For Sale Lazarus Cascade Classic Tube Preamplifier - $629
This is a very cool valve-based preamplifier, with lots of inputs and outputs, all in a low-profile rack-mountable form factor. It uses 12AX7 tubes throughout.
As shown in the photo, it has dedicated Tape, Aux, Phono, CD, Video, Tuner and Phono inputs, with Main and Tape Outputs.
The only odd thing about it is that the standby feature is a bit counter-intuitive, but it all works. Sounds great too!
$629 + freight. Shipped in original carton. Check or money order preferred.
SEAS A26 in oversize cabinet
I ordered the SEAS A26 kit (mid woofer and tweeter) and am about to build the cabinet (aperiodic) which is specified at 28 l. volume.
I'm mostly after the above 80Hz spectrum as the bottom two octaves are taken care of by my distributed bass system.
I've been thinking of increasing the cabinet volume but mostly for the soundstage enlargement sake, not bass.
I will appreciate any thoughts, opinions, advice on this idea.
Real life experience cases also appreciated.
Pro-Ject Phonobox MkII - no sound
This is probably a shot in the dark and/or a vague and unhelpful question but -
I recently got a Pro-Ject phono box to hook up a turntable to my focusrite soundcard and monitors, to listen to and record vinyl.
Bought it second hand (perhaps my first mistake) and it didnt come with a power supply. I tried an adapter I had that said it did a range (15-22v or something IIRC) and the phono box wants 16V so i thought it might work but it didnt. Bought a power supply new that is sold as being correct spec specifically for the preamp, still no signal coming through.
My question is whether i fried it with the first PSU or whether there are any other simple things i might be missing or components to poke inside with a multimeter that might diagnose the issue, dont want to chuck it but not exactly where to start with fixing it, aside from taking it to a repair person.
NB - when its all hooked up, theres a slight pop through the monitors when i plug in or unplug the sound, so there is something getting through, just not my music! 🙁
Any leads most welcome 🙂
High Quality Passive PA Speakers?
My reference speakers used to be Gedlee Summas. I sold them a few years back, they were just too big. Great sound, huge speaker.
A few years later, I bought some Yamaha DXR12s. The DXR 12 is a prosound two-way with a 12" woofer and a very nice waveguide. The Yamaha uses the same compression driver as my Waslo Cosynes. So it's been nice to be able to do A/B comparisons of the two, and get some inkling of how a wooden unity horn compares to a plastic waveguide.
My wife has banished all of these speakers, because they really don't work with the decor in our living room. (The Cosynes are for sale in the swap meet here.)
I've been buried in work for two straight years now, and probably spend 5X less time on DIY than I used to.
So....
Are there any good prosound speakers that are passive?
I came THIS close to buying a set of DXR10s this morning. The cabinet is about half the size as the DXR 12. Compression driver is the same, I think the amp is the same too.
I don't have any real complaints about the SOUND of the Yamahas. But they don't fit in the decor.
If I could find something passive, there are two advantages:
1) I may be able to remove the guts of them and put them into a knock down plywood cabinet from Parts Express, a cabinet that I could veneer and make it look nice.
2) My DXR12s have a nasty hum that's really distracting. Not a huge deal for a nightmare or club, super annoying for a living room. I know that I could run balanced connections instead, but my living room already has a mess of distracting cables and I don't have the time or energy to route everything through the walls.
Teac V-5000 cassette deck's take up spindle (the fwd spindle) stops rotating randomly in the middle of play
I purchased this casette deck used on ebay, but in excellent condition. It has this problem.
Cassettes play and record satisfactorily. However I have this annoying problem.
Usually in the middle of play, the take up spindle stops rotating in the middle of the play and then
deck stops playing. I turn off the deck, or even fast fwd or rewind the cassette. Then when pressing play, the playing starts, then shortly after that, the take up spindle stops rotating and the play stops. I don't have a service manual of it, but I have good understanding and technical skills. I am an engineer.
It appears it has 3 motors and 2 belts. I havent opened the case yet. Could this be a worn belt problem, which may be easy to replace,
or more of a logic control issue? Has anyone experienced such thing?
Thank you in advance for any help.
Dinu
Tapped Port Modelling in Hornresp
Hi Folks,
I am intrigued by a few cabinets available for the bass guitar player that are more or less conventional shelf ported designs that have the woofer mounted in the port firing from one side to the other.
One such example is the Bill Fitzmaurice Omni 15. I own one of these and the bottom end is quite spectacular. The port is flared, and the space behind the baffle is completely open (that is to say that its just a reflex box with a flared port and the woofer mounted in the port
There are other examples, such as the Boom Bass Cabinets that have a second woofer firing downwards into the slot port.
I believe that the two woofers in this box share the same airspace, But for the sake of this post, lets assume the front facing speaker is a sealed back midrange.
How would I model such a beast in Hornresp? I've tried modelling them as a tapped horn but can't seem to get anything approaching a normal looking output.
The BFM Omni 15 is a great box in the low end (it has a pretty undesirable midrange), so I would like to understand how to model these beasts to see if I can tailor them to drivers I own.
Can anybody help?
FS: Hiraga LeMonstre clone Class A
Selling in excellent conditions hiraga amp clone. See pictures . Ship to Europe only. 350eur or best offer. Smooth and warm sounding amp in classe A.
Reactions: Pano
KEF Reference Model Three Schematic
I am looking to do a complete crossover rebuild for my late 90s Model Three.
Was wondering if anyone has or knows where I can obtain schematics with component values. I want to build a fresh pair of x overs with poly caps, better overall parts quality using point to point ect, Then keep the originals untouched I can put back in if I ever decide to sell. The speakers are the original versions not the three two with boundary compensation.
Thanks in advance.
PCL82 Amp Build
I have been busy building a PCL82 based amp with EM84 dancing indicator valves.
Based on stephe's 6BM8 amp design.
Reusing parts so didn't have the option to ultralinear the output. Nevertheless the result is rather nice sounding, especially combined with a little subwoofer I have rebuilt using a cheap Chinese plate amplifier.
A little cheapie passive tone board provides volume, bass and treble control and seems to operate really well for very little effort 0 money.
Currently using shade feedback resistor of 220k not sure if I should up this given the lack of ultralinear.
Cheers
Reactions: Fuling and decramer
For Sale Some nice stuff. HP audio equipment, Semisouth, vFETs
Hi guys. I have reached to end of my diy audio path and I sell some nice things. So, I have one HP3580 in good state, working; one HP 8903B working too. And I offer two nice sets of transistors... four vfet sony 2sk82 tested and one 2sj28 (tested but I have not data when I did it). And I add to batch two 2sk183V. On the other hand, I offer four SJEP120R063 (fantastic for clonning of J2 or F2J).
vfets set ...... 250 eur + shipping + fees
SJEP120R063 ..... 240 eur + shipping + fees
HP3580 ..... 300 eur + shipping + fees
HP8903B ...... 300 eur + shipping + fees
Grounding vintage amplifier to mains
Old vintage 1976(?) Harman Kardon 900+.
Just got done doing a very comprehensive restoration - all the caps, nearly every transistor, etc. Plays wonderfully, but still has a bit of annoying mains hum that comes through the speakers. Not very loud - don't even notice it when music is playing - but it is considerably louder than just about any other vintage gear I have owned.
