Motor run capacitor??
Hey guys.
I have a really good bench grinder an old one that is robust and well built as they are back in the old days haha.
The capacitor has let go. Now the grinder has no centrifugal switch so I’m assuming it needs a motor "run" capacitor NOT a start up capacitor as it has no centrifugal switch so I guess the capacitor is in circuit all the time. I found this cap in my draws and my question is: is this the type I need? And how do I know?
The photo is the one on the left is the old one and the right is the new one I have.
I just want to make sure as 240v can be lethal plus an exploding cap is definitely not what you need!!!
Cheers
FS: Legendary Paravicini The Head TX-4 SUT
Sadly, but I am selling my Paravicini The Head TX-4. It is in very nice condition, with very small signs of usage, but considering it's age I would consider it normal.
I've been using it for many years with great pleasure and I hope it will get into good hands.
It's a legendary SUT with magnificent sound. According to my best knowledge only 200 units were made, this is No.28.
They show up for sale very rarely so now it is your opportunity to get one.
Item is located in Budapest (Hungary) and I am happy to ship it internationally. I will pack it very carefully.
Asking price: EUR 1.650 including shipping
(I am also open for best offers)
If you are interested, please send me a PM.
Raspberry Streamer Hifi
Hi everyone, I'm new to the forum and this is my first post ever.
I apologize in advance for the long post.
As a budget-conscious audiophile, I decided last year to assemble a budget-wise streamer
but of quality, based on Raspberry.
I already had a stereo hifi system composed of:
- Advance Acoustic X-i60 amplifier
- Totem Acoustic Mite speakers
The whole system is inserted in IKEA cubes hanging on the wall and suspended 1.5 meters above the ground.
So I assembled the streamer with Raspberry like this:
- Raspberry PI 3 B +
- Official Display Touchscreen 7 ’’
- SmartPi Touch 2 Case
- AUDIOPHONICS Digipi + PRO Digital interface WM8804
- QED Performance Digital Coaxial Audio Cable
- LEICKE power supply 20W 5V 4A
- SanDisk microsd 16 GB
- USB LED to control the shutdown
- Volume as software (2.779 so far)
[240 euros in total]
The streamer connects to my amplifier's DAC [the Cirrus Logic CS8416 chip (24 bit 192 kHz) is associated with a CS4344 DAC (24 bit 192 kHz), signal filtering is guaranteed, for the CS4344, by a filter organized around to the operational amplifiers NJM4558 of the manufacturer New Japan Radio Company] via the aforementioned coaxial cable.
After a few months of listening to webradio and Spotify, I am very happy with the purchase.
Some things have happened, however, that push me to an upgrade.
While using the touch display and starting the system, Volumio signaled me an error of "Under-voltage detected!" and a lightning bolt image appeared in the top-right corner of the screen.
I search on the web and I have identified a temporary solution by adopting the CRAAP settings mentioned here:
Archimago's Musings: MUSINGS: Raspberry Pi 3 B+ "Touch" Optimizations; CRAAP Settings, and the "Extremus" Filter Setting.
# Archimago's CRAAP Pi 3 B + Settings ...
arm_freq = 1000
sdram_freq = 500
core_freq = 400
gpu_freq = 300
over_voltage = -3
over_voltage_sdram = -3
# Force max current to USB 0 = OFF (600mA) 1 = ON (1.2A)
max_usb_current = 0
in this way the raspberry is weakened to offer a better sound and the error has never occurred again.
However, I realize that it is necessary to offer adequate power both to the display and to the raspberry plus the Digi HAT in a case suitable for the rest of the hifi system. Finally, I realized the usefulness of a power button that allows me to easily switch the streamer on / off.
I decided to write here, first of all because my skills in electronics and assembly were exhausted with the construction of the first streamer (which is practically child's play, everything is ready for use!) And because I believe that a DYI solution is the most economically sustainable. In recent months I have searched a lot and the idea that I made of the future streamer could be very close to an approach of this type: (I specify that I would like to keep as many pieces as possible made in the first purchase)
Raspberry Pi Hi-Fi Audio Streamer With Touchscreen Control and Max2Play : 9 Steps - Instructables
I created a render of what I imagine:
in the front side the touch display, inserted in a ventilated rectangular case, the power button on one side, behind the coaxial socket and the LAN socket, in addition to the power socket of a toroidal linear power supply, a small on / off switch; inside the raspberry, the digi HAT, the linear power supply, possibly all located on the bottom of the case, to avoid extension cables.
My main goal is to get the best possible audio quality with the least expense, in the simplest way possible.
The environment in which the streamer must be inserted is above the current amplifier, which heats up a lot, so the case will have to take up as little space as possible. I attach photos. I specify that it is an IKEA cube suspended and affixed to the wall. The maximum dimensions of the environment are 43 cm wide, 28 cm deep (the same depth as the amplifier), 11 cm high. Considering that I would like to be able to take advantage of the support base of the SmartPi Touch, 18 cm wide, a possible case could be 22x28x10.
