Apex AX-14 power amp, and Apex stereo preamp. Finally comleted.
Apex A class shunt regulator for preamp also comleted. but have some problems with it. When connect 2x15V on input, I get on output +/-18V and there are no changes, even when I'm turning 4K7 bourns. Can someone you help me, please?
You should check transistors if they are at their places. As i can remember there are many BC556-546 and others with similar marks and close placed-you might made a mistake there. I have built it,and it works just fine-after few years i have checked it and voltage was just as i left it last time: +/-15V.
hi apex sir,
can u tell me what is the value of the resistors i marked in red arrow.
Use 560R resistors.
Nice work.
Use 560R resistors.
is it 560r resistor same value for all series resistors? or different value to one by one for series resistor?
hi apex sir,
Hello nazirdigi,
What program did you used to make your pcb design?
i am using adobe illustrator.
Thanks...
Yes, all resistors are 560 ohms.
About this PSU post to thread http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu-5.html
hi apex sir,
i finished the vu meter,left side with 21 leds -right side with 21 leds. its very high resolution vu meter, but when i increase the volume to high, the top 4 leds not lightning, including the clipping led also not lightning. where will be the problem?
tomorrow i will post the pictures.
- 100W Ultimate Fidelity Amplifier
