triode Dicks Topcap 807PP amp from parts off ebay. They turned out pretty darn good for my first ever build. Fun project. I found out though that, for my DACs output, the 6SL7 had too high mu and not enough swing at the OP. 6SN7s fixed that but the OP is really low. The 807 THD was also high. So, looking at Triode Dicks later projects, I decided that I could adopt what he learned over time and make some big improvements to the early 807 design. The attachment is a pdf of what I'm about to do. I decided late to make a PCB for the CCS and Neg Bias circuits so while I'm waiting I thought I'd share this and have others poke holes in it so I end up with the best mods possible. What do you think of Mono Bills Topcap?? Please let me know!
Reactions: decramer
Nakamichi 1000ZXL Playback and Recording chains isolated schematics + CR7A/Dragon playback diff
The Nakamichi 1000ZXL is the best cassette deck for recording, based on specs.
For playback the CR7A is regarded as the most accurate one.
Here's the playback and recording chains isolated from the messy schematic.
The deck isn't very new so there's no Dolby C, S, SR. No HX Pro or DBX.
It could've likely been upgraded with HX Pro capability since the recording bias level is already set by the CPU. There's an A/D converter. So all the circuitry is there that would allow HX Pro to be implemented in software.
Today you probably could drive the recording heads directly from a DAC and avoid all the analog complexity
The RAMM code is an audio signal encoded on the cassette that stores the calibration data when recorded on this deck so you dont need to run the auto-cal procedure.
For the CR7A/Dragon schematic; The schematic is from the CR7A, the text in red is the differences in the Dragon.
as you can see it's nearly the exact same circuit. Biggest differences probably are the 4066 switch which are problematic and add noise. And the change in the feedback circuit resistor on the first opamp from 280k to 316k.
John Crabbe - A Concrete Horn Loudspeaker
I recently found this articles as a collection separate JPG images. It was published originally in Hi-Fi News in October and November 1967. Since I did not find this article on DIYAudio I converted it to PDF and post it here for general interest.
This is the site I found the article: http://www.saturn-sound.com/history/hi-fi, diy projects.htm
8uF Gudeman Hermetically Sealed Cap
Picture is a Gudeman 8uF 115Vac 200VDC capacitor that I got (QTY 8) surplus in, I think, the 1980s.
I think that I also have some Spragues that look exactly the same but maybe .5" shorter, same value.
115 Vac does this suggest a motor start or run cap?
I might use them in a crossover network if I could confirm that they're film.
Does anyone know if these are paper in oil, or film, they measure like a film in terms of value is
very close within 2% and DF is the same as a film.
Normally I'd throw these away but they look so darn high quality, thought I'd ask first.
The end terminals come out through what looks like glass.
Markings are value as above, and:
GUDEMAN
F54-019JT-10
72928-7101
Date code looks like 1971 first week. The picture brings out the surface imperfections, it is actually a nice shiny silver:
Hello from Barcombe, East Sussex
Hello
I'm in need of audio help so have joined this forum in the hope I'll get some good advice...
To introduce myself....
I studied electronic engineering decades ago and have forgotten almost all of it, sadly.
I love good sound and run a whole-property streamed audio system utilising Slimdevices/Logitech/Lyrion streaming software hosted on a dedicated Raspberry Pi. It serves roughly 10 endpoints; a collection of dedicated Logitech hardware, UPnP compatible devices, Google Chromecast Audios and a Fidek/Azatom iBigBoy 2 (a beast, and the reason I am here now). The lounge hifi consists of a Naim NDX streamer, Naim olive separates and Shahinian Arc speakers. The system rocks (if I say so myself).
I also play the guitar and sing. My name is Simon.
Advice for Developing a Tube Preamp with Warm Sound
Hello everyone,
I’m new to audio equipment development and would appreciate some recommendations and ideas. I’m currently working on a tube preamp project with the goal of achieving the warm sound characteristic of these devices. I’m implementing a +17V and -17V power supply, as well as a 48V phantom power.
I plan to use this voltage phatom power to bias a tube stage that I want to amplify to 60dB (equivalent to 1000 times gain). I’ve looked into the 12AX7, but I’ve heard it can present distortion at low voltages. I’m currently testing the 12AU7, which is said to have less noise, although its amplification factor is much lower.
I’m wondering how I could achieve the desired gain to get that "warm" sound. I was considering a dual amplification stage using the 12AU7 along with a FET. What recommendations would you have for tackling this issue?
Sorry if my question seems basic; I’m new to this. Thanks.
Here is a basic dual-stage preamp with a gain of 15 per stage, along with some curves I obtained from the 12AU7 in Multisim.
