Also at least 1/3 the overall gain must be coming from its head amp to dominate any full preamp's noise performance.
Yes, now that I think that's a good point.
Thank you also, I think from now I can make my hybrid JFET/triode input with a different valve.
That's in dB not to forget I clarify.
The idea of the common grid stage only contributes its own noise regardless its gain is enough to make me think a little, clarifications are welcome.
Since entering the forum, every day I learn something new, thanks again.
Vacuum Tube Amplifiers-G.E.Valley, H. Wallman
M.I.T. Radiation Laboratory Series 18
This book is a clear example that any subject can be as dark as desired.
At first I thought that my brain is not working properly, but at page 253, mentioning Chebyshev polynomials, author/s make reference to Courant-Hilbert, "Methoden der Mathematischen Physik"
Funny thing, the last is an extraordinary book, useful and readable, and I would say even better than his counterpart by Morse-Feshbach.
Chebyshev polynomials are so common, and can be found in any respectable book, why need a book in German?
That's I call "Mathematical snobism"
No, given the same valve and bias a cascode has exactly the same gm as common-cathode. The difference in gain comes from the different output arrangements. The cascode largely isolates the lower valve from anode feedback, so the effective mu is raised to pentode-like figures. The raw signal current and noise current generated by the lower triode are the same as for common-cathode, but there is no anode feedback to then reduce them. The signal-noise ratio stays the same, except for a little extra noise from the upper triode - usually negligible.
I repeat the question, if you haven't the answer, it's fine, sorry to ask again.
So, what about upper triode's noise ?
Why is usually negligible ?
Merlinb and Salas gave me good advice, but I need equations.
Or at least a good reading reference.
Will this as a message in a bottle?
Because the noise from the lower device gets amplified so that it swamps the noise of the upper device. That's all there is to it.So, what about upper triode's noise ?
If you haven't understood the previous posts then you probably need to learn more about fundamental noise theory. You can then derive your own equation (although I doubt you will ever need to use it...). Find any book on electrical noise. I like Low-Noise Electronic System Design by C. D. Motchenbacher
That I understood, when you kindly explained to me, thanks again.
I need equations to design properly, especially in the selection of the upper triode of the cascode, the book of M.I.T. is horrible and will only help me a bit in terms of concepts. It's so hard to write R, gm, etc. ?
I could make a "translation in the notation", but there are many things that the authors draw from the galley.
Thanks for the reference, I will do my best to read, if I can get it.
Then perhaps: Amplifying Devices and Low-pass Amplifier Design by E. M. Cherry, D. E. Hooper
This I've wanted since recommended it ruffrecords, thanks again for your patience.
It is a very poor answer. Upper triode may have less, equal or higher nose than the lower amplified by the upper.
I believe Popilin's question is still open.
Cascodes has been used in front end of FM and TV tuners because of the low noise contributions (between other so important particularities), I also have seen it in some ham radio receivers, because of it important property (In fact, my Yaesu FT 767 has one inside it made with two FET´s). It is clear it laks the partition noise as pentodes have, but WHY is low noise, is still a doubt.
- Tubes / Valves
- 12AU7 Phono Stage