I can power this thing using my bench supply and it is dead-quiet. I been looking around and it seems these old HK receivers were prone to humming noise.
One guy - who seemed to be a former HK repair tech in the 70's and 80's had mentioned some of this was eliminated by re-routing a ground wire that runs by the tone board - but he has seemingly been offline since before the pandemic (gulp).
Another person (maybe it was here) somewhere had mentioned also having a 900+ that always had a bit of hum when the bottom cover is installed. I do notice the hum slightly more when the cover is on mine, too.
But the real reason for this discussion is: I notice that there is a 2.2M ohm resistor that connects one side of the AC power cord directly to the chassis ground.
For those who do not know... on this particular model, ground is ground is ground. Signal ground, power ground, chassis ground... is all one ground. Also seem to be a couple potential areas for ground loops from what I see and understand of the schematics.
Since the ac plug on this stereo is non-polarized... it seems to reason that the "ground" on this unit could be connected to either side of the AC line (nuetral or hot).
Would there be any harm in removing this 2.2M resistor bridge? If not, you think it is likely to help any of the hum feedback I am getting?
If I unplug this unit while powered on, the humming stops instantly. Keep in mind: it will continue to play music for 3-4 seconds after unplugged due to the large PSU caps. So the hum is certainly coming from the AC line.
Another thought: would it be of any advantage to install a grounded plug on thus unit? Or is connecting chassis ground to earth ground not a good idea?
-Dean
Deoxit???
I'm building a pair of loudspeakers that are intended as heritage cabinets which I hope will outlive me (at least as furniture). I'm paying great attention to crossover assembly, internal wiring, etc., but at some point I'll be sealing up the boxes (although access will still be available by pulling the drivers). I've heard that Deoxit can be helpful in deterring corrosion. I'm not familiar with Deoxit other than as a spray-on contact cleaner...does anyone have any experience with it as a corrosion preventative, and are we talking about Deoxit Gold or something else?
Thanks!
thermistors in crossover
I have a pair of Triangle Celius 202 (vers 1) that has two thermistors per speaker on the crossover pc board.
I rebuilt them using better parts (caps). At that point I thought the thermistors were just their way of having a fuse in circuit to protect the drivers. I read in one place to leave them and in another to pull them and replace with wire. So of course I measured the resistance at 72F and replaced with mills 5w of those values (.62 & .75 ohms). So everything was good except one of the caps I added failed after a few years, so when I opened up I figured, hey try the straight wire change on one.
It's very different, very bold and louder sounding (that's a lot resistance taken out), but the depth seems gone - the other way they sound like very stately dipoles. Coherent, flat, good depth, clean taut bass, but maybe too tame.
I know now the thermistors were to change resistance if the crossover got heated to a certain temp to keep the behavior of the drivers/xover in sync with the change. I dont know what the original values were, and Triangle is legendary for not dealing with products that are no longer made.
I don't listen loudly so the change over feature of the thermistor isn't a big deal, not enough to deal with it. So what's my recommended move here? I don't think an SPL meter will clue me in. Given no input I'll go back to the resistors back in.
Efficient Home Theatre Systems
Almost everything electrical in my house boasts its A+Energy Star rating except for the audio systems. If I take a typical big-box system: the JVC NX-F7 offer an SPL of 76db. Simply changing the speakers would reduce the power consumption at any given listening level.
Energy prices have doubled in my country. Throwing gazillions of watts at tiny speakers doesn't seem to be the best way forward. It seems bizarre that, when cranked-up, my sub consumes more power than every light-bulb in the house.
Has anybody considered efficiency as a primary design concern?
Hopefully, I want to build something in the Spring.
Any ideas?
need some help for testing my Sony TA4650 vFETs
Hello ,
Sorry for my Englisch.
I Have / had a nice working sony ta 4650.
I did the diode mod.
And after this mod my sony did not work any more.
So i have test the vfet 2sj18 and 2sk60.
did remove them from the Amp.
i have test them with a vom meter
i think the 2sk60 are not good any more
how can i test them ?
housing to G is 60 ohm
housing to S OL
G to S OL
Are they defekt ?
Thanks for help ore info.
Bart Wolters.
Extreme Outdoor Speakers
I am looking to upgrade my backyard system. I currently have Apollo MTMs that are not cutting it. My plan is to have four 18s for subs and 12” tops (either coaxial or waveguide). These are not just party speakers as I would like to do critical listing so sound quality is #1 But of course I want the ability to crank it. My budget is around $250 per sub driver and $500 per top. I have two NU6000‘s to power the subs and a XLS2500 for the tops. I would rather go passive for the tops but I have not found a kit that will work for my application and I am not good at crossovers. All drivers will need weatherproof cones. They will be out of direct rain. I have a front yard system that has four PA380’s and two HTM10s that sounds very good but I want better for the back yard. Listing to music out in the open with no walls or reflections is as good as it gets. I’m in the county so neighbors are not an issue. Please given recommendations. I am leaning towards Faital drivers as they are mostly waterproof.
F5 Turbo self-oscillation in low frequency
I'm finishing assembling my second F5 Turbo in a hybrid version, a V2 with transistor V3 driving.
the power rail increased to 39V with mosfet stabilized power supply.
During the tests I noticed a self-oscillation on my analog instrument connected to an 8ohm load when injecting a sine wave signal below 120Hz.
The blocking capacitor (C3 C4) for the self-oscillations I have tried various values from 560pF to 1.5nF the self-oscillation remains. Has anyone noticed a similar thing on their F5? Thanks to all who want to participate. Sorry in advance for my english google translate
Question about Lundahl transformers from a complete noob
I want to build my first ribbon mic and I have everything except the transformer.
I don't know anything about transformers but I do have a friend that told me he can make any transformer from scratch as long as I give him every technical detail required.
During my research from years ago I kept hearing about Lundahl transformers being some of the best for this job (like the LL2912).
My question is, why are transformers like these so expensive in particular?
Additionally, I cannot find any information online such as number of turns and wire gauge/materials to attempt to replicate them (a.k.a. buy the materials and throw them at my friend).
Is achieving the quality of these transformers virtually impossible without spending close to €80-90? Should I start experimenting with cheaper builds?
Orion HCCA5000.1D
This amp came with shorted outputs so I replaced them and the IR2110S. With the outputs in the amp I have rail to rail oscillation but it goes from 140volts to 40 volts and starts to draw 9 amps. With the outputs out I don’t get any low side drive unless I short pins 6&7 on the TL072.
Optical to Coaxial digital out-how to? (Denon CD player dcd-700AE)
Hi all,
I am in a position to get used CD player Denon DCD-700AE in fantastic condition for cheap. Only problem is it has optical out instead of coaxial S/PDIF that my DAC has.
Looking at the attached schematic I`m a bit confused. I can see digital out from the DSP chip TC94A14FA and then to 74WHC157 multiplexer before it meets TC7SHU04 (inverter/unbuffer-powering led diode?).
At what point (and if it`s even possible) to tap a spdif signal and route it through 75Ohm coax? I actually want to use BNC connectors for this, but that is beside point here.