Monarchy Audio Digital Interface Processer 24/96 aka DIP fault issue
The 'Lock' LED on the front panel blinks intermittently and coincident with that the signal fails. Waiting awhile, sometimes the led and signal will return, then fail again.
Any ideas on how to fix, what might be the root cause? CC Poon the proprietor is retired, but the company was formerly in South San Francisco. I happen to live nearby so could certainly deliver to any former tech available locally.
Thanks for your insights in advance. No schematic available that I am able to access.
Vintage solid state amplifier troubleshooting
Hi everyone,
I'm troubleshooting this old TESLA amplifier from the mid 80's.
The person who sent me the amplifier stated that the midrange speaker sound distorted. On the video it almost sounds like the diaphragm is broken.
On the oscilloscope I found that at the powr amp secion there is a crossover distortion as you can see in the image.
I measured all the transistors and diodes. They are all fine. Also all voltages are as they should be.
The disortion can aready be seen at the base of T3.
Any idea what could cause it?
Thank you
Just approved, new here...
Hi all,
My name is Bas and I am an owner of a erotic shop & cinema but that is not important now...
I have been lurking here for some time, learning about the magical world of audio.
One of my former occupations has been a certified electrician with a basic electronic education on the side.
I also had occupations as designer/layout person and as a programmer.
The reason for finally having the balls for picking up one of the hardest fields of electronics (audio) has to do with a best friend that died in 2009 due to cancer.
He tried many times to educate me on this subject but never succeeded, only now with all my live experience and completeness of skills I am able to scratch a sliver of this subject and have a lot to learn.
That friend has built me some amazing (sounding) equipment that I still use, I want to be able to repair that so I need the skill for that, further I am curious and ambitious enough to want me to design and build some stuff myself.
This era is very exciting for me as programmer too because of embedding micro-controllers into audio equipment, as this is a field that I do have skills for.
I see some of you are here for a long time and others have great fame, so I hope to be at least relevant to this community at some point.
Anyway, enough talking.
Greetings to all.
Reverb tank solution needed for vintage British guitar amp...
Hi everyone,
Hope you are all well. A friend has asked me to repair his 1962 Bird Golden Eagle guitar amp. This website has all the details including the best drawn schematic for it (https://www.backfromthesixties.co.uk/bird-golden-eagle-2-15). I have managed to get rid of the awful popping sounds it was making (dry solder joint reflowed) and fixed the tremolo (loose wire). I have replaced a number of power resistors whose value were way off the schematic.
However, I'm stuck on the reverb. The original reverb tank is there (identical to the one pictured in the website above) but the phonograph cartridges are completely knackered with no hope of resurrecting). I tried putting in a reverb tank from my home made Fender Deluxe Reverb (https://www.hotroxuk.com/modr-4eb3c1b-reverb-tank-rohs-compliant.html) but this does not work either! I'm thinking this might be something to do with the impedances being totally inappropriate for the driver (V6) and recovery (V1) on the Bird but TBH this is an area I'm not strong on. The configuration of the reverb driver for a Fender deluxe reverb is rather different and also usually uses an ECC81 valve rather than an ECC83 and an EF86 for recovery. Also the deluxe reverb runs at much higher voltages than I am measuring on the Bird.
If I shake or bang the tank it the reverb thunder sound does come through but no even a hint of reverbed guitar comes through when I play. Is the driver too weak for it or is there some other issue? Any thoughts or recommendations as to a more compatible replacement tank if that is the issue?
Thanks in anticipation for your help
Cheers and all the best
Tom
6AQ5W for sale in pairs
EL90/6AQ5W long life beam pentodes made by Cifté in 1963 for the forces armées françaises. Best possible quality. These were kept in an underground weapon shelter and came up for sale a very long time ago. The person that bought the lot also had to buy the tools and jeeps. Which he did! Still have some NOS/NIB uninsulated French army pliers.
Word is that these were used in the reverse gear of military vehicles so they were of the utmost importance and therefor preserved in watertight containers. I even have some that have "tube condoms". No joke, birth control is a serious matter.
Make me an offer for these beam pentodes/Strahlpentodes/tétrode à faisceau dirigés that I can not refuse. By PM. Abbrassive PM is OK, I am used to something 🙂
This is your chance to obtain 61 year old true European top quality tubes/valves/Röhren. Sold in pairs or multiples of 2. EU only and preferably France. These should be yours, copins et copines.
VT-137/1626 pair for sale
Brand new/unused NOS/NIB Hytron triodes. Made in a year when intense cooperation between the USA and Germany occurred. This led to a fast and exciting development of electronics.
