Favorite ouput tube (SE only)
The nicest sounding SE output tube is the one I use ;)
I actually use a GU50 pentode on about 45mA with 430V plate and 250V G2. However this is in a tight feedback loop with it's driver so I suspect not much of it's signature can be heard, especially as (as a pentode) it's an extremely fast and easy to drive tube.
It manages to fill a medium sized living room with wonderful sound with 87dB/watt speakers too - i.e. it's pretty powerful, but no idea of the actual power (estimates welcome!)
I'm going to build a PP amp using the same driver/output tube combo too, although maybe experimenting with a Schade with a loaded SRPP and a mixing resistor - mixing with the Schade resistor into the GU50 grid.
I was just wanted to ask in this topic is some one tried a GU50.
Did you also tried in a Triode strapped mode ? Thats what im curious for.
Yes I did try it like that first, it sounded pretty good but the topology is so different now (and more powerful) it's difficult to say if it was the triode mode.
One benefit of triode mode is the impedance is lower, which you have to synthesize with a pentode. IME a low impedance driving the OPT makes a big improvement in quality.
has anyone heard an 6H13/6AS7 amp? some people say that they sound very nice.
I own an Audio Mirror amp that uses a pair of 6as7/6080 tubes per channel. That's 4 triodes paralleled for each side. I gotta say it's one impressive amp. A useable power output for regular speakers, really natural sound, and the tubes are cheap! This is the only SE 6as7 amp I have ever heard, I have also heard them in OTL applications and they do quite well there too. Since this is a DIY place, I'll say that it is my understanding that the 6as7 doesn't give you many options for topology if you want to run them SE. They also have a very low mu, so the gain has to come from somewhere other than the output stage. Give them a try, they are plenty cheap...
I have 2 allready... and i was thinking about a simple SE amp. One tube per channel. Might work well
What is the type and impedance of your output transformer?
Have you measured the output power and distortion?
Hi Andy, the tube doesn't require any forced air cooling at the relatively low plate voltages used. Here is the breadboard:
‪Greenvalve Audio breadboard SMPS 826 IT GM70 Tube Amp‬‏ - YouTube
Thank you for your good work on the 26 preamp. Recently I lashed up your circuit loading the 26 with 2 of the Hammond 150H chokes in series. It sounded excellent. Soon the 24bit/192Khz DacMini will have the 26 on its output.
Greenvalve,
What is the B+ and the bias voltage on the 826? Also, what load does it see from the IT?
Thanks,
John
Sorry no idea about the OPTs, it was a re-built FU50 Sweet Peach which used the GU50s in triode strapped mode.
With the new SEP configuration I haven't really managed to clip it I don't think, the power seems immense but it can logically only be around 10W or so.
I only have a scope, so I do a lot of listening once the scope shows no oscillations and a reasonable frequency response. It's great for thumping bass and subtle vocals and strings - quite surprised how capable it is. The key is a very (Very) tight feedback loop from GU50 plate to driver cathode. I.e. feedback is a 22uF capacitor in series with a 27k resistor direct from GU50 plate, into the cathode of a 6N2p SRPP circuit with 1k resistors. This gives the GU50 the energetic _drive_ for the OPT and is the only feedback in the amplifier.