As I said, I read a lot and there are beautiful DIY projects that I found, but with few details on the method, made by people who are experts in electronics, welding, carpentry etc:
HifiBerry streamer in a classic audio case | HiFiBerry
Music Server….my way | Sound&Music Blog
HiFi Streamer : Build thread - Diy Volumio Projects - Volumio
https://theartofsound.net/forum/showthread.php?62839-Audiophonics-RaspTouch-case-with-DigiOne
Best way to lay out multiple power supplies (Raspberry streamer)
On the topic "best linear power supply for Raspberry" there are a large number of links and tips:
https://community.volumio.org/t/psu-for-raspberry-3/10012/3
https://musicboxit.wordpress.com/2019/04/24/alimentatore-lineare-raspberry/
https://www.dimdim.gr/2018/03/linear-power-supply-for-the-raspberry-pi-is-it-worth-it/
http://www.raspyfi.com/the-best-raspberry-pi-power-supply/
I have a keen eye on the wallet so I have found some PSU from China that could be right for me, honestly I don't understand anything about the differences:
https://www.ebay.it/itm/Assemble-5V...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
https://it.aliexpress.com/item/3289...88#3325#6_668#2846#8108#112_668#2717#7565#748
(which is the same but without the connectors)
https://www.ebay.it/itm/HiFi-Walt-J...784995?hash=item594102b1e3:g:QEgAAOSwGTheBwAt
I read that it would be preferable to avoid using the USB connectors present in the first link and to use the stripped cables, but I think it is necessary to carry out soldering. This is definitely the part I ignore most. Do I need something else for power connection?
For the power button I would have found this solution, the RemotePi (only the version for PI 4 is available from their website):
https://www.msldigital.com/collecti...s/remotepi-board-for-pi-4-external-ir-and-led
that together with an extension cable of the GPIO and a ready-made LED button should allow me without soldering anything to have the button together with the HAT (I asked by email directly to them for confirmation, and they said that the RemotePi can power all together correctly with the USB-C socket after the GPIO 18 -> GPIO 17 modification has been done on the RemotePi Board, made by them before purchase).
This solution is particularly convenient, as there is a plugin for Volumio that deals with the software side for the implementation of the various scripts
https://www.msldigital.com/collecti...nated-pushbutton-for-remotepi-board-for-pi-4b
https://www.msldigital.com/collections/all-products/products/gpio-adapter
https://www.msldigital.com/pages/remotepi-board-compatibility-matrix
finally this could be an alternative to RemotePi, but perhaps more complex:
https://www.audiophonics.fr/en/raspberry-pi-and-other-sbc-accessories/audiophonics-pi-spc-ii-power-management-power-supply-for-raspberry-pi-p-11504.html
So let's come to some technical questions with a premise: I have no skills or equipment in soldering, in advanced electronics, in advanced modding of the Raspberry. I am a normal user who has many questions but little experience!
Going into more detail, what I understood is that it would be preferable to separate the power supply of the Raspberry and the HAT, acting on the single pins of the raspberry.
But with my current HAT, fully welded, how can you get such a thing?
Do you think the linked power supplies are valid for what I try to achieve?
What else should I take into organize everything? Shield the various wires inside the case? With what?
But I realized that you don't need a reckocler (like Kali) for the HAT digi:
https://support.hifiberry.com/hc/en-us/community/posts/207749389-HiFiBerry-Digi-Pro-beta-test?page=5
Coming to the case, obviously I am not able to handle aluminum in an advanced way. In your opinion, could wood be a valid alternative? I have seen many projects in this regard, but almost everything involved an aluminum base and a wooden case around it.
I close by saying that I know people who could help me both for the advanced electronic part and for the construction of the case (I hope in wood). I would like to receive advice if the road I am traveling on is right. Maybe someone after me will find it useful.
Thanks!
Greetings from Italy!
Gianluca
Philips 22-AH309 DC amp-interesting antisaturation circuit
Today i found this amp in a not so great state, but it was about 3 dollars so i couldn't resist.Looking at its schematic i saw some interesting features as being a dc amp its thermal stability is important, but the things that set this thing apart in my limited view were the first two antisaturation diodes which were distributed in the first two stages instead of being placed in the first stage.Can anyone shed a more comprehensive theoretical light over this circuit?
Sony xm-d1000pf
Having an issue with this amp pulling excessive current. I have my power supply set to limit of 15 amps. When I originally got this amp it only went in protect when applying the remote and it never pulled any current. I replaced the in put and output transistors I got the amp to power up out of protect if I remove the two legs of each rectifier if I connect the two legs of each rectifier the amp Powers up it doesn't go into protect but it pulls a tremendous amount of current and my power supply drops from 14.7 to 8.9 at 14 amps. With the rectifiers removed the amp idles only at 1 amp just fine. If I connect the speaker It don't get sounds from the sub nor does the amps change. Any idea where I need to look at? Thanks
Us amps 3 channel
Just acquired a us amp 3 channel? Not sure the model amazed by the lack of information. Any help is appreciated on identifying it.
Currently has output but only when the rcas are plugged into 1 of the sets of input (not sure of both are inputs yet but I believe 1 is a pass thru)
1 channel had no output the other 2 are low medium range (not as loud as i would expect)
Altering Attenuator Advice
I have a 4w Vox AC4TV, which I'm trying to bring further down in volume than it already is by patching an attenuator in between the amp and its speaker. I mistakenly bought a 8ohm/15w TubeJuice Attenuator (which I think have been discontinued) when I should have got something rated for the amp's 16ohms. It actually works ok but I've got hold of a 16ohm/100w L-Pad and I'm planning to put it inside the TubeJuice enclosure.
I thought it would be a straight swap for the L-Pad in the TubeJuice but it having opened it up it looks to me like it operates on a different set of components.
Instead of an L-Pad I think it has a potentiometer (its part number comes up as the component in the screengrab) attached to two (4ohm?) resistors. Is that correct? Is that another definition of 'L-Pad'? Is this a 'better' attentuator than an L-Pad?