Never have been powered up, tested by me or otherwise. The boxes are worn because of me (they are in my possession since I was a kid) and of course their age as these are 82 years old. No guarantees and I want serious money to be able to buy class D amplifiers.
Make me an offer via PM.
EU only!
intro
Hey all,
I've been fiddling with audio gear both PA and home for 10ish years, and am now embarked in the journey of learning to make speakers. I've been researching and tinkering for a while, finished my first pair of subs off of free plans yesterday (Technically, the nicest looking I could find that had a simple enough model that I could manage to plug into hornresp to simulate by myself, and be satisfied-ish that I understood how they were supposed to work).
Still in the process of learning more about horns to be confident enough to design my own, but hey, hopefully Soon^TM
Jeff Bagby Designs - still available or still to build?
Hi!
I never heared one of Jeff Bagbys Loudspeakers and unhappily I have to say, I think they are very unknown here in Germany.
For me they could be quite fitting, because several of his designs were small ones and thats what I`m in need of.
Now I`ve seen, the Meniscus Store is down.
My question: Are the plans for his speakers (the continuum for example) still available?
Bye
Ralf
New Desktop 3-way build: The Thumpers
In about a month I will have a new, much larger, office. I currently use a two way on my desk and I think the new office dictates some new 3-ways. This is my justification anyways....
Intended Budget: under $300
I'm calling these the thumpers because I want the to hit low. If I use silicone pads I can keep most of the vibrations from shaking my mouse when I do CAD work.
To use this Dayton woofer they will need to be 0.4-0.5 cubic feet. I think that is feasible on my desk which is a giant slab of wood.
Anyways, let me know your thoughts on my driver selection. This will be the first time using a dome midrange. I'm pretty excited about that. Its not the best one in the world but I think its worth trying out. PE has minimum order of 1000 but digikey has them for $22
All data is just traced data so I can see if everything "should" work together. I'll take all the measurements and redo the crossover when the actually drivers get here.
Over Compressed Recordings: Does Pitch Reduction Make Them Sound Better?
I’m posting here hoping that most readers will have horn type speakers and also have Audacity, JRiver, Foobar and/or other software with lossless pitch control utilities.
Sadly, many of my favorite vintage pop, jazz and soundtrack recordings from the 1960s were deliberately hit with excessive dynamic range compression applied almost routinely during mastering sessions to prevent mistrackings on cheap vinyl players, to extend storage space on vinyl LPs and CDs and/or to allow higher signal levels to compete in the loudness wars https://en.wikipedia.org/wiki/Loudness_war#History.
Consequently, somewhat depending on which speakers used, they can sound especially flat-literally, since the natural dynamic peaks along with all the levels of all different sounds in the recording were limited and/or squeezed to one level.
I’d like to know how over compressed but otherwise reasonably well engineered commercially released CD tracks sound on high resolution horn speakers when the pitch is reduced by between ~ 2 and 7%, depending on the tempo and/or other aspects of the recording. Granted, aesthetically, the idea of doing this to music seems silly or even perverse, but it’s your subjective impressions of hearing the change through your horn speakers that I’m looking for.
Therefore, please run these tests on 6 or more such over compressed CD recordings-ripped and saved as uncompressed WAV files-at your earliest convenience and describe the before/after sound over your horn speakers.
Please reply or pm me for further assistance. Thanks.
US Amps AX3200DE Schematic
Hey all,
Does anyone have a schematic for a US amps AX3200DE amplifier? I’m trying to work out why it’s not oscillating but I’m coming up short.
This amp came to me already worked on and it was in a mess. Ive replaced the power supply section (fets, gate resistors, driver transistors) and the output section (fets, all drive transistors) and I can’t get any oscillation at all to take place.
I’ve attached the schematic that I’m using as it is similar, but it’s missing some stuff in the output section. I’ve got all my 12V voltages, negative and positive rails, and I’ve got PWM coming into the output section but it stops right at “Q44” on the diagram that I have. “Q43” I have my PWM but it don’t go any further. Even when I inject a signal it don’t go anywhere.
I’ve replaced random diodes, resistors, and even the TL072 that feeds the PWM to the rest of the output section. What am I missing?
Another QUAD ESL Problem
I have a pair of ESL989 which I just bought. Before buying them I heard them and they were playing fine, they were recently completely rebuilt by Electrostatic Solutions. I put them in my car, got them home, and plugged them in.
Now one of the speakers plays fine. The other powers on but there is no sound coming from them. The fuse is fine. I don’t see any destroyed components, wires seem in intact. The indicator light is blinking and I can hear the panels charging. It just seems like the audio signal isn’t getting through somehow.
does anyone have any ideas?
