#251 |
Edit , another point to make... the .0008 - .001 % is ALL loads and ALL frequencies and is obtained between 70 - 110ma per device (NJW21193/4 or NJW0302/0281) . If you increase the self type 3 driver current (R50/51 = 22R) , total distortion will not drop significantly, but H2 will be the only remaining component (H3/5/7 just "disappear")[/QUOTE]
Is it better, no ?!! |
#252 | |
Another factor is the biasing , the T3T can stay within 1/2 mv Re on the Op's indefinitely. For these small improvements - 5 components... and it is as stable as an EF type 2. One could just build a standard DX type amp or self amp with a standard OPS , but there would be many limitations. BETTER ???, that is totally up to the application. OS |
#253 |
Hi OSTRIPPER,
Have you done a final "maybe" Schematic of your supersym? Considering it as my next project. To go beside my symasym... thanks, |
#254 | |
PCB made great! Where can you find a shematic (circuit) of this amplifier? http://i43.tinypic.com/2cx6d7n.jpg thanks and cheers ! Last edited by radio; 18th August 2011 at 05:50 AM. |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 09:49 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 08:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 05:39 PM |
| Page generated in 0.11192 seconds (54.67% PHP - 45.33% MySQL) with 11 queries |
