A Big'un - the Audio Nirvana Super 15
Old 15th August 2012, 08:06 AM   #41
DeonC is offline DeonC  South Africa
DeonC's Avatar
Not a labrinth, as the verticle strips are made up of damping material, not solid wood. So it is more like a silencer. The strips are made from something like carpet felt. At least that is my understanding of it.
Enjoy,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 15th August 2012, 08:10 AM   #42
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Would need to be a lot longer to be a labyrinth. It would be called a heavily damped U-Frame in today's nomenclature.
Was patented 4 year sbefore the labyrinth.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th August 2012, 08:14 AM   #43
frugal-phile(tm)
planet10's Avatar
Exactly. Today you'd use Ultratouch (as Gary Pimm does), or fiberglass insulation.
dave
Old 15th August 2012, 09:47 AM   #44
Melon Head is offline Melon Head  Australia
Banned
Originally Posted by freddi View Post
although its motor is small/weak, you could put it into a Karlson enclosure from K15 to K18 size. Coat the front chamber well with varnish, etc. and enjoy.
What are the optimum parameters for the Karlson?
Old 15th August 2012, 07:07 PM   #45
Bare is offline Bare  Canada
Originally Posted by Bigun View Post
the floors in my house use wooden i-beams, very stiff (much better than my last house that used regular joists) and lightweight (photo) and much more practical than using thicker and thicker floor boards.
Do know that Tannoy DMT II's Twin 15's, use a Medium sized BR 'Box' comprised of a double layer of 1" MDF stuck together with some rubbery /absorbant adhesive. Box within a box setup. Also have crossed internal Driver bracings.
Seriously heavy but it clearly works.
My listening experiences with these... genuinely Impressed.
The Bass is simply astounding. deep, clear and sharp. (Ferrite Motors= sharp bass) It's more than palpable.
Marvelous midrange and exquisite highs. Very little about those to criticize.. albeit only IF the upstream sources are capable :-).
Find and emulate their constructions? One could do a lot worse for a startpoint. Google is our friend.
Ohh by the way: Truss joists, those things in your Photo.. are BAD for turning floors into drum skins.. true.
Even the 1 1/2" concrete topping typicaly poured over, only partially deals with the problem.
Often New isn't always improved .
Old 15th August 2012, 07:49 PM   #46
freddi is offline freddi  United States
freddi's Avatar
for a Karlson and fullrange, low moving mass, some on-axis rise and qts not much higher than 0.5 are good - but I've had some speakers such as guitar speakers and vintage fullrange with Q around 0.7->1 play well without boom---- if the speaker has a "bright" character as a direct radiator it will tend to balance well in a Karlson.
A Karlson will make good use of a fullrange speaker's power by controlling in band and below band cone excursion - to me that's more important than small signal extension and allows better performance on complex passages than reflex.
Old 15th August 2012, 09:02 PM   #47
Bigun is offline Bigun  Canada
Bigun's Avatar
I like this idea Bare. I am now planning to start the build by constructing the 'inner box' from the 11.5 mm Birch Ply. Then after that, I will add a 2nd box over the top, gluing it on top one sheet at a time, using a viscoelastic glue.
The internet brings up a lot of talk about Green Glue for this purpose. I checked out the MSDS for this material - it's nothing more than Latex glue loaded with chalk (a common practice). So I'll be looking for a much more cost effective option of a generic latex glue from a local store.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th August 2012, 09:25 PM   #48
Banned
You can make it yourself
Old 15th August 2012, 09:28 PM   #49
Banned
Go back to page 1 and look at the spec sheet.
What part of Qts=0.483 is considered weak
Old 15th August 2012, 09:31 PM   #50
Banned
I thought you didn't want a heavy box. Hahaha
Go for it.
A Big'un - the Audio Nirvana Super 15Hide this!Advertise here!
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
audio nirvana super 8 cascadeguy Full Range 21 25th March 2007 03:11 PM
