Volume control behaviour on Roadstar RCR385.
- By edbarx
- 2 Replies
About the product:
Roadstar RCR385 is a radio cassett recorder with a CD player. The product is from 1994.
i) Since the CD player could not play music CDs, I removed it altogether. Instead, I am using a portable mp3 player.
ii) The volume control started developing issues after about 2 years of use. The multiresistor pot was replaced with another one, but the latter is completely different. The original one was a tailor made component which seems to have been designed to make the product almost useless after about two years of use.
The Issue:
To power the mp3 player, I tried the internal built in power supply, 12V DC, with a linear voltage regulator to reduce the voltage to 3.7V DC, which is required by the mp3 player. This means, the common ground terminal of the radio cassett recorder merget with that of the mp3 player.
Playing audio tracks revealed that when the volume pot is set to minimum, that is, the signal output from the pot is shorted to ground by the volume pot, the actual audio volume does not go down to no-signal and an appreciable loadness is presented to the speakers.
Trying instead, an isolated DC power supply of 3.7V to power the mp3 player does not affect the volume pot with the latter duly presenting no signal when it is set to minimum.
The Question:
Can anyone explain why having a common merged ground, as is common practice in electronics, made the volume pot to fail to reduce the signal to zero (silence)? It seems, with a common ground the audio signal uses another path besides the legitimate one which uses the volume pot to achieve a truly zero signal.
The Issue:
The Question:
