Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st January 2005, 10:38 PM   #41
Now I have som photos and information that might be useful for those who are going to put an solder iron into this box.
If you are going to keep the original o/p contact, DON'T try to bend the leads going down on the circuit board after cutting. I did that and then it broke deep into the plastic, not possible to solder on. So, better to cut in two places - see red marking. And a Neutrik contact doesn't fit in the original hole...
I slitted the band cable with a razorblade, cutting lead 7,8,10 and 11.
The Zapfilter fits into the box. I haven't found place for power supply board and transformer so they will be placed in a separate box. The 5W on the power board becomes rather hot, so if putting all in the DEQ2496 box - venting holes has to be made (I guess).
So what about the sound?
A way to describe the change in sound is to go from pixeled sound to a more organic flow. The sound became "darker".
Did I loose some energy (and resolution) in the upper register?
I made some adjustments in the mid-high range on the DEQ, going from -2dB to +1,5dB.
Well, no doubt that there is more dynamics, more extension in the lower frequencies.
Around voices a small tendency of "ringing" before now disappeared. I can play at higher sound levels, keeping sonic appearence.
In conclusion, its definintivly worth the hours and money, not saying that Zapfilter is the ultimate solution. There are as Kuei Yang Wang writes others.
deerhunt
Old 25th January 2005, 11:59 PM   #42
Hi All
Where can one download the DCX2496 schematics from?
Thanks in advance
george a
Old 22nd February 2005, 09:28 PM   #43
Geoff4 is offline Geoff4  United Kingdom
Hi
Ive just started modding my DEQ 2496. The first thing was to
try to tame the SMPS. I used an active gyrator type filter which
attenuated the line noise somewhat. Next Ive fed the clock inverters with a relatively clean +5V using an LT1763. Also
replaced the ADC & Dac decoupling and voltage reference caps
with Oscons. Also the o/p caps have been replaced. I use the
AES/EBU input from my Pioneer DV565. I can do a direct comparison with my switched pre-amp and the modded DEQ
sounds just a lttle bit veiled compared to the bypass. Next
is to do something about the o/p stage which is currently the
NJM 4580 op amps. Since Behringer wont release a schematic it
looks like Ill have to do my own o/p stage.
Geoff
Old 22nd February 2005, 09:59 PM   #44
Previously: Kuei Yang Wang
ThorstenL's Avatar
Konnichiwa,
You can do that. Or if you can read a principle schematic and translate this into what is on a PCB you can mod the original. I can post a principle schematic of the circuit in the DEQ, both analogue input & output, if there interest. Note it will not show component designations but values, which should match the DEQ but may be slightly different.
Sayonara
Freedom is always the freedom of those who express ideas and views that YOU disagree with.
Old 23rd February 2005, 03:51 PM   #45
Dear Kuei Yang Wang,
Thanks for the suggestions on i/o using transformers, I will try to implement these in my dcx.
What would you suggest as the road to take for the power supply ? Accu/battery based ?
Thanks for sharing your ideas !
Leo
Old 23rd February 2005, 04:33 PM   #46
ThorstenL's Avatar
Konnichiwa,
Hmmm, switched mode supplies are a lot better, POTENTIALLY, than their reputation. I'd probably fix the existing SMPS, which is not too difficult if you know what you are doing and have a fast and sensitive 'scope.
DIY Supplies, batteries are always a PITA. I'd probably make a raw 20V + 20V + 9V supply that is choke input and uses multiple layers of RF filtering plus schottky diodes and feed that into the SMPS PCB and upgrade the reg chips there.
If I get the time anytime soon (unlikely) I'll mod my own DEQ.
In mind I have an abridged version of the original analogue stage (I&O) with consumer levels and SE (RCA) jacks (fitted instead of XLR's), the remaining Op-Amp's changed to AD8066 and the "liberated" op-amp's used as DC servos to allow direct-coupling of Inputs and outputs. If I get any suitable size Transformers in time from S&B (it's on their list to develop) I'll use these of course.
Then quiet down the SMPS and upgrade all the digital supplies.
Sayonara
Old 23rd February 2005, 08:40 PM   #47
Hi Kuieu
I for one would be interested in any schematics you can come up with. It would take far too much time to reverse engineer the
original design thats why I was thinking of doing my own.
Ive delevoped my own discrete opamp specially for this kind of
application but it is quite big.
I managed to filter the main power rails to the op amps
quite well. I originally tried LR/C networks but this didnt work as well as I hoped due to the inductors interwinding capitance I
think.
I think its worth perserving with this device because even in its current state I like what it does the sound of my system in my room.
Geoff
Old 23rd February 2005, 10:30 PM   #48
ThorstenL's Avatar
Konnichiwa,
Analogue Input section:
Analogue Output section:
Sayonara
Old 7th March 2005, 07:48 PM   #49
petervv is offline petervv  Netherlands
Default DCX2496 minus 16 dual opamps + 8 transformers
hi guys,
I just posted a message in the loudspeaker group about the modification of my DCX2496, hope this link works:
http://www.diyaudio.com/forums/showt...624#post591624
regards, Peter
Old 7th March 2005, 08:17 PM   #50
The schematics posted below are for the DCX not the DEQ.
Behringer DEQ2496 Schematic Claus Digital Line Level 12 10th July 2011 02:40 AM
FS:Behringer DEQ2496 Ryssen Swap Meet 15 16th April 2009 09:24 PM
Behringer DEQ2496//Non-Delay Mod**HELP** syntaxsinner Digital Line Level 5 26th April 2006 04:27 PM
FS: Behringer DEQ2496 UltraCurve Pro Rescue Toaster Swap Meet 3 4th February 2006 02:38 AM
Behringer DEQ2496 into T Amp? joesan Digital Source 7 19th October 2005 11:30 AM
Page generated in 0.13081 seconds (79.16% PHP - 20.84% MySQL) with 11 queries
