Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th June 2011, 01:02 PM   #111
OK.
How should I handle the transistor-modified regulator if I want to use it for higher voltages, like 60 volts? I mean keeping the improvements.
Old 13th June 2011, 07:25 PM   #112
The improvements stand. And there is no problem to using a 3x7 at voltages above 37v in the datasheet. That '37v' is maximum differential between input and output voltages allowable (subject to thermal constraints)
The trick is ensuring the LM317/337 is not exposed to more than about 30v differential from IN to OUT during startup and normal running.
The easiest way to do this is to use a large zener diode , say 15 or 18v , min 1.3W or 5w rating preferrd, in place of th reverse-bias diode between IN and OUT pins. Then, when the PSU starts-up, the zener avalanches until this voltage differential diminshes to something the regulator can withstand. At swtch-off, it behaves like the recommended diode. The zener only needs a voltage rating of a volt or two greater than the expected input-output differential so that it is 'out of circuit' during normal operation.
If you need to stand-off very high voltages the extended datasheet contains several suggestions - up to 2000V!
Old 18th June 2011, 11:50 AM   #113
io is offline io  Hungary
Hi
I use this low-impedance analog LM317/TL431 5 volts to Wolfson DAC.
simple
io
Old 18th June 2011, 02:08 PM   #114
jackinnj's Avatar
Really good LR on that IO Shunt -- I would like to confirm it experimentally:
I get impedance of around 2milliOhms which is consistent with your chart.
Old 18th June 2011, 02:43 PM   #115
Hi
Yes it is.
intermediate version is stable curves (bond will not be published)
and bottom of today (srb-Snoise)
Old 18th June 2011, 03:18 PM   #116
and bottom of today
What do you mean in these two phrases?
Old 18th June 2011, 03:19 PM   #117
mid-development version, stable operation
Top line probe gnd,
bottom line power ON
Old 18th June 2011, 07:27 PM   #118
Hi
Yes it is.
Are these curves for real or simulations?
The impedance curve gets to improve on the Jung Super Regulators?
They were 100 microohms at a 10K frequency:
http://waltjung.org/PDFs/Regs_for_Hi..._Audio_2_B.pdf
How can that be possible without the massive feedback in Jung's regulator?
Old 18th June 2011, 07:59 PM   #119
upgrade now circuit
simulations 100hz-1Mhz= max 290 nanoOhms
real? I can not be measured
Old 18th June 2011, 08:19 PM   #120
That sim performance absolutely will not be what you get if you build one - the TL431 will dominate, it can be a noisy little sod - and does not have much gain at all; certainly not enough to drive output Z down to these levels, or maintain it there to a few 10s of khz, let alone Mhz.
Improving a turntable (motor controller circuit) ;) sek Analogue Source 26 15th September 2008 08:44 AM
Improving on LCaudio LowNoise regulator ABO Power Supplies 43 14th January 2005 11:53 AM
Fet regulator circuit HarryHaller Solid State 47 8th January 2003 03:26 PM
Copyright ©1999-2013 diyAudio