"EigenDAC", pure R&D project
Inspired by EigenTakt D-class amplifier by Bruno Putzeys and Lars Risbo,
I got very curious if it is possible to build self-oscillating DAC.
Few weeks I was struggling to understand how to implement a loop filter with proper frequency response.
It turns to be of 9th order.
I didn't read the Bruno's patents.
Understanding this official "pidgin-lawyer's" language is far beyond the scope of my intelligence.
So, I simply started playing with Bode diagrams using "trial and error" approach, playing with zeros and poles.
Than carefully transferred the result into digital domain by using Z-transform.
Fortunately, there was no problem with hardware. I used a prototype of my FPGA DAC.
Only FPGA configuration was updated.
The performance of the EigenDAC is quite impressive but still not as good as my traditional PWM-SDM.
1) Bode plot.
2) Animated THD @ 0..-100dBc.
3) Wide band 20-384k noise+distortions @ 0dBc
Reactions: eclipsevl and stv
APT Holman Preamps and relay repair
I have two APT preamps. Both working. The main issue...the pictures attached called "APT Holman factory mod" are my original unit I purchased in 1980. The relay was sticking on the left channel so I decided to open up the bottom cover. Please take a close look at these pictures labeled "APT Holman factory mod". The factory did the mod in 1986 or so and cut the mute relay components out and did this monstrosity. I have three brand new relays I acquired in the last 3 months. I was able to inject some Deoxit into the jump board relay and it seems to have improved. The real fix is to return this unit to its original condition and install the relay back to the PC board. I have two problems. There are three transistors. The schematic is so small and illegible that I cannot tell if they are Q17, q18 and Q19 are PNP or NPN transistors. Second problem, both 2n5087 and 2sc1345e are no longer in production. Now it looks like APT took those transistor and mounted them to the relay board in the picture. But one is a 2n3906?? I cannot read the others. I have the other preamp and those pictures are labeled "APT Holman Standard Relay" and it shows how it should be built or repaired in my view. I want to return my original unit to factory board parts and really need DIYer's advice on the best way to approach the repair. I know many of you have helped me before and I have beginner to lower intermediate skills. I have a temperature controlled soldering iron and a solder sucker. I recently recapped a Hafler DH110 so I am able to recap units if that helps. I work very slow and the unit that needs repaired have a partial wire sticking out of the board. Thanks for any advice.
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair1.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair2.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair3.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair4.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair5.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair6.JPG
  • APT Holman Preamp Factory modified relay installed under the mod 1 factory repair7.JPG
Reactions: booja30
Interpret Step response in tweeter selection
I see that often the step response is not included in the tech specification of many common brands,while I think this parameter is impotant becouse lets us know how “fast” the tweeter is and therefore if it can accurately reproduce all the details.
I have compared these misurations:
Bliesma T34A-4
https://hificompass.com/en/speakers/measurements/bliesma/bliesma-t34a-4
SB Acoustics Satori TW29TXN-B
https://hificompass.com/en/reviews/satori-tw29txn-b
and from what I see in the step response the Satori TW29TXN-B is much more faster then Bliesma T34A-4 and frankly did not expect this as I thought the Bliesma T34A-4 was superior to the Satori in this aspect as well, but apparently I was wrong.
And so maybe I should reconsider the Satori, in my next 3 way project (Woofer: Scan Speak 26W_8534G00, Midrange: SB Acoustics Satori MW16TX-8, with crossover cut 250 Hz, 2.5 Khz )
Then there would be the preference of the “relaxed” sound to consider. In the hificompass.com review:
https://hificompass.com/en/reviews/bliesma-t34a-4-34mm-alumag-dome-tweeter
they called it relaxed perhaps precisely because of its “slowness” but this is just theory.
I like to understand better if this paramenter "Step response" is important, or is perhaps something secondary.
What do you think ?
Thank you !!
R2R or single-IC for DAC?
Own one of the Denafrips R2R "ladder" dacs. Also own many classic and newer CDPs with multi-bit IC dacs (TDA1541, etc) or even Delta-Sigma or Bitstream. And also have some cheap kit dacs lying around based on ESS or Philips TDA chips.
I've heard this from reviews of R2R dacs, like Denafrips and Soekris, is that while they sound warm, clean and musical, they can sound "slow", lacking rhythm and drive. And that's what I've found, even with the Denafrips oversampling mode engaged.
Could it be all those R's in the discrete R2R (Denafrips, Soekris) topology?? That it takes some time for the signal to make it through those long R2R traces. Is that what slows the music down, taking away its sense of pace and drive?
