Complete and Tested LT4320 based active bridge rectifier
SOLD SOLD SOLD
Info on the boards :
https://www.diyaudio.com/community/threads/lt4320-based-active-rectifier.336572/page-78#post-7729619
MOSFETs used are TPH4R008NH, which is one of those listed by Prasi
https://www.mouser.sg/ProductDetail/Toshiba/TPH4R008NHL1Q?qs=sA3qAAQcQeEIWvkYMlVV6Q==
I have not installed the LED, which i deem as redundant. C1 and C2 are not really necessary but I installed C1 (1uf x7R ceramic cap) anyway. Some well-experienced member has also reflected that the caps on board is not really necessary unless your reservoir cap is some distance away.
Some members who were interested in the empty boards I posted for sale expressed some worry about soldering the smd MOSFETs.. so I did up a pair with the hope of clearing my extra boards.
My listing for empty boards here:
https://www.diyaudio.com/community/threads/prasi-lt4320-based-active-rectifier.416460/
The pair of boards + shipping to you ( registered + tracking) = USD 42
Paypal FF only please.
Want to learn about SMPS building
Hello members,
I want to learn building smps. I used to work with my father who did all the things. He passed away. Now i am left with the business.
I have learned alot from my father about amplifiers and doing well in that section. But i don't get a thing about power supplies.
He taught me a little about dcdc boost converters. But i don't know anything about push pull type convertors.
I hope someone will be wanting to teach me everything including the basics.
I am already accustomed with repairing of these type of converters but don't know how to build an efficient one.
I have tried to copy push pull types from other car amplifiers but they don't work as intented on heavy loads. Till 200w i got these to work but above that i don't think i could do anything without tutoring.
Basically, i am a newbie. I hope some of you guys can help me out with every lessons.
From calculations of dead time, transformer construction, inductors, mosfet selections, everything.
I hope to learn from you people.
Thanks in advance
Contact for Ovidiu Popa aka syn08?
Hi guys, I'm trying to get in contact with Ovidiu Popa, who was a member here under the monniker syn08.
He hasn't been active for a few years and cannot be PM'd. Anyone has a contact for him?
Edit: My face is red - I have been informed that Ovidia has passed away. Apologies to his famuly and close friends.
Interestingly, his website is still accessible so someone apparently keeps on funding that.
Jan
Greetings from Colorado
Hello all. I just was approved for this group and was given instructions to post here to provide an introduction.
I am an electrical engineer by training and have spent the majority of my engineering career with HP (including Agilent and now Keysight). I've worked on multiple product lines ranging from microprocessor emulators to logic analyzers to oscilloscopes. In my day job I'm working with other measurement scientists on test methods for 128GBit/s to 1.6TBit communication standards. Funny, in my spare time, I really get excited when I see nice flat performance out past 20KHz. They are really quite different worlds. Nevertheless, I've been building out my personal portfolio of audio band test equipment and have spent time most recently engaged in high-end cassette deck restorations. It was my era so I'm still fascinated by how some of the TOTL machines respond to alignments, component updates, and recalibration.
Cheers.
Hypex FA503 to drive dual 15" subs in Ripole vs Drivecore XLS2500
I've been exploring the idea of building fully integrated active tower speakers using Hypex plate amplifiers. I've been driving the subwoofer section lately with a Drivecore XLS2500 amp, with Dual 15" RSS390HF-4's in parallel (2 ohm load). In this configuration, I require between 600 and 1000 watts to meet my needs.
The Hypex FA503 offers 500W + 500W + 100W, which seems like a good candidate. My plan is to:
  1. Use the two 500W channels to drive the dual 15" subs in my ripole (25-110Hz). (500W into 4Ohms, each channel)
  2. Use the remaining 100W channel to feed a 3-way passive crossover for the midbass, midrange, and tweeter section (110Hz-20kHz).
Power Requirements​
I’ve conducted measurements on the upper 3-way drivers during extreme listening sessions (painfully loud) and found that they draw less than 50W. Based on this, I believe the 100W channel is sufficient for the 3-way.
Pros/Cons of an Integrated Approach​
Pros:
  • Cleaner appearance
  • Higher damping factor
  • Built-in DSP
  • Remote control options
Cons:
  • Higher cost (I already have the DriveCore amp for the subs and several stereo amps for the 3-ways above).
Damping Factor: Does It Matter?​
This brings me to my main question about damping factor. If ever there were an application where damping factor mattered, I would expect it to matter most on a Ripole, without any meaningful air spring restoring force acting on the cone.
The Crown DriveCore XLS2500 claims a damping factor of >200 at 8 ohms (10-400Hz), which translates to an output impedance of 40mOhms, below 400Hz. In contrast, the Hypex amp has an output impedance of ~1mOhm (<1kHz).
I assume wiring resistance adds to the denominator to give DF = Load impedance / (amp output impedance + wiring resistance). My calculations follow:
  • Integrated amps (Hypex): ~363 DF installed, assuming 2ft of 14ga cable (10mOhms for wiring, 1mOhm output impedance).
  • External amps (Crown): ~22 DF installed, with 10ft of 14ga cable (50mOhms for wiring, 40mOhms output impedance).
My Questions:​
  1. In the frequency range of 25-110Hz, would a damping factor difference of 22 vs. 363 produce an audible difference?
  2. What measurements could I run to visualize or quantify the potential audible differences?
  3. Is there a practical limit where damping factor improvements no longer translate into real-world benefits?
  4. Has anyone actually measured the output impedance of the DriveCore amps? (Delta load method?)
Any insights or suggestions on this design, especially regarding the audible impact of damping factor in the low-frequency range, would be greatly appreciated. Thank you!
Audio-Precision System One repair
Hello to all members.
I'm repairing an AP System One that has out of spec distortion in part of the of the audio spectrum. I checked with another THD analyzer that the problem is really in the generator and I removed all the add on options (IMD, etc.) to be sure they were not at fault. To be sure I replaced all electrolytic and tantalum capacitors on the generator and power supply without any improvement. In most of the spectrum the distortion is 0,002% or less, jumping to 0,004% from 205 Hz to 2047 Hz, when the "1 KHz" band is selected by U352A pin 1.
Since distortion is OK in all other bands I would say that the two MDAC hybrids are OK and also that the three OP amps in the oscillator loop are OK too.
Have you seen something like that before ?
