| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#421 |
The bearings for motion in the vertical plane that I used in my 1980s Tangential Arm and later in my 2010 Tangential Arm are of the zero friction/ zero stiction type. I don't know that Frank is using those bearings, but the description fits.
I am also using them in my 2012 Tangential Arm. This is a servo arm with absolutely no tracking error. I'll describe it soon in its own thread. Sincerely, Ralf |
#422 |
Here's an interesting arm that uses a straight headshell with no offset angle. The idea is to lessen side force so, alas, it has nothing to do with tangency. The bearing design is interesting with floating liquid. Check out the website.
ViV Lab Rigid Float Tonearm ----------------------------------------------------------- ![]() ![]() ![]() ![]() ![]()
#423 |
Definitely the best solution cause it solves near all issues at once. No distortion due to angle error, no distortion due to angle errors of the cantilever and non symmetrical forces on it, no added frictional or inertial forces.
Remain only one: Torsion constraints on the signal wires. Can be solved with 4 neddles immersed in 4 buckets filled with liquid metal. That i did in 1967 with mercury (allowed at this time). Strait arm on a ramp addresses a great part of this problem as the arm don't change his angle if the record is flat and well centered. So the wires can be in neutral position. Last edited by Esperado; 25th November 2012 at 06:01 PM. |
#424 |
A Van Eps tonearm was sold for over $2500 last year on eBay. Check out the pictures.
Highly Desirable 1960's Van Eps 2A Dual Compensating Playback Tonearm, Complete! |
#426 | |
I can't figure out where is the vertical pivot. |
#427 |
#428 |
#430 |
| String suspension vs. uni pivot or gimball tonearms | nghiep | Analogue Source | 26 | 13th August 2011 04:27 AM |
| 90+90 volt rails | sakis | Solid State | 42 | 5th April 2011 01:38 PM |
| Angling drivers left and right in a vertical line-array???? | ozziozzi | Multi-Way | 12 | 16th January 2009 04:23 AM |
| Tangential Arm Floating Magnets | ebijma | Analogue Source | 8 | 6th December 2004 06:37 PM |
| Need Amp For 90-0-90 V DC | Drafance007 | Solid State | 15 | 12th October 2003 08:03 PM |