Unfortunately I am not an expert in digital electronics or S/PDIF protocol so your help would be greatly appreciated, thanks!
Help with these speakers
Yesterday i came across these speakers which immediately bought because they are full range drivers ans i was looking for a pair to build a set of speaker boxes. It says dew dortmund and that's all. Does anyone have information about these speakers? How good are they...?
They sounds wonderful when i hooked them up to my sansui au-alpha 999. However one speaker still needs some repair i think, i better take it to a professional speaker repairman to get it done right.
Any suggestions on how to fix it? You can see it in the photos, the one with damage gives a strange rattle.
oversizing an enclosure; à la Le Petit
does anyone any insights on designing oversized enclosures for single driver speakers?
as i understand it, when he made Le Petit, Hiraga used a big port to boost frequencies below that of the resonant frequency of the little fostex but i dont understand his reasoning behind the size of the enclosure, and i read the original L'Audiophile article.
please no critique of the design itself (dave 😉 but i would like to hear how people approach making oversized enclosures for single drivers.
  • Locked
Forum suggestiion/question - repository for manuals
Is there an easy way for the admins/designers to create a repository for manuals or links to them? this has probably been asked before. seems like there are many threads with manuals attached, sometimes deep within the thread. now that hifiengine won't allow downloads for a lot of people, just see the thread What is going on with HifiEngine ?
https://www.diyaudio.com/community/threads/what-is-going-on-with-hifiengine.385444/latest
On upgrading Infinity Kappa's 9.2i
I have been thinking about doing some upgrades to ma Kappa's 9.2i.
Then I looked at the crossover and had a second thought! It just seems very well made. The speaker cables also look descent.
Many other Infinity speakers have a back placed tweeter. I once had a pair of Sigma's and always liked the highs on them. I think it was because the tweeter on the back. It just filled the room in a nice way. So maybe doing the same on the Kappa's? Installing a back mounted tweeter?
Have some of you here ever done any modifications and improvements on those speakers?
Alternative USB to I2S DAC similar PCM2706 ?
Hello Forum,
I'm trying to build my own IcePower 2.1 amplifier setup with a self designed DSP board at it's center. So far, I'm progressing well. My first test setup is working and I have identified some points I would like to improve. One point from this list is an USB input. So my amplifier should be wokring as a simple USB soundcard under windows. Should not be a problem. I could use a PCM2706 chip form TI to archive this goal. But the PCM2706 seems to be outdated. Yes it supports 48 kHz, but as a Hifi enthusiast my heart is screeming for 192 kHz sample rate. You know for reasons.
Any suggestions which IC I could use a a simple USB to I2C DAC / Bridge? USB goes in, I2C comes out and is routed to my DSP IC. That would be all the functionality I need from it.
My first amp build. Need some guidance. Icepower 1500S PSU + 400A (x4)
Hello everyone.
I recently decided to build some high end 3 way floor standers using the SB Acoustics Santori Textream series drivers (tweeter/midrange) and SB Acoustics 8" SB23MFCL45-4 (woofer x2). I will post that build in the multi way speaker part of the forum in the coming days. I have always designed my own passive X-overs for the speakers I have built in the past but this time I decided to go active after purchasing the Dayton Audio DSP-408 and giving it a listen and liking it. So this meant I would be needing separate amplifiers of course and rather then hobble together something from the hodgepodge of different amps I currently own, some good some not so good, I decided I would try my hand at building a class D amp using amp modules. Simple right?
So after doing a ton of research on what's available and what I could afford I decided I would go with IcePower. They have a good reputation for quality products and they aren't exorbitantly expensive like the Purify offerings. After going through their catalog I decided on the 1500S PSU and the 300A amp modules. After ordering them I was informed that the 47 volt version of the PSU needed to power the 300A modules was out of stock and It might be a while before they got any more and they suggested I use the 69 volt version and the 400A modules all of which they had in stock and could sell me for the same price. I went with their suggestion and that is what I now have 1- 69 volt1500S PSU and 4- 400A amp modules. (I will attach the data sheets below) So I have a lot more power then I will ever use when driving these speakers but the extra head room is welcome.
So now on to the build. I picked up a new case from the DIY store here. It's a pretty nice case made in Italy and should suit my needs just fine. I also ordered all of the necessary wiring from IcePower when I ordered the other stuff so I have that. I ordered a power switch for the front of the case along with some LED's. I ordered some RCA's for the inputs, (I'm going single ended for inputs because that is what my source and DSP unit have.) The rest of the things I already have.
After thinking about it for a while I decided on the layout of the components. I plan on putting the DSP unit inside the case to cut down on the amount of interconnects that otherwise make for an unsightly mess outside. So far, as of the writing of this post I have the PSU and all four of the modules mounted in the case along with the DSP and some shielding to separate the back side of the PSU from the wiring coming from the DSP as it is mounted above the PSU. I also have all of the wiring going to the 69 volt +/- rails hooked up. I have drilled out the back plate of case for most of the connections I will be using and have installed the speaker binding posts, in this case they are sockets for banana plugs. It is here that I find my self needing some answers to some questions that I have.
1- So first question relates to Vdrive. The PSU shows it as an out put and the modules show it as an input so I assume these two connect together correct?
2- Next has to do with DVDD/DVSS and VDD/VSS. The data sheet says to only hook one or the other up but not both. I believe that VDD/VSS are +/- 5V supplies and DVDD/DVSS are +/- 12V supplies. I have no idea which one of these supplies I should hook up. Is there anything needed in between? (resisters, capacitors, ect for current limiting and ripple)
3- Then there is some confusion with how the PSU starts up. The data sheet says:
ICEpower 1500S will start operating in disabled mode when mains power is applied to the module with only DVDD,
AVDD, AVSS and Vdrive running. Thus, to enable the main converter an external enable signal is required, or a pull-up
from DVDD to PSU_Enable. For more advanced applications, a wide set of control, status and monitoring inputs and
outputs are available.
My assumption is that you need the signal from DVDD out to jumper to the PSU_Enable input to start the unit? This also brings up how to incorporate the DSP power up function into the amp. It has 4 pins. 12 volt power, ground, 12volt trigger in and 12volt trigger out. I want to use the 12 volt trigger to enable the DSP as opposed to RCA sense as it is to flaky. So do I use the DVDD or VDrive to power the unit. I assume that I hook the 12 volt power and the 12volt trigger in to the same source or is there a better way of hooking this up?
4- This has to do with bridging one of the amp modules (BTL). The data sheet says:
12.4.2 BTLselect input
The BTL mode synchronizes the two SE channels to avoid idle tones and to improve the performance when driving the
two channels in BTL. To enable the BTL mode the BTLselect, pin 8 on connector P7, needs to be pulled high.
In BTL mode invert the polarity of channel 2 relative to channel 1, as illustrated in Figure 28.
There is a PullUpTo5V pin on the P7 connector. Do I just connect that to the BTLselect pin on the same P7 connector to enable BTL operation along with the audio input connections which I understand?
