900W H-class PA Amp with Limiter
Hello sir mile,
After a long time due to lockdown and covid-19
I made 2 pcb, but heat sink are defferent, so i thought of such kind of mounting, is it ok?
Heat sink weight above 3kg...
And i need led vu meter please suggest me...
Found some mistakes on pcb...104 cap not connected to gnd. 100k resistor not connected to 22k
Hello sneha,
Dont go with any pcb design.
So much people are uploading bad design.
So much errors and all,
Just sir mile( apex audio) designs are tested himself...so you can use it with trust......🥃🥃🥃🥃
I suggest you to make your own pcb design...
Btw, come soon back,
I agree 100 %
thats why I have design myself Class D UcD PCB from schematic Mr. Kartino
Dont think its easy like class AB/H,
also you need PCB design software to proof PCB routing mistakes V/S schematic otherwise sure you will get first time smoke
Be aware to buy amplifier PCB from 3th party, make it self
I losing time and money, and be aware to buy IR Mosfet driver, Power Transistor in epay if you design amplifier
buy from mouser, digikey, farnell, tme, lcsc and you will have working amplifier
