#701 |
What about resistor power dissipations? Has it required a heatsink for BD139 and BC337?
#702 | |
The BC327 needs no heatsink.
#703 | |
Life is a succession of hard choices.
#704 |
which are the correct connection of R18 and C12
#705 |
Both are correct: the first is suitable for zener level shifting, and the second for a cascode configuration.
#706 | |
Q3? BC639/BCP56, 2SD669, 2N3501? a similar selection to the amplifier's phase inverter? What percentage of input voltage is seen by Q3? Q2 surge voltage tolerance options? 2SD669, MJE344, 2SC3421, 2SC5171? Q2 sees full voltage, doesn't it? Q1 sturdy options that may withstand a surge? mjl21193 (16a, hfe25~75, 4mhz, 200w) mj15004 (20a, hfe20~140, 2mhz, 250w) mj15023 (16a, hfe15~60, 5mhz, 250w) I tried to narrow down possible options, but I'm not knowledgeable enough to narrow it down further. We do get some huge power surges and an MOV on transformer primary doesn't seem like a complete solution. Which resistors need to be more sturdy to withstand power surge conditions? Approximately how much capacitance smoothing should be provided directly at each rectifier? P.S. It seems no problem to provide 2.5v more input than zener, because most unregulated power supplies have a sort of weak peak, charged up on noise (diode, static, line noise) of insufficient current that wasn't going to be useful to power the amp at high output levels anyway. And there is also the matter of transformer pulldown. With 2.5v margin (and 300va transformer), full output doesn't have any more than 0.2v margin remaining. Should it have more margin at full output? Last edited by danielwritesbac; 26th February 2012 at 01:58 PM. |
#707 | |||||
When the protection is active, they can see up to the full input voltage, if the output is shorted. Quote:
#708 |
I modified powerflux's (lost?) pcb respecting CFP implementation as much as I can do. I built and tested its an earlier version with BD249C output transistors without any observable (eye for smoke,, ear for sound, fingers for heat) problem. This layout hasn't built yet.
I want to share printable pdf's after some reviews and suggestions. Thanks. Last edited by terranigma; 26th February 2012 at 09:55 PM. |
#709 |
I could switch 15K B-E resistors and compensation network just below of them..Mislabeled resistor is 27R.
#710 | |
| Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
