need to check this one. Russians are cheap around here4П1Л (4P1L) is the killer for SE.
Hi!
I also like the 211 and also run them hot. But do yourself a favour and don't buy them cheap. NOS GE211 are still reasonably priced and last many many years even if you run them hot. Sound is much better. Just IMHO
Thomas
211, run them hot and bye them cheap.
Thomas
Hi!
My indirectly heated favorite would be the 6CB5A
Thomas
Indirect heating and low power : EL84
Thomas
6П15П is modified EL84 for better linearity. Try it instead (different voltages on grids are needed for an optimal result!)
I like it like driver for direct heating power tubes!!6П15П is modified EL84 for better linearity. Try it instead (different voltages on grids are needed for an optimal result!)
Agreed!!
- Tubes / Valves
- Favorite ouput tube (SE only)
