500W PA amplifier with Limiter
Nice work, small offset positive or negative is normal.
I suggest to use red LED, did you measure ldr resistance whan led off and on?
2k2/2W must be hot, for +/-85V use 3k9/5W or two 8k2/2W in parallel.
Thanks for shareing picture and expirience with B500.
Hello Apex,
Yeah I did use red LED, the green one is only for testing.
Test procedures made with red LED/LDR assembly:
1. Resistance when LED is off roughly it's @ 800K - 1M.
2. Resistance when LED is on it's @ 300 Ohms.
I have seen lots of post for the step driver circuit and some have corrections. I wonder what's the correct circuit to use and the proper wiring for the said circuit. Can you post the right ones please?
Thank you once again!
Blueice23
Hi apex,
can i use mjl21193-mjl21194 in place of 2sc5200-2sa1943.
which circuit to use for soft start.
Also i will be using 3 pairs per side. what should be the output.
This is the pcb i will be using for regulated psu 75-0-75, is it fine.
thank You
apex,
please make i.c resistor stabilizer guide,we know this value change according to PSU,different volt if possible
please help thanks😀
marked🙂 in blue
Hi, Apex.
I have some minor problems with your B500 amp:
1. When I connect +/-63V, there is about 50mV on output.
2. 400mV on input.
3. Resistor 22ohm is little darken, but no change in resistance.
I had used 2 pairs of output transistors 2SC5200/2SA1943, and MJE15030/15031, 4K7/2W resistors.
ZD12V and TL072 are only changes. And I didn't have 33pF capacitor, so I put 47pF. 😱
Can you help me to locate source of the problem? Please sir.
Regards 🙂
B500 in the finish line
Hy Apex! Thank you again for this great amplifier, I made tests during the weekend, it worked with 2 15"+1" 300W 2-way speakers, and it ran for 7 hours at the speakers' top volume. The amplifier was only about 30°C, the caps and the transformer performed also very well. The supply voltage was 2x76VDC before use, and after 4 hours of continous use it only dropped 1,5V, and it was smooth, not dropped even at the hardest beat. Now I disassembled it, because the casing will be painted, and then I make pictures of it, and share on this forum.
Thanks, bye!
Thanks, bye!
did u check the amp at the full volume for 7hours in indoor or outdoor with speaker.
Thanks, bye!
how much ampere transformer do u use and the core size, bobbin size.
for stereo one transformer or two?
200m2 mean what?
It was a room with 10 meters x 20 meters (200 square meters) - and full of people 🙂
Well, I bought the transformer. I use 1 transformer, but as I am limited with the space I can use (because of the casing) it is a 1500VA, has 2x55VAC+2x18VAC secondaries. I don't know the exact inner parameters (core, bobbin)
I hope I could help.
Bye
