Mark Audio CHR-70 Application Thread - Page 27 - diyAudio
Old 11th August 2009, 06:28 PM   #261
vaughn is offline vaughn  United States
These new designs look great Dave! I have been holding off on the Lotus because of low WAF factor but these look very living room friendly. I have my chr-70's up for sale but this changes the situation.
I do have one question...
If I need to place my speakers about 12" from the rear wall do you think the version with the driver firing up would be better than the opposing "bipole" scheme?
Old 11th August 2009, 07:27 PM   #262
frugal-phile(tm)
planet10's Avatar
Yes... if you get it this close (or even right up againt the wall) you will likely need to damp the port a bit to curtail the bottom. As well you might want to consider a variation that tips the top driver slightly forward (i just posted an illustration in the other thread that will better explain what i mean)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th August 2009, 07:50 PM   #263
chrisb is online now chrisb  Canada
While we were also comparing the metal coned CHR70 to paper coned EL70, I quite preferred top mounted version "Castle" as Dave likes to call them.
Of course, I can't think of any reason either driver couldn't be used in either box. Just verify your amp's comfort with low impedance loads before wiring 2 of these up - we ran ours in series and connected to 8 ohm tap on EL34 P/P triode amp.
on hiatus
Old 31st August 2009, 02:52 AM   #264
Originally Posted by HareBrained View Post
Please post your honest impressions of the design when you've had a chance to listen. I found it took only about 20 hours of playback before the output started to crystallize.
I have them for about a week now. Overall – that’s exactly I was looking for.
Design is not too complex, to be impossible to implement, same time not too simple – to be interesting and challenging enough.
I like the way they sound – clean and powerful. Way better than my old Quest 5.1 set (to be fair I paid 100CAD for the whole set including active sub).
Treble is incomparable to my other pair of OB-RAW with ribbons, and base is incomparable with my Cerwin-Vega floor standers. But that’s PC speakers – sitting in front of me right now, playing music really-really sweet. They not take half of my room. They even not take a lot of my desk. They don’t mind to play in the corner, right against the wall.
So, one more time: thank you HareBrained, really like them.
Old 1st September 2009, 06:43 AM   #265
dougr is offline dougr  United States
Is the minimum impedance in use >= the 4ohm spec? Has anyone confirmed this with measurements?
Old 2nd September 2009, 03:29 AM   #266
geepee is offline geepee  Australia
Default chr-70 Pensil Design
Hi, quick question on the chr-70 Pensil design, The measurments on the plan from the MA website, are they internal dimensions? Also the figure of 393mm down for the driver, is that to the driver centre or to the top of the driver where the line arrowhead points to? sorry if this is a dumb question but i am dumb...
GP
Old 2nd September 2009, 03:44 AM   #267
frugal-phile(tm)
planet10's Avatar
This might help
dave
Old 2nd September 2009, 04:02 AM   #268
Thanks. It sure does help...
GP
Old 3rd September 2009, 04:53 AM   #269
qingcai is offline qingcai  United States
waitting for more building pictures.
Old 4th September 2009, 04:51 AM   #270
preiter is offline preiter  United States
preiter's Avatar
Is there still a US distributor for these drivers? Alpair USA apparently doesn't carry them anymore.
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
Copyright 1999-2017 diyAudio