Can you have a look and tell me if all I need to do is swap in the L-Pad and detach the resistors?
Ericcson SMPS
Gooday all,
I have got two of these units, both had a lot of dry joints that I have re flowed. They are adjustable between 45-54VDC. One is working OK, the other cannot adjust at all and sits on 36VDC on the output. Might be some more dry joints or a faulty adjuster. There are two pots, one is for voltage and the other sits next to a CD4069ube chip. I do not know what it adjusts but I'm leaving them alone. Any idea what the VA of these units might be and are they usable for diy amplifiers.I have not worked on smps's before, I know there are high voltages and to discharge the caps before working on them.🙂 Help appreciated !
High pass filter with subwoofer
Hello. This is my first post here, after years of being a member.
I am trying to get a handle on the pros and cons of the following scenarios when running "bookshelf" speakers (6 inch woofer+tweeter) and a subwoofer:
1. Subwoofer with built-in high pass filter,
2. High pass filter or "bass blocker" between the power amp and the speakers
3. High pass filter between the amp and preamp, with the subwoofer still getting a full range signal.
I am interested in advantages and disadvantages (and implied considerations) of each approach, but with a particular interest in whether or not there is a difference in the power demand on the main amp.
I have seen debates in other forums as to whether or not a high pass filter inserted between the main power amp and the primary speakers significantly changes the demand on the power amp, with some arguing that this is only the case when the filter is ahead of the power amp and others arguing that the effect on the power amp is the same in all of the three scenarios.
I guess it comes down to whether or not the power amp has to produce a full range signal when the filter is implemented downstream from it (vs before it)?
Thanks in advance.
EDIT: To clarify, I am referring to a passive filter in all scenarios. Also, unless I am mistaken, scenarios 1 and 2 are effectively the same.
DAC for Raspberry Pi
Hello,
I have developed an new dac for the raspberry pi. About a year ago I built a big version based on the PCM1794 with separate power supplies and I'm still pleased with it. Btw. I still like the BurrBrown sound signature, if there is any, and I prefer it over the newer 32bit dacs. In my ears its more musically and real.
I was wondering how small it can be without lots of compromises in sound quality and started developing a hat dac for the raspi. I chosed the PCM1793 with I had good results in the past. The schematic is nearly the same like the datasheet, except a few changes in the analog filter stage. Here the OPA1642 with Jfet inputs gave the best in my ears. Finally it is ready and with some changes in resistors and capacitors its damn near on his big brother.
A separate power supply is necessary, I'm using linear power supplies for the raspberry and the dac. Other tries with one supply for all failed. So an external power supply for the dac is a must for proper HiFi.
As player software I'm using Moode player. This all is running on a Raspi3.
What have you built -tried for traditional Karlson in smaller sizes ?
I have a "K5" built by a skilled long-distance friend, scaled from the 1960's Karlson K8, and a scrap "K6" made quickly with my unskilled hands
XRK971 has used 0.43 scale K15.
The Karlsonator and XRK971's "XKi" alignments have dominated the small K-coupler arena.
Perhaps there's still use for little Karlson couplers (most likely supplemented with a little subwoofer)
If you tried one - what driver did you employ? What was your design method? How did it turn out?
6J6 and it's history
Currently I'm reading George Dyson's book Turing's Cathedral in it's 2012 German edition. Chapter 7 describes the development of the IAS machine, an early computer, driven by 3474 vacuum tubes. Among them were 1979 pc. of 6J6 tubes, configured as flipflops. John von Neumann (Johann Neumann von Margittai, as he was Hungarian origin) and his co-designers bought these tubes from WWII military surplus, as Dyson says.
The 6J6 caught my interest, as it has been my very first contact with tube circuitry in my early youth. It's got a rather unusual construction: It has a rectangular cathode sleeve, both triodes were places at the the long sides of this rectangle each. Does anyone know the application(s) it has originally been designed for? And, as the book and some other informations I got gave me some thinking, am I right in my assumption that this tube was the first one with the 7-pin B7G socket, and that B7G tubes in general were preceeding the B9A Noval tubes?
Best egards!
All-in-one portable Bogen Challenger PA
Just scored this guy at the flea market for a very, very fair price. It's a tube-powered Challenger 35A and a matching set of L123C-A speakers ... But the speakers open up like a clamshell and nestle the head inside for transport! It's even got a couple (broken) handles to carry it around.
The seller had already turned it on, so I figured it couldn't do any more damage to run it a bit before I opened it up. As expected, there's a little 60Hz hum (the power supply is a half-wave doubler), but it works! The aux input is working great; the hi-Z mic inputs don't do anything, so I figure the 6EU7 is probably dead. I'm going to rewire that socket for 6N2P, since I've got a pile of those.
Anyway, I've never seen anything like this, and I figured I'd share. I'll probably leave it stock and plug an amp sim pedal into it, at least for now. If I end up keeping it, I may swap the 7868s for something a little more friendly.
Oh, and it came with a Shure 585SA, an AKG D109 lavalier, and a little Realistic lavalier that uses a 7V button battery. Not a bad haul!
Analog audio doubled up with TV input?
Sorry, just joined as I am looking for home theatre/stereo answer. If there is a better group in this forum, please redirect me.
Should/could I double up the input from an amplified analog audio signal (from a kareoke mike output) with the analog output from my TV cable box to put back into a single HMDI input in the home theater amp.
That is, I would use a rca Y-cable to combine the two analog signals and then put into a simple converter box from Amazon to get a single HDMI output to the receiver.
