Piezo speaker amplified for long distance (50-70m)
- By Alarm
- Planars & Exotics
- 6 Replies
Hello !
I am interested in a small diy solution in order to transmit a high frequency sound to a long distance (approx. 50-70m).
My first thought was, well that is not going to be that hard, you have a good amplifier and speakers, find an app that creates a 20-25khz signal and done (yes, as others in here, i try to solve a dog barking issue unfortunately), but that seems not to be the case.
Reading several threads here, i found out that my solution are not normal coil speakers but piezos in combination with a ultrasonic generator (like Kemo M048N Ultrasonic Generator) . As my knowledge on electronics is really limited, except of the basics about speakers/amps wattage/impedance etc, i got lost in the information found here. Like the need of a resistor or capacitor that i read in some topics. On this topic i would like your help. Allow me to ask a few things and excuse my ignorance on this topic.
1) I got an old 2x100 Watt 4ohm amplifier. If i would connect the signal generator and the correct piezo speaker on this amplifier, would i end up with the results i want or i will fry my amp?
2) If the first option with my amplifier is not possible, what is alternative simple solution for this purpose ? How else can i drive the piezo speakers to output in such high volumes ?
3) What specs to look on the piezo speakers for this scenario? Any recommendations ?
4) Is the Kemo M048N Ultrasonic Generator fine to create those frequencies ?
If possible, give me some details of what i will need after all to buy. Is there a simple explanation in this forum of how to connect all those components together? This would be really helpful.
Thank you!
Thank you!
