Old 11th November 2012, 11:41 PM   #2951
Mark Kravchenko --- www.kravchenko-audio.com
mwmkravchenko's Avatar
I think you used to be able to do that. As in customize the graph range. Useful when working with subwoofers. But I can't seem to do it now.
I know that in the wizard if you double click on the bottom part of the graph you can toggle up to the 100 hertz to 20 khz range. That would show you something closer.
Mark
Old 11th November 2012, 11:55 PM   #2952
It is a basic problem.
One graph has a span that is ten times that of the other.
You can get a better view f the low end in the wizard and the top end in the SPL graph.
Mark
Old 12th November 2012, 03:11 AM   #2953
tb46 is offline tb46  United States
Hi Mark,
That may well be all that's going on. Thanks.
Oliver
Old 12th November 2012, 11:00 AM   #2954
Originally Posted by tb46 View Post
I just ran into a small problem with the response display in the Wizard v. the SPL screen:
Hi Oliver,
Many thanks for this feedback, you have found a bug. It may take me a day or so to track down and fix :-).
(Note that double-clicking on the "Frequency (hertz)" label at the bottom of a wizard chart will toggle the frequency range between 10-2000Hz and 100-20000Hz).
Kind regards,
David
www.hornresp.net
Old 12th November 2012, 11:09 AM   #2955
Hello David
Would it be possible to make the frequency graph scalable?
As in a user could adjust the scale?
I thought you had that feature at one point, and I found it quite useful in determining resonances in tapped horns and undersized front loaded horns.
Mark
Old 12th November 2012, 01:52 PM   #2956
Default Posts #2955/2956
Hi David,
Thanks for looking into this.
Also, I agree with Mark: being able to scale the graphs would be great. For working with subwoofer enclosures I really don't quite care what's going on above 1kHz in just about all graphs, so maybe a bass/fullrange toggle would be helpful?
Thanks again,
Oliver
Old 12th November 2012, 09:29 PM   #2957
Originally Posted by mwmkravchenko View Post
... I thought you had that feature at one point ...
You may be thinking of AkAbak, which does have that feature.
Old 13th November 2012, 06:17 AM   #2958
Hi Mark,
The way that Hornresp is structured, it would now require a lot of work to add user-scalable frequency ranges to the charts. Sorry, but it's not going to happen :-).
It is of course possible to export the Hornresp chart data, dump it into an existing Excel spreadsheet set up as a template, and adjust the frequency range as required. This can be done reasonably quickly.
Kind regards,
David
www.hornresp.net
Old 13th November 2012, 06:28 AM   #2959
Hi Oliver,
I have found the problem - it will be fixed in the next release.
I am currently working on another change to Hornresp, so it may be a few days before the new version becomes available.
If you are connected to the Internet when Hornresp is started, you will be automatically advised of the update.
Kind regards,
David
www.hornresp.net
Old 13th November 2012, 07:41 AM   #2960
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Hi David,
It appears that Ap1 is not working for Nd and OD, then again it could be the pilot.
Dan
Hornresp Class FlipC Subwoofers 8 3rd November 2008 06:23 PM
Some questions about hornresp brsanko Full Range 4 18th October 2008 09:36 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 03:56 PM
Copyright ©1999-2013 diyAudio