This is so I can add a miked sound to the kareoke channel from the TV.
Or will I push some unwanted signal/current back to the TV box?
Already have great kareoke stand alone, but would like to add mike this way to TV too.
Silly question? Blame my lack of experience.
First Shot with a Phono Stage
Hello Everyone,
for my Preamp Project (https://www.diyaudio.com/forums/analog-line-level/359465-time-preamp.html) I've decided to start with the design of the phono stage. I've designed this one based loosely on an old circuit I found at my dad's electronics workshop and some guessed knowledge 🙂
Before I buy components and try to build it, I'd like to hear your opinion. At the moment, it's just a MM stage, I'm planning on adding an MC preamp too.
I'll attach a picture and the Spice File of the schematic, I'm happy to use your comments for improvement 🙂
Lukas
EDIT: The OP U4 is just outputting a reverse RIAA curve for testing purposes.
  • PhonoPre.asc
    PhonoPre.asc
ERC Stereo Amplifier 120 Watts - any feedback?
Hi all,
Just got an ERC stereo amplifier for 25€..
From a quick search couldn't find anything in net.
It's a 2n3055 based amplifier with BD139 & BD140.
Anyone got any feedback? Seems quite good construction with module pcbs.
Some photos attached.
Thank you
Hi there earthlings
Hellooo, I've just arrived here following links as I poked around tintyweb to do with Rauch DVT 250 S amps and of course I've got very sidetracked. This is one of the most interesting forums I've encountered and I'm very old. I'm interested in all of it, always have been. Learn something every day, teach something every day and help someone every day. They are the best days. I fall somewhere in the middle of the quagmire of musician, sound engineer, technician, experimental artist, analogue and digital media, interactive installations and stuff, taught stuff at uni and still always learning stuff. They call me crazy, I get sidetracked a lot and don't make much sense a lot of the time and I'm a bit of a tosser too.. I try not to be. Hmmn, seems I've gone off on one already. I'll just blend in as best as I can, like the sound engineer I am. Wearing black, at the back... I'm open to anything, I live for this whole sound and music thing. It's in my blood and it won't let me go. Looking forward to having some very interesting inspirations from
you all and if I can give back a little then it's all good. So hello....
Headphone Amplifier
To sell a new built Headphone amplifier, based upon the very good design by Per Anders Sjostrom.
Fully working unit, with RCA line in.
Alps Blue volume control.
Neutrik plugs all around.
I will supply the power cable.
Price 225€ plus Shipping (please consult)
I accept Paypal.
Technics Vintage Amplifier, Compact Disc and Twin Cassette Deck
Hi there, we have the following vintage items which we would like to sell. Wanted to get your thoughts on possible demand and an idea of fair pricing...? (see attached photos). Many thanks!
i) Technics Stereo Integrated Amplifier, Class AA (SU-V50) - in working order
ii) Technics Compact Disc Player (SL-PG500A) - in working order
iii) Technics Stereo Double Cassette Deck (RS-B66W) - in working order except one cassette player has slight issue
iv) KEF C Series (C40 Type: SP3054) Two Floor Speakers with stands - in working order
Tube Power Transformer
To sell 1 Power Transformer with the following charateristics:
Primary: 230 VAC
Secondaries:
1x250VAC 0,2A
1x6,3VAC 5A
1x12VAC 1A
The transformer as been slightly used, but is in like new condition.
Price 70€ + Shipping (please consult).
I accept Paypal.
SMD TDA1541 board... "analysis"
First: No discussions about non-oversampling... Thats another playground... I do it (with JLSounds I2S board).
I fancied one of these new TDA1541 boards with all-around TPS7xxxxx V-regs.
Set it up with just some minor changes:
- NE5534 => OPA1611
- OP42 => ADA4627-1
- replaced all signal caps with WIMA MKPs (<2,5%)
- I/V resistors 1k8 => 1k3
nice crafted board all together, although there are some drawbacks:
- no i2s in-line resistors (typically 33-120Ohm)
- only coax SPDIF receiver
- gets hot, SAA7220 victim
SAA7220P/B #1988
Headphone amp is INA1620EVAL.
Beyerd. DT990PRO
Ebays TDA1387 adapter board with 4 chips sounds better than all my original TDA1541As (4pcs). That is what makes me think 😕
Amplifier PCB with 4 layers. Right method for signal GND and Pow GND
Im trying to make an amplifier with 4 layer PCB. Many reasons is that one Compliancy, second reduce noise and shorter trace lengths and shorter loops and loop area. Now I have a question is that how to have the ground plane.
Option one: I read it somewhere that to use complete ground place both signal and power ground as one plane.
Option two: Use star ground in one plane for signal and use another star in another plane as power ground and then join them using a 10ohm resistor in the coaxial of both. Stack as Power GND, signal, signal GND, signal.
use ground pour in the left over places of signal plane and then short it to signal ground in both the signal planes.
If anyone has got CE approval with low noise performance with 4 layer PCB please guide me on this aspect.
Help Identifying Tube Amps
Hello All,
Long time member of DiyAudio.com but a first time poster in the Tube/Valve Thread. I was gifted these mono block amplifiers years ago from an elderly gentleman that appreciated and shared my love for music and audio gear. I was told they are 15 watt, Class A push-pull. Based on Google searches they seem to be similar to Heathkit or Zenith kits, all point to point wiring, possibly from the 60’s. Although the chassis sizes are slightly different they both use the same EL34/6CA7 power tubes, rectifier and input/preamp tubes (although they do have different brand output transformers) so I’m assuming they’re just different versions or editions of the same design. I have all of the tubes they came with and a compliment of extras (all used) as well.
