Go Back   Home > Forums > Amplifiers > Class D
Old 22nd January 2013, 01:45 PM   #61
manojtm is offline manojtm  India
manojtm's Avatar
Hi IR,
MOSFET HOT b'cause of your filter not a gate resistor.
MANOJ
Old 22nd January 2013, 02:34 PM   #62
pravpa is offline pravpa  India
Default AUD600
Originally Posted by Vostro View Post
Hi Pravpa, do you mind posting the artworks for AUD600,
Im also going to make this Amp, but finding all the details isnt made easy.
Hello Vostro,
Here is the entire file of AUD600.
Pravpa
Old 22nd January 2013, 02:56 PM   #63
IRSound is offline IRSound  Germany
Thanks Manoj ,
but why ? because I checked the value of filter with accurate LCR meter..it was about 70uH.
what should i do then ?
what you think about EER cores with 1~1.5mm air gap ?
and my last question...what is your recommendation for output filter @ 250KHz ?
IRSound
Old 23rd January 2013, 04:31 AM   #64
Default Texas TPA3116D2 Chip.
Hi, Have you had a chnace to look at the Texas TPA3116D2 Chip board yet?.
tabarddn
Old 23rd January 2013, 05:14 AM   #65
manojtm's Avatar
Hi IR,
my choice is 47uH for 250KHz fsw
use T106-2 with 59 Turns 0.8mm wire
MANOJ
Old 23rd January 2013, 06:15 AM   #66
i found 2 stacked CK270060 from CSC in my magnetic component box. i will give it a try.
also i have CS270125 and CS330125.
how about the capacitor ? 470nF should be enough ?
this capacitor can effect the mosfet temp or not ?
Thanks Manoj for helping me in this way
Old 23rd January 2013, 01:16 PM   #67
Vostro is offline Vostro  Madagascar
Vostro's Avatar
Originally Posted by pravpa View Post
Hello Vostro,
Pravpa
Thanks, this is a great help.
Old 23rd January 2013, 05:02 PM   #68
Hello Vostro,
Pravpa
Hi Pravpa.
Have you set up this amp?
Works perfectly?
Need a change?
I'm precuisando a good class D amplifier and want to ride without concern for errors in the layout.
Thank you.
Old 24th January 2013, 06:50 AM   #69
Default AUD600
Originally Posted by luizcpimenta View Post
Hi Pravpa.
Works perfectly?
Need a change?
Thank you.
Sir,
This AUD600, has already been tried and test by Mr. Manojtm, and he found it's results are satisfactory.
Pravpa
Old 25th January 2013, 06:40 AM   #70
AUD 600 was so powerfull Amp
i try 4*6975 pioneer band and a 250Watt-16ohm band and a 307D4 pioneer subwoofer in same time and just only with 1 channell.
my Ear
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 1 20th December 2012 08:12 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
