| Chip Amps Amplifiers based on integrated circuits |
Hello all,
This is my first attempt to design and realize a BPA200 based amplifier with 200W per channel. I have named it Wendy200 after my better half of course ! The amp features: - 2x LM4780 power amps per channel, in an BPA200 arrangement as seen in figure 17 of the AN-1192 application notes (using the non-inverting part of the circuit only) - LM4562 instrumentation amplifier front-end / buffer - THS4131 for voltage gain - 0.1% quality resistors all around - SMD components all around for compact size and short signal path The front end and power supply scheme is quite similar to the Sympatico amp from my favourite twistedpearaudio. The attachment shows the schematic. The instrumentation amp has a gain of 2, the THS4131 has a gain of 1.1 and the power amps have a gain of 20+20=40 (due to bridged configuration) I just want to share it with you all to debug, improve it and choose the right components. Thanks Evan |
#2 |
Alternatively this design (attached) could be followed, which theoretically is the same as the above (I think), the only difference is the negative feedback point of the THS4131 is now from its output directly (as in the THS4131 datasheet applications) and not the output of the LM4780. Is that a better implementation and if so why ?
Another question I have is what type of capacitor should I use for C1 - C4 ? In the national's application notes they use both electrolytic and non-polarized ones - which is best? Would ceramic or niobium oxide ones be ok? Another option is to completely ditch them, is that going to be okay? Also is 3 watts rating enough for R13 - 16 ? It's difficult to find 5W resistors. Cheers Evan |
#3 |
All depends on what your looking for.
My personal tastes would be to take the output from the LM4870. One suggestion increase C1-C4 from 22uf to 47uf, I tried going to 100uf and low frequency motor control became an issue 22uf is to low for solid low frequency's 47uf is the best compromise. 3 watt output resistors are fine, I have used 3 watt ones in all my BPA's with no issue. |
#4 | |
Thanks for your advice tiltedhalo My aim is to achieve good low frequency response so I will follow your advice to use 47uf for C1 - C4 What material did you use for these capacitors? Evan |
#5 |
OK hold on to your hat! I use 47uf 24V tantalum's jumped with a .47uf metal film WIMA. I tried black gates, muse, oscon's jumped with poly and not jumped and found the best sound, response, and control from the tants and wima combo.
here is a pick of my daily user ........... |
#6 | |
Wow nice project tiltedhalo! Seems like you've done a thorough job. As for the cap material ... I see !! I will try different ones and pick the best then. One more question, when you say you are using 2 caps "jumped", do you mean in series or in parallel? In that case you would get 94uf or 22uf respectively and not the 47uf you suggested right? Cheers |
#7 |
A 47uf paralleled with a .47uf metal film WIMA.
I have built a bunch a BPA's to come up with what to my ears and test equipment sounds the best. IMO I think the combo of the of the THS4131 and LM4562 will be very clinical to bright sounding, but that's all personal taste. I will never listen to anything else, I first thought the idea of chip amps stupid, then with all the hype I built one and have been hooked from then on. I replaced a Carver 4.0t and Krell KSA250 for my BPA300 and 200. |
#8 | |
Thanks for your reply once again I get it now 47uf + 0.47uf As for the op-amps yes I think you are right but I prefer a power-amp to be clinical or as transparent as possible. I can then inject some warmth by using a valve pre-amp. I think BPA200 with LM4780's is perfect because it's compact and paths are short. In BPA300 the chips are getting too far away from each other plus it's getting expensive or at least of a similar price tag as the class D amps. Cheers |
#9 |
I would use each dual chip to amplify one inverted and one non inverted channel rather than each chip amplifying the same polarity channels.
I agree, C1 to 4 need to be larger. I would try 100uF or 150uF and try to solve the PSU motorboating problem rather than restrict the LF content. Each chipamp is driving the equivalent of the load impedance. If your load is 8ohms then each individual amplifier needs +-20mF for C1=150uF. But the inverted signal passing through the dual chip may allow this smoothing capacitance requirement to be relaxed substantially. A dual chip passing the same signal would require the +-20mF for each half equaling +-40mF per dual chip and +-80mF for the complete amplifier. Have a read of W.Jung's paper on composite opamps. Most of what he has to say applies to your composite. The gain in the final half is determined by the overall gain you require. I think he suggests something like 2 times. If I recall that gain advice correctly then the gain stability of the power chipamp will not allow you to follow Walt's composite model. i.e. it might not work. Also read Walt on balanced audio. He advises very high impedance on the balanced inputs. i.e. replace 100k with 1M5.
regards Andrew T. |
#10 | |||
AndrewT thanks for your educated reply.
Note that I am not any expert in design so your suggestions have triggered a lot of questions to me: Quote:
Ideally I want to keep the gain of the composite front-end to a minimum and really use the op-amps as buffers and for noise rejection (oh and XLR inputs too). So, If I set the instrumentation amp gain to 1 (by removing R21) and change R22 & R23 from 22k to 44k to get a gain of 2, would that be in accordance to W. Jung's recommendations if I understand well? Thanks again and apologies for the many questions... I am over excited about this project ! Evan |
| 200 watts Gäjnklon (Gainclone) - BPA200 | peranders | Chip Amps | 87 | 6th December 2010 02:40 PM |
| WTB - DIY poweramp 150-250WPC, Hypex UCD or Gainclone based | spurzheim | Swap Meet | 0 | 1st January 2007 07:39 PM |
| FS inverted 3875 based gainclone | bqc | Swap Meet | 1 | 27th February 2005 05:43 AM |
| Opamp based preamp, for a gainclone | Bricolo | Solid State | 5 | 9th March 2003 05:36 PM |
| Page generated in 0.15681 seconds (73.75% PHP - 26.25% MySQL) with 11 queries |
