My class D amp
hi sir manoj
i want use you OCP shematic for another amp
http://upload.tehran98.com/img1/mwlg1ozq1t7im5mcuknf.pdf
i want use this shematic for a class AB OCP section
my supply voltage in this amp is + - 35 VDC
can i drive a relay with S output pin ?
my relay is like AUD600 power section relay
it must protect in 3A and when the out put is shorted
which one off resistors must be change ?
thanks
Hi all,
Could Some one please Post the Schematic diagram of aud600, I really need it. This is my first project, and hope can got help full things from all of my friend in this forum..
Thank you
Syaelend
hi all
aud600 is best choice to you syaelend.
this amp have nice sound and work very well
have nice time
sir manoj
hi
are every thing ready about aud 600 ver 3.0 ?
i am waiting to you sir :)
Nee Schematic of AUD600
Dear Manoj,
Could you please send the schematic Diagram of AUD600.
Below is my email address
syaelend@gmail.com
I really need it...
Thank you very much
Syaelend
Hi all,
Thank you
Syaelend
hi sir manoj
http://upload.tehran98.com/img1/mwlg...7im5mcuknf.pdf
thanks
Hi Manoj!
does this applies to AUD600?
You have mentioned T106-2 iron powder, I have them and I wanted them to be of use on AUD600, but before that....a few question here..:)
Can I power this amp using a lowly -/+35vdc? Was there a needed adjustment on the circuit?
Can I also use an external 12vdc bias circuit? (not the one on your psu board)
Please guide.
Regards!
Sir abetir where did you ordered your T106-2 iron powder core? Thanks
Revised PCB for AUD600 Ver1.0
Hi Manoj:
I have revised a PCB design of AUD600 ver1.0. In this pcb heatsink will be placed on top of board and few more caps to eliminate EMI/noise.
Please let me know improvement areas.
Raj
  • 001. AUD600 Ver1.0.PDF
