#391 |
According to my current needs and personal taste I will start to make something like this.
#392 |
Hi am most pleased with the L-MOSFET version and that is why I have not had any further contributions to the thread.
Those who want to run with the simplest of the suggestion would end up with an excellent product that will be very hard to beat. I have compared to listening to the BJT version as well and cannot hear any difference that would make me prefer the more complex versions. The L-MOSFET version sounds absolutely superb, is unconditionally stable and currently used on 4 ohm speaker and 32VDC supply. Kind regards Nico |
#393 |
Lazy Cat, well done, you have brought something superbly different to DIY audio, thank you.
Kind regards Nico |
#394 |
My deepest gratitude for all your support Nico. I am pleased that you enjoy in music with your SSA amp.
Yes, two things I brought to this forum BIGBT and SSA front-end and some ideas how to implement these, that's all. Best regards, Andrej
#395 | |
Ic=Ie-Ic/β Ie=((15V-0,6V-Re*Ie)/Rs)-((0,6V+Re*Ie)/(Rfo*Rfg/(Rfo+Rfg))) Ic - desired cascode collector current Ie - emitter current through input BJT β - input BJT current gain Re - input BJT emitter resistor Rs - current supply resistor (resistor connected between 15V supply and emitter resistor) Rfo - feedback resistor from OUT Rfg - feedback resistor to GND Simple as that.
#396 |
Thanks... I now run 3 mA through the input/cascode.. 20 mA through the VAS and 200 mA in the output sets...
Getting PCB's-done and will start assembling i app. 2 weeks time...looking forward...
#397 |
LC, you are being modest; no need for that, take a bow!!
I would say that your circuit is the fully complementary big brother to FetZilla, and one day I hope to compare the two. I have a notion that the SE circuit will have higher even than odd order distortion. Again, thank you, Hugh |
#398 |
......and now rev 1.5 for BIGBT variant ......
please check PCB for errors , not tested .Alex. |
#399 |
Alex, so this is now schematic from post 217 ?
#400 |
Alex mm, well done!
By which schematic this was done PCB? Regards |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
