Hey All,
Put on your "Double E" thinking cap and give me your opinion on this.
Now I was weened on audio electronics in the late 70's, and for the past 40 years or so I've designed, built and repaired a lot of stuff, but I just ran upon something that baffles me.
A guy brought me a powered sub-woofer to fix, and there's something about the power supply that I don't get.
Look at this schematic, the transformer has two secondary's, the top one is a single ended higher voltage that feeds the power amp, (which is also a strange design).
But look at the bottom secondary, a lower voltage "center tapped" winding that feeds two typical bipolar zener supplies off the same bridge rectifier, each one supplies a few opamps (I guess the designer thought it was more cost effective to double the parts count rather than using bigger parts, like a 1N4744 which has twice the current of the 1N5245, and 1/4W 330 ohm resisters instead if 1/8W).
But look at the center tap, it is fused to the chassis ground (what?).....
So if some over-current event happens and blows the fuse,
IF all the components are still good, but the supply's no longer reference to the center tap,
THEN in theory, does this become a "dual voltage" supply instead of "bipolar"?
That is, does the negative rail become 0V, and the chassis ground become +15V, and the positive rail become +30V?
OR IF a zener on the negative rail is shorted, THEN the negative rail become 0V, the chassis ground becomes 0V (due to the shorted zener), and the positive rail becomes +15V?
OR IF a zener on the positive rail is shorted, THEN the negative rail becomes 0V, the chassis ground becomes +15V, and the positive rail is also +15V (due to the shorted zener)?
Am I missing some obvious "good design practice" here, or does this look as goofy to ya'll as it does to me?
JohnR
