| Class D Switching Power Amplifiers and Power D/A conversion |
#1 | ||||||||||||||||||||||||
This is about a module based on the EPC eGaN mosfets.
It's a fork from another thread, to keep that one focused. As introduction, here is a copy-paste of relevant posts so far. I am also including the most recent few attachments. Please see the original thread for the rest. Quote:
![]() Quote:
![]() Quote:
![]() Quote:
#2 |
I'd like to throw in a few opinions here
![]() These fets are designed to have their heat removed from their 'top' side - opposite the connections. This is why the original idea of laminating them between a PCB and a copper tongue was so promising. Mounting them on an alu-core PCB without any sort of sinking on the top will result in 1 thing - they will desolder themselves! While alu-core board as extra heatsinking may not be a bad idea, it is extremely costly, and since you would still need to sink it from the 'top' side I don't really see the necessity. Also - that circuit is plenty simple enough for a tiny 1 sided board
O2 amp Australian parts GB Interest form-----Thread-----Spreadsheet - CHECK YOUR ENTRY |
#3 | |
Nice thing about alu-base PCB is that you already have the mounting base without additional thermal glueing - the only thing left is, as you say, to figure out a way to get the heat off the chip substrate. I mentioned spring clips (eg berillium copper), or even a bar on top of the chips, say screwed down into the PCB. See drawing. Both of these may be difficult to implement, and perhaps not effective enough, so I would still like to keep the FR4-to-metal-tongue option open. |
#4 | |
![]() Are we sure we need the two additional power pins? How about thicker legs? What are the trade-offs? Ok for the thermal sense resistor, but it would be easier if it was connected to the low side (electrically, but not necessarily mechanically). What do you say? |
#5 |
While I'm trying out layouts, it would be nice if somebody could guesstimate the realistically max power into loads achievable with a half-bridge and a full bridge using these fricking sharks with fricking laser beams.
Let's just assume we can somehow carry away the heat for now...Thanks |
#6 |
Damm cool, although I have to warn you having used EPC GAN devices the reliability isn't there if they are on a silicon wafer. Basically repeated cycling of Vds causes the gate to separate from the channel due to a peizo electric effect in the substrate. This manifests as excessive DC gate current and eventual device failure. SiC based GaNs don't appear to have this problem.
Anyway if you can make this happen count me in for a few modals!
CHR-70+Subs |
#7 | |
- Were you using KGDs or did you buy wafers and saw them? - Is the failure mode directly related to the number of Vds on/off cycles? - Does dV/dT on Vds (both up and down) play a role? - What about temperature? ie does the failure rate get worse when cycling at higher temperatures? I’ve always been a fan of SiC myself, and am eagerly watching eg Cree come out with a few interesting devices. IMO they could “use” a module like the Uber, if only to mask the awkward Vgs which is often seen as a showstopper... (ref: the 1200V 80mR SiC MOSFET Datasheet ) Cheers and thanks for reading, E Last edited by elevator; 3rd September 2011 at 08:49 PM. Reason: "the" not "their" awkward vgs... |
#8 |
Here is a half-baked sketch of the latest module and possible construction (still with 6 pins plus temp sensor).
It’s a top view. The module proper measures 28 by 18 mm, bounded by the pink outline. Stackup would be (from bottom up): - Aluminum base (bounded by the outline in pink). About 2mm thick - PCB dielectric (not shown, also bounded by the pink outline) - copper traces (red). Layout is NYI - Invar alloy frame, tinned etc., of the same thickness as the mosfet chips (olive-green). Except maybe for the pin attachments, this could be reflow soldered on the PCB as any other component. Supports trimmed away at the end. - Top conductor (not shown) which would sit tightly on both the mosfets and the invar frame, having cutouts where components stick out - Top cover (not shown, bounded by pink again). Alternatively, epoxy pour. Heat from the mosfets would be directed to a) from the substrate to the top conductor, then back down through the invar frame to the alu base; b) from the pads to the copper traces, then through the dielectric and finally to the bottom aluminum. I like the top cover because it allows mounting the module with either side facing the heatsink. BTW that would make for a nice symmetrically laid out board with two half-bridges on opposite sides, like the YAUSA. Total module thickness would be about 5-6mm Speaking of easy integration, pin spacing is 150mils (3.81mm) ![]() Enjoy, E |
#9 |
I didn't do the testing so what I know is second hand. related to number of cycles not dv/dt. The devices were prepackaged like these, however they were been used for linear amplification and may not have issues in a switched application as other people seem quite keen on them:
EPC1010
CHR-70+Subs |
#10 |
Hi All,
After posting the Uber with EPC2010s and Zetex drivers, I spent some time thinking .The EPC GaN mosfet has very little gate capacitance, so does not really need large amounts of drive. Slamming the gates on and off only increases ringing and high-frequency noise, especially with not-so-short PCB traces as typically unavoidable in through-hole designs. What these mosfets need in my view is some clean drive, with clean and short traces - IOW physical proximity to the drivers. So, considering that I already was looking at a 9-pin module using the ZX drivers, I thought why not directly use the Silabs driver instead. Available drive current should be plenty, and mounted close to the mosfets, parasitic inductances can be minimized for fewer losses and better EMC behaviour. Maybe I could even push the PWM frequency up a bit towards 1MHz without dissipating too much. The preliminary result of the effort is a 14-pin half-bridge module, which should bring hundreds of watts from PWM input to output inductor in a zip. All components are mounted on the top side, except for the two mosfets (see pics). This allows their heat to be dissipated through the substrate to an alu or invar plate which in turn would be mounted to a heatsink via two screws. This time, pins are spaced a DIY friendly 100mil ).Goal is 160V Vdd-Vss, so passives must be rated >=200V. Before finishing the layout, two things: - I plan to add a few more thermistors mounted close to the two mosfets, for testing. Size 0402 NTCs should fit on the bottom, staying below the height of the mosfets. Their contacts would be brought to pads located conveniently, but not brought out as regular leads. - There is a hitch with this combination of driver and mosfets. The GaNs do not like Vgs much over 5V, while the Si824x goes into undervoltage lockout below 8V or so. Maybe somebody can help with the translation here. I would like to set the driver VDD to 9, maybe 9.5V to keep sufficient margin from its 8V UVLO. Other than a TRANSIL diode (eg this) or a resistor divider nothing comes to mind.Thanks, E |
| Half bridge Vs full bridge smps supplies | jaiaditya4u | Power Supplies | 5 | 27th July 2011 05:12 AM |
| half-bridge to full-bridge | nek antunes | Power Supplies | 3 | 27th May 2010 01:04 PM |
| half-bridge VS. full-bridge | gearheadgene | Class D | 3 | 25th May 2007 08:49 PM |
| The difference of Push-pull,Half-bridge,Full-bridge | digi01 | Chip Amps | 0 | 8th September 2006 02:10 AM |
| Whats the difference between full bridge and half-bridge SMPS ? | skaara | Class D | 6 | 3rd February 2005 07:23 PM |
| Page generated in 0.17059 seconds (88.21% PHP - 11.79% MySQL) with 11 queries |
