Can You help me to build crossovers for my setup?
I have read many threads, but all designs mostly versions of Mr. Hiraga crossover are for 825/828 horn cabinets. My cabs are 8,3 cuft bass reflex very similar to Altec 620, with 1005B/288 sitting on the top.
I will be grateful for tips.
For HIFI apps you can use from 300 Hz - up since you're shelving the driver down so much efficiency wise, so what's your woofer and any particular XO point?
500 Hz was the preferred since it's the ~half acoustic power point of a large orchestra, but assuming a wider range of musical types, not necessarily the best overall choice. Note too that with this much shelving you may not need a super tweeter once CD horn EQ is applied to flatten it.