Thank you !
iPod Touch 4th Generation - Wolfson DAC
I am still using the iPod Touch 4th generation which sits in a simple docking station that enables connection to a processor via RCA out. I absolutely love the sound of the Wolfson DAC in the iPod which to me; is better than than engaging the higher end DAC in my processor via an NVIDIA Shield and Spotify Connect. The former sounds much more dynamic and interesting, the later sounds flat and subdued. After researching this on the net, I'v come to learn that a lot of people loved the musicality and dynamism of the Wolfson DAC. Furthermore Apple engineers chose this DAC for the early iPod range and that alone says something about this DAC.
I have some questions:-
1. Are the classic Wolfson based DACs still available in an outboard / standalone version?
2. Is there a standalone DAC out there that comes very close or is identical to the Wolfson DAC?
3. Is there a way to turn the iPod into a standalone DAC? - Has anyone managed to do that?
I love the efficiency of Spotify Connect but I want to maintain the sound signature of the iPod Touch Gen4. Just to clarify, the EQ on my iPod has been deactivated.
To enjoy music, I have to physically copy the music files on my iPod which is becoming a bit frustrating.
Reactions: ranshdow
Constant Directivity without Horns or Waveguides
I recently made a fascinating accidental discovery: By choosing unconventional crossover frequencies and baffle dimensions, you can achieve Constant Directivity using regular woofers and dome tweeters - without waveguides, horns or dipoles.
I call it Zero Horn Constant Directivity (ZHCD). Jack Regula (@nc535) ran some simulations and helped me refine the model. First I’ll show off the end result, then I’ll explain the theory and model and give you a design guide.
Example #1: 5” 2 way with dome tweeter. Focal 5N402DB 5" woofer + Audax TW025 25mm dome. Front baffle is 8" wide.
First I tried a 1700Hz crossover which got me this frequency response at 0, 15, 30, 45, 60, 75, 90 degrees off axis:
Notice some "bunching" around 2500Hz. This bunching comes entirely from the tweeter, as the crossover is 1700. At 45 degrees off axis, the output is +4dB higher than on axis.
BUT guess what… if I set the crossover at 4900Hz I get this:
Theory (what I thought I knew about tweeter dispersion = omnidirectional below 8KHz) said this was impossible. Simple theory would predict the woofer is directional above 1K while the tweeter is not directional until 8-10K, but as you can see here, the tweeter’s directional characteristic matches the woofer’s almost exactly.
I might have just thought it was odd and shrugged my shoulders and went on, but I noticed the same thing with another smaller system – A JVC HSA1014 + Dayton ND16FA. Cabinet is 4.5” wide and 6.5” tall.
I attempted a 3KHz crossover and got similar results as my first try above (bunching around 4KHz), but then a 7KHz crossover got me this result:
This is an almost perfect Constant Directivity result above 1KHz with considerable directionality from a tiny 16mm tweeter… which I would expect to have NO directionality!
This was a big surprise. So I got curious. This reminded me of a phenomenon that I observed with the Live Edge Dipoles, which have a wide 19” live edge wood baffle and an 8” coaxial mid-tweeter. The Live Edge Dipoles have a minor but noticeable “bulge” at +/-45 degrees off axis, at about 1KHz:
On the low end, Dipoles start rolling off at λ = 2X cabinet width, and normal box speakers similarly have a -6dB Baffle Step at λ = 2X cabinet width. Lots of speaker designers know about these.
Now there are a couple of other baffle diffraction modes I don’t recall getting much attention. If you know what you’re doing, you can really take advantage of this and achieve Constant Directivity without horns or waveguides.
It turns out this +/-45 degree bulge at 1KHz in a 19” wide baffle corresponds to the 2.5KHz bulge from the 8” wide baffle, which also corresponds to the 4KHz bulge from the 4.5” wide baffle. I call this Baffle Bulge. It occurs across a range of λ = 0.5X to 1X cabinet width. At this frequency the on-axis response is the “normal” and “expected” but the off-axis response has a peak caused by diffraction from the edges of the baffle.
Then at even higher frequencies, where λ = 0.25X to 0.5X cabinet width, you get a Baffle Beam and over this octave, on-axis radiation is strong; but off axis drops off much like if you had a waveguide.
So if I draw these points on the polar plot above, it looks like this:
So this means in the 5” 2-way with 8” wide cabinet, most people would cross the tweeter at 2-3KHz fearing that the woofer will get too beamy, and has too much cone breakup. That’s what I did in my first attempt. But what I found was: Even the small 5” woofer begins to beam above 1K and then the tweeter has +4dB lobes at +/-45 degrees at 2.5KHz and the off axis response is very uneven.
Yet if I cross it over at 5K, the woofer’s natural beaming has already kicked in and is not as bad as I feared; also, the woofer’s beaming is not affected much by the front baffle dimensions; and then the tweeter is benefiting from Baffle Beam from 4KHz to 8KHz; and above 8KHz the 1” dome begins beaming naturally because of its dimensions; and viola, I get Constant Directivity behavior from 500Hz up. The combination of woofer beaming and calculated cabinet diffraction gets us almost identical polar patterns and CD behavior from woofer and tweeter alike.
Again:
In the 4.5” 2-way with 4.5” wide cabinet, the woofer’s beaming from 3-7K is matched by the tweeter’s Baffle Beam above 7K and even this tiny system gives me Constant Directivity behavior from 1000Hz up:
I’ve been designing speakers for a long time, so I’m conditioned to avoid woofer beaming and breakup and handoff to the tweeter at a low frequency. But it turns out if your woofer has well behaved gradual breakup modes at the upper end of its range, and you design the crossover appropriately (the woofer crossover on both of these was more complex than usual), you get the fantastic imaging that CD designs are known for and both of these systems are well behaved at the upper end of the woofer’s range.
So I asked Jack Regula ( @nc535 ) to run some simulations to shed light on this. All of these simulations are of a 1” tweeter only (there is no woofer in the simulation) mounted on a box of dimensions 8” wide x 13” tall.
So let me step you through the research Jack and I did. First, Jack experimented with rounded vs sharp edges, and found that an 18mm bevel on each edge greatly reduced high frequency ripple. So all the simulations that follow assume that 18mm bevel.
Secondly, asymmetry in diffraction is also desirable. The worst situation is a tweeter in the middle of a round baffle. Second worst is putting it in the middle of a square baffle. Third worst is putting it in the middle (as I admittedly did in my small 2-ways).
When Jack put the tweeter in the center of the baffle, this is the polar heat map he got:
Notice significant “Baffle Bulge” at 2.5-4KHz which we are avoiding by choosing a 5KHz crossover.
Jack moved it off center and found a really nice spot here. The red dot is the tweeter location:
At this off-center position, Baffle Beam is working for us from 4-8K and has no nasty peaks or surprises:
[Please note that Jack’s models have irregularities above 8K that are a result of not using tons of points in the calculations, to save computer time – artifacts of the simulation.]