I have a couple of other questions but I will inquire about those a little bit later as I'm already asking for a lot of information here and I don't want to overwhelm anyone including myself. So yea I would appreciate any help I can get here and hope not to be a pain in anyone's back side but like I said at the beginning this is my first attempt at assembling one of these and the data sheets are geared toward someone who already knows the terminology and speaks engineering speak. I'm a carpenter by trade so hopefully one can excuse my under qualifications in this arena.
I will include some photos here shortly.
Powering up tube amp after sitting for 3-4 years
So I built a pair of the Uniamps designed by Pete Millett, They gave me fits with a low frequency oscillation but Pete helped me fix it. I only used them for about 40 hours when one of the Svetlana KT88s died, It must have been a leak in one of the pins all of the silver getter was gone. So they have set in the closet for several years until I decided to just buy a quad set of JJs to replace them. I have a variac should I bring up the voltage slow to give the caps (black gates) time to reform? How long and at what voltage would be good, I will either put a speaker or 8 ohm load resistors on it when I do this.
Thanks for your help.
Bill
By the way I will be open to offers for the 3 tubes, it is a shame they are much better than the JJs ,
Bill
Improved donations / membership upgrades system
I'm happy to announce that the donations / membership updates system has just been updated and cleaned up. Gone is the messy landing page with confusing options. In is a minimal and straightforward presentation. This is only a first step but I think it will go a long way to improving communication.
Firstly, thank you to everyone past and present who has contributed financially to support the operational costs of diyAudio.
Last year we engaged quite a bit of external development help. This allowed us to successfully move to this new, stable, secure platform (XenForo), with almost zero downtime and no significant hiccups since the migration. The new software and hosting configuration will enable us to meet the needs of the community over the coming decade, or two. If it were not for the generous donations towards operational costs from members, and the financial support from the diyAudio store, this would have been possible.
Here's what has changed today:
  1. All membership benefits are the same or slightly upgraded compared to what they were before
  2. We're now using the default XenForo upgrades system. Simple is sometimes best.
  3. Communication has been improved about what will generate a membership upgrade, how much it costs, and how long it will last for
  4. The entry level membership upgrade has been renamed from the ever-so-awkward "Aficionado" to "Enthusiast", and reduced in price from $25 to $20
  5. The also ever-so-awkwardly named "Connoisseur" level has been renamed "Patron"
  6. All levels now enable multiple recipient messaging
  7. The only difference between each level is more signature lines, and Patron level allowing commercial links, but we may add new features in the future.
  8. Members often reported missing re-subscription emails, or having problems re-subscribing. There are now recurring subscription options for each level for your convenience. Set and forget, but you can cancel at any time to stop the recurring billing. You choose what suits you.
  9. We have switched the system that sends emails to a new one, and the emails have been improved to help with better communication
What's coming in the future:
  1. This week there will be an update to the "postbit" (the part of the post where you see a member's name, avatar and their details) to add country flags. When this is launched the "donation star" is being changed to a more compact blue "donation shield" which better represents its purpose.
  2. Soon after this the "Enhanced Thread Print" system will get a bit overhaul to make it fit for purpose. The current post-XF implementation is not up to scratch (primarily, it can't handle very long threads).
  3. In the near term future, any member will be able to gift a membership upgrade to another member, should they be feeling generous
  4. In the medium term future, upgraded members will gain additional access to more forum visual customisation options, as time goes on (show/hide flags, various other requested niceties, more themes, etc). And other stuff we will endeavour to find and create to give you value. None of these things exist yet, so take this with a grain of salt, but we will be endeavouring nonetheless.
Again, thank you very much for your support over the years. Especially those who have re-subscribed year after year. Your contributions go a long way to the keeping diyAudio operational.
Jason.
Reactions: krivium
Bypass loudness on integrated amp
I'm trying to repair a Sony F 630 ESD, from which the volume pot has broken off.
I know of ALPS pots that have a 4th lug, unfortunately I can't fit those between the PCB and the faceplate. I went for a normal 100k pot instead, not feeding anything back to the loudness circuit. Which results in a strange feedback and hum.
How do I overcome this? I'm confused on how the circuit works (see attachment). I'm guessing I can hardwire the source direct switch to a "always on" but I still want to keep the EQ
Firstwatt F3 preamp recommendations
Hi everyone!
i've been using a simple PP integrated tubeamp for the last couple of years but was always curious how a FW amp would sound, so i've been reading up on it the last weeks and searching the internet. accidentally i came across a used F3 clone and after some research and a good talk with the owner i decided to buy it. From all the FW amps i was the most interested in the F4 but that can be a project for next time. I will receive the amp in a week or 2 and now must choose what pre amp to match it with.
I am a novice DIY'er, i have decent soldering skills but not much electrical knowledge. i do read alot here and slowly do start to learn more. my speaker setup for the moment is a pair of cabasse sloop M4 speakers, 94 db. sealed, 12 inch woofers and presumably, going of old documentation from cabasse, a minimum of 8 ohm impendance as you can see in the attached picture.
I am looking for a DIY project, that is not impossible to accomplish by a novice and that will be a good match with the F3 amp. Ideally also a match with the F4 for futureproofing myself.
The most cost effective option i was looking at is the B1 korg pre. i still have to go through the entire thread, but at first glance the impendance is low enough and it seems to sound pretty good.
other options i thought of where the iron pumpkin pre, and the BA3 pre. The pumpkin looks great and i've only read good things about it. other recommendations are more than welcome btw
cost is a factor, so a cheaper option that is suitable and sounds maybe a tad worse but still matched wel with the F3 will be preferred.
So, if anyone has some experience or has some input on which pre amp will be the best match with the F3, i will be glad to hear it 🙂
I do like to have a bit of a tube sound, but is does not have to be dripping in sugar. Details, imaging, smoothness and 3D soundstage are the things i'm looking for.
Thanks for the help
Patrick
For Sale 2SJ109 BL
2SJ109 BL
18 of them for $180
I’ve been sitting on them for over 10 years. I haven’t tested them so if for some reason these are not the real deal I’ll except a refund.
Free shipping.
Reducing Secondary Voltage
New to this and I'm trying to reduce the secondary heater voltage on an amplifier I just finished...
The amp has a 6072 and 12AU7 that need 6.3V. Currently, the tubes are running a little high at 6.8V, so I am trying to bring it down a touch. These tubes are the only tubes on the secondary, it is not center-tapped and I would like to put a resistor in series to achieve this.
I've poked around online and found some info at http://www.valvewizard.co.uk/heater.html that seemed to be applicable to my situation. I've gone through the calculations and would love a second opinion(s) on my math.
The 12AU7 and 6072 draw .3A and .35A respectively and each needs 6.3V. I need to lower the heater voltage by .5V and have the following worked out.
Resistance: .5V/.65A = .769 Ohm
Dissipation: .5V x .65A = .325 W
Does this approach make sense? Haven't seen many resistors lower than 1 Ohm, so unsure how to move forward.
Thanks in advance.
Barrett Strong RIP
Barrett Strong February 5, 1941 – January 28, 2023. One of Tamla Mowtowns founding artists and contributor to many Motown hits.