Bliesma T34B-4 on Waveguide No.2439
Introduction
In this post I test a new waveguide design that I came up with for the Bliesma T34B-4 Beryllium dome tweeter. The specification page for the T34B-4 can be found here. The tweeter retails for around $500 USD. I directly compare this new waveguide/tweeter combo against the RCF CD350 compression driver with the ES-800 Biradial. I chose this comparison because the RCF/ES-800 combo represents a pretty standard setup, and a good all-around performer. The RCF retails for $90 USD, and so there "should" be a considerable step up in performance with the Bliesma.
Waveguide Design Elements
I wanted a waveguide that was based on my ES-Biradial horn flare geometry so that I could control vertical and horizontal directivity independently. The biradial shape also provides closer driver spacing to the low frequency driver.
The horn is 3D printed in two components. The first component is the throat piece which closely follows the shape of surround. This requires high precision printing which is why this is a separate piece. The second piece is the horn mouth which is printed in a different axis than the first piece.
Measurements
I began by measuring the raw 2439 frequency response at 1m (see red below). I then installed a capacitor to flatten the response for further testing. I found that a 6.8uF capacitor was ideal (see red response below). The raw impedance sweep is also shown as an overlay in black.
I then conducted the same response with the RCF CD350/ES-800 Biradial combo. A 3.3uF capacitor was enough to provide a reasonably flat response.
I then measured the horizontal and vertical directivity of the T34B/2439 combo.
Horizontal coverage is characterized as a consistent and wide coverage of 120 degrees however it narrows somewhat starting at 8kHz where we see directivity at 70 degrees for the 11kHz region. Pattern control is maintained as low as 1.2kHz.
The vertical directivity is characterized as a gradual narrowing starting at 2kHz narrowing to 40 degrees at 11kHz. Overall behavior is devoid of any diffraction or spurious resonances.
I then measured the RFC CD350/ES-800 Biradial combo which provides constant directivity across the operating range. Coverage starts out at 120 degrees at 1kHz and ends at 100 degrees for the 11kHz region.
The vertical is characterized as a gradual narrowing starting at 2kHz and ending at 60 degrees coverage for the 11kHz region.
Generally we see a more optimal polar map for the ES-800 biradial. One factor contributing to this is the larger throat of the bliesma at 1.33" versus 1".
Time Domain
I then measured the Burst Decay for the Bliesma. We see a perfectly clean result within the audible band.
The CSD plot also is very commendable.
I then measured the RCF CD350/ES-800 Biradial combo. The burst decay shows some ringing in the 10kHz region out to 15 periods. Personally I like to see a clean burst decay to within 18 periods. So this is acceptable.
The CSD plot is shown as well for reference.
Distortion
I then looked at distortion using a 95dB test signal level referenced at 1m. The mic was placed at 20cm from the horn mouth. H3 and H4 measure at around 0.008% for the 2kHz region.
If we change the vertical scale to dB instead of percent, this translates into -82dB.
I then measured the RCF CD350/ES-800 Biradial combo under the same conditions and achieved 0.007% for H3 and 0.014% for H4.
Again, changing the vertical scale to dB results in H3 at -83dB and H4 at -77dB.
Conclusion on Harmonic
Both the RCF CD350 and T34B have similar harmonic distortion profiles for H3 and H4.
Intermodulation Distortion using Multiband Multitone
I then measured the IMD of the Bliesma at the same 95dB test SPL that we used for the Harmonic test. IMD is at -60dB for the 1.5kHz region increasing to -70dB for the 5kHz region. Upper treble is around -65dB.
I then tested the RCF CD350/ES-800 Biradial combo. We -64dB for the 1.5kHz region -61dB for the 5kHz region and -55dB for the upper treble.
The Bliesma seems to outperform the RCF marginally on the IMD by about +5 to +8dB dB. This may be more academic since both results are far below the threshold of audibility.
Gedlee Distortion (Gm)
Below is direct comparion using Gedlee Distortion for the 95dB test SPL. I'm using Virtins Multi-Instrument Software to conduct this test. The RCF is shown in red with the Bliesma in Blue.
Conclusions
The RCF CD350/ES-800 Biradial combo is a tough act to follow but the Bliesma pulls it off by offering a smoother response, lower distortion, and a cleaner time domain. However the larger diameter of the Bliesa introduces some narrowing of directivity in the critical upper treble where soundstage width could be compromised. The Bliesma has no trouble digging down deep into the lower midrange without sounding stressed or resonate, which is often the case when mounting a dome tweeter in a waveguide.