TDA1387x8 - I/V stage w/ NE5534 - Aprox. -4.4V DC in output, why?
Hi all.
I am building a 8 ch DAC based on 4 TDA1387x8 boards. Each TDA1387x8 I/V stage is based on two NE5534 with a 1k feedback resistor (R4/R5) + 4.7nF cap (C3/C4). A 47pF cap connects pins COMP and COMP/BAL. It is basically 4 ProtoDACs with an active output stage.
I am a computer engineer for 30+ years, but went down the software path. So electronics is not my strong... What I am trying to understand is why I always get aprox. -4.4VDC before the coupling caps (opamp output - pin 6) when there is nothing playing. If I put a 2kHz sinewave at 0db, I get aprox. 6.8V peak to peak (a little bit more than what I aimed for, need to adjust R4/R5) but the osciloscope shows that the minV is -8VDC and maxV is -1.2VDC. I.e., the signal is "centered" at -4.4VDC.
I built a single chip version (2ch only) in a perfboard and it plays just fine - after the MKP 4.7uF coupling caps (C13/C14), I get the sinewave from -3.4VDC to +3.4VDC as expected. Too early to say something about its sonic capabilities as I have just one channel pair done and the PSU built in a protoboard.
I've attached the schematics of one channel pair (1 TDA1387x8 + its I/V stage) and the oscilscope measurement.
Is it normal to have the signal "shifted" by -4.4VDC? Why?
Thanks!
Reactions: m-a
IXFN400N15X3
I am contemplating using a pair IXFN400N15X3 in TO-227 packaging to replace the 6 IRF244 in my Aleph 5 build, to get away from the matching issue.
On paper it seems to be impressive RDS, lower than 3 IRF244 in parallel, VDS is lower but adequate for my Aleph 5, ID 400A, Qg higher than 3 IRF244, PD 695W.
Anyone knows if this is suitable as IRF244 replacement?
If some expert here could help with designing the output stage of the Aleph 5, I shall be happy to be the guinea pig to report the outcome, with fire extinguisher on standby, of course.
Here is the data sheet.
Quick Sophomore Question About Resistor Voltage Rating
In vintage tube amps repairs or clones I've always used 1/2 carbon comps where called for, never gave much thought to the voltage rating as I was doing "like for like". My supply of NOS is finishing, I'm not going to bother with modern carbon comps, the tolerance is sloppy and the leads are too short anyway for repairs or building ptp. I'm looking at the KOA Speer CF carbon films, rating is 350V, is this the max voltage drop across the resistor or the value it'll see on the side feeding it?
Some companies don't give a max rating telling you to use Ohms's law for whatever resistance value you are using but as a general rule when buying batches can I assume 350v rated 1/2W resistors are fine for amps below 500V on the output tube plates, your typical Vox, Fender, Marshall, Dynaco etc?
BTW I do use 1W or 2W in the power string and will use 1W for cathode followers or on the tail of a phase inverter, and yes I should just use 1W carbon film all around but I want to stock up on 1/2s as I also play with ss and I want to try the KOAs which have a good reputation, Mouser, Digikey etc don't offer 1W KOA carbon films in many values.
Verification of speaker selection for a 4-way design
Inspired by a friend and his new OB, I finally decided to take the plunge on the endgame design (for me). A few years ago I was trying to figure out how to make a stable 3-way with a larger woofer and there was always something wrong...
A friend of mine has already created beautiful 4-way OB based on BlieSMa beryllium domes. I want to use slightly cheaper versions of the BlieSMa midrange dome - TeXtreme version. The whole thing is to be controlled from miniDSP Flex Eight and actively powered. Of course, someone familiar with the subject will come to help with tuning.
I'm getting ready to assemble a set of speakers and today it looks like this (almost TeXtreme team):
Bass: SB SB42FHCL75-6 - interesting loudspeaker with a stiff diaphragm - it can be extended to around 300 Hz (planned closed housing and cut around 150 Hz)
Low-mid: Satori MW19TX-8 7.5" version with TeXtreme diaphragm. (planned division 150Hz to approx. 600Hz)
Diameter: BlieSMa M74T-6 version with TeXtreme diaphragm (planned division 600Hz to approx. 3500Hz)
High: SATORI TW29TXN-B-8 version with TeXtreme diaphragm (planned division from approx. 3500Hz)
I wonder if, for highs, e.g. BlieSMa T25B-6 (Beryl) would be better? I think the 34mm BlieSMa T34B-4 would be an unnecessarily large dome (when used with a midrange dome)? It seems to me that the low-mid Satori MW19TX-8 7.5" would be a good choice. I considered the 6.5" version but it seemed too small. Maybe it's worth considering a different speaker?
An original, high-performance complementary transistors matcher
Transistor matchers are not uncommon: in fact they are all over the place, and generally work satisfactorily. A good example has been presented recently by Mark:
The vast majority however matches identical transistors. Complementary matchers are much rarer, and sometimes have issues:
It is possible to build something much better, whilst keeping things simple.
This matcher places the BE junctions in parallel, and biases them with two 1K resistors.
If the transistors have identical Vbe and Hfe, the circuit is perfectly balanced and the average voltage taken from the bases and emitters will sit exactly at mid-supply, and can be compared to a reference divider:
In this case, the complementarity is unperfect, the conduction of the P transistor is stronger, driving A negative wrt the reference divider.
Because of the exponential relationship between the delta-Vbe and the collector current, a tiny mismatch is easily detectable.
The Hfe of the transistors also affects the result, to a lesser degree.
You can convince yourself that the principle is sound:
Here is the jig fitted with a synthetic transistor, a sex-changed BC547B into a BP547B:
As you can see, the match is perfect.
Here are some pics of the jig in action:
To be continued....
  • Qmatcher1.asc
    Qmatcher1.asc
TDA1540 - I2S to Offset Binary, no CPLD, no FPGA
Final verdict:
Don't build it with these logic chips and do it with my CPLD solution.
CPLD is very fast and accurate. I created open solution for all of you:
I2S to TDA1540 with CPLD: https://electrodac.blogspot.com/p/tutorial-how-to-programm-altera-cpld.html
Building TDA1540 from scratch: https://electrodac.blogspot.com/p/dac-ad1862-almost-tht-i2s-input-nos-r.html (look for TDA1540 section)
Hi folks,
my first attempt for converting I2S to Offset Binary. This format is used in the old 14-bit R2R DAC chip TDA1540.
The conversion from I2S to Offset Binary is as simple as inverting the MSB bit. It is easier said than done 😀
My logic is created from naked logic gates and a few shift registers. It is working for the standard I2S word in length of 64 bits (generated from well known XMOS based converters, or PCM2706/7).
