Go Back   Home > Forums > General Interest > diyAudio.com Articles
Old 20th June 2012, 08:02 AM
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Amp Camp Amp #1
Introduction
Do-It-Yourself audio is a great activity. Many major audio components are easily constructed and made to perform as well or better than what we see in the stores and at considerable savings. The process is educational and therapeutic and there are few greater satisfactions...
13th March 2014
Bone
Is there an alternative for the 2SK170/LSK170 FET. these are not easy to find in UK and I am reluctant to buy from eBay.
17th April 2014
gwrskien
You can get them from the store..
8 pieces of LSK170 ULTRA LOW NOISE SINGLE N-CHANNEL JFET - Parts
Gisle
15th May 2014
hapinoregon
Can I safely (and musically) use my Creek OBH-12 passive preamp with my newly acquired Amp Camp Amps?
Speakers are ~94db, sources are CD/DVD, satellite receiver, Squeezebox and vinyl...
MTIA
4th September 2014
bigfishe
Can you use a battery??? 18 volt??
12th September 2014
chrisb
Bigfish - I think the current draw on a class A amp would make for very frequent charge cycles, and unless already extant in your system, the cost of batteries and charging system might be far more than the SMPS bricks with which the official kits are shipped.
The point of these kits is low cost and simplicity of build, and while I've only just received mine yesterday and only just inspected the parts, it certainly looks like a simple build.
on hiatus
16th August 2015
kaboomoo
Nelson YOU ARE my hero. I should of come across this kit earlier... Now it is out of stock.
25th September 2015
vizion
What is the input sensitivity of this amp ? 2 volts rms to get max power ?
1st October 2015
Sprags
I am a total newb to electronics. A while ago I was talking to another member and was convinced that I could probably handle building a Tubelab SSE amp from the board and instructions on the DIY Audio web site but I'm thinking the ACA may be the better starter kit to build ...especially now that complete kits are back in stock. Can anyone offer opinions? What is the sound quality of this amp? Like the SSE I'm also going to need a preamp too correct?
2nd October 2015
Variac's Avatar
Variac
diyAudio Editor
Here's a thread that might be a better place to get an answer:
https://www.diyaudio.com/forums/pass-...p-amp-aca.html
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
17th December 2015
dondiba
hello
i'm newb too
but i'd like to discuss the design : why not put four same transistors instead of one ?
and upgrade the others componants's wattage accordingly? with the same design
then when listening at say 4 watts, each transistor give 1 watt and the distorsion remain low? it there good reasons for not trying so?
Copyright ©1999-2017 diyAudio
