#111 | |
Yes, the g1 to anode capacitance is only some 30-50 micro-pico-farads when the shildings are grounded, so anode and g3 should not be measured together with g2 for capacitance. It is the stray capacitance between the shildings inside that is left floating, that makes the higher readings when the anodes (and g3) are included. By the way, do you have problems with microphonics with these tubes? Many people say that they are, but I suspect there in many cases are VHF self-oscillation, that's causing the exaggerated microphonic rumors...... |
#112 |
diyAudio Chief Moderator
Thanks for the work Johan. They need Rg stopper in most cases, which works against best noise in a head amp to a point. Kinda prone to oscillation sometimes, yes. When cranked for gain with much Miller at play you know how it goes when stray inductances are meeting the grid.
#113 |
I used trioded E180F in a mic preamp and you would certainly get a nice silvery shimmer if you banged the case but in actual use there was never a problem. I am currently using trioded E810F(and I can drop in E180F,E280F or EF184 as I have switchable capacitance in the HF EQ stage) in the second stage of my phono amp without any problems whatsoever-you have to really hit the case near the valves to get any ringing at all. I always use grid stoppers with these kind of valves.
| Aikido Phono Amp Output Tubes 12AU7 and 12AX7? | JustinJ | Tubes / Valves | 28 | 17th August 2010 02:42 PM |
| New Phono Stage | Lee35210 | Pass Labs | 7 | 19th February 2009 02:30 PM |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