Basic principle:
  • MSB bit is inverted after each LRCK edge, controlled by XOR gate + pulse
  • BCK is inverted for TDA1540, and used for shift registers for better timing
  • DATA are shifted, aligned for left and right channel, latched together in 14-bits and the rest of unusable data are ignored
  • LATCH is generated after each LRCK cycle
Note: instead of NOT and AND gates are many NAND gates used (6 NAND gates in one chip).
Converting serial to parallel - inverting bit - parallel back to serial seems be hungry for parts, so I did it very simple, simple but not perfect. There is no synchronization and maybe a hidden timing issue.
Any improvements are welcome, like stop clock operation for both channels, better timing, ...
Do these actually decode?
I bought both of these from aliexpress, and I can't get either of them to give 5.1.
I've tried all types of input, and there's either no output to the surrounds, or the surrounds replicate the fronts. The centre has non dialog, and the L/R contain dialog.
Has anyone got these to decode?
6GM8/ECC86 Tube preamp for 30VDC supply
I have decided to build my first TUBE amplifier. Using ECC86 triodes from Telefunken.
It is a preamp with a little voltage gain. I hope getting good tube sound.
There are 3 different ways to go. The first is simply using 1/2 ECC86 per each channel. This only requires one tube for stereo.
The second way is to parallel triodes in one tube. This needs 2 tubes for stereo Gives twice the current and lowers the output impedance.
The third option is to make a differential tube circuit. This also needs 2 tubes for stereo. This option will preserve the correct phase. While option one and two gives inverted output.
I post here 3 images with the 3 choices. Which one should I go for 🙂
SL1200 inexpensive high performance external PS
I've managed to put together a low price, high performance power supply for the SL1200 for under $50 parts cost. Its centered around the Mean Well LRS 50-24 SMPS.
This supply is very well built, using United Chemicon capacitors, a well laid out chassis and a high quality PCB design - pretty good for a $14 power supply. Output shows very little noise and ripple with more than enough current (max 2.2 amps) to feed the turntable.
The output voltage is adjustable via a small pot in a very wide range of 20 - 31V. It also has a soft start and a nice status LED. This can be extended out to the chassis for an external power indicator. The SMD series resistor on the bottom of the PCB can be changed to suit the current needed to run other LEDs.
With this PS you can turn the output voltage all the way down to 20V for a direct application, bypassing the stock reg or instead of a 3 pin based circuit. You can also turn it up to supply enough voltage to accommodate the drop of the stock reg or your 3 pin based reg of choice.
The SMPS regulation is very tight and I'd feel very comfortable using this straight into the supply rail of the SL1200's motor PCB. I would however fuse the main B+ rail into the TT if I chose to do this. Its just as a precaution against an eventual fault or failed component inside the TT to protect the main PCB from burning up any traces.
I configure the front panel to include a ground lift switch in case of noise issues due to grounding. Coming out of the PS I chose a typical 4 pin screw lock connector used in many low voltage applications. I left an extra pin available to shield the umbilical cable going into the turntable.
A KAB 3 pin reg board was used inside the TT instead of the stock reg. Honestly, the OE Technics setup is more than adequate for the job as long as the filter caps are all in good shape. Of you need to replace them, I'd recommend the Panasonic EB series caps. They're inexpensive for being rated at 105 deg C along with excellent ripple current capability.
The chassis I used was an enclosure made by Context Engineering, part number 4006. I had it in stock already, as this is an enclosure I use for many projects. I don't know if these are still being made, but I'm sure there still are other suitable enclosures being sold for this purpose.
Reactions: 6L6
Dynaco ST-70 modification help!
Hello! I have recently purchased an ST-70 from someone who had it for 4 years. He bought it on ebay from a store that got it from the estate of a deceased musician. The late musician either modified it him/herself or had it done by someone else. There is no schematic or record of what was done. All I know is that it comes from around the Woodstock, NY area. I have never seen mods like these before. Bias pots under the chassis (in addition to the regular pots on top!) LED light in the front left octal socket?? Why??? Not sure why they upgraded the quad cap to 80-40-30-20 .... maybe it has to do with all of the extra wiring under the hood. I'm trying to retrace their steps and understand what was done! Hopefully, someone here can help me figure it out. If you need more detailed photos, I'm happy to provide them.
Any thoughts or advice or input you have is welcome!!! I'm a n00b so no advice is too small.
Thx!!!
Hello everyone!
Hello everyone!
I'm thrilled to join this vibrant community of audio enthusiasts. My name is Maxim, I am from Canada, and I'm passionate about all things audio electronics.
From vintage gear to the latest innovations, I love exploring and experimenting with different audio equipment like DJ Mixers, HiFi sources etc..
A bit about my background: I've been involved in the audio industry for several years, working on everything from recording and producing music to designing custom audio systems. I'm particularly fond of vintage audio equipment and enjoy restoring and collecting classic pieces.
I'm looking forward to learning from all of you, sharing my experiences, and contributing to the discussions here. Whether it's troubleshooting a tricky issue, sharing tips and tricks, or just chatting about our favorite gear, I'm excited to be a part of this community.
Feel free to reach out if you have any questions or just want to chat about audio electronics. Let's make some great sound together!
Best regards,
Maxim
DJ-Tech DJM-303
Hi everyone!
Does anyone have experience with the DJ-Tech mixer, specifically the model with plate number DJM-303?
I’m looking for the firmware for the MC9S08AW32CPUE controller.
The chip has completely failed, and I have a new one, but I need to program it first.
Could you please help me locate the firmware file?
Thank you!
For Sale Small Solder Pot, bar solder, and small quantities of other solders
SOLD
Asking $60 to include continental USA shipping.
USA sale only.
I have a small Chinese solder pot (36 x 30 mm pot) for sale. Works as it should.
Also included is an additional 1 lb 2 oz of bar solder (Cardas and Wonder Solders)
Additionally, there are some small quantities of other, mainly lead free, solders in the lot.
-WBT-0800 Silver Solder, 2 or 3 oz
-Marigo Labs, 6 ft length. Not sure of makeup.
-Welborne Labs Silver solder, maybe 2 or 3 ounces.
- Fire Metal SN/PB/AG/Cu 1/4 lb.
- Radio Shack 0.5 oz silver solder
No returns. Will need to ship ground due to HAZmat.
