| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 | |
Boky |
#42 | |
The fact that you used step up transformer could be the problem. Depending no Shanling design and capacitor ratings, it may be possible that higher than nominal capacitor voltage rating caused some damage. You were supplying more than 220V, which could produce DC voltage levels above capacitor nominal voltage levels. Get the circuit diagram and check voltages around servo section. Check main power supply voltage levels first. The new mechanism you installed probably had a solder bulb somewhere to protect the laser from static discharge; did you remove it? Boky |
#43 | |
is badly inserted or damaged.If it is reinsert again at both ends or get a new one.Hope this helps. |
#44 | ||
Best regards, Martin. |
#45 |
I was looking at this treat (allways usefull to read a lot).
I read about the soder bulb, i allways was wondering why there are in Philips 600 series cd-players a "fat"bulb of solde was put on the print, so that is for discharging! Thanks. And i wish you good luck with repairing your cd-player! Greetings Ralphies.
Don't thouch that stereo |
#46 |
If you guys want to try another source for the transport, MCM electronics sell original Philips transport VAM1201, VAM1203 and CDM12.1 for $26.47. If that is the right model.
http://www.mcminone.com/product.asp?...5&info=details |
#47 |
Sorry to take this slightly OT, But,
Does anyone have schematics for the scd-t200c ????????? |
#48 |
Glad to say my Shanling cd-t80 is back to spinning cd's and sounding quite nice with the OPA2132's. All this without sending it to the repair shop. On seeing that the original cdm (that I had replaced) worked when I connected a 1.5v battery (post 36) I figured there might be an intermittent connection. I removed the screws holding the board that sits below the cdm. photo and gave a little push to all the plastic wire connectors making sure that they were seated properly. I put the board back in place and to my surprise it came back to life.
#49 |
Congratulations Phil!! Glad it worked out in the end.
#50 |
Hello all i have a shanling t100se and when i turned it on tonight,It moves the cd anticlockwise in a few pulses then says no disc.....
Im gutted to say the least but do you guys think the lazer mechanism is whats dead?Its what im thinking after reading this thread(Thankyou to phill) Any help is great,thanks.
| Crossover nightmare...... | barackuda | Multi-Way | 11 | 19th October 2009 07:47 AM |
| Transformer nightmare!?! | metallifornia | Parts | 1 | 3rd April 2008 06:14 PM |
| SI nightmare | gvr4ever | Class D | 16 | 20th September 2006 04:20 AM |
| my titanic nightmare | chainenoble | Subwoofers | 1 | 20th May 2006 04:15 AM |
| Cartridge nightmare's | pete.a | Analogue Source | 14 | 5th December 2003 03:00 PM |
| Page generated in 0.10692 seconds (81.77% PHP - 18.23% MySQL) with 10 queries |