Together with Norman Whitfield, he wrote some of the most successful songs released by Motown, including "I Heard It Through the Grapevine" by both Marvin Gaye and Gladys Knight & the Pips; "War" by Edwin Starr; "Wherever I Lay My Hat (That's My Home)" by Marvin Gaye; and the long line of "psychedelic soul" records by the Temptations, including "Cloud Nine", "I Can't Get Next to You", "Psychedelic Shack", "Ball of Confusion (That's What the World Is Today)", and "Papa Was a Rollin' Stone", amongst others. Strong and Whitfield also co-wrote the ballad "Just My Imagination (Running Away with Me)", a 1971 hit for The Temptations (the last single to feature original members Eddie Kendricks and Paul Williams).
Reactions: pl802
Modifying diffuse speaker with twin tweeters to direct single tweeter speaker.
I have a pair of old Boston Acoustics VRM-X speakers that I would like to use in an Atmos surround setup. These speakers employs one active
woofer, a passive radiator plus two tweeters.
I would like to use these with a new cabinet, but only use one tweeter.
I have not had access to the crossover yet but would it be likely that this modification would be ok path to continue and achieve a good level match between the tweeter and woofers? I can open the speaker and take som pictures of the crossover to get a better understanding of what type it is.
I have a Dayton Dats V3 to measure the tweeter TS parameters.
Thank you.
Remix of Bob Dylan's Time Out of Mind
What is your opinion of the Time Out of Mind remix? RollingStone writes Michael Brauer was tasked with taking a beloved, Grammy Award-winning album.He went into the project knowing little about the creation of the album, so he was stunned when he pulled up the tracks and realized that 12 musicians were playing at once, creating a wild cacophony. Lanois had decided which parts to keep, and which to discard, during the mixing process.“Normally I just pull up the tracks and I mix, and all the ingredients are there, and I don’t have to think about arranging or re-arranging,” Brauer says. “In this case, I had to go through every section, instrument by instrument, and decide what I liked, and what I didn’t like. Once I did that, I’d go back and forth against the final mix and see what Lanois had done and kept, and see if it was how I’d done it or not. It was a very, very long process.”Brauer wanted to restore much of Dylan’s original vocal, while still staying true to the signature sound of Time Out of Mind. Luckily, Dylan’s master vocals had been recorded separately by Lanois, and preserved. “That meant I had control over how dry or how wet I wanted to make the vocal, which was great,” says Brauer. “Otherwise I would have had no flexibility, and there were many times they wanted more natural voice without as much amp sound.”
Any thoughts about the remix? I think it is better than the original Much more detailed with more instrumentation and Dylan is easier to understand. The elimination of what Dylan did not like about the album, the Lanois swamp sound. To me just an overall improvement that almost sounds like an new album.
Re-capping Denon HA-1000 mc headamp
Hi everyone, I recently purchased a Denon HA-1000 mc headamp. It's in great condition, working fine and sounding fantastic.
I opened her up and there is either some mild leaking of some EL caps but it could also just be glue. Most of the edges are really smooth so that probably means glue. There is one place where some crystals are showing so that area is probably from a minor leak. All the other caps show no signs of glue or leaks. The unit is probably from the late 70s or early 80s so some preventative recapping is not terrible idea.
I've found a schematic online and I'm looking at what I might want to change. I really like the sound so I don't want to change too much right away, but I am open to discussion if there is something (like improved voltage regulations) which could elevate the sound. In general I don't like the shotgun approach of changing everything at once. I'll just start with a few select locations where the caps could be leaking or stressed from age, or where I think a more modern cap can be an improvement.
My plan so far is to focus on the rather generic black wrapper chemicon larger caps. I want to do Panasonic FR for the outboard PSU (2200uf/35v: C4,C5), the larger rail bypasses (1000uf:C11,C12; 2200uf:C7,C8,C9,C10,C33,C34,C35,C36; 330uf:C13,C14) and I'm also thinking about Panasonic OSCON for the input blocker caps (470uf/6.3v: C1,C2,C3,C4) and maybe for the 1000uf at C15,C16 which I think might be part of the feedback loop. The input caps are too big a uf value for film caps, so I think OSCON is a reasonable upgrade. Since it is just a MC headamp there is no RIAA circuit.
I still need to measure the diameters of the caps and lead spacing so I am in no rush. I'm just at a planning and thinking stage now.
I'm searching for some discussion on the circuit. Is there some other parts I should focus on?
After the initial re-capping, is there some part of the circuit that could use an upgrade like improved voltage regulation.
cheers jeshi
a crazy idea (?) for volume control in DAC
Hello,
In a new AD1865 based DAC, I'm thinking about volume control, but not in the traditional way. What if I would build a 24 step step 200 Ohm log "pot" and use it as I/V resistor before the triode preamp?
At the moment I use 200 Ohm resistor, but as I know if I reduce the resistor, the voltage over the resistor will drop. Can I reduce to zero?
Problems I'm thinking about:
  • the resistor will be more "complex". Even if I do not put the resistors in series, but connect all to ground on one end and select single resistor. As I see I should be able to pick from E96 line. Does a little additional inductance matter here?
  • the resistors (or the selected resistor at a given setting) will not be a tantalum or caddock or similar, only ordinary metal film resistor. I do not know how much difference it makes. Maybe I loose more here than what I gain with the lack of volume control later
  • during switching, the resistance will go high momentary, resulting loud transient noise into the amps.
I'm wondering did any of you experimented with this?
Thanks,
JG
Magnetic tape head voltage output
I am currently working on a cassette tape deck project trying to build a unit entirely from scratch. I have the microprocessor controlled motor and control systems completed and have partially completed tone control and balanced output stages done and am now starting on the tape head amplifier and frequency compensation stage.
Unfortunately I am as of yet unable to get any accurate measurements from the tape heads I have been using (not sure if they are still in working condition) and am still trying to hunt down some good replacements.
In the meantime I am keen to keep working on the project so was wondering if someone could give me a rough mV (I am presuming that is the range I should be looking at) values for what I should be expecting from the tape heads so I can start the circuit design?
Many thanks in advance for any help, also any general advice on tape head equalisation would be appreciated
Tom
Genuine Toshiba transistors?
Over 12 years ago, I purch'd, brand new, what I think are genuine (made in Japan) Toshiba To-92 transistors including :
SC2240
A970
K170
Pretty sure these are from Newark, and some from Futurlec, both in the United States.
The Newark plastic baggie has a printed tag that notes: Japan and Toshiba. I'm pretty sure these are genuine. But any way be absolute sure that these are "genuine"?
I do have the ability to test them, as shown.
Aragon 8008 troubleshooting
I've built this amplifier and put it in my bench to test. All the components has been inserted (as shown) except for the power transistors and the load. I wanted to check if all the voltages are correct at their nodes. After powering it up with +-12V DC, the marked resistor is getting too hot, although I've checked each and every component before assembly.
I've also rechecked the driver transistor after the initial result and replaced it but the problem persists.
What can be the reason behind this resistor getting hot without the power transistor and a load connected?
Heathkit TT-1 with TTA-1-1 Tube Tester Mutual Conductance
$450.00 OR BEST OFFER
Heathkit TT-1 with TTA-1-1 Tube Tester, Mutual Conductance type.
Good condition, does show some wear.