Bonjour de Nice France
Bonjour la communauté,
J’adore mon système Thule Audio composé de:
PA + PR 150b CD 150b. TU 150b sur une paire de Dynaudio Contour 1.4S câbles XLR QED
Pour quelle raison avoir choisi ce système? C’est très simple une visite dans un auditorium Parisien un CD de piano à la main suivi d’une écoute de plusieurs solutions jusqu’à ce que le son du piano soit réaliste j’ai dit c’est bon j’avais trouvé chaussure à mes pieds!
J’aimerais partager avec les amoureux de cette marque trop vite disparue et maintenir ces électroniques en bon état de fonctionnement le plus longtemps possible….
Cordiales et musicales salutations🎶🎶🎶
Hello community,
I love my Thule Audio system consisting of:
PA + PR 150b CD 150b. TU 150b on a pair of Dynaudio Contour 1.4S XLR QED cables
Why did you choose this system? It's very simple, a visit to a Parisian auditorium with a piano CD in hand followed by listening to several solutions until the sound of the piano is realistic. I said that's good, I had found a shoe. at my feet!
I would like to share with lovers of this brand that disappeared too quickly and keep these electronics in good working order for as long as possible....
Cordial and musical greetings🎶🎶🎶
SONY E9000ES
I pulled this unit from E-waste knowing it will end its life under landfill. Actually thought it was a surround reciever. After further investigation i realized it's a multi channel controller. So, what to do with it? Im a 2 channel person, having any more options is just a waste on me. Is this unit suited as a 2 channel preamp or a better home in stead?
LM3886: Why open input leads to large DC at output?
I was experimenting with point-to-point wiring with LM3886. Notice that almost full DC power supply voltage at output terminal! I thought I was losing one side of power supply but after carefully check, the power supply working correctly. Later on, I found that part of the input is not connected, after reconnect it works. I also try shorting the input to ground, there is no DC at output as well.
Why is that? Is it because incorrect input bias when disconnected?? I tried simulate on TINA-TI, and it is kinda show what I experienced.
Closed SW1 = Normal/ correct wiring. Only 1.18mV at output.
Open SW1 = Disconnected input bias circuit. Simulation show 22 V DC at output.
Please share your thoughts.
AP
BJT internal emitter resistance
A recent thread discussed the internal emitter resistance of BJTs and its effects on thermal stability.
Since I was curious, I fitted a BJT model with an emitter resistor to the Vbe-versus-Ic graph in the MJ15003 datasheet. A reasonable match was produced with 40 milliohms at 25C and a 0.16 milliohm/C temperature coefficient. The Vbe sensitivity to temperature was -2.1mV/C and Is was 10^-12 A.
I am curious if anyone has similar data for other power transistors.
Ed
My second adventure: Simple Integrated
A little less than a year ago, I successfully completed my first tube audio project: an RIAA phono amplifier. It was a fantastic success, and my family and I have been thoroughly enjoying it. Winter is coming again here in the Rockies, so it's time to start thinking about indoor projects. At the moment, the preamp feeds into a set of computer speakers, which is pretty anticlimactic. It's time to start working on the rest of system!
I think what I want to do is an integrated amplifier (I might could be convinced to go another route) with a similar basis. I want the most minimalist circuit possible (100% tube and passives), single-ended class A, all analog (including power supply, because this is part of the fun for me), low power (pushing shelf speakers in a living room, rarely might need to compete with a vacuum cleaner), using modern, current production components (future proofing). My current setup consists exclusively of a record player, but there's an ancient Sonos that my wife uses from time to time, and I'd like to replace it with a better streamer down the road (phase three?). A third, maybe fourth channel would probably make for all the extensibility I'd need for quite a while. Aside from that, I think I don't really want much more to it than a volume control, again, for the minimalism to keep the part count to a minimum.
What thoughts or advice do people have for me? Any designs/schematics out there that fit the bill?
UAC2 I2S input on STM32F723E-DISCO
I made a simplified version of my STM32F723 firmware for STM32F723E-DISCO board with just I2S input (no I2S output). Should work at least at 192k/32.
It uses this board:
https://www.mouser.fi/ProductDetail/STMicroelectronics/STM32F723E-DISCO?qs=DXv0QSHKF4wBapbNjrzotQ==
Attached is the source code. It runs on FreeRTOS although this version does not really utilize it.
I used STM32F723E-DISCO board's Arduino connectors CN11 and CN13 for all I/O.
I2S signals are at CN11.1 (FS), CN13.4 (BCK) and CN13.7 (SD).
I2C2 is available at CN11.10 (SCL) and CN11.9 (SDA).
4 GPIO outputs at CN13.3, CN13.5, CN13.6 and CN13.8.
GND at CN11.7.
The source code also includes a "driver" for my AK5394 board which uses all 4 GPIO outputs. This can be used as an example of how to connect to ADC board.
STM32F723E-DISCO board is of course not optimal for running I2S as it is meant to be a showcase of various MCU capabilities. For best results a custom board dedicated to I2S should be used.
Have fun!
Atmos sucks. I have a better idea
I own 2 atmos avrs and find both disappointing. IMO, height sounds such as aircraft, birds, thunder, rain, wind, spacecraft, rocket and other height sounds should only come through height speakers. Atmos is overhyped and basically snake-oil. There's no unique content in the heights. It's just a replication of the bed layer channels. Manufacturers are no longer making bluray players, because physical media is dead. Everyone is streaming. But streaming has a bandwidth problem. You can have quality 5.1, or compressed & lossy atmos. Since the heights are just the same data repeated, it makes sense to save the bandwidth and do the replication in the avrs instead.
I also want to boost the bass only for gunshots, thunder and explosions, and not music. And have automatic attenuation.
These are my goals...
Matching complimentary BJT pairs
Hi first time poster.
I am restoring a '73 Minimoog synthesizer and it requires a complimentary pair (in this case 2N3904/2N3906).
I noticed in a previous post that a test circuit designed by Elvee might be the answer.
The attached is the circuit from the Minimoog service manual.
In note (4) the request is that the PNP Vbe is 10-20mV lower than the NPN at 200mA.
I'm not an engineer, but I think at that current it would deep fry the BJT's or cause thermal problems in the matching process.
Any help appreciated.
Mic / SPL calibrator - cheap ones on Amazon (or elsewhere?)
Anyone using a mic calibrator?
Not frequency response, just level - 94 / 114 dB @ 1 kHz. I do acoustic measurements, the mic has a cal file but the sound card I have has a gain knob. So FR should be right(ish) but who knows about overall sensitivity. So, calibrated reference source to the rescue.
B&K and GRAS make expensive ones and that's great when work is paying. But for hobby projects I'm looking for something cheaper. There are a few of them for sale on Amazon for around $100. Are any of them worth while?
Let's see, here are some examples...
