Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd July 2012, 03:12 PM   #21
tvrgeek is offline tvrgeek  United States
Guess just going with either a decent transformer ( Jensen) or a THAT part is not of the quality you are looking for? Unless you have your own source of master recordings, you are probably listening to several of each already.
Old 22nd July 2012, 03:16 PM   #22
Joachim Gerhard's Avatar
I think Patrick talked about this already. The Thats chip is just fine. I use it with good results. So this is more a philosophy to use simple Fet based circuits and also much more fun.
Old 23rd July 2012, 04:27 AM   #23
EUVL is offline EUVL  Europe
If that is the argument then the audio world will only have LM3875's and opamps.
And they cal also sound very nice, as our own ES9022 modules showed.
But as Joachim said, this is philosophy, and a lot more fun.
Have you heard an audio chain with no global loop feedback at all ?
Patrick
xen-audio.com
Old 23rd July 2012, 06:00 AM   #24
Calvin is offline Calvin  Germany
Calvin's Avatar
the J111 is quite high in noise specs, equivalent noise voltage as well as 1/f figure. Any experiences abut practical behaviour and at which signal levels?
jauu
Calvin
Old 23rd July 2012, 09:10 AM   #25
Line level. Used only as a cascode.
The J174 is much worse.
Is it your experience that J310 is better ?
Then we have to try it some time ....
Thanks for the hints,
Patrick
xen-audio.com
Old 23rd July 2012, 09:34 AM   #26
Calvin's Avatar
so far I´m perfectly happy with the 4391s, especially in cascode with the lownoise BF862 and more so the LSK389C. The latter makes matching and output DC-blocking nearly obsolete (apart from some really ´off´ 4391s). Noise is no issue here. Unfortunately only N-channels and quite critical against oscillation in a modulated CS-loaded-source-follower fashion. So one better sticks to the simple CCS-loaded cascoded-Source-followers, even if that means less drive capability of 1xId.
jauu
Calvin
Old 23rd July 2012, 04:40 PM   #27
bcarso is online now bcarso  United States
jauu
Calvin
Except for the nuisance of the extra required voltage, I concur on the 4391-like parts as cascode devices with the lower-voltage shorter-channel families like the 2SK170, BF862, et al. The drain-gate breakdown of the 4391 is also usually much higher than the guaranteed spec, which tempts one to madness, although for anything production-worthy one must stick to the guarantees.
For still-higher output impedance, an iterated cascode with additional devices works, with even more of a voltage drop penalty, and the need for some floating gate bias. It's usually not necessary
BTW Walt Jung is working on presenting some history of JFET cascodes and has dug up some details on pioneers of the technique, so I shall say no more about the probable first uses of the technique. However, the principle is clearly along the lines of the first use of the bootstrapped cascode using bipolars by Aldridge; and the effectiveness in the FET case, besides the increase in low-frequency output impedance, is particularly due to the pumping of the output drain-gate displacement current back into the lower JFET source. This is only effective when there is substantial Z in the source compared to the reciprocal transconductance, so that most of the current flows in the source.
Old 23rd July 2012, 05:34 PM   #28
Please keep us posted when Walt is ready.
Thanks in advance,
Patrick
xen-audio.com
Old 25th July 2012, 10:23 AM   #29
Ordered 10 pcs for the XCEN prototype today.
Cute little thing at 42x40mm, double sided.
4 of them will be shipped to Joachim when they are ready in a week or so.
Patrick
xen-audio.com
Old 25th July 2012, 10:28 AM   #30
Thanks, i am looking forward how they perform.
Single Ended to balanced for F4 Joshua_G Pass Labs 10 24th April 2011 10:57 PM
How to add balanced input to single ended amp? jaistanley Class D 5 2nd December 2010 04:29 AM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2013 diyAudio
