Hello DIYers, as I've mentioned a year back in
THIS thread, I just decided and pulled the trigger on the
2x B&C 21SW152-4 subs for my 2ch music setup.
The project consist on 2x 21" subs with down-firing ports tuned between 18~20Hz to replace the
current sealed Ultimax UM18-22 ~5FT3 sub, in hopes to target the best of both worlds or at least to be close, to get some deep lows and high impact upper bass with low distortion.
I have to admit this is the first time I work with this kind of large subwoofers, and I want to post here my current design options and get some advice of the owners with success on this kind of subs before deploy the project.
Also like previously mentioned, this is a 99% music setup and I listen to a very broad variety of music genres but mainly rock, oldies and electronic when I'm in the "Moar BASS" mod.
I currently have two own designs which are very similar to the "PSA TV3612" in regards to the port location which is down-firing, unfortunately I can't get them work with single 6" ports without having a lot of air velocity/lots of chuffing when the subs are drived at maximum capacity(regarding WinISD), then my only options here are between 2x 6" ports, one 8" port or a straight slot port embedded in the rear side of the box, so my bias for now is the single 8" down-firing port.
I will post some images of the cartoonish paint draws(sorry I'm not good at drawings
😱) of the two boxes design, one resembles the one with the 8" port and the other with the slot port, while the one with the 2x 6" ports being discarded; the planned box material is to use between BCX, cabinet grade ply or marine grade ply, however since the cost of the marine plywood here in P.R. is way expensive, I guess that I can try and find average quality on probably BCX or cabinet grade plywood and double up 3/4" to form a 1.5" sandwich on all sides.
Also here is a material that I'm looking to know if it may be useful for this large sub boxes project, it is called:
EB1S White High-Pressure Laminate Plywood Melamine Board, I can also double up those material as well and they look very flat stable and seems to have little to none voids, well at least looks like so at naked eye.
Well to conclude, here are the draws of the enclosure design in question, so what design is more appealing for this 21" drivers:
Measures: 48" H x 24" W x 24" D.
Walls: all 1.5" thick walls with braces.
Finish: Black-mate laminate.
Volume: 11.5FT3 gross, around 9.2 FT3 Net. after port/driver/bracing.
Alternative measures using 5/8" sheets:
Measures: 42" H x 24" W x 26.5" D.
Walls: all 1.25" thick walls with braces.
Volume: 11.8FT3 gross, around 9.5 FT3 Net. after port/driver/bracing.
Design with an 8" down-firing port:
Design with an back straight slot port:
WinISD Maximum SPL and current UM18-22 for compare:
Regards, sorry for my English.