My subjective evaluation was brief and conducted in mono. Overall I would say that the Bliesma sounded excellent, with just a slight lack of upper treble energy compared to the RCF. Directly comparing the two revealed that the compression driver is more expressive and colorful, highlighting dynamic contrast more readily. Both had similar levels of clarity through the midrange and treble.
Capacitor values?
Could somebody please tell me what the values of this capacitor are? And any other information that can be taken from this image.
It is approximately 5mm wide and 2.5mm deep.
It is in a really tight spot so it’s hard to see the height but it’s maybe 5-7mm.
Any help is appreciated.
Sony's mysterious PLM DAC technology
Several Sony CDP's from the early 1990s received high praise from the audiophile community ... and continue to do so. The resale value of certain Sony CDPs from 1991-1994 seem to hold up ...
Login to view embedded media
What they seem to have in common is Sony's own CXD2565M 1-bit (PLM) dac chip. This was an DF+DAC device that was apparently an evolution from separate DF and DAC devices [CXD1244S, CXD2552]
In any case, the vintage 1-bit Sony dacs (or complementary DF chips) are hard to find on ebay, etc. Also, not sure what the input format is. EIAJ or I2S. I can't tell from the datasheet timing diagrams.
Sony seems to have kept a tight lid on the details and distribution of these devices -- compared to Philips, AD, Burr-Brown, that is. Not sure why Sony was overly protective of these devices?
Would be interesting to make a diy dac based on CXD2565M, maybe being fed by a USB adapter.
I have a feeling that such a project -- even if everything was very optimized and cleanly powered -- would only yield so-so sound.
Something magical and dreamlike happens when the whole OEM box -- say, classic Sony or Philips CDPs , with all those manhours of R&D -- is used. Something about the dream of totality.
Also see:
https://www.datasheetbank.com/datasheet-download/340323/1/Sony/CXD2565M?v=V2
https://pdf1.alldatasheet.com/datasheet-pdf/view/46935/SONY/CXD1244S.html
https://pdf1.alldatasheet.com/datasheet-pdf/view/47027/SONY/CXD2552.html
https://www.hifiengine.com/manual_library/sony.shtml?category=cd-player
Reactions: lrocha and Scytales
For Sale Eton mid+tweeter+enclosure
For sale Eton mid drivers from hex series and soft dome silk tweeters.Bouth in verry good condition and working order.The units are:
2x mid 5-880/25 hex
2x tweet 19SD-1 silk dome
If the buyer will I can add the nice made par enclosures with zebrano wood veneer and made of 19mm mdf.Dimensions are H-30cm,W-19cm and D-25cm,with bassreflex tunel on the back.The price for the drivers so 2x mid and 2x tweet is 200 eu including shipping inside EU.With enclosure shipping the cost for shipping are way more high,but for someone that will build some nice monitor speakers out of this drivers I think is worth,becose by carpenter you will pay such enclosures at list 250-300 eu!More info on contact!
Reactions: vassilis1984
Working on Technics SA1000, wanting to replace TA7136P opamps
This receiver is fairly highly regarded, it was the largest to come out of the receiver wars of the 70s, making 330w per channel. Pretty outstanding if it isn’t the prettiest girl at the dance.
It uses 6 TA7136P seven pin single opamps. Now this opamp isn’t highly regarded, not even slightly. It’s known to be a pretty poor performer. I see that there are a couple of people that sell adapter boards to where you can attach your own opamp, but at $5-$7 per adapter board I’m going to look at other options. I am currently trying to get accustomed to Kicad and EasyEDA so that I can make up my own adapter boards and order 50 for less than the cost of the 6 I would have to buy (I will share the gerber when I do).
One board is supposed to be used with the OPA604, but it’s generic pinout where they just attach the appropriate pins, V+ to V+, output to output, etc. So this board can be used with any single opamp with the same pinout like the TL071. Speaking of, I’ve also the TA7136 repalced with a TL071.
The other board that is available can be used with single opamps like the OPA604 and NE5534AP, but can also be used with dual opamps like the TL072, NE5532AP. With the dual opamps you’re just supposed to wire the two opamps in parallel, so parallel the outputs, + and - inputs and such. I still don’t know what the advantage of using a dual opamp is over a single opamp. Is wiring a dual opamp in parallel give better performance?
Until I get well enough acquainted with Kicad or EasyEDA I’m thinking I’ll just use these small adapter boards I have on hand and wire leads that go to the appropriate spots on the TA7136 pinout.
I can use standard 8 pin opamps or I could use a smaller SOIC-8 package. For standard packages I have TL072CP, NE5532AP and then the single NE5534AP. For the smaller packages I have some OPA1656IDR and then for a single option I have OPA1641AID.