All knobs & switches move freely, switch covers for "Normal-Disconnect" & "Normal-Life Test" (bottom left & bottom right) are broken, switches move freely. Knobs for "Leakage" & "Bias" are cracked but intact and functional. Clear covers over Meter & Tube Charts show some wear, paper tube chart scrolls well.
Outer case shows wear. See pics.
Untested, not powered up. Came from the estate of closed electronics repair shop owner, has been sitting unused since late 1990's.
Sold AS-IS
$40.00 shipping to USA lower 48 states. Shipping to other US regions available at fair price, TBD.
Worldwide shipping available, please inquire.
Will be packed with bubble wrap and/or styrofoam on all sides to immobilize in box and sufficient to prevent any damage from occurring during shipping.
Shipped promptly, tracking shared, safely packed. Gear will be padded on all sides and secure in box, care will be taken to protect anything that stands proud of the surface, knobs, switches, etc. I pack to preserve this irreplaceable, cool, old gear.
See my other listings for Hickok 209 VTVM, Gates Transcription Turntables CB-100 with 16" platter, Audio & RF Engineering books, and more.
Pick up in person welcome, no shipping charge.
Litchfield IL
Newb Question: Series Resistor on Woofer
Built my first two-way recently, with an emphasis on aesthetics but with a careful eye on T/S parameters, FR response, et al. I attempted a crossover without measurement and didn't mind the results, but paled to some commercial (NHT) speakers in my living room, so decided to take the jump to measurement and CAD based crossover design. After taking 180 degree horizontal far field measurements of the woofer and tweeter and bringing them into VituixCAD, I have a response I like the look of.
Two things give me pause however, my original crossover modeled in V.C. didn't match my measured real world response, and while I used two ordinary filters: a 2 way LR low pass for the woofer and a 4 way high pass for the tweeter, the only way I could get a curve I liked was with a 22ohm series resistor ahead of the woofer crossover. While I like the response, I don't quite understand what happened with the design with the addition of that resistor, and I can't get a response I'm happy with without it.
Moreover, I worry that while the simulated FR looks good, there is some reason I shouldn't have that resistor there. Drivers are Visaton W100S-8 4" 8ohm Woofer, and Morel MDT 29 1 1/8 soft dome tweeter, also 8ohm.
Question is whether a series resistor on a woofer is odd, or otherwise what I could be doing wrong. Images below are the response curves with and without the series resistor shorted in VituixCAD.
Feel free of course to berate me for whatever other mistakes I may have made here on my first run. I'm happy with the cabinet, and just want to do my best on a passive crossover for non-perfect listening while also trying to learn as much as possible going forward.
Can someone please model these speakers?
BIB enclosure
Fr=Fs=45Hz
Vas=87,30
Qts=0,25
Qts'≥0,338
Vb=308,65L
Internal dimensions - 18,87"(D)x13,34"(W)x74,80"(H)
Faital Pro 12FH500
https://faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=151050100
Markaudio CHP-90/Markaudio CHR-90
https://www.markaudio.com/online_shop/ch/chp-90/
My biggest concerns are the performance of the pairing and driver excursions (low cut needed?), followed by a need for cross over points, and lastly a curiously of frequency response.
Thanks in advance. 🙂
Dahlquist DQ10 midbase upgrade
I have owned my DQ10's since the early eighties and after some 35 years I have replaced and upgraded almost every component including drivers, redesigned crossover, capacitors and wiring. However I have yet to find a 5" midbase driver to replace the 5" 4ohm Philips woofer which is now the weak link in the system. I have read on some sites that some had good results with Dayton Audio RS125-8 5" Woofer. Looking at Madisound's website it appears that a Scanspeak 15M/4624G might be a good fit. It is important that this driver has a linear response up to 10k where it blends in with a HF1 Sequerra ribbon tweeter.
I would appreciate advise, incl. crossover change, from those who have successfully replaced this driver.
For Sale: Matched TOS-K1530/J201 (12 pairs)
For sale is 12 pairs of TOS:K1530/J201 precision match. I bought these from Zou Fangp. They are N/P not NP matched..
Asking $240 + shipping
Payment by PayPal Friends and Family
Prakit
PCM1794 vs PCM1793 balanced output?
I want to use a PCM179X DAC to output a line-level analog signal to a pair of balanced XLR connectors. The PCM1794 provides differential current output, while the PCM1793 provides voltage output.
However, I've only seen examples and schematics where the outputs are summed into single ended. I'd like to keep the outputs balanced.
1. If I understand correctly, in the case of the 1794 I'd first have to convert the current differential output into voltage. However, on the datasheet it shows the use of opamps for this purpose, which also convert the differential output to single ended. I want to retain the the positive and negative signals and route them to the XLR connectors - how do I go about I/V conversion in this case, without converting to single ended? (Figure 1).
Figure 1:
2. In the case of the 1793, I assume this step is completely unnecessary, and I can just wire it like below? (Figure 2). If so, what is the disadvantage of using the 1793 over the 1794?
Figure 2:
Thanks!
Sub amp auto on/off audio sensing switch
The external amps for my sub do NOT have signal sensing or other means of auto on/off. I am looking for a box that senses the receiver's audio signal and either puts out a 12V signal (that I can use for a high amp 110V relay) or already has a relay included. Only boards I find are from Israel or China and take forever to get here.
Reactions: Lawnboy
Stereolithos Build - BIB for full bass
Being I am slightly deviatingfrom the original design, figure need a new name. 😛 Instead of monolithos (original spelling), they are in stereo both being a pair of speaker cabinets and a pair in each cabinet, unlike the traditional BIB using one driver.
This forum is dangerous, came here with a folded horn question and now going to build a pair of BIBs. I am looking for input and someone good at modeling to do so, please.
The original BBBIB used a subwoofer for a PA system, as they were for for a one time parade and then tossed, more importantly, the subwoofer is NLA. The Faital Pro 12FH500 is on sale at $100 and looks to have great specifications. https://faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=151050100.
The design also calls for a tweeter, though why not an about 4 inch full range, kind of like a WAW (though there limited at the bottom to 300Hz)?
The more I read about Fostex, the more concerned I became and happened on a member making a positive statement towards a Markaudio Alpair drivers, though too large, so went on a long hunt and the most research I could, and love the sound of the Pluvia drivers; the Seven is a four inch. Dave (@planet10 ) said this: "Makes a good midTweeter in a WAW. So does Alpair 5.2/3 (CHN-50 if you are on a tight budget), and i expect the MAOP version (it should be killer in that application)."
https://www.markaudio.com/wp-content/uploads/2019/06/Pluvia-Seven-HD-gen-2-spec-sheet.pdf
For now, chosen a Fr of 45Hz (equal to Fs of the 12FH500 and about half (Fs=72,55) of the Pluvia), will achieves at least 22,5Hz on paper.
Would the Faital Pro 12FH500 and the Markaudio Pluvia Seven be a great pairing together?
Using the Faital Pro 12FH500 produces a far narrower and shallower cabinet compared to the BBBIB, only 13,34"/33,89cm internal width, 18,87"/47,93 internal depth, and a mere 74,80"/190,00 internal height.
Edit. A post by @zman01 in a different thread caused me to realize I should mention the music I enjoy is varied, pre World War Two jazz, blue grass, oldies, disco, 1980s pop, some classical, and love organ music (which I prefer above the about 35dB I normally listen at).
