500W PA amplifier with Limiter
Nice work, small offset positive or negative is normal.
I suggest to use red LED, did you measure ldr resistance whan led off and on?
2k2/2W must be hot, for +/-85V use 3k9/5W or two 8k2/2W in parallel.
Thanks for shareing picture and expirience with B500.
Hello Apex,
Yeah I did use red LED, the green one is only for testing.
Test procedures made with red LED/LDR assembly:
1. Resistance when LED is off roughly it's @ 800K - 1M.
2. Resistance when LED is on it's @ 300 Ohms.
I have seen lots of post for the step driver circuit and some have corrections. I wonder what's the correct circuit to use and the proper wiring for the said circuit. Can you post the right ones please?
Thank you once again!
Blueice23
apex,
please make i.c resistor stabilizer guide,we know this value change according to PSU,different volt if possible
please help thanks:D
marked:) in blue
Hi, Apex.
I have some minor problems with your B500 amp:
1. When I connect +/-63V, there is about 50mV on output.
2. 400mV on input.
3. Resistor 22ohm is little darken, but no change in resistance.
I had used 2 pairs of output transistors 2SC5200/2SA1943, and MJE15030/15031, 4K7/2W resistors.
ZD12V and TL072 are only changes. And I didn't have 33pF capacitor, so I put 47pF. :eek:
Can you help me to locate source of the problem? Please sir.
Regards :)
B500 in the finish line
Hy Apex! Thank you again for this great amplifier, I made tests during the weekend, it worked with 2 15"+1" 300W 2-way speakers, and it ran for 7 hours at the speakers' top volume. The amplifier was only about 30°C, the caps and the transformer performed also very well. The supply voltage was 2x76VDC before use, and after 4 hours of continous use it only dropped 1,5V, and it was smooth, not dropped even at the hardest beat. Now I disassembled it, because the casing will be painted, and then I make pictures of it, and share on this forum.
Thanks, bye!
Thanks, bye!
did u check the amp at the full volume for 7hours in indoor or outdoor with speaker.
Thanks, bye!
how much ampere transformer do u use and the core size, bobbin size.
for stereo one transformer or two?
200m2 mean what?
It was a room with 10 meters x 20 meters (200 square meters) - and full of people :)
Well, I bought the transformer. I use 1 transformer, but as I am limited with the space I can use (because of the casing) it is a 1500VA, has 2x55VAC+2x18VAC secondaries. I don't know the exact inner parameters (core, bobbin)
I hope I could help.
Bye