Im thinking for simplicity I’ll use of the single opamp options, unless someone has a reason as to why I should go dual.
It should fairly simple, joining the correct pins.
Just omit pins 1 and 5 and remove the components on the board at 1 and 5 as stated in the photo. Also attach a 100 nF from pins 4 to pin 7, the supplies.
So my questions, any reason to use a dual opamp over a single? And do all of my choices look like they would work well? That being NE5524 and OPA1641 for the singles and NE5532, OPA1656, or TL072 for the duals?
Appreciate any and all thoughts on this.
Dan
For Sale MiniDSP DDRC-88A with Bass Management, Dirac, and Remote
I paid $800 for this unit used from the original owner and had good intentions of using it in my main setup, but I am constantly changing my amps and speakers that I got tired of running new sweeps each change and only used the unit for 4 months and it's been in my closet since.
I created my own phoenix adapters for balanced input and used it to run two speakers and two subwoofers. I ended up re-painting the top cover matte black because it was scratched up.
The only issue with this unit is something other users of this unit have reported having as well. If you use a fully balanced setup (input and output), the outputs 1 and 2 (only on XLR output) had some noise if you put your ear close to the speaker. I ended up just changing the settings where outputs 1 and 2 ran my subwoofers off RCA and 3 and 4 were my speakers. There are not issues using RCAS on 1 and 2 or issues with XLR input on 1 and 2.
I am asking $625 SHIPPED for it or open to trade offers for diy parts or anything else cool.
Any questions just ask. Shipping to CONUS only please.
Power Transistors - availability
With the growing popularity of Class D amplifiers -> use of MOSFETs, I’m wondering about the future availability of BJT transistors. Could their production eventually decline, making them harder to find , purchase? Aside from their use in high-voltage applications and certain SMPS designs, will BJTs remain readily available?
Mainly I'm talking about Power transistors , complementary NPN-PNP parts.
Additionally, what are currently considered " the best " power transistors for output stages in audio amplifiers?
I often come across designs that feature older power transistors, so I’m curious—are there any newer options on the market?
When it comes to output transistors in audio power amplifiers, how do epitaxial planar transistors compare to triple diffused ones? Is one generally a better choice, or do the other specifications ultimately dictate the decision, regardless of the transistor type?
For instance, if two transistors share the same specifications, but one is epitaxial planar and the other is triple diffused, which would you choose? Would there be any noticeable difference in sound quality or performance? From what I’ve read, epitaxial planar transistors tend to be faster and more linear, while triple diffused transistors are more rugged with higher current and voltage ratings.
- Bruno.
CEC DX51 DAC, R channel pops
Hi everyone hope everyone is doing great.
I acquired this DAC and looking for a popping solution.
The right channel will pop whenever audio starts playing. It can be replicated by either play/pause or turning volume up from 0.
There are a pair of CHAMP Modules (pictured, horizontal with many LEDs) which I assumed was the cause. After swapping the cards the popping did not swap so it could be up stream.
The three boards (vertical) are Decoder board, Digital Filter board, and DAC board.
The dac uses 4 PCM1704 chips.
No service manuals are available and information is sparse.
Aside from the popping and slightly higher noise floor compared to modern DACs, it sounds great. I use it for my tv as well so the pops between quiet passages doesn’t sound great.
Ps; this dac has a quirk of never turning off. When you press the front power button everything stays lit but the input/output relays are disengaged. I assume they’re subscribed to the idea of leaving your equipment turned on makes it sound better.
Guitar speaker cab series/parallel switching
I have two single extension cabs with a 10" 8ohm speaker each. Would the following doodled diagram work if I wanted to run one into the other as either series or parallel? I have amps that are 4 or 8 ohms only as well as a few that are selectable between 4,8, and 16 ohms so it would be nice to have it as versatile as possible. So the three jacks (in, series out and parallel out) on one cab and just a single jack on the second cab.
Edit:replaced crappy doodle. 🙄
Hello
Hello,
My name is Robby and i live in Montgomery, AL. i have many different stereo components, mostly vintage integrated SS amps and many different types of speakers. Looking for more information on tube amplifiers, especially one that i picked up used. i will ask for help in a new thread. Thanks for all the great information on this forum. i am a tube amp novice. Looking forward to learning more.
Thanks,
Robby
For Sale UNBUILT NOS Heathkit Audio generator IG-5218
Bought this from an estate sale a few years ago. opened only to figure out what it was. all parts are there and 100% brand new old stock!!!! OH the joy of building your very own HEATHKIT!!!
Super cool!
$125 plus shipping
***NOTE: the last picture showing the built unit is a photo i found on the web so you would know what it would look like.