Reed Instruments R8090 - $179 (the expensive one!)
This silver cylinder calibrator - sold by multiple vendors - ~$111
Grey rectangle with orange band calibrator - multiple vendors - $79
Black cyl with blue LCD - $109 (sometimes this one is called ND9B, but then it's ~$200)
Anyone know?
A bummer - these all seem to be targeted at SPL meters and accomodate 1" and 1/2" mics but I think the typical FR measurement mic is smaller. I can probably 3D print an adapter, if I seal it...?
Allison Six _ what is your opinion?
Hi ! i am watching this most unique speaker The old Allison Six
i do not understand the rationale behind this design
I guess that the cross Hz between the woofer and the tweeter should be around 2kHz ?
for a good part of its range the woofer should be directional
I wonder what the designer tried to achieve
Can anyone explain me please this design ?
I would like to replicate it but with a wideband in place of the tweeter and lowering the cross frequency
What would be the best cut ? 500Hz ? less ?
i am lost but intrigued
What chip is in HW-715 AliExpress module?
Hi all,
I bought a small cheap amplifier from Ali, claimed to be TPA3116 (but cannot be, of course, at this price; i just hoped will be some 10W peak but is not, at least not on 4 ohms), and I did some tests. Audio speaking, appears to cough (typically overload audio interruptions) at beyond 3W peak/6 ohms (subjective, hearing only) . Current supply from 12 to 24V rises a bit from 25 to 30mA (for the whole board) . Oscilloscope output shows that the rectangles are full voltage, so is not supplied through some kind of internal buck converter. The output frequency is at 370kHz.
Peaks seen on oscilloscope appears to be at 700mA at 8 ohms and 1A at 8 ohms, irrespective of voltage (12-24V) but dynamic response is far better at 24V, audio interruptios are rarer.
Do anyone knows what chip was really used in these?
Transistor matching circuit
Hi guys,
I'm trying to build a circuit to match NPN and PNP transistor pairs for my SymAsym amplifier. The basis for this exercise is the paper by Ian Fritz, see https://www.dragonflyalley.com/synth/images/TransistorMatching/ianFritz-transmat0011_144.pdf
Since I need +12V and -12V I want to use my lab power supply at 24V and use a virtual GND with voltage divider.
Here is for example the circuit for PNP matching made with LTSpice:
Voltage across the leads on the right side is measured for calculating the mismatch. R4 and R5 values should be as close as possible. I want to use 1% tolerance resistors, that's why I simulate with 99k and 101k.
The NPN version looks like this:
Due to the simple voltage divider the voltages are not +12/-12V but +13.18/-10.82 V for the PNP version and +10.82/-13.18 V for the NPN version.
I don't see a problem with that, except for the difference in current at which the transistor mismatch is measured.
Will this work? Am I missing something?
Best regards,
Jonas
  • Locked
Building the Lhotse designed by Scottmoose
I have a matched pair of the MAOP 11 and want to built the Lhotse with them.
I already started fabricating them, nice speaker!
Reactions: LeifB60
Bag End 400 A Infra 18 Sub Amp
Hi I am Christos Spanoudes , 71 YOLD , electronics engineer, building DIY since i was able to solder, designed / built / serviced mainly PSU and audio gear but also control circuits , 40 years under name of CVRC ELECTRONICS , retired , now electronics is just for fun and hobby.
my question
following a relative thread on this forum :
I have an amp that output devices Originally were 2SA1302 / 2SC3281 ( BAG END 400A )
Found a good direct replacement for the output devices possibly to be MJL1302/MLJ3281
The output driver transistors were 2SC3907 and 2SA1516, and i found equivalent to be possibly 2SA1943/2SC5200,
but could one use the MJL1302/MLJ3281 ( TO264 ) or even the smaller case NJW3281/NLW1302 ( for same case ) ,
as drivers to the MJL1302/MLJ3281 ?
because the MJL1302/MLJ3281 and 2SA1943/2SC5200 have spec almost same between them , except for case and max power etc.
and the MJL1302/MLJ3281 will be more robust if they will work ok .Unless there would be a catch .
Any response welcome to start in this super nice / useful ( I found ) forum.
New Issue Scrolling broken on iOS & Firefox
hi, I am experiencing problems since a couple of weeks with scrolling in mobile view on a fully updated iOS device (18.2.1) with up to date firefox as browser (Firefox 134.1 (49636)). This started a while ago, maybe a month. I have no addons installed.
description: the scrolling does stop, and does not float. it happens either way no matter whether the finger is released from the screen, or touching will scrolling. this behavior is periodically interrupted by a normal scrolling experience.
New Balance Potentiometer for Rotel RA930AX
Hi All,
I am looking to replace the balance potentiometer for the rotel ra-930 ax. Trying to work out which replacement will be most suited. I think the resistance value is 100k ohms. I'm currently looking at some options by Bourns, but it's hard to know which is the right one. Any thoughts/links to appropriate replacements would be welcome, thanks!
Finished Aleph J build - first thoughts and comparison to my other gear.
I thought this would fit best here, as it is more of a 'whatever we want to talk about' post vs. putting it in the build thread or the like.
First, I won a gold medal for the s l o w e s t build, I think ordered the parts 4 years ago, and due to a job change, move, life stuff, I got the power supply built/tested, then didn't progress from there. Anyway, finally got it done and running today. Everything went smooth, no issues at all (I was VERY careful and sweated the details).
My main system is a McIntosh C53 preamp and I have a MC462 (450 watt SS amp) and MC275 (75 watt tube)...I swap between the amps as I feel like. like them both for different reasons. I also have the little 2.3 watt Decware Zen amp (it has some background hum that is preventing me from falling in love with it). I'm currently using and loving a pair of Zu Audio DW6 I picked up at the factory (about 45 minutes away, my welcome to Utah gift). Also have a pair of Sonus Faber towers that are currently off to the side while I enjoy the Zu's.
The main reason I did this build was to learn and sharpen my skills. I learned a TON, not only about electronics, but the build process. I remember the first time I tried soldering vs. now, where I can 'feel' the molten metal flowing and manipulate it (but still a lifetime of learning, I'm no pro!). As such, the amp itself was more of a curiosity and side effect vs. the main attraction. Maybe it would be good, maybe not, but not really the point.
Holy ****... I've been listening to it all evening, and I'm still not comprehending it. OK, maybe I am just in a really good mood tonight - but need to say my personality is NOT one of a honeymoon, most things I buy (or make) I generally don't like at first, then either stay that way...or grow to like them. This amp just immediately grabbed me and had be stand to attention.
