Old 20th November 2009, 03:22 PM   #21
klewis is offline klewis  United States
klewis's Avatar
Originally Posted by janneman View Post
Assuming you measure the voltage across the Re without signal, then your measurement shows underbiasing. Vbe < 0.6V so no bias current so no drop across Re. Increase the bias until you see Vre rising, until you have the desired bias current.
jd
Janneman,
Thanks for the help. I ended up rebuilding it completely and am now getting bais, this time too much (0.93v emitter to emitter), but, have worked out with the simulation what my resistor values should be. I will try the new resistor values this evening. I'm trying to implement Bob Cordell's Thermal Trak bais scheme.
Ken
Old 25th November 2009, 03:06 PM   #22
panson_hk's Avatar
Default 19 + 20 kHz IMD spectrum
IMD is said to be more important for indicating sonic performance. Here is an FFT of 19+20 kHz at 80 W peak into 8 Ohms of the Compact 49810 with ThermalTrak. The corresponding IMD is 0.001 %.
Old 25th November 2009, 03:43 PM   #23
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Very good!
JD
Old 25th November 2009, 03:50 PM   #24
panson_hk's Avatar
Default same test for a tube amp
I just simply plug-in my only tube amp (5687SE) to performance the same test. Just for fun!
It is indeed a harmonic generator.
Old 25th November 2009, 04:07 PM   #25
blueskynis's Avatar
Send a message via MSN to blueskynis Send a message via Yahoo to blueskynis
Hello panson,
Have you considered to use some kind of different compensation, eg. like Edmond Stuart TMC? It can bring down some harmonics generated in OPS by a few decibels. Do you have time to test it?
Here are some details about it:
Bob Cordell Interview: Negative Feedback
Cheers
Windows-free with Fedora 13
== www.diy-audio-engineering.org ==
Old 25th November 2009, 09:22 PM   #26
blueskynis's Avatar
Originally Posted by blueskynis View Post
Hello panson,
Cheers
I meant something like this:
The value of Cc would be as in original design, Cc2 should be 5 to 10 times Cc, and Rc is determined from R=1/(2*pi*f*(Cc+Cc2)) where f is the frequency when the circuit slowly reverts to a conventional and safe scheme.
I have drawn two ways to apply this compensation. The first way (1 in schematic) is more conservative and includes VAS only, where the second way gives less THD, because it includes the predrivers also, but can have more problems with local stability.
Old 26th November 2009, 09:56 AM   #27
panson_hk's Avatar
Hello panson,
Cheers
Hi blueskyins,
I love to try these compensations in order to learn more. Let me read the threads to get ready. Thanks!
Panson
Old 26th November 2009, 11:08 PM   #28
blueskynis's Avatar
Hi blueskyins,
Panson
OK, I'm looking forward to this. My LME's will arrive in a month or two and I will definitively try this compensation. Unfortunately, I don't have precise instrumentation as you to measure the benefits if any.
Cheers
Old 2nd December 2009, 04:09 AM   #29
panson_hk's Avatar
Default Output resistance with output coil removed
Here is the output resistance without output coil of Zobel network. It is essentially flat from 10 Hz to 100 kHz.
Old 7th December 2009, 04:40 AM   #30
panson_hk's Avatar
Default THD vs time from cold start
Output at 18 W into 8 ohm. THD vs time from a cold start. It takes about 20 min to reach the min. THD level (optimum set point).
Bias scheme: Two ThermalTrak diodes in series with a 1 k pot.
File Type: jpg THD vs time from cold start 18 W 8 Ohm Run 2.JPG (91.2 KB, 222 views)
On Semi ThermalTrak davidallancole Solid State 630 11th August 2010 05:26 PM
LME49810 plus ThermalTrak single-board layout panson_hk Chip Amps 1 28th September 2009 11:57 AM
LME49810 W/ Thermaltrak CFP Output BarryJF02 Chip Amps 6 13th September 2009 01:23 AM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 05:09 PM
In search for a compact sized motorized pot yairf Parts 1 19th October 2004 03:56 PM
Page generated in 0.13276 seconds (88.47% PHP - 11.53% MySQL) with 11 queries
