#101 | |
Banned
It's fine to email me. I just looked at the file size limit for the forum, and it's 976k for zip files. I would think that a schematic would be smaller than this, but if you have a problem posting it, don't hesitate to email. Last edited by andy_c; 31st October 2009 at 08:37 PM. |
#102 |
Hi Thomas,
The HiFi is fine. The basement floor isn't completely flat and the stereo is at the high end. It was only about an inch of water in the low spots. I am sitting in my chair, but my feet are wet. The shop is fine. It doesn't have a basement. Andy, I guess I haven't tried to post a large file since the upgrade. Wasn't the old limit 100k? I will make a PDF and post it. |
#103 |
Banned
I can't remember what the old limits were. The attachment below shows the new ones. By using zip, you can get the biggest file size even if the file type is one of the others.
#104 | |
The omnipresent Net Nanny ![]() I actually edited that post about 2 or 3 minutes before your reply appeared (while you were typing). It was a remark on the comments of others intent on resurrecting this 'debate'. I deleted it because I figured it would be taken personally. |
#105 |
I have hate mail now so I turn this over to andy_c who I trust totally to be objective.
Pain is never permanent |
#106 |
Referring back to my question in post 77,
Krill - The Next Generation I am not trying to insult GK with my question. Perhaps I am misunderstanding what is being said by either GK or Andy. It seems that Andy is saying the circuit will only operate as I think at high frequencies and GK is saying it can only work at low frequencies. Since these appear to be opposing views, I simply ask which is correct. I could be interpreting on of you incorrectly. Is that the case? |
#107 |
As a follow up to my previous question, here is what my simulator says. This was run on the amp that I started this thread with and is the one I will be posting the schematic for later. The first 3 are at rated output of 50W into 8 ohms. This is the minimum current in each emitter resistor at the listed frequencies. You can see how this could lead me to believe the outputs stay on. These numbers lead me to believe GK might be correct at some sufficiently high frequency, but it should be well outside the audio band.
8.87827M amps Minimum at 20 KHz 9.98479M amps Minimum at 1K Hz 10.0355M amps Minimum at 20 Hz 9.99978M amps at DC with 28.3VDC at output with 8 ohm load |
#109 | ||
I checked out the Intusoft demo package. The 20 component limit does make it pretty useless. I just tried to attach the Zip file and was told it exceeds the limit. I will try breaking into 3 files. |
#110 |
We will see how it goes this time.
| Symasym - the next generation (supersym) | ostripper | Solid State | 253 | 18th August 2011 06:47 AM |
| boltar generation x old school | badcompany | Car Audio | 2 | 27th July 2008 01:13 AM |
| generation x old school | badcompany | Pass Labs | 0 | 25th July 2008 04:32 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 09:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 06:39 PM |
| Page generated in 0.87894 seconds (10.73% PHP - 89.27% MySQL) with 11 queries |
