Old 28th April 2010, 03:48 PM   #1
ikoflexer's Avatar
Default Simple 60dB discrete low noise amplifier (lna)
This subject started in another thread
Super Regulator, collecting the facts
but it seems a discussion on its own, so I moved it here. The idea is to build a low noise amplifier with 60dB (1000x) to use it as for noise measurements. Initially I built the circuit from the Linear Technology application note 83
http://cds.linear.com/docs/Application%20Note/an83f.pdf
but I wanted something with even lower noise so I put together a simple discrete circuit using paralleled jfets (2sk170v). However, I used no feedback so setting the gain to 60dB with low tolerance is something that relies on a very good AC voltmeter. Jan recommended using feedback to be able to calculate and implement the gain accurately. What comes next has been moved from the other thread.
This is what I built
The subtler issues escape me, as you can see.
Old 28th April 2010, 03:56 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Yes that's open loop. Is this the measurement amplifier you mentioned before?
jd
/Another new issue: Linear Audio Volume 3!
Old 28th April 2010, 03:58 PM   #3
ikoflexer's Avatar
jd
Yes. I might have to stick with the opamp one, to avoid all those issues.
Old 28th April 2010, 04:04 PM   #4
janneman's Avatar
Try this: multiply the two collector resistor values by 10. Replace Q2 with an NPN. Feedback the output signal via 6.8k ohms to the input stage sources.
Rough maths says you've got about 59.92dB gain.
Then put 400 or 500 ohms in parallel with the 6.8 ohms source resistor, should get you at exactly 60dB.
I haven't looked at DC stuff so try first with cap coupling at all the sensitive points
jd
Old 28th April 2010, 04:09 PM   #5
AndrewT is online now AndrewT  Scotland
is that r5 & r12
q2 is a common collector (= emitter follower).
Are you suggesting that it becomes a common emitter to generate some voltage gain?
regards Andrew T.
Old 28th April 2010, 04:32 PM   #6
jackinnj's Avatar
Omit C5
Old 28th April 2010, 04:40 PM   #7
janneman's Avatar
Originally Posted by AndrewT View Post
is that r5 & r12
yes R5 & R12. I think you need to invert the output signal to make the feedback negative, and in my stupidity I said change Q2 to an NPN which, as a common collector, doesn't invert the signal of coure. Leave Q2 as-is, use a collector resistor equal to the emitter resistor and take the feedback from the collector. If the output sticks to the supply I've got it wrong and then take the feedback from Q2 emitter
jd
Old 28th April 2010, 04:41 PM   #8
janneman's Avatar
Originally Posted by jackinnj View Post
Omit C5
Sure? That'll kill the gain again, I think.
jd
Old 28th April 2010, 05:12 PM   #9
ikoflexer's Avatar
Just got back from getting some parts. I'll try your suggestions and let you know.
OK, so I simulated the changes. Adding 6k8 feedback from between the collector of Q2 and a 100R resistor to the source of jfets in stage one doesn't change the gain. Making R5 = 6k and R12 = 9k1 kills everything. Are you sure about this?
Old 28th April 2010, 05:25 PM   #10
jackinnj's Avatar
jd
Yes, but look at the response curve IKO has provided -- and where does 6.8R x 470uF work out?
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
Howto - phantom-powered low noise in-mic-amplifier tomjoad2000 Solid State 6 7th September 2010 10:56 PM
Noise of discrete opamp robmil Solid State 11 14th September 2009 09:47 PM
Low noise amplifier design fundamentals GlidingDutchman Analogue Source 5 25th May 2008 04:14 PM
Simple and Low noise Pre-regulators for DAC machinow Digital Source 2 10th September 2004 01:04 PM
Page generated in 0.55982 seconds (18.35% PHP - 81.65% MySQL) with 11 queries
