Go Back   Home > Forums > Blogs > lrseries3
Rate this Entry
Cyrus 1 Caps
Posted 7th October 2009 at 04:16 AM by lrseries3
Hi, anyone know how to determine the polarity of old Elna caps? They are orange electrolitics but have no indication of the negative side.
Thanks Stuart
Posted in Uncategorized
Views 1408 Comments 1
Total Comments 1
Comments
  1. Old Comment
    destroyer X's Avatar
    Having a rubber side, then it is positive....not having may be non polarized, or having indications erased...when we remove them from the circuit, sometimes some electrons remains..and you can measure some milivolts...this way you will know the polarity using your multimeter..if shows non negative reading, then the red probe point will be positive and the other, of course, the negative one.
    Other way is to put voltage on them and to measure the leakage current..some microamperes may leak..the less leaking polarity is the correct one.
    permalink
    Posted 7th October 2009 at 01:48 PM by destroyer X destroyer X is offline
Copyright ©1999-2017 diyAudio
