#21 | |
Any spider dumb enough to build a web across one of my woofers deserves the headache it will get. Oh, wait... |
#22 |
So been thinking about this and I sure like my idea of running the OB woofers on the loudness control and the subs not.
But I have not come up with a wiring scheme for it yet. Pencil and paper are needed. Time to start drawing lines. As for the tapped pots mentioned earlier - yes, it was done that way. I think I have some motorized Alps pots that are tapped for loudness, will have to check. Had a late 70's Pioneer amp that did it, and still have a 1930s RCA radio with a tapped pot. So not a new idea. Don - watch those spiders. In your part of the world they are deadly serious. Oh wait, you're in NZ.
Take the Speaker Voltage Test! |
#23 | |
I don't mind loudness controls but to protect a driver a shelf control makes more sense since it controls all freq below a fixed point. In normal use you could call it a subsonic filter, this is what is needed here. Having a variable one is good. I think it was silicon Chip magazine, yes it was, July '96, that developed a parametric equalizer. This had a very useful shelf filter down the bottom end that worked very well. These things are also useful for helping with room acoustics if used carefully. Terry
What we don't understand is called magic. |
#24 |
Here are EQ curves based on the "new" ISO 226:2003 (http://www.nedo.go.jp/itd/grant-e/re...pdf/is-01e.pdf):
![]() Best, Markus |
#25 |
Banned
Chase RLC-1 might be a cheap solution
TEA6320 pdf, TEA6320 description, TEA6320 datasheets, TEA6320 view ::: ALLDATASHEET ::: |
#27 |
Thanks for the link. Unfortunately, it's not very suitable.
![]() Reasons: - It's controlled via I2C bus, rather than direct interface. - The loudness function mimics the operation and control law of a classic tapped pot, rather than providing a fully progressive boost with level. I really must get my schematic scanned. I did my design and simulation with AkAbak, which doesn't output diagrams... |
#29 |
Don Hills, how is it going with your circuit. Don't want to lose track of this. Will you be making available to the forum. I appreciate all the help you have given to date.
jamikl |
#30 | |
I can't find mine! Thanks Terry
| Tone Control with Loudness ? | thoronx | Solid State | 43 | 2nd March 2011 05:26 AM |
| Loudness Control Calc - Help Please | LinuksGuru | Tubes / Valves | 0 | 14th December 2008 04:43 PM |
| Looking for info on loudness control | normanjr | Tubes / Valves | 5 | 26th September 2006 05:43 PM |
| loudness control | maylar | Solid State | 6 | 28th March 2004 05:12 AM |
| Page generated in 0.12009 seconds (79.08% PHP - 20.92% MySQL) with 11 queries |
