#21 |
mjl or njw X302/281's have about 2X the Hfe as their X21193/4 counterparts. They don't push the limits on the mje's/properly heatsinked. If I used 6 or more pairs , I would go with the OP's as drivers. 21193/4's are at best 50Hfe (often less) , 3 pair drawing up to .5A @ 2-4R. The mje's are at best 300ma @ 75v soa.
Some on the forum will "pile" up a dozen OP pairs on a EF2 w/mje's - bad . Not I.... Electrically , njw0281/0302 is identical to the mje's , just a bigger die - a bit more Cob.You are fine as is , but if you build a new amp - why not ?
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper Last edited by ostripper; 25th June 2011 at 06:03 PM. |
#22 |
#23 |
Well - SSR is almost perfect, when properly designed. Standard relay is almost incapable to interrupt high current DC arc, that may occur in a high power amplifier. And, even if it succeeds, you have to change it after 1st interruption
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#24 |
What do you mean "almost" perfect?
#25 |
High supply voltage of amplifiers like Bonsai's dictates to use MOSFETs with very high V(br)dss. Then you get Rdson of some 20 milliohms per device, 40 milliohms per pair. So you reduce DF a bit. I do not think this is crucial, but just realize it.
#26 | |
![]() simple. Looks like some of the opto-coupled big industrial SS AC switches I've seen. 3uS turnoff - 100's of ac volts. .01R Rdson !ASSR-1611 (halfway down the page) - ASSR-1611 datasheet, Pinout ,application circuits High Current, 1 Form A, Solid State Relay (MOSFET). That's a small one - 30-60A units run $100usd and up. Would be much cheaper to build one. ![]() OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper Last edited by ostripper; 25th June 2011 at 06:49 PM. |
#27 |
As you have guessed, I speak about the built circuit.
Attached.
#28 |
![]() ![]() I can reverse engineer that by just seeing it - just kidding (the SS relays are essentially the same circuit minus the DC detect). No heatsink ? With super low RDSon not needed ? I was thinking a tda-xxxx protection IC triggering opto X2 (stereo) ... much better than contacts .. regardless. OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper |
#29 |
#30 | |
Which is why I said, generaly. Just like ordinary switches, there are ones designed to switch DC, normally at lowish potentials, the downside is the costs. |
| Leach amp - need suggestions for output relays | velicko | Solid State | 15 | 16th April 2011 09:55 AM |
| how to install more relays? | scampo77 | Construction Tips | 17 | 28th October 2009 06:17 PM |
| Reed Relays Vs Standard Relays | steevo | Solid State | 9 | 21st September 2009 05:08 AM |
| Relays or switches | chalkandtalk | Solid State | 17 | 9th September 2007 08:05 AM |
| Relays for Alpeh P 1.7 | Miles Teg | Pass Labs | 1 | 6th September 2001 09:49 AM |