I’ve had these for over 10 years and had hoped to refurbish them and get them up and running but haven’t had the time, or any experience with tube gear. I have however built kits from the DIYAudio Store. Can someone tell me what they might be, and what they’re possibly worth? I’d like to sell them because I’m realizing I’ll never have time for them. From what I’ve gathered on line the Hammond Transformers (which are very heavy for their size) alone are “fairly” expensive on the used market.
Any help, advice and information would be greatly appreciated!
Exposure 3010S Bias adjustment
Hi All,
I have an Exposure 3010S integrated amplifier for a very long time now and I would like to adjust it's bias voltage.
I've sent an email to the manufacturer asking for the optimal bias setting but there is no response from him (customer service, hello????).
Does anyone can share it's service manual (if there is any) or knows the optimal bias setting?
DIY ported enclosure with Tang Bang W5-2143 FR driver vs Q Acoustics 3020i and 3090i
Project goal
To make well designed enclosures with full range drivers for LCR with drivers in the price range of USD150-200 for 3 drivers to use with Marantz NR1510 - 50W/channel @ 8ohm that match the general sound quality that one would get by using the branded Q Acoustics 3020i and 3090i combo and if possible supersede it.
Speaker driver
I've found Tang Bang W5-2143. Reason for choosing this driver is that its 30W @8 ohms, FR with phase plug and has good reviews especially for Mids tonal quality which I think should make it a good center speaker. Since it has a Qts of 0.38 ported enclosure is what I'm thinking. Using WinIsSD to design the enclosure. At the moment sealed Subwoofer to go with them is the plan.
Main question
In terms of tonal quality would a well designed DIY be at least be equal to if not better than the Q Acoustics ?
DIfferential pair transistors
Gents,
I need some help with acquiring reliable replacements transistors for the common pair of transistors - C3200 GR and A1268 GR when used as differential pairs.
I read through numerous threads and datasheets. I purchase at Mouser, most of what is recommended is either not available (either or/complimentary), the gain is way lower than the c3200/1268 pair, or the voltages are not high enough to be substituted in place of the 3200/1268 pair.
In the lanzar opti thread I repaired, it came close to having to replacing the differential pair, but the problem was solved prior to this. I have a couple more Korean amps that came in all utilizing 3200/1268 transistors. I haven't assessed them as yet as see what's required but I'd like to be prepared.
In other parts of the circuit I can work around them but thus far not the differential pair.
all help will be appreciated.
Cheap full range for small test cabinets
I'm looking for some cheapish drivers for testing purposes. (Building an amp) If I blow them I can just buy more and not cry too much. I think they should be 8ohm and rated to minimum 25-50 watts. I can build whatever cabinet is necessary.
I was thinking possibly 75mm - 100mm (3 or 4 inch) full range. It obviously doesn't need to sound hifi with flat extended responses, but when testing, music should sound reasonably like music.
Was hoping to get drivers for about $30 NZD each or less. Including freight. Or if any NZers know a source in NZ.
Any ideas.
From where can these transistors be bought?
I would like to buy some BD329 and BD330 transistors. I found a web-site based in Greece but, for some weird reason, it crashed while I was compiling my order. As this may be the result of a fake fraudulent site, I am very hesitant to order my parts from it. The site is radio741.com which is new to me.
The problem with myself ordering parts are postage prices. I live in Malta, an archipelago of very small islands about 60 miles south of Sicily, an Italian island. I would like to order from a supplier with reasonable postage costs. When I tried Mauser, I was dissuaded by its very costly postage.
Harman Kardon HK980 Cannot power ON
Hi dear members,
I need your help, about a problem with my HK980.
It worked flawlessly until yesterday.
I plugged in new speakers, the BW603, and plugged in the amplifier on power socket. The amplifier did not turn on, like usual, in standbuy mode - an orange light on the power on button, but a white light was turned on on the power button and the tone control button. The amplifier does not respond to commands, cannot be turned on, or turns off on the power on button, the display does not turn on. No ofcourse any sound.
Do you have any idea what that might be? Are the new speakers defective and caused damage to the amplifier?
unfortunately i don't have another amp at the moment to try the speakers.
do you have any idea what it might be, where to start checking? Should I measure the characteristic voltages at some points?
Power stage for piezo-crystal ultrasound transducer.
I need a power stage plus driver to power a piezo-crystal based ultrasound transducer. The operating frequency is 1MHz and the waveform is a square wave of a duty cycle of 25% to 80%.
My initial idea is to use the NE555 IC to generate the square wave at 1MHz, a buffer stage consisting of an emitter follower, and a driver stage consisting of an emitter follower like those usually used for audio amplifiers. The output stage is thought to consist of an NPN and PNP complimentary transistors.
Since, I never built such a circuit I am asking the more experienced to avoid difficult to foresee electronic pitfalls.
The ultrasound power output needs to be known. A formula to calculate the ultrasound power for a driving square wave would be very much helpful and is appreciated.
Need Guidance: High Power LCR Home Theatre Build (Crossover Components)
Hello Everyone,
I am working on a high power LCR speaker build.
The components I have chosen are as follows:
The crossover points are as follows:
Below are the frequency response curves in REW (var smoothing):
Plus I know the woofer is really bad 🙂
Below are the frequency response curves in XSim:
This is my first attempt at building a crossover based on measurements and I will need help. I am not taking impedance measurements for this project.