OK, as I was listening, I was trying think of ways to describe what I was hearing. Like riding a motorcycle for the first time after driving your whole life, yup. Like standing at the rim of the Grand Canyon in person after seeing a documentary on it, yup. Like listening to a set of good headphones (I really got that feeling), yup. Like playing a synthesizer vs. hearing a recording of one, yup.
The sound clear, immediate, fast, nimble, precise, liquid. It is almost like the sound is playing faster than my brain can keep up with. And on these high-sensitivity speakers, ENDLESS power and dynamics. The speakers felt like they were pulled up close to me, the imaging was wider, taller, deeper. Also on a technical note, zero background hum or hiss (something I can't say for the Decware).
I'll make a quick reality check to say I HATE bright sound - and while this amp certainly brings endless high frequency energy, not once was I wincing or wanting to turn it down for being bright or shrill. This also means a product that tries to sound 'lively' by being bright is immediately on my naughty list. I think this amp would be a disaster with a bad source, the wrong speakers.
While I still like my other big amps, this one is special, and I have a LOT more listening to do.
I was not expecting this outcome, and that is not a bad thing!
hello!
Longtime lurker here but i finally got to a point where im stumped and am hoping that one of you geniuses are able to help me out. I run roughly 12 picoreplayers pumping to 3 12 channel amps for whole home audio. Prior to that i used Amazon Echo Flexes since they had a headphone jack out and that worked well. Since moving to picoreplayers (using squeeze and airplay paired with LMS or music assistant) i've run into some unique use cases that the echo's handled fine.
Basically im looking to learn more about if picoreplayer can detect different audio input from different sources (airplay from my phone, squeezelite from LMS/MASS, announcements from homeassistant, etc) and automatically switch audio renderers when a new one makes a request. The issue i have is that if i start airplay from my phone and then there is an announcement or something from home assistant (via a direct squeezelite integration or via MASS) it just turns airplay off but doesnt play the announcement.
Im hoping to find a solution that can be a controller and switch between different audio sources on the fly. I have messed with volumio and moode in the past as well. Moode was close. it actively stops the audio renderer but there were some issues with it relying on MPD as the main audio renderer vs squeeze or airplay. I am familiar with the Wiim devices and they seem to be able to do this but i am already invested with these pi's and would love to find a solution to this. TIA!
Sonos Port S2 Model S23 output audio not working
hello i have a Sonos s2 port model s23 that output audio not working was working for a year no issues but now nothing works it plays in the app also when i connect my laptop with music it wont work either ...i opened the box looked at the boards capacitors and i don't see any that look exploded looking at the RCA Qr code give me this 54303rc1mvd47c1a and the main board QR code give me 62202mb1mu7be71a.. i hopping that i could find out whats the issue im ordering a meter to test caps...if any body had this issue please let me know... thank you
Hello
By way of introduction, I have but a single question that involves a stereo board amp I want to use in bridge mode (BTL). The board/chip is a TDA7498 and info on which jumpers config for bridge mode and which output to use is very scarce. I will start a new thread elsewhere when I can, if necessary. Thanks.
Scott T.
Completed Amiga variation
Sharing pics of my build. They’re Paul Carmody’s Amigas built as bookshelves (baffle width, drivers, crossover per the design). I lost my notes for whose cabinet I copied but they’re .5 cubic foot with 2” by 5” port.
The cabs are 3/4” MDF with quarter sawn khaya veneer in a pattern inspired by this webpage…https://woodworkersinstitute.com/the-sunburst-burnett-table/
Plan A for aesthetics of the cabinets was having the burst from one corner of the baffle only with the rest painted gloss black. When my wife saw the test panel I made, she challenged me to step it up. Im happy I did. I’m not an experienced builder and this is my first try at veneer work. The finish is danish oil and lacquer.
Logan from Canada (Yet sadly, not Wolverine)
Howdy folks! Absolute newbie here, just starting into the hobby and still very much learning.
I gotta’ say, audiophiles are both incredibly helpful with their deep knowledge of this world — and simultaneously caused me untold headaches as I tried to pick up equipment! Haha
It was an odyssey and forgive me if any of this is completely incorrect, these were just what I was seeing along the way:
I started out wanting an all-in-one player, thinking there would be quality options and otherwise… only to find out that pretty much anything with a built-in speaker was going to cause playback issues. Learned something right off the bat!
I next switched gears to a ‘set’, a turntable with separate speakers included, only to be scared off by people saying that the quality of all of these components would usually be more than lacklustre.
Ooookay, moving on, I switched to trying to look for a decent budget manual turntable — while trying to keep the budget not far off from my original all-in-one estimates — only to find that it was recommended by many posters, resources, etc for newbies to stick to fully automatic turntables until they get their sea legs.
So I narrowed it down to the usual suspects of Audio-Technica and Sony, and eventually even hit buy on the entry-level automatic Sony option. But something felt off, couldn’t say what, so I cancelled the order (I very rarely get buyers remorse so I took it as a sign).
Started doing a bit more digging and was finding a lot of ‘You’ll want to upgrade in months if you go with either of the above. The sound is going to be noticeably inferior even to a layman’ — and also that modern automatics tend to be more prone to failure because there’s more mechanics at play. Okay. Jeez. So where do I go from here, I thought?
That’s when I honed in on ‘modern’. Started researching why time and time again people kept saying they preferred the vintage stuff to modern, and that to get the same sound that even entry level vintage pieces provided often required extremely high end modern equipment. That things were built better because of the mass proliferation and competition of the turntable market in decades past.
From here I started digging into vintage Technics, found them to be reputable, reliable, and have longevity — and discovered linear tracking along the way.
After doing as much of a pre-deep dive as I could for my first turntable I ultimately decided on going the vintage automatic, linear tracking, direct drive route! Vintage build quality with new user simplicity — plus my wife would be comfortable with it as well.
I picked up a Technics SL-Q5 for $95 Canadian (around $65 USD)— vintage turntables are a little harder to find in Canada due to a smaller population and thus smaller collectors circle. It’s a bit grimy but I love the 80s styling abd it (mostly) seems to function properly, though I’m here to work through some potential issues.
And now I’m here to solicit a little guidance from people who know this technology far better than I!
Transmission Line vs. Sealed enclosure
I always understand that the sealed enclosure has a better transient response than the vented enclosure and may be in the top position compared to other enclosure types.
Recently, my friend, who is a fan of the transmission line system, told me that the TL gives overall better performance than the sealed enclosure. He described that the TL won't produce any emphasis on the bass like the sealed system, no matter how well designed it is, and the TL gives a better transient response.
Unfortunately, when I tried reading Vance Dickason's cookbook, there was little information in the TL chapter compared to the sealed and vented chapters.
