Old 25th June 2010, 08:02 PM   #91
apexaudio's Avatar
With all this informations "Begginers will become Experts"
Old 26th June 2010, 10:11 AM   #92
apexaudio's Avatar
There always be begginers, and some people with expirience go back to this simple design 20 years after they build first one. This is clasic circuit as bridge rectifier, and always will be usefull,
Old 26th June 2010, 01:58 PM   #93
tiefbassuebertr's Avatar
about follow website you will find more interesting approaches:
Audio Amplifier Design
Old 27th June 2010, 12:18 PM   #94
apexaudio's Avatar
50-500W classB
Old 27th June 2010, 05:25 PM   #95
At my view beginners should not start with an high power audio amp circuit appropriate for supply voltages between 80V until 160V !!!
20-40 volts (+/-10 - +/-20 volts) are enough for starters and first projects. Because this means much lower output power, more amp devices and multi-amping modes resp. active crossover solutions are necessary.
The great advantage by carried out this solution is the possibility to go on in steps (at first small amp, after checking the reliability the clone of more such devices and as last step an active crossover network).
BTW - in the schematic from previous post I would introduce additional resistors in the collector lines of the BC546, so that the voltage from C to E arround 20-25 volts
Old 27th June 2010, 06:24 PM   #96
apexaudio's Avatar
For absolute begginers,
LM3886 Schematics + PCB
Old 27th June 2010, 06:30 PM   #97
apexaudio's Avatar
Stereo with PSU
TDA7294 Stereo/Bridge with PSU
Old 27th June 2010, 10:36 PM   #98
apexaudio's Avatar
Power is not that important, this is simple schematic with no adjust. Begginers may have problem with any amp no metter what power it is.
About resistors in the collector... This is oldest schematic version, I add cascode, current miror, VI limiter, bias adjust... but that is new amplifier,
Old 1st July 2010, 12:32 AM   #99
joka22 is offline joka22  United Kingdom
Hi guys i am willing to trade a one dhr turbo board industry standard for the two quasi board of any quality as long as it does the job.
or dx blam es boards two of them for two of quasi board. the dx blame es - one of the board is complete with parts and transis. i would like one of the quasi boards to atleast come with some parts resistors and caps not big issue but would like to have the little transistors the 2n773 dnt matter but welcome it if offered.,
Old 1st July 2010, 04:14 PM   #100
mihailo is offline mihailo  Serbia
Can you post some pictures?
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 40 21st November 2012 01:37 PM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
How to identify a quasi-complementary amplifier? motbuddy Solid State 8 24th April 2011 11:59 AM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright ©1999-2013 diyAudio