I had to manually trace the graphs using the pictures supplied in owners manual (using FPGraphTracer). Hence, before I start I wanted to check with you folks if there isn't anything crazy wrong with the frequency response graphs? I will also post the pictures next post.
Thank you in advance for your guidance and valuable feedback.
Cheers
Rotel RB-960BX - pop sound when turning on/off
Hello, I haven't found too much about this amp in the forums so I though I would ask. When turning my amp on, and when I turn it off, there is a little noise coming through the speakers. Almost like a scratchy pot, and I suspect it's capacitors. Otherwise it sounds great. Would this be more or less the power supply caps causing this or just something totally different? Attached is the service manual and I'm currently trying to find these power supply caps online.
Thanks in advance
OPA1656: THD vs. Rs
I want to drive a non-inverting OPA1656 from the wiper of a volume pot -- which means a range of source resistance for the OPA1656 from 0 to <del>Rpot/2<del> Rpot/4. TI has characterized the THD vs Rs for a lot of its recent devices, but alas not the OPA1656 (at least that I could find). There isn't enough info about the topology of the input stage either that could lead one to an educated guess.
Has anyone done any testing or have any other insight about what to expect when the part is driven from something on the order of 5kΩ to 12.5kΩ?
Designing cabinets for high Qts DIY drivers
Hello!
I'm a beginner in building speakers, but I have studied acoustics, and I have some woodworking skills, so I decided to design and build my own speakers from scratch.
I made the drivers (woofers, mids and tweeters) myself also. They don't sound horrible, but they have quite high Qts values. LIMP measurements gave the woofer Qts of something from 1.4 to 2, and Dayton DATS V2 gave 2.1. Usually speaker drivers have Qts much lower than that, and most speaker volume calculators and design tools cannot handle a value that high. I know I could maybe make some open baffle or onken speakers, but I don't want to, because those would have to be ridiculously large.
I have read from some other threads, that there is a few tricks to deal with this situation. I tried adding some acoustically resonant material (wool) behind the cone, on the back of the driver, and it really seemed to lower the measured Qts. Other possible solution would probably be some kind of leaky enclosure.
However, the problem is that I have no idea how big should the leaky enclosure be, so that it would dampen the Q just enough. And also, how much should it leak? Should I just add some small holes, or should I make big holes and stuff them with absorption materials?
Here is some parameters of the woofer (I think the mid driver and tweeter cabinets are probably much easier to design, so I wont include their specs):
Woofer:
d = 165 mm
Qts = 2.1
Fs = 39.4 Hz
Qes = 3.0
Qms = 7.3
Vas = 33 litres
After adding few layers of thin wool on the back of the driver the Qts dropped to 1.6 and Qms dropped to 3.5. Other parameters stayed mostly the same (sadly I forgot to measure the new Vas). I believe that a good layer of mineral wool would drop them even more. However, I don't know if it can also cause some other problems, I have not found much discussion on that.
I'm planning to high pass it from 80 Hz (to leave some room for a subwoofer) and low pass it at somewhere around 800 to 1000 Hz. Hence, the resonance at 39 Hz (if it stays there with the cabinet) would not even be on its range. However, I have no idea if the high Qts (which means that the system is underdamped...?) has some effect on the sound quality on other frequencies also. In other words, should I worry about the Qts if the resonance peak will be high pass filtered anyway, or is it still important to lower it some way?
The text is long and the problem is pretty unusual, but I really appreciate if you have any suggestions or opinions about this. I have invested so much time on making the drivers, that I don't want to waste all that effort by just making some random enclosure for them and hope for the best.
Rockford T1000-1bd eq card bypass
Working on a Rockford T1000-1bd (non CP), and found I had no signal going into the BD card (1325-52874) on Pin 1 (P401-A) of the back header. I checked and I had signal coming out of pin 9 (P200-I) on the front xover header and going into the EQ card on pin 9 (P301-I), but no signal coming out of EQ card on Pin 9 (P302-I) which goes to the BD card input.
I checked the LV + and - and found it pulled down to about +7 and -8 volts (should be about +-13V)
Pulled the EQ card and found I had a short from Pin 14 (S2) to pin 13 (V+) on the DG201BDY analog chip. With the card out my LV is back to +-13V.
I do not have a spare DG201BDY, so while I wait for one to get to me, how best can I jumper from the xover to the BD input, just a jumper wire, or should I use a capacitor? That way I can finish testing the amp (just in case I need to order anything else).
Thanks in advance.
Crazylogix
Self designed balanced output - running into problems
Hi All,
I have been trying to pick a balanced output stage design for my active crossover, and I haven't seen a ton of variety. I made up a test board with a 2 op amp Doug Self design using a single LM4562. When I tested it the THD+N was not good. 90db range. With such a simple design and quality opamp, I was expecting to be in the 110's.
When I look at the design, I'm seeing that it calls for 2 100uf capactiors. In order to find such a high value, I used bipolar electrolytics from nichion. Everything else is good quality surface mount components.
Are the caps likely my problem?
Are my expectations unrealstic?
Are there alternatives to electrolytics I should be looking at for such a large cap?
Am I screwing up something else?
Thanks!
How to find a short in transformer (korean 6k amp)
Hello mates
I'm repairing a big korean amplifier a 6k.
I've done a full rebuild on the PS section. New drivers, new irf3205 which are from reputable source - farnell, gate resistors, pull down resistors and etc.
The problem is that one of the bank, keeps driving the PS mosfets into short. Only this bank, as seen on the photo.