All in all, Is my friend correct?
I'm looking for the Peter Gunn XO schematic for my MG-12
I've had a pair of Magnepan MG-12 sitting here for over a year. I have to redo the goo holding down the wires on the right panel because I'm getting some buzz out of it on bass-heavy material. While I have it apart I'm going to redo the XO and probably set them in wood frames while I'm at it, basically do the entire Peter Gunn approach. I found his original XO schematic posted on the IA/MUG forum, which was based on the SMGa. However, many of the Magnepan models had parts selected to tailor the crossover point to that particular panel, and of course the PG parts list was an ever evolving work in progress. Also, I'd like to get a clarification on the below diagram because it doesn't make sense:
First, why is the panel on the left shown as "right speaker" and vice versa? I suspect it has to do with flipping the panels but I still can't get my brain to understand it. Also, where is the resistor for the tweeter? PG quite clearly talked about using a single resistor there.
If anyone has a recent schematic and parts list appropriate to my panels please DM me.
The diyAudio Firstwatt F6
After a quick blessing from our technical, spiritual, and menu advisor, Nelson Pass, I am glad to present the preliminary discution for the diyAudio Mosfet F6.
Cool, huh? 🙂 This is made for IRFP420, or a similar Mosfet that has a Vgs in the 4V range. This is a beautifully simple amplifier!
Member Didiet78 has done some preliminary layout, (Thanks a million! It looks wonderful!!) this is the current thinking - 2 PCB, a left and a right, in order to keep the input transformer as far back as possible on both sides, and to have the Mosfet mounted low on the heatsink. The PCB will be designed to only mount the specified Jensen transformer, but I'll look into the possibility of a second set of pads, if possible, to mount a Lundhal or something... No promises.
The diyAudio store is also looking into stocking the transformers, which would make the whole process quite easy.
The other consideration in this project is the PSU, by which a shielded transformer is going to be very necessary, mounted as far from the input transformer as possible, and possible in a screening can as well. Or, of course, a separate box for transformer, diodes and first capacitor bank. Other than that, everything is straightforward. The diode, cap and resistor bank are the 'Firstwatt vernacular', I.E., look at any Firstwatt amp and use that PSU. The diyAudio PSUv3 boards will work beautifully, as will many other PCB.
The floor is open for discussion. 😀
Alpha Nirvana 39W SE Class A Amplifier GB
This is the Group Buy and Build thread for the Alpha Nirvana 39W SE Class A amplifier designed by AKSA. The technical discussion thread is here:
Alpha Nirvana 39w 8ohm Class A Amp
PCBs:
795976d1574122101-alpha-nirvana-39w-8ohm-class-amp-0b1b27aa-1350-49e2-a594-304e256b0462-jpeg
Production ones will be 2mm thick, 2oz Cu, ENIG gold finish, and Blue solder mask.
Amp module looks like this assembled:
797233d1574584334-alpha-nirvana-39w-8ohm-class-amp-build-prototype-completed-main-01-jpg
Includes helper snubber boards to allow remote mounting of MOSFETs for flexibility and ease of installation by decoupling the installation of the PCB and the MOSFETs:
797481d1574673293-alpha-nirvana-39w-8ohm-class-amp-sound-00-jpg
Latest Schematics and BOM will be updated soon, but current version (very close to final) is below:
I recommend use of these Fairchild MOSFETs (higher power rating than IRFP's):
FQA40N25 ON Semiconductor / Fairchild | Mouser
FQA36P15 ON Semiconductor / Fairchild | Mouser
The SLB PSU is also highly recommended - proven to work with single SLB and Antek 600VA 24v (AN-6224) trafo. Should work as dual monoblock with dual SLB and Antek 300VA 24v trafos (or equivalent). Also, a ready to run (RTR) solid state relay (SSR) DC protection is highly recommended to prevent turn on thump and provide safety net for your speakers should something fail.
Also tested to work on DIYA Store Dissipante 4Ux300mm chassis. Board is UMS compliant and I did not have to drill and tap a single hole on my UMS heatsink. Chassis temp is 57C at hottest point in 20C ambient. A 5Ux400mm would be much more generous and allow higher bias current.
Pre-Orders are now being taken in my Etsy shop for the GB.
Pricing is $37ea (includes pair of snubber boards - which cost almost as much as the PCB, hence the higher price). Thus, a stereo pair requires two boards. Free shipping in USA. Etsy calculated shipping elsewhere - circa $23 via tracked and insured USPS First Class mail.
If you place a pre-order, please add your name to a running list below with name, qnty, country. Thanks!
A huge thank you to Hugh (AKSA) for the design and JPS64 for the superb professional layout.
Here is the schematic of my amp "AS-BUILT". These values should work and clears up any ambiguous locations where multiple values are possible.
799467d1575397209-alpha-nirvana-39w-8ohm-class-amp-proto-schematic-built-dec-3-2019-jpg
Schematic of snubber boards:
802740d1576585812-alpha-nirvana-39w-8ohm-class-amp-5783c1a2-a042-4257-b3bc-b51a85b88505-jpeg
Edit Dec 26, 2019: AndyR has put together a nicely annotated BOM for both the 8ohm and 4ohm versions here:
Edit June 13, 2020: note that the feedback resistor R126 and R124 could 1% metal thin film or hand-matched carbon film as 1% not available at reasonable price. This needs to be done to get the same gain from left and right channel. It’s more important that they are matched left and right and not for absolute value. Also note that metal oxide thick film should not be used (dominant H3 and high THD). Do not use carbon composition - that is an error in the BOM. Sorry about that. Carbon film will have a slightly higher THD but more H2 vs H3. Metal thin film will have lower THD but relative H3 will be closer to H2 but H2 still dominant. Safest bet is use 0.5% metal thin film for these 2 resistors. But I personally like the carbon vs metal thin film.
Edit Feb 7, 2020: Pin diagram for Molex quick connects to MOSFETs
815078d1581102749-alpha-nirvana-39w-se-class-amplifier-gb-alpha-nirvana-molex-pinout-jpg
Edit Mar 11. 2020: helpful pin diagram for MOSFETs
824010d1583864664-alpha-nirvana-39w-8ohm-class-amp-a_nirvana-png
Edit Apr 24, 2020 - Dual Monoblock Connection Diagram if using SLB PSU's:
837360d1587747684-alpha-nirvana-39w-8ohm-class-amp-a190389f-cdd0-45c7-8d35-354511cdef86-jpeg
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,809
Members
7,889,258
Messages
Filter
Forum Statistics
Threads
406,283
Messages
7,889,258
Members
507,809
Latest member
ellingboe
