Here is my Pete Millet low mu preamp with transformer volume control and input relays activated by knife switches.
Wow! ("japierdolę" in polish 😉 )
I really like that steampunk design!
It's always confusing when people are trying to use Latin letters to write down what is printed on Russian tubes.
It helps if either the Cyrillic letters are used OR the if the Russian letters are transcripted.
Two tubes that are easy to mix when codes aren't written correctly are 6R3S and 6P3S.
Kakie tam za lampi? U menya v knizhke (Lampovyi Hi-Fi Ysilitel svoimi rukami), jest lampa 6P13S - Vykhodnyi luchevoi tetrod. Eto ona?
The double triode with a low internal resistance.The lamp 6Н13С has the Soviet analog 6Н5С. There is still an analog under the name 6AS7
I have both curves, 6H13 and 6H5 they are not the same envelope. One is soviet the other Chinese.
The first is the 6AS7G, the other is similar in the aspect is 13watt, same Rp.
You can ask to atmasphere member, he has a lot of experience with this kind of series regulator valves.
Fine construction Dimitri, could you explain what is the board in the preamp?
Best Regards
Best Regards
Best Regards
It not in front of the amplifier. This is the amplifier of power for earphones. the first cascade is made on entrance transformers which do a signal balance.the second cascade is made on 6H7C double triodes and on an exit stand 6H13C with output transformers under different loading.straightening works on two parallel 5Ц4
Sander'Z, nice phono preamps.
Did you measure distorsion figures?
And is there a thread of the build?
Ronny
Ronny
Joined 2009
EF806S/ECC99 phono preamplifier with two inputs and output volume control.
Very nice, spotless work
Nice Pre! congrats!
How do you get the chassis? I need one 🙂
Ronny
Ronny
SEEK thermal imaging camera
I got one of the first released batch of these marvelous devices for the Android format. I don't own a smart phone so then I discovered I had to pay big bucks to get a tablet that could drive it. Nobody could sell me a smartphone without a service provider contract. Most cheaper tablets don't have OTG to Go on their mini-HDMI receptacle, which this camera head accessory requires. I ended up with a top notch Samsung Tab-S with the very high def 10" OLED display and an octal processor. Man I LOVE this powerful tablet! It operates really well with the SEEK thermal camera head and I actually much prefer the really big images it makes on this tablet than the much smaller screen of a phone.
These imagers use a special non-glass Chalcogenide lens and see the light band below where our eyes are sensitive. They see the same thing in daylight or in a dark basement. 720-1300 angstroms. They can resolve to 0.1K or C if you like. Mine can clearly see the thermal paw print track left by a walking housecat on a carpet!
I use the SEEK thermal camera for evaluating electrical wiring for overtemp, components in an amplifier, tube or SS. If you build a tube amp with a power tube(s) that eat filament current like say 6C33C's, then you can IR photo image the wiring and sockets to see if they are heavy enough for the job, or overheated and even read their temperature. Also good for heat leakage surveys around the house, and even for paranormal research. Mine actually saw a commercial jetliner outside late dingy afternoon, hidden totally in overcast flying overhead at what, 30,000 ft? How's that for paranormal? Haha.
It takes good videos also.
Nice addition to the electronics lab if you can afford it!
Seek Thermal, plug-in for iPhone.
Just for fun: A set of SE mono blocks that fit on top of the speakers, no FB, conventional dual PSU. PSU switch is a key switch with off, filament pre-heat (2.5V), and HT/Filament on positions. Indicator are orange for filament volts and red for 6CA7 bias current. 😛
Very nice build!
A little advise
You should remove your amplifier from the top of your speakers, those tubes will be grateful to you especially if you drive the speakers at least at medium volume
Tubes does not (happy) likes resonation 🙂😀
A man after my own heart!!! Great work U. How do they sound?
@ djn - IMO they sound great, particularly for female vocals and individual instruments, surprisingly good low end & more than enough power for my needs!
@ gaborbela - thanks for the advice, I did not think about that! (but the volume is pretty low (no more than a few 100 mW...) and the speakers are quite solid) but I may well move them...
- Tubes / Valves
- Photo Gallery
