#101 |
here you go
#102 |
(65v)²/2 / 4r = 528.125w
#103 |
So you have a regulated supply, and an amplifier circuit that can swing rail-to-rail with zero loss?
Candidates for the Darwin Award should not read this author. |
#104 |
my point is, what do you assume to get from a +-65V supply to the 2xxW at 4Ohm load.
This seems a little too low to me even when you also take output swing and rail "breakdown" into account, and I want to understand how you got to this figure. |
#105 | |
#106 |
ah, thanks apex.
#107 |
so anyone interested in swapping?
#108 |
sir apex,
do you have a design of simple amplifier that can be used to drive a sub on 4 ohms load at 2000 watts and dont have a step driver? |
#109 |
Without a step it would require 40 of MJ21196 outputs, two of the basic design (bridged, 20 per half amplifier) and running on about ±95V. Doubling up on the drivers will also be needed, and most of the smaller transistors (including the drivers) will need to be changed to higher voltage types.
I would consider a stepped supply, six pair of MJ21195/96 on the lower rails would be adequate for 2KW/4R.
Candidates for the Darwin Award should not read this author. Last edited by djk; 31st July 2010 at 09:48 AM. |
#110 | |
135vdc supply do you have a schematic for 2kw at 4 ohms |
| MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! | apexaudio | Solid State | 40 | 21st November 2012 01:37 PM |
| A.Holton AV400 using irfp or Quasi mosfet amplifier ? | medogrizli | Solid State | 49 | 5th November 2011 11:04 PM |
| How to identify a quasi-complementary amplifier? | motbuddy | Solid State | 8 | 24th April 2011 11:59 AM |
| question about quasi nmos500 amplifier schematic? | muky006 | Pass Labs | 3 | 8th May 2008 09:07 AM |
| Quasi N30 ClassA amplifier | AndrewT | Solid State | 8 | 9th January 2008 07:57 PM |