If there are no PS mosfets fitted in this bank, gate drive is good and strong, no problems.
As soon as I fit new FETS - excessive current and the 4 fets which are the one driving the problematic transformer are shorting out.
I've pulled out the transformer. PS section now works but the rail voltage are not correct due to the missing bank of ps section.
There are no solder bridges. I've pulled out the transformer and can't really see if there is a short without unwinding it (i don't think i'm capable of rewinding it).
Is there a way to check if the transformer is shorting out or not ? There is no short between the winds, but i suspect it is shorting into the core ? Any ideas ?
recommendations for a small form 2.1ch BT AMP board
guys, i'm chasing preferably a combined BT/Class D 2.1ch amp, which hs a small footprint.
if possible, one with a separate sub channel pot to adjust the output, i sort of cocked up on a small build i'm doing and would really benefit from an adjustable low pass filter\volume, my current setup has an inexpensive 2.1ch amp from Parts Express and a M28 Bluetooth chip from Banggood and i'm getting issues when the volume is up where it appears to be clipping. I'm wondering if it is linked to the DC Step down module, also having an issue with the CE65W i'm using as the 0.1ch sounding a bit average.
I tested it all using the below amp (which unfortunately is too big for this build. This amp lets you pick your low pass frequency and adjust the individual channel volume, which ended up sounding pretty good, just unfortunate i dont have the space or opening to use it now.
Zk-tb21 tpa3116d2 bluetooth 5.0 subwoofer amplifier board 50wx2+100w 2.1 channel power audio stereo bass amp Sale - Banggood.com
sorry for the longwinded question, but i would appreciate any help in finding something around that 50mmx50mm size roughly.
Elekit TU-8200R Stereo Tube Amp Kit
Hello All,
Hope all is well with everyone during this pandemic. I just joined the forum and this is my first post. I bought an Elekit TU-8200R Stereo Tube Amp Kit from TubeDepot online and should be getting it probably next week. This will be my first DIY tube amp kit. I like to listen to music and would like to get the best sound out of this Tube amplifier. My goal is to replace the stock 6L6GC and 12AU7 tubes and coupling capacitors. I need your recommendation to what brand of vacuum tubes is the best and coupling capacitors to get the best out of this amp also are there any other like resistors and electrolytic capacitors on this kit that I need to upgrade? The source I'll be using is the analog output of Bluesound Node 2i and EVGA Nu Audio sound card that has Burson V5i-D opamp and connect it to the 2 inputs of Elekit TU-8200R amplifier. Also what kind a speakers you recommend to pair it with this amp I only have an old Pioneer SP-BS21 bookshelf speaker. Your help and advice is greatly appreciated.
Jerry
Arm identification
Hi all - first time poster, long time lurker. I got a new (well, 1983) deck which has an arm with no name. The only markings I can spot are a 5 on the rear behind but not on the counterweight. Can anyone tell me what it is please, and maybe even a bit about it?
Thanks in advance.
QSC PL 238 vs Crest 8001
I am aware they're 2 different animals but for portability, although 8001 is cheaper used than PL I wish not to carry a boat anchor in my DJ setup. I was planning on using the Crest as from years ago before these lightweights were used in concerts and permanent installs, but my back is not the same as when I was 25 years old. I wish to use 2 x QSC PL amp used market for a full range and sub for my DJ rig (BFM 12 Omni Tallboy/ Double 2226 loaded diy sub). In comparison my question is the Crest give better bottom end and more ump than the PL. Can someone maybe give me a little education between these 2 amps.
The subs hp at 40Hz(40-100Hz sub). Thanks!😕
Experiences with external devices that keep voltage steady?
I get a split second voltage sag (aka brown-out) when my roof mounted air conditioner unit kicks in, which cuts the audio from my vintage Pioneer M-22 amp for a second. We've had the sag since we bought a new unit four year ago, and it's never switched anything off or cut out sound, but now I have this amp which is susceptible to power fluctuations.
Our air conditioner tech took a look, he said the compressor is drawing a lot of power when it first kicks in (which apparently isn't unusual) then stabilizes, so he's not surprised by the momentary sag. He recommended getting an electrician to look at the breaker panel and wiring (which are not old). Speaking to a few electricians on the phone, they all have different theories, and I'm reluctant to get into the expense of a wild goose chase if this ultimately can't be fixed?
It's worth mentioning that it's a Japanese amp, so I'm using a step-down converter to feed it 100v. I could dump the converter if I had a variable device I could just set to 100v.
I know the ideal solution would be something like a PS Audio Power station (AC regenerator), but I don't want to spend a few grand. I'd rather spend a couple of hundred, tops.
There are uninterruptible power supplies, which are often used in the computer arena (kicks in a battery if the voltage is lowered) but I don't know how well that would get along with a 30w amplifier?
There are also variacs, constant voltage transformers and servo transformers, but I've no idea if they're ideal for this application? I hear CVTs are noisy.
Digital Recreation of a Big PA System
Hi community.
I'm a composer, producer & sound-obsessed "mastering engineer".
I'm developing a particular mastering style where I'm essentially trying to recreate the sound of a big PA system, but at a digital level. Please let me explain:
So my top reference for how I want music to sound is the way I heard it through different systems in a few nightclubs mainly, but also some other speakers I've come across. I always paid attention to the characteristics of the sound and tried to make as many mental notes about it as I could. What I'm trying to do now is to recreate those characteristics as close as possible but within a digital audio workstation, that is by splitting the signal into different bands and filtering/eqing each of them as if they were a subwoofer, woofer, tweeter, etc.
