I want to build class D amplifier, the power output is arround 500W @4ohm. Have you got schematic or reference design for it?.. Please help.
Thank you
Syaelend
Thank you
Syaelend
Hi sayelend
i don't have shema for this .it was my old design with carrier based class d amp +/-90v supply
regards
manoj
Thank you
Syaelend
try aud600
hi sir manoj
i want use you OCP shematic for another amp
http://upload.tehran98.com/img1/mwlg1ozq1t7im5mcuknf.pdf
i want use this shematic for a class AB OCP section
my supply voltage in this amp is + - 35 VDC
can i drive a relay with S output pin ?
my relay is like AUD600 power section relay
it must protect in 3A and when the out put is shorted
which one off resistors must be change ?
thanks
thanks
Hi all,
Could Some one please Post the Schematic diagram of aud600, I really need it. This is my first project, and hope can got help full things from all of my friend in this forum..
Thank you
Syaelend
Thank you
Syaelend
hi all
aud600 is best choice to you syaelend.
this amp have nice sound and work very well
have nice time
sir manoj
hi
are every thing ready about aud 600 ver 3.0 ?
i am waiting to you sir
Nee Schematic of AUD600
Dear Manoj,
Could you please send the schematic Diagram of AUD600.
Below is my email address
syaelend@gmail.com
I really need it...
Thank you very much
Syaelend
Dear Manoj,
syaelend@gmail.com
I really need it...
Thank you very much
Syaelend
Hi all,
Thank you
Syaelend
hi sir manoj
http://upload.tehran98.com/img1/mwlg...7im5mcuknf.pdf
thanks
thanks
AUD600
For AUD600, Please check post #62
http://www.diyaudio.com/forums/class-d/226812-my-class-d-amp-7.html
Pravpa
Hello Syaelend,Dear Manoj,
syaelend@gmail.com
I really need it...
Thank you very much
Syaelend
Pravpa
Hello Syaelend,
Pravpa
Dear Mr. Pravpa,
Thank you, On Post #62 only PCB Top print that exist, but no schematic diagram, We need The Schematic to Re lay out the PCB by Myself.
Where is I can got the Schematic of AUD600?
Thank you
Syaelend
Sir abetir where did you ordered your T106-2 iron powder core? ThanksHi Manoj!
does this applies to AUD600?
You have mentioned T106-2 iron powder, I have them and I wanted them to be of use on AUD600, but before that....a few question here..
Can I power this amp using a lowly -/+35vdc? Was there a needed adjustment on the circuit?
Can I also use an external 12vdc bias circuit? (not the one on your psu board)
Please guide.
Regards!
Revised PCB for AUD600 Ver1.0
Hi Manoj:
I have revised a PCB design of AUD600 ver1.0. In this pcb heatsink will be placed on top of board and few more caps to eliminate EMI/noise.
Please let me know improvement areas.
Raj
Hi Manoj:
Raj
Hi AKRAJ,
Good design. use 18A(6mm) carrying HV track OR 4mm with lead coat.
and if you use AUD600 in bridge mode its give amazing power supply rail -/+73V
MANOJ
Hi Manoj:
Thanks for your suggestion. I will do that.
I also have ground pane at top layer, but not posted here. Do you think ground pane on top will improve quality?
Raj
Hi Raj,
IR2110 pin 5 not linked to junction point(feedback)
no improvements for sound quality
MANOJ
MANOJ
Hi Raj,
MANOJ
Thanks a lot Manij, I will correct that. Except this everything is okay?
Can you please give me any address of Calcutta for T-106?
Raj
- Class D
- My class D amp
