Old 6th May 2011, 09:13 AM   #821
apexaudio's Avatar
Originally Posted by shreya View Post
Sir 'faster' in the sense?
'Slow' and 'fast' with 20kHz square wave.
http://apexaudio.rs/
Old 6th May 2011, 09:41 AM   #822
Default Set Bias
I've just build AX-14 with 32 Vac supply voltage,but hard to set bias to find 2V on R10 Ohm insted fuse....Why???
Old 6th May 2011, 01:14 PM   #823
shreya is offline shreya  India
what is the value of cap when it is slow at the time of testing
Old 6th May 2011, 01:59 PM   #824
apexaudio's Avatar
Try to set 0,5V-1V on 10R, with 2V bias will be 200mA, it's to high. Start with 50mA (0,5V on 10R), and check heatsink temperature after 10min.
Old 6th May 2011, 04:11 PM   #825
You want to build 500W Hi-Fi amp
I must draw schematic for this version, than I will share PCB
Have you draw this project Sir???
Old 6th May 2011, 10:53 PM   #826
apexaudio's Avatar
Values from post #1.
Old 7th May 2011, 02:29 AM   #827
Thank you sir
Old 7th May 2011, 11:16 AM   #828
I've adjust bias 50mA and it works now....very2 clear sound....
I use 32VAC supply........heatsink temperature is normal.......
What is the minimun load impedance for AX-14??
How to get more bass???
Old 7th May 2011, 12:53 PM   #829
apexaudio's Avatar
Nice, but can you post pictures?
Minimum load is 4ohm.
Old 7th May 2011, 07:29 PM   #830
I made this amplifier for test my home DIY speakers (two way TL).
I remember seeing that layout in a kit amp , attached .
Where did you get that though ?
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