Now, I understand this is something I could never truly recreate because of the simple fact that the sound wouldn't be coming out of that actual speaker. I also understand in the process I'm limited by my own listening environment, in this case KRK Rokit 8 inch studio monitors in a 3x7 metre apartment.
Still, I'm on this obsessive mission to fully design a chain of separate driver emulators and in the process somewhat recreate how it would sound (to me) through this ideal big PA system.
It's driving me insane. Not only because I don't know exactly how these ideal speaker drivers would be set up, their frequency ranges, crossovers, etc. but also because I don't know how to emulate the same filtering they have. I've researched and in some cases guessed regions in the frequency spectrum where the bands may be split, but it's the filtering which is driving me the craziest. The plugins I know and have tried alter the sound in a way I don't want. They are not truly customizable as they don't have the curves you would find in a speaker crossover but most importantly they are not truly clean, they squash the sound, they create pressure instead of liberating it, they just don't do what I want them to do basically...
So my first question to you all is if you know of a software that's designed to create speakers, with filters, ranges, crossovers, etc. but that actually processes an audio signal in the software itself, a digital rendering of what the speaker setup would be later on.
I know this may not make much sense, but it could also be a plugin that you know works in the "same" way a physical crossover in a loudspeaker would, not necessarily one specifically designed for building speakers.
The second question would be if you know of a good list with all the values: frequency ranges, crossover points, slopes, etc. for a big PA system that sounds very clean, very airy, but beautifully full and immersive. A system that blasts the sound at you but never tires your ears, that plays back the bass in your face & yet constantly breathes and feels like a soft cushiony mattress under your feet, that plays back shimmery highs that never sound strident. There's never a buildup of energy, no matter what. This is somewhat the description I can think of for this ideal system I want to recreate.
A third question: recently I came to the conclusion that in these systems I liked some parts of the frequency spectrum felt somewhat removed, especially around 200hz. It's the only way I found to create some of this breathiness I mentioned. Still, limited by the way plugins work I can't seem to find the perfect spot, and thought I'd ask if anyone has any info on this point specifically.
Well, thank you so much for reading & for whatever answers you may have. Also, please let me know if I should post this in another section 🙂
David
Jbl extreme 2 joined in stereo (wired)
Hey folks, its been a very long time since i have been here mainly due to lack of spare time...
Just wanted an honest opinion on something, now when i lived in a house i had a set of bowers and wilkins towers with a rega amp and was very happy with the sound they produced, a change of circumstance now means i happily live on a houseboat.
My question is due to the obvious power and space constraints i had to shed the previous setup and i now own a pair of jbl extreme 2,s which i chose after many reviews and listening to many portable speakers and for the money i felt they had the most natural sound and decent power, you can pair them in stereo if you own two or party mode if you have more (i do have two of the jbl charge 3 also but we will focus on the stereo arrangement of the two bigger ones).
One important thing to note is the extreme 1 is very different in sound and is tuned as a party speaker with high bass emphasis, so if you have only heard this version please dont compare the two when considering my question, the extreme 2 is tuned for accuracy as much as possible and sounds pretty flat to me.
I wanted stereo with lossless so i made a cable to replicate what the wireless stereo mode does (left and right on each speaker driving the LL and RR respectively) and use the line input on each speaker, they are positioned as i would my hifi speakers angled in and a seperation of roughly 6ft and the source is a samsung smart phone playing flac files.
To me i have been very suprised with the fidelity of these little speakers and they have pretty much the same advertised frequency response of the smaller b&w towers i had (50hz-20khz) now im hearing more detail in these speakers than i ever heard in my towers and better bass (cleaner and more precise but maybe not as deep) but the highs and mids now this is where im stunned the detail is so much better than i expected dare i say it much better than my hifi now i want to know if anyone else has heard these and has any critical things to say about them? Are they actually a bluetooth speaker done right or am i just immagining it!
Look forward to some feedback from people with experience of better than the maybe humble b&w towers.
Thanks Mat.
Icepower 6 channel BTL amp build
I have my amp ready to wire, and I could use some help, as I have never done this before.
1: How do I know which pin is which on the amp modules... I looked and I do not see any numbering, nor did I see any in the pdf file either. I am using Ghent Audio wiring for the job.
2: What is the best way to route wires? Under the amp modules?
3: Should I twist the wires in groups according to amp modules...ie left hf amp, and left lf amp together?
4: Should all the power leads be run together?
5: On the BTL amps it says to drop the pin to signal ground. What is meant by signal ground?
6: Do I ground the amp modules with a central grounding point or are the brass standoffs sufficient for grounding?
received_1015912672168933.jpgreceived_1004920380024087.jpgreceived_2872409739653427.jpgreceived_2519979374961568.jpgreceived_348587999527455.jpgreceived_2699110800362810.jpgreceived_1042819499502190.jpgreceived_379162143253735.jpg
What is the effect of different shapes of the surround of passive radiators
How does the shape of the rubber surround affect the acoustic performance of a passive radiator? What are the benefits over normal design?
I have attached some related images with such passive radiatos.
I assume that it must have advantages over normal forms as well-known brands like Bose implement it in their successful products.
I searched for a while but couldn't find anything on the subject. I also noticed that it only seems to have to do with passive radiators, not speakers.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,801
Members
7,888,932
Messages
Filter
Forum Statistics
Threads
406,265
Messages
7,888,932
Members
507,801
Latest member
TMCK001