RPi OS 64bit with GUI. Can I screen blank on no audio?
I have a streamer on RPI 3B+ 64bit bullseye running plexamp headless.
Although it's a headless player I wanted to see what was currently playing so I installed a waveshare 5inch DSI touchscreen.
If I disable screen blanking I'm worried about screen burn-in if it's paused for days.
My problem is that screen blanking turns the screen off while music is playing as there is no user input.
I want screen blanking to detect when no music is playing, and then blank the screen. If music is remotely started, then wake the screen.
This could track either audio output or screen activity as there is a song progress bar that moves and album art/song info that displays.
Does anyone know how to achieve this?
For Sale JC2 Clone Preamp Board with Transformer
For sale: JC-2 Preamp clone board with transformer...works great.
I remember years ago reading a thread where Mr. Curl advised the ideal voltage settings for the JC2 for both channels...they are all set as advised...just don't use it anymore as the chassis was repurposed to a Korg B1...
How's $50 + ship (should be cheap - small flat rate box - conus)
For Sale 4U 500mm Dissipante chassis (Pico's Toxic Masculinity Class A Amp Chassis)
For sale is a 500mm deep 4u Dissipante chassis. I bought it as part of the group buy ran by 2 picoDumbs, but didn't end up using it.
It comes with the inner steel mounting plate and the handles at the back. It also has a square hole machined in the front panel which I was going to use to mount a power switch.
For more information on the chassis please see the following threads:
https://www.diyaudio.com/community/threads/picos-toxic-masculinity-class-a-amp-chassis.362494/
https://www.diyaudio.com/community/threads/ultimate-4u-500mm-chassis-who-is-interested.360807/
Price: 200 AUD
Reactions: ronex
C++ Easy and Scalable Software for BIII38Pro
Hi guys,
I have been looking for good, easy and scalable software for BIIIDAC, but couldn't find anything useful. I know, there are some guys writing the software, but it is mostly C or Microcontroller based and very difficult to follow or change.
I decided to write easy to follow software, based on C++ classes, which is as close to TPA Firmware as possible.
I use Atom + PlatformIO and Arduino DUE for this.
For remote control i use Apple Remote and the Display is 4,3" 480x272 TFT LCD mit Touchscreen SSD1963.
The software is based on TPA firmware, it behaves the same way: power up, reset, communication, configurateion, etc... is all based on TPA firmware.
The software gives you at this stage basic interaction, like volume change and input change, the rest of the configuration is read from the switches on the BIII board.
This software is easily scalable, you can replace any of the classes with your own or modify existing.
I have added some "interfaces" for editing, like eeprom or touch (didnt test the touch, but its easy to figure out how it works and correct it).
I also prepared the settings page for the tft screen so one can add it later on.
Main function is literaly 20 lines of code, it just takes the action from interface and apply to the DAC class.
As I said, the heart of the DAC Class is TPA Software.
The configuration file is the copy of TPA, ES9028_38.h file.
DAC class constructor is build of TPA functions, slightly modified for Arduino needs ( i use Wire.h for I2C communication ), but the funtions:
powerDACup();
initializeDAC();
configureDAC();
are practically the same you get with TPA firmware, those work the same way and are called the way TPA is doing it.
Simplified soft looks like this:
setup:
dac = new DAC();
remoteInterface = new RemoteInterface();
touchInterface = new TouchInterface();
tftGraphics = new TFTGraphics();
loop:
action = remoteInterface->getAction();
if( action == NONE )
action = touchInterface->getAction( MAIN_MENU );
if( action == NONE ){
dac->readSwitchStates();
switch ( action ){
case NONE:
break;
case CHANNEL_LEFT:
tftGraphics->printChannel( dac->decreaseInput() );
break;
case CHANNEL_RIGHT:
tftGraphics->printChannel( dac->increaseInput() );
break;
case VOLUME_UP:
tftGraphics->printVolume( dac->increaseVolume() );
break;
case VOLUME_DOWN:
tftGraphics->printVolume( dac->decreaseVolume() );
break;
case ENTER:
tftGraphics->printVolume( dac->muteVolume() );
break;
default:
break;
action = NONE;
All you need is Atom + Platform IO + ( Arduino Due, remote, TFT) and the repository:
GitHub - poninskit/TPA_Buffalo_IIIsePro38_Software: c++ Microcontroller Software for Buffalo III 9038 Pro DAC
happy coding.
here is how it looks like:
yqQ9CrrVu7Xb7bB5EOSaX3syui8JQDgekV3C0vzfhpB50Ts14nL_5qqSfa-5uBWXlxchDBVvNY-aBYIbZ6O6lKmd6GLhyO1bUiFTyI-CyNzCQqWMccbE78AaMSAHlFCVcXOZAhWz75iA8g5X4Tl9LAtLf9jCmD6hPGd-98JHRdehFDZ5FyZh9K2jfPah9j6rrLExJRpOeDui1UMz3TY0I8bA0g59LuWsxXn7q7cAlYgWq_DIGzMCyv-Tqk4flPTaKnZ7s3RJqr1pCxML1qLrwyUZytKhPQ1rLyCAvFdCTZbNycD5YGwoCdmdYC2bF6H5PR77D_VUYl7jPc6jSZi0ttjQw0R-uAya5-b4iVKukzJKcWtG1Ly-9ngr_ZgmWWIrJ5PP2Gkw3jmedrOMgNwKqv6Zlq2W0UYHB-l1f4zJxKuDkK-tbKI1LgIyzXgSz7rkJcU8yem0Ec71n-JgOiZqQlBXTUEu2D7_FNt2laGy7HwkhlcbpVbKEWgJAGNqMuYJj3rVx7z-XxdhN7SBMLYtai6PGzJuGrkBntoAK1fJ_QQUazjbF2Wa7BIDOuuB8MOBzTiJ-9Vpe5y6lpMZL6wHQ_4oYjdJ947LiGNV0ldSkKygpIn0qbqEqH8fi2DF_328lwrtgcogi0T42Y5MLhH_qCyEZfeUpB8=w629-h472-no
