F5 Headamp ?
I have been asked again by PM about my reply in post #6.
a) Please post your question here in the future. People do not expect perfect English. And for me no excuse either.
b) People who knows me knows that I do not have time to nurse every project from a to z.
And epecially those I have not built or am not building.
If I give you an idea, and you cannot take the idea and realise it on your own, then I propose you find something else to build.
My sincere apologies for being rude, but I'd rather be honest.
c) If you wish to build a preamp based on the F5 topology, you may have a look at these threads :
http://www.diyaudio.com/forums/pass-labs/171827-f5-preamp-simulation-shoot-out.html
http://www.diyaudio.com/forums/pass-labs/125893-preamp-ideas-f5.html#post1555551
http://www.diyaudio.com/forums/pass-labs/244106-lsk-pre-baf-2013-a.html
If you have questions, please post it directly at those threads, so that people who have built those circuits can help you.
I myself have not built any of them, as I mostly only build balanced circuits.
Thank you for your interest in any case,
Patrick
Yes, and in principle you can adapt the circuit to your headphone impedance.
The limits are :
1) Vds for the JFETs (absolute max. +/-24V)
2) Dissipation of the JFETs (I would not go over 150~200mW)
3) Dissipation of the MOSFETs (limited by the heatink)
4) Dissipation of the 500R feedback resistor (+/-24V output sinewave would mean 0.4W).
I assume you would not turn it on too loud to kill your headphone. 🙂
Patrick
Thanks Patrick. I've already built the supply using Rods version of a capacitance multiplier and it seems to be working well with virtually no ripple when viewed on my scope.
By the way, why do you suggest '(Fig. 3, replace BD139/140 by BC550/560, TIP35/36 by D44/45H11.)'?
I figured I'd make it as described so I could reuse it in some other higher power project if required. But the lower noise is interesting. I'll use it as is for the time being, and if I like the prototype amp, I may follow your advice and build a more modest supply for my final version.
PS. thanks for your help and really prompt replies. Really appreciated.... particularly as my knowledge is somewhat limited.....at least it means I'm always learning.
