Go Back   Home > Forums > Blogs > panson_hk
Rate this Entry
Measuring compliance of passive radiator
Posted 14th July 2015 at 01:32 AM by panson_hk
I am using a handheld force meter and caliper to measure compliance of passive radiators. The force meter is clamped to the caliper. Caliper is used to show the panel displacement whereas force meter displays the corresponding force. I can then obtain compliance C mm/N. I am planning to use an Arduino controlled Z-axis for automatic measurement. The force meter has a USB interface for data acquisition.
I should be able to measure BL vs displacement of a driver by adding a programmable DC supply.
Click image for larger version
ID:	1672   Click image for larger version
Name:	force meter.jpg
Posted in Uncategorized
Views 636 Comments 0
Total Comments 0
Comments
Copyright ©1999-2017 diyAudio