KxyP3k0N8YXF9lDxv3I8Y8xbGcpE-hKz_hzo5Fuop9frTlU8HqZufYSJRjNKnJ_NVJOTWDRR2Ud0grGy-eBTYfE6GvskEuF1P1rYPcF9Y_oOpVI0iFFgKwU9_kYLGFAGb3moU6uzfHhZyUJ0sskghIQE0Vsyt7ne0BBfPdMJRmGhjTZRbuknWelInA6cveBholIb4g-oS6bQEeNqNZLTmZiSbqrVHnPLz0NFq_SgEqqmu-BdKPUYsbdVC_aA0ar75EmqzIJHWZuH3iMbCvavcHHir4TY3hc4MEy1U-4RAtl6_7EZ6a4LmeQujjDBKWYPBisAcLC27RbanLlIzlm6MznOPlLpPqLTiGWQJGQcu_EBAa0M4PcUuzaRFR8btEbRGBGggmm2wqWqCkPUmq9dMn0F65r4OdPvuAugCqA5Uo7elQszUTmA3IoCCCN_amrB3UqbTR0J81R_-EHnJjBboMEudz_VXUJSrCpPfAbquzwSjUJz-N96ILliHtP7UIWrX2gfSMAma-YnFJu4QWY3znuDit8rX-fY2E0bH_-yYfgP7vOLJBZFiANAKZEIjGrhJXvlbf5nSdrgIKh1ATj0RpeeGYHTUGyrHGBbhNMhDOwTQLYItyu_R8V6fVrsjT29dAwPAAWlrabRqjpWJQc267pSz2RRQqM=w768-h291-no
zkRqDPEuRi6vSUFmGQ9mrf87AA4T5VbU8Cb9EACm9nOUybnZXs1Re1Izrj9AbYUArMhCHroG-LFfvDBh6mulLn1PlGjPxeMP5GuyHyDI7EAnqnuUlGMTet6GmbK4ptn7QKWT-xVbcnLstCNOC2dYd8ouSijqmZOH1XOF0IVoZqdbsU3niNNCudEN-SLmm58JGlF8tpCGLJpkLAgSBM3GHUvT4JFicfwjm06v_FZ-pIthaZKG_rMpVnJN1VDMdWTYLUS1P2Lhndt3NtlXp2zJEJqS8G4AwZE-yqRWQJCmNeQ8MA2glMnG8oxqGCn3zIiGMhCxbFEcakv4HFRJVAVw6asx__9zJd0VoDb6v4KEnyzNyZGvg1tWau4yjpzAWQWer63mkIzwQ9xOUH7yaCoAfg1jGh9-q9KPTFgHpm0lFhlUREZ1lOrhYkXBo9URFt_iMHNm_opKwlZU9CgbAuyso6VOqJXSqAIgT4F3CfBEFSxYspUgVtbiUeD8_liipG6oTqEEvQ72NkL-AHhjQu4NEyQ1VxzThtQ7XctJpkrnfTLWQC9XB3ptU9g0BmN8KW-KK8b-Sf8Rk2UEguhy3r7Kni3tBfcTkU5OcpoEnaXHNlJUNBqLxosO7k9Rk0h1dF9g8u3rM_PgY6DRlnK7WQ-xS5GBCXZVcNo=w707-h472-no
Mw6W0y_rPa2mg_m24aCDC9DSnqNeL5vcxooC5GJB87a0pS_lg7j2r7SFaywXjTHNqvj2t3zNMyUaj1IJLLp8YpdzHwAgI9D0sfbK3FcTKTf1CD55Hx6Q-44J9ACUwgMSNU3Yxml-iGZ6lhWiDPui2BXpDrkTydcB4lIyyuTjRq3OEGY7TV7d45tGCJDf8FOhYUAnHxfwUjjmIIRBonTiRBegGxjINz3DkmFFC-mbaeqtn4E1fAQjA0dHlIXQzQlucX0c1g0Zmp6ksbrDi7EQCDjPHdgu9P77j22hrDM7CH6c4OBnP3sofzmTegn8GODdxKqkcyIZQBn6TaFk8nEzQjHxbpDO-QUzEvBVxnBZWwMJoif2tJ2S1honc9rGMnOWP9bUV91l_yMYc9DTc_M4Fr5tmnTIY7GjILbBR5BUQGNIHew7HFNyyMNtcWfTQi9ShyrgW1LuAUpHg5KO3filFg3QemZHs4eODkl53l7OMQYqiAkEsjoYlvODz5nOOhWo9p_gQCj1hRvqAkbiQjqDdPlbYtYquBkUpuoYbosfvanQG_dwOv71rrL1sKowmY7dyKCkdFA2JpyuLO4JI7tpmB4XGpUV3NLv9HXg6PMl-AiYMzXV1OdV4d5KVF8Ho-NRIrbFu1OTNtYVAsbSG2HPmKtrA-Z7u4I=w708-h943-no
Optional DAC settings page could be written like this:
3VV3ScWokz9P-rWTDtX6Il9m_i-qgAycaq2Wv4CugTL94bN_KFR89jJ3V3DgusqjRMNNy7tUkGygcbna4ERSwbhnwU7PCOzGwcD1EYfNeRIyWEht_WI3bEEHhASw5xXXo6Djl6JlBCV2dMLS5k9bEaSYQOH4TyqPkNjTEFkA7ioWdTX4DsyQGzoiWeXGFt0RiLMBZEUqvMdNdhp1QHrZyIA5gktWkIrx2eyS4_67cuKAsNLM2heh5xMegR4wE1wk_Xa7O2I0z7sMkQdl9Mt5Y2EMDwyLuITmQNQjdwnsm7HOuWItTOVh-rX_jH2iWQGCc_p0lkncbYBuezyjjnX0jaiIKFg8efULXlfNeLQe_DSq-lFBeuszi0-u7naRyvKzF4Nk0UwvCbYXN0gcKvKlYsn6IfVGN_GUeR2BFnTIpb1ClbsiasApL7veCMTPTTJc2kbxnYKca6DAJzYVgudCZm6sy-M0wtLzxH570LYGKWFNMZM-J9HisNJDPyiBdyP2V5JnWR7mNDOY6NEI1uGSgKvVEZTW6xXZc_U8kORNu8rMysxa1murM3uHzDY2rWTZH_RwXs4VG_y46EEzCOrnetNqLdm1xEkaZx-OeATPh2dFCU6JTCspw0KKsxiiiq1Q6OPM00QGryoLQVjwuo3-MqmGFY27pyk=w405-h276-no
and this is how it works:
VID_20190507_095456.mp4 - Google Drive
Internal balance adjustment?
I have an old Pioneer KE-2323 cassette stereo in my car and the left is louder than the right. balance adjust helps, but it's definitely something with the radio itself. Is there a 'master' balance control or something somewhere, maybe inside I can adjust? I'm handy with soldering etc, so if anyone can point me in the right direction, I'd appreciate it!! It's an old Jeep CJ-7 and I want to keep the original shaft-mount setup.
T+A A1530 power amp needs repair AS-IS
SOLD
I am posting this here because this unit needs a repair but will post to other sites later if I don't get hits here.
When powered on, the left and right speakers pop and there is no sound coming from the speakers. That's all it does.
Again, the amp powers up. I talked to T+A Germany and this is what they said and I quote.
"The pop noise that is being complained about indicates an offset in the audio signal. There must be DC voltage in the audio signal. It is somewhat unusual that this is audible on both channels. In this case, there must either be something wrong with the unit's power supply or the offset control of the power amplifier circuits is not in order".
The unit has some scratches here and there, it is door/lid does not close all the way but this is only related to the small plastic mechanism not holding the door/lid. The bottom metal feet have thin plastic stickers that are missing, easiest fix. If you must need more photos, I will take them for you.
Again, the unit has few scratches but no busted corner or huge dings or similar.
Please make an offer as I have no way of knowing what is worth the way it is. I know that the MSRP was $7500 like 12 years ago and they go for $1500 on used market.
Will ship anywhere but it is pretty heavy so shipping won't be cheap. My zip is 33326.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,774
Members
7,888,063
Messages
Filter
Forum Statistics
Threads
406,220
Messages
7,888,063
Members
507,774
Latest member
pete2000
