apex sir,
how does this limiter works???...how do i know that the limiter limiting????...how do i modify the circuit if use to another amp???...
tnx...
ees...
Limiter activate amp output voltage at clip level (or low if you want limit amp under full power) and it atenuate amp input. Clip level voltage is about 5-15V under rail voltage ( rail voltage +/-75V DC, clip level about 65V).
You can adjust limit level with different value of resistors 820R to get 2V in point 820R, 68R whan amp out is on clip level voltage.
Use formula: Rx=Uclip/0,03 or Uclip=0,03XRx
Rx is 3280R (4x820R) in schematic, Uclip is 100V this clip level is for APEX H900 you must use low value for Rx depend of rail voltage or if you want limit amp at low than full power power use formula P=(UrmsXUrms)/Rload, Urms=Uclip/1,4
hello sir
this is my project....
Thank's for share, is this project working?
hello sir
You sounded so convincing Mr. Jon and I assumed it really worked. Post me the schematics. This is my email echobase@tm.net.my. Hope to hear from you soon.
Best regard
Albert B.
with one pair of 2n3773 what is amp,s wattage.nd pls tell me about transformer for 2 channel .
With one pair of 2N3773 you can get output power 100W/4R. 2x35vac transformer 150W for single channel.
Instead 22k use 2x15k in series (30k), and you can drive 2x15",
apex, you mean 3 pairs of 15k resistors?
No, this resistor is part of CCS.
Could it work with BD711? I have a zillion of those.
With +/-40V DC rail voltage it could, and use 4 pairs of outputs (BD711) if you have zilion of them
Hi Miles,
Can this quasi amp work for simple subwoofer amp?
I want to have a quick try for my simple sub.
Thanks.......Raj
Quasi amp is very good for subwoofer amp.
Thank you Miles,
Good to try if that is.
Cheers.
I'm convinced with Jon's work and I am ready for the Apex 550 watt class B amp, but need you to clear out two things:
1. the schematic/circuit doesn't fit with the PCB layout, why?
2. which one i have to follow: the schematic or the PCB?
Best regard,
Albert
Go to posts #131 and #132
Yo, happy "1 Malaysia" never tought some one back home does interest in building amp.
Nice to hear.
Raj
- QUASI Amplifier for Beginners