Longtime reader takes the next step
Hello all, reading and building a lot of designs here from the forum. I want to share some of my experiences in the future. I can draw my own schematics and PCB's. I have also a nice workshop where I can 3D print and solder my projects. My skills are with tubes, through hole and SMD designs. I appreciate the knowledge here on the forum. Some favourit members are Abraxalito, Mooly, Jan.Didden, MarcelvdG, Krivium, b_force and Kevinkr.
Projects from the past,
  • 1541 DAC
  • TDA1383 DAC
  • PCM1792 DAC
  • ES9038Q2M DAC
  • Tube phone preamp phonodude
  • Hybrid phone preamp
  • Passive preamp with remote and source select.
  • SE 813 Tube amp
  • Several Hypex UCD and Ncore amps.
  • Purifi 1et400a amp with and without (tube) preamp.
  • JBL/Eminence loudspeakers.
  • JL Audio subwoofer.
  • A lot of power supplies.
  • Rebuild Thorens TD160 mk2 turntable.
  • Tube preamps with 6n6p/ecc99.
  • 6 x LM3886 composite amp.
  • 2 x LM3886 composite amp.
Ronald
Complete and tested Prasi LT4320 based bridge rectifier
SOLD
Posted some time ago to sell some spare blank boards but there was no interests.
So i went ahead to purchase parts to populate and tested.
Info on the boards :
https://www.diyaudio.com/community/threads/lt4320-based-active-rectifier.336572/page-78#post-7729619
All the parts are smd devices, hand soldered by me meticulously. Boards are cleaned with IPA to make sure there is no residual flux left behind.
MOSFETs used are TPH4R008NH, which is one of those listed by Prasi
https://www.mouser.sg/ProductDetail/Toshiba/TPH4R008NHL1Q?qs=sA3qAAQcQeEIWvkYMlVV6Q==
I have not installed the LED, which i deem as redundant. C1 and C2 are also skipped, which i feel is unnecessary unless the rectifier is wire over a long length to the filter caps. Some well-experienced member has also reflected that the caps on board is not really necessary.
The pair of boards + shipping to you ( registered + tracking) = USD 50
Paypal FF only please.
Two 8 inches or one 10?
Hi to all,
I plan to build a three way in a simplified form of Watt Puppy. I don't want to try to replicate it.
My question is should I use two 8 inch woofers or one 10 inch. We often say that there is no replacement for displacement. Also I beleive that a pair of 8 inchers will not sound the same as one 10. Even if the 8 inch pair has more displacement than the 10 inch by approx 30%. I aim to have deep yes but mainly articulate bass. On the downside, that a 10 inch facing driver is quite big visually (not to mention a 12 incher).
I have not chosen the other drivers yet. But I want top tier stuff!
Thanks for sharing your experiences,
Walter
Sansui AU-D33 recap e-cap replacement question
Hello all, i just bought Sansui AU-D33 already recapped. im still in progress checking all caps one by one.
I found that in lC2 0.47uF/100 prev owner replaced it with 0.47/50 ?
Located in F-3592 Protector Board (l)
And if i must found replacement, i cannot find Ecap with 100v, most of them is MKP or MKT or worst case i must buy pink WIMA. (worst at price side 😆 )
That is so far my question, i will add more question if im confused.
Thank you so much
New to DIYAudio
Hey all. I am new to the site and newish to servicing Class H Crowns (DSi, CDi,XTi). I work in digital cinema service and got into fixing Crowns as an extension of the service. I am hoping to get advice on more advanced servicing of these crazy amps (very complex) and pass along any info I might have on audio (Dolby certified in ATMOS design and set up) and Crown repair, or anything other related stuff.
Matt
For Sale Stereomour II DHT 2A3 amp
Hi selling a stereomour ii set for 240 V with shunt reg mod and upgrades as:
4x Vcap odam + khozmo 48 steps attenuator. (only those cost approx 650 Eur)
The price I list is for the working unit only without tubes! As you can see painting has some defects. The unit works perfectly of course with its hum reducer pot.
If you want I can add tubes of your choice. Shopping can be as follow
2a3 Linlai mesh or linlai candle type titanium or cheaper ken rad
12at7 can be mullard or others of your choice between my collection.
Price demanded of the unit without tubes 900 eur+shipping obo. If you want tubes as well we can sort out a great deal.
Prefer to ship to Europe to avoid insane ship costs for far away destinations
Any question just ask
Fair offer will be accepted
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,534
Members
7,875,924
Messages
Filter
Forum Statistics
Threads
405,670
Messages
7,875,924
Members
507,534
Latest member
Fireball2020
