Low-distortion Audio-range Oscillator - Page 114 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th December 2012, 07:53 PM   #1131
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by dimitri View Post
AP internal oscillator
so thier spec is for the whole deal; source and analyzer, together, I would suppose? Or does the total sum of the harmonics shown = thier spec number? Thx. RNMarsh
Old 13th December 2012, 08:12 PM   #1132
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Richard, they specify THD+N in 22kHz bandwidth:
Analog generator residual THD+N At 1 kHz _(0.00025% + 1.0 μV) [–112 dB], 22 kHz BW
Analog analyzer Residual THD+N: At 1 kHz _(0.00025% + 1.0 μV) [–112 dB], 22 kHz BW
Old 14th December 2012, 02:08 AM   #1133
RNMarsh's Avatar
Yes. OK, I can see that. Then, I still need much better performance from these analyzers by one more zero. But that may not be possible? Thx-RNMarsh
Old 14th December 2012, 04:43 AM   #1134
richiem is offline richiem  United States
richiem's Avatar
Richard, you never made clear the frequency range of interest for you -- what resolution at what max freq. do you want to see?
Dick Moore
Old 14th December 2012, 06:05 AM   #1135
RNMarsh's Avatar
I'd like to see what existing/future designs can do, so being about 20dB better would give some semblence of accuracy; So around -130/-140 thd+n over 20Khz bw. Or better. Thx-RNMarsh
Old 14th December 2012, 06:18 AM   #1136
RNMarsh's Avatar
Default 339A Residuals -
Using 339A analyzer - here is where the HP339A source residual is at (1KHz) [full scale is -80. 10dB/div]:
Old 14th December 2012, 06:48 AM   #1137
richiem's Avatar
Well, the EMU 0204 and the QuantAsylum 400 ADCs, used with spectrum analysis software, can both do -140dBV or better noise floors, RE 1VRMS input, out to about 30kHz, but then both show a rising slope due to the noise shaping ADCs out to the 90kHz limit, when 192kHz sampling is used.
As I've mentioned, I use an Active Twin-T filter to notch the fundamental out of the way of the ADCs. I've also used it as a front end for my Tek 7L5 with good results. The self-distortion of the Active Twin-T is unknown to me at this point, but I have reason to believe all of its products are below -135dBV RE 1VRMS input. The Twin-T has metal film resistors, wirewound pots, and polyester caps at this point.
I'm very impressed with what you and David have gotten from the 339A -- it's nice to have a single unit for source and analysis that gives dependable results, and your 2ppm result is pretty darn good. I look forward to tackling my 339 after the first of the year, tho it may be quite a while after.
Dick Moore
Old 14th December 2012, 04:17 PM   #1138
klewis is offline klewis  United States
klewis's Avatar
Have a look at my post #772 in this thread. Using the Jim Williams super oscillator through Dick's active twin T with the HP3562A. I can see out to 100kHz with a noise floor around -135db. Also note that the oscilator output in these examples is at about 1.4vrms.
Ken
Please ignore the THD values in the aforementioned post. It's calculated by an HP8903a. I usually hand calc the THD.
Old 14th December 2012, 05:57 PM   #1139
Well, the EMU 0204 and the QuantAsylum 400 ADCs, used with spectrum analysis software, can both do -140 dBV or better noise floors.
I can see out to 100 kHz with a noise floor around -135 dB.
He wants -130/-140 dB THD+N. Using large FFTs to move noise into even smaller bins doesn't help at all for THD+N...
Samuel
Old 14th December 2012, 06:25 PM   #1140
RNMarsh's Avatar
Samuel
Right.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
